B+ audio enhancement...
I have tested B+ audio (via analog output) and yes, personally, the reproduction itself sounds a bit more real and rich than it is at B or A models. And default output level is aprox 3db louder. Thanks for that enhancement.
But I have found that there is some slight level of noise hearable from my B+ model in case that a "silence" is played.
I have tested it using a couple of headphones only (have no opportunity to test it with profi sound equipment or osciloscope yet).
Level of this noise is not affected by volume control, and is hearable only when "silence" or very low signals < -20db music (wav/mp3) or < -40db 1kHz signal (wav) is beeing played. When the signal is higher and fades out to silence then after aprox 2 seconds the noise reappears.
Model B and A have no hearable noise - it is clear silence when clear silence (wav/mp3) is beeing played.
I have tested it with "omxplayer -o local" (latest software and firmware (6.Aug) + firmware from 1.Aug - (and additionally on A and B with SW+FW from 18.Jun 2014)).
It seems to me that some kind of signal compression or ALC is used somwhere at the sound path.
Does someone other noticed this behaviour? Or does someone know if there is some kind of ALC used at B+ model?
Looking forward to release of the full B+ schematics...
