It is possible to do micro-stepping with PWM using a L298 driver.
This is an example on how to create 10 micro-step per step. This mean that your stepper has now 2000 step per revolution.
It is not perfect because the Raspberry Pi latency make it a little bit unstable but it does the job and the PWM signal is only 8 bits.
I connect the L298 like this
OUT1 Coil A+
OUT2 Coil A-
OUT3 Coil B+
OUT4 Coil B-
IN1 BCM GPIO 17 ( STEP_A in source code )
IN2 BCM GPIO 18 ( STEP_AN in source code)
IN3 BCM GPIO 22 ( STEP_B in source code)
IN4 BCM GPIO 25 ( STEP_BN in source code)
ENA BCM GPIO 23 (PWM_A in source code)
ENB BCM GPIO 24 (PWM_B in source code)
You could change the number of micro-step with the define MICROSTEP and the time delay with StepperDelay.
Micro-stepping will reduce vibration and create inner step. The L298 is not perfect and the PWM works because of stepper inertia. For better micro-stepping accuracy , it is preferable to use specialize driver like the SLA7026 with a D/A signal on the reference.
this is the code in C
Raspberry Pi Micro-stepping demo
using GPIO connected to a L298 I.C.
Author: Daniel Perron
Date: 7 Septembre 2014
External library :
PIGPIO http://abyz.co.uk/rpi/pigpio/download.html
How to compile :
gcc -o stepper stepper.c -lm -lpthread -lpigpio -lrt
GPL License
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <fcntl.h>
#include <sys/mman.h>
#include <unistd.h>
#include <string.h>
#include <errno.h>
#include <sched.h>
#include <string.h>
#include <sys/time.h>
#include <time.h>
#include <pthread.h>
#include <pigpio.h>
#include <signal.h>
// ========= GPIO IO DEFINITION
#define STEP_A 17
#define STEP_AN 18
#define STEP_B 22
#define STEP_BN 25
#define PWM_A 23
#define PWM_B 24
#define MICROSTEP 10
long StepperDelay = 50000/MICROSTEP;
#define STEP_PER_REVOLUTION 200
// BCM2708 DEFINITION FOR MEMORY ACCESS
#define BCM2708_PERI_BASE 0x20000000
#define GPIO_BASE (BCM2708_PERI_BASE + 0x200000) /* GPIO controller */
#define PAGE_SIZE (4*1024)
#define BLOCK_SIZE (4*1024)
int mem_fd;
void *gpio_map;
// I/O access
volatile unsigned long *gpio;
// GPIO setup macros. Always use INP_GPIO(x) before using OUT_GPIO(x) or SET_GPIO_ALT(x,y)
#define INP_GPIO(g) *(gpio+((g)/10)) &= ~(7<<(((g)%10)*3))
#define OUT_GPIO(g) *(gpio+((g)/10)) |= (1<<(((g)%10)*3))
#define SET_GPIO_ALT(g,a) *(gpio+(((g)/10))) |= (((a)<=3?(a)+4:(a)==4?3:2)<<(((g)%10)*3))
// 32bit parallel mode gpio handling
#define GPIO_SET *(gpio+7) // sets bits which are 1 ignores bits which are 0
#define GPIO_CLR *(gpio+10) // clears bits which are 1 ignores bits which are 0
#define GPIO_READ *(gpio + 13)
// =========== STEPPER DEFINITION
#define MICROSTEP_PER_REVOLUTION (STEP_PER_REVOLUTION * MICROSTEP)
#define CoilTableSize (4 * MICROSTEP)
unsigned long StepperCoil[CoilTableSize];
unsigned char StepperAPWM[CoilTableSize];
unsigned char StepperBPWM[CoilTableSize];
unsigned long StepperMask = (1<<STEP_A) | (1<<STEP_AN) | (1<<STEP_B) | ( 1<<STEP_BN);
volatile long StepperPosition = 0;
volatile long TargetPosition = 0;
volatile int StepperReadyFlag = 1;
pthread_mutex_t StepperThread_mutex;
pthread_mutex_t Stepper_mutex;
pthread_t StepperThreadId;
// ============ FUNCTION
void set_max_priority(void) {
struct sched_param sched;
memset(&sched, 0, sizeof(sched));
// Use FIFO scheduler with highest priority for the lowest chance of the kernel context switching.
sched.sched_priority = sched_get_priority_max(SCHED_FIFO);
sched_setscheduler(0, SCHED_FIFO, &sched);
void set_default_priority(void) {
// Go back to default scheduler with default 0 priority.
sched.sched_priority = 0;
sched_setscheduler(0, SCHED_OTHER, &sched);
// ======= stepper thread
void SetStepper(unsigned long StepperMicroStep)
int index = StepperMicroStep % CoilTableSize;
GPIO_CLR= StepperMask & ~ StepperCoil[index];
GPIO_SET= StepperCoil[index];
gpioPWM(PWM_A, StepperAPWM[index]);
gpioPWM(PWM_B, StepperBPWM[index]);
/* printf("Position = %d Index = %d PWA:%d PWB:%d",StepperMicroStep,index,StepperAPWM[index],StepperBPWM[index]);
if(StepperCoil[index] & (1 << STEP_A)) printf(" A+ ");
if(StepperCoil[index] & (1 << STEP_AN)) printf(" A- ");
if(StepperCoil[index] & (1 << STEP_B)) printf(" B+ ");
if(StepperCoil[index] & (1 << STEP_BN)) printf(" B- ");
printf("\n");
int exitFlag=0;
int ThreadReturn;
void* StepperThreadFunction(void * arg )
long ltemp;
set_max_priority();
while(!exitFlag)
// Lock position
pthread_mutex_lock(&Stepper_mutex);
if(TargetPosition == StepperPosition)
StepperReadyFlag=1;
pthread_mutex_unlock(&Stepper_mutex);
break;
StepperReadyFlag=0;
if(TargetPosition < StepperPosition)
StepperPosition--;
else
StepperPosition++;
ltemp = StepperPosition;
SetStepper(ltemp);
// Set Current Position
usleep(StepperDelay);
// printf("Thread close \n");
set_default_priority();
pthread_mutex_unlock(&StepperThread_mutex);
pthread_exit(&ThreadReturn);
return NULL;
// FUNCTION
long GetStepperPosition(void)
long ltemp;
return ltemp;
void MoveStepper(long value)
// Lock mutex to create Thread
pthread_mutex_lock(&StepperThread_mutex);
// Set new Target position
TargetPosition += value;
// create the thread to move stepper
int err = pthread_create(&StepperThreadId, NULL, &StepperThreadFunction, NULL);
if (err != 0)
printf("\ncan't create thread :[%s]", strerror(err));
void BuildCoilTable(void)
int loop;
// Set first coil
for(loop=0;loop<(CoilTableSize/2);loop++)
StepperCoil[loop]= 1 << STEP_A;
for(;loop<CoilTableSize;loop++)
StepperCoil[loop]= 1 << STEP_AN;
// Set second coil
StepperCoil[(loop + CoilTableSize/4) % CoilTableSize]|= 1 << STEP_B;
StepperCoil[(loop + CoilTableSize/4) % CoilTableSize]|= 1 << STEP_BN;
// Set Power to coil
for(loop=0;loop<CoilTableSize;loop++)
unsigned char _temp;
double sinV = fabs(sin(M_PI * loop / (CoilTableSize/2.0)));
_temp= (unsigned char) floor( 255.0 * sqrt(sinV));
StepperAPWM[loop]= _temp;
StepperBPWM[(loop + MICROSTEP) % CoilTableSize]= _temp;
void setup_io()
/* open /dev/mem */
if ((mem_fd = open("/dev/mem", O_RDWR|O_SYNC) ) < 0) {
printf("can't open /dev/mem \n");
exit(-1);
/* mmap GPIO */
gpio_map = mmap(
NULL, //Any adddress in our space will do
BLOCK_SIZE, //Map length
PROT_READ|PROT_WRITE,// Enable reading & writting to mapped memory
MAP_SHARED, //Shared with other processes
mem_fd, //File to map
GPIO_BASE //Offset to GPIO peripheral
close(mem_fd); //No need to keep mem_fd open after mmap
if (gpio_map == MAP_FAILED) {
printf("mmap error %d\n", (int)gpio_map);//errno also set!
exit(-1);
// Always use volatile pointer!
gpio = (volatile unsigned long *)gpio_map;
} // setup_io
// exit handler. Just kill the thread
void bye(void)
exitFlag=1;
puts ("\nGoodbye, cruel world....");
usleep(100000);
// Control-C handler. Somehow the pigpio unhandle it properly
void MyCtrlC(int sig)
exitFlag=1;
int main(void)
int loop;
printf("Raspberry Pi micro-stepping demo with L298 driver\n");
printf("(c) Daniel Perron Sept.2014\n");
printf("Micro-step= %d (%d steps/turn)\n\n",MICROSTEP, MICROSTEP * STEP_PER_REVOLUTION );
// initialize pigpio
gpioInitialise();
// create exit handler
atexit(bye);
signal(SIGINT, MyCtrlC);
// memory map GPIO. This way I could use GPIO in Parallel mode.
setup_io();
// Create Stepper table
BuildCoilTable();
// printf("GPIO Mask : %08lX\n", StepperMask);
// for(loop=0;loop< CoilTableSize; loop++)
// printf("%d: %08lX %03d %03d\n", loop, StepperCoil[loop], StepperAPWM[loop],StepperBPWM[loop]);
// set PWM
gpioSetMode(PWM_A, PI_OUTPUT);
gpioSetMode(PWM_B, PI_OUTPUT);
gpioSetPWMfrequency(PWM_A, 100000);
gpioSetPWMfrequency(PWM_B, 100000);
gpioSetPWMrange(PWM_A,255);
gpioSetPWMrange(PWM_B,255);
// set GPIO OUTPUT
INP_GPIO(STEP_A);
OUT_GPIO(STEP_A);
INP_GPIO(STEP_AN);
OUT_GPIO(STEP_AN);
INP_GPIO(STEP_B);
OUT_GPIO(STEP_B);
INP_GPIO(STEP_BN);
OUT_GPIO(STEP_BN);
// put all Coil to 0
GPIO_CLR=StepperMask;
int p;
while(!exitFlag)
printf("Stepper position %ld. Number of step to move (0=exit) ?",GetStepperPosition());
if(scanf("%d",&p)==1)
if(p==0) break;
MoveStepper(p);
MoveStepper(0); // this will just wait until is done.
usleep(100000);
return 0;
And this is how you compile it
This is is a small video of the micro-step in action. The "stepperFull" application is full step and you will see that the vibration is strong enough to move to motor by itself.
https://dl.dropboxusercontent.com/s/zrk ... tepper.mp4
P.S. you could break the program if you enter 0 at the prompt or press ctrl-c when it is running.
B.T.W. Normally I use a sine wave with the SLA7026 from Allegro but with the L298 I had to use the square root of the sine wave if I want the equally space angle.
Daniel
