Hello, My Raspberry Pi is a Model B and I'm trying to make it work on my AOC e2239fwt. I have Raspbian flash on my SD card and it boots.
I know of this because I tried plugging the RPi on my Samsung LCD with HDMI and it works. The Screen has display and I was able to boot to Raspbian without a problem but when I go to my AOC e2239fwt (I need this screen because it is touchscreen) there is no display.
I've tried to add this on my config.txt
hdmi_drive=2
config_hdmi_boost=4
hdmi_force_hotplug=1
hdmi_group=1
hdmi_mode=4
hdmi_ignore_edid=0xa5000080
and still the RPi gives no display.
I've tried to list down the problems:
HDMI cable busted = Not possible because it worked on the Samsung
HDMI signal too low = I've tried to boost it to 9 still nothing
RPi did not boot = Not possible because it booted while on Samsung and on SSH
AOC is not compatible for RPi = Not possible due to : https://www.youtube.com/watch?v=bHfulmm7_9E
(a User plugged in the same monitor that I want to use and it worked for him and not for me)
So, Any ideas ? I really need help here I've stayed up 5 hours trying to troubleshoot this darn AOC monitor.
