Hence my embarrassment at thinking they has stopped working !mahjongg wrote:strange that you had a B with LED's in the Ethernet connector, normally they are simply absent.
PeterO
Is there a Linux driver for SPI1?OTOH the expanded GPIO header now means you have access to both the existing SPI0 (with 2 chip-selects) and SPI1 (with 3 chip-selects).
Dunno if anyone's written that yet. Even the current drivers for SPI0 (https://github.com/raspberrypi/linux/bl ... -bcm2708.c and https://github.com/raspberrypi/linux/bl ... -bcm2835.c) were written by members of the community Chris Boot and Stephen Warren...notro wrote:Is there a Linux driver for SPI1?
You have the datasheet, don't you?notro wrote:Is there a Linux driver for SPI1?OTOH the expanded GPIO header now means you have access to both the existing SPI0 (with 2 chip-selects) and SPI1 (with 3 chip-selects).
Rev 2.1 was brought in to partially bridge the BOM gap between Rev 2 and B+. In this design, certain high-value parts that would be differentiated between B and B+ were made interchangeable between the B rev 2.1 and the B+.jojopi wrote:Model B Rev 2.1 actually does have the extra holes to accept a magjack with built-in LEDs. There are even pads R41/R42 to allow the signals to be routed to the magjack instead of to the separate LEDs. I do not know if any were ever made like that, though.
According to https://github.com/raspberrypi/document ... /105/filestlc wrote:Does someone know to where are GPIO28-31 connected on B+ model, please? Or do I have to wait till the complete circuit diagram / schema will be released by the Foundation?
According to a preliminary version 1.2 dated march 7 2014 of the B+ schematic in my possession, the above assesment is correct, and GPIO 30 is not used.AndrewS wrote:According to https://github.com/raspberrypi/document ... /105/filestlc wrote:Does someone know to where are GPIO28-31 connected on B+ model, please? Or do I have to wait till the complete circuit diagram / schema will be released by the Foundation?
- GPIOs 28 and 29 are connected to I2C0 (possibly on the CSI and/or DSI interface?)
- GPIO31 is connected to "LAN NRESET" - driving this to the wrong value will have 'turned off' the LAN9514 chip, which is what will have stopped your USB ports (and Ethernet) from working
But yeah, waiting for the full schematics will be the only way to be 100% sure what the pins are connected to!
If you're compiling a list like that, you'll find http://www.raspberrypi.org/documentatio ... /README.md very usefulwallarug wrote:Can someone please post a list of part IDs (J1, J2, J3, etc.) for the USB, Ethernet and ports on the B+.
Thank you! I will see if I can find others from pictures.rpdom wrote:From what I can see on the board:
USBs J11 (middle), J12 (edge)
Ethenet J10
GPIO (40-way) J8
RUN Not marked!
You've already got the others.
Which JTAG? ARM or VidCore?rpdom wrote:J5 is the (unpopulated) JTAG connector on the other side of the board to the HDMI socket.
J9 is the micro SD card socket.
I can't see J2.
J5 is VideoCore jtag.wallarug wrote:Which JTAG? ARM or VidCore?
Thanks Dom and Andrew for you help!dom wrote:J5 is VideoCore jtag.wallarug wrote:Which JTAG? ARM or VidCore?
Interesting! These were originally going to be a pair of EMI4182 common mode filters for the four HDMI differential pairs. The same chips as on Model B Rev2.1, which was intended to reduce the number of BOM differences to the B+. Looking at B+ photos, they have been replaced by different filters, L4…L7.mahjongg wrote:U6 N.U.
U7 N.U.
With that gone, I do wonder whether Q6 is really still required?U12 N.U.
Is there a way to read input voltage with 'vcgencmd measure_volts' or something similar?jdb wrote: Note that the PWR LED is now connected to an undervoltage supervision chip. The PWR LED will flash (or go out) if the PSU voltage drops below ~4.63V.
