vector.S
#include "exception.h"
.global reset
.global _undefine_instruction
.global _svc_smc_call
.global _prefetch_abort
.global _data_abort
.global _not_used
.global _irq
.global _fiq
.global _start
.global temp_label
.section .vectors
.align 5
_start:
b _reset @0x0
b _undefine_instruction @0x4
b _svc_smc_call @0x8
b _prefetch_abort @0xc
b _data_abort @0x10
b _not_used @0x14
b _irq @0x18
b _fiq @0x1с
reset:
b _reset @hello_world
_undefine_instruction:
b undefine_instruction
_svc_smc_call:
b svc_smc_call
_prefetch_abort:
b prefetch_abort
_data_abort:
b data_abort
_not_used:
b .
_irq:
b .
_fiq:
b .
boot.S
.equ Mode_USR , 0x10
.equ Mode_FIQ , 0x11
.equ Mode_IRQ , 0x12
.equ Mode_SVC , 0x13
.equ Mode_MON , 0x16
.equ Mode_ABT , 0x17
.equ Mode_UNDEF , 0x1B
.equ Mode_SYS , 0x1F
.equ I_Bit , 0x80 @ when I bit is set, IRQ is disabled
.equ F_Bit , 0x40 @ when F bit is set, FIQ is disabled
/* descriptors for Sections */
.equ L1_COHERENT , 0x00015c06 @ Template descriptor for coherent memory (and L2 cache enabled)
@.equ L1_COHERENT , 0x00014c02 @ Template descriptor for coherent memory (and L2 cache enabled)
.equ L1_NONCOHERENT , 0x00000c1e @ Template descriptor for non-coherent memory
.equ L1_DEVICE , 0x00000c06 @ Template descriptor for device memory
.equ temp , 0
.global _reset
tlbs_l1_base:
.word 0x8000
.section ".text"
.type _reset, %function
_reset:
.fnstart
.cantunwind
b main
.fnend
.size _reset, . - _reset
#include <common.h>
#include "reg_debug.h"
#include "checker.h"
void svc_smc_call(){
blink();
void undefine_instruction(){
blink();
void prefetch_abort(){
blink();
void data_abort(){
blink();
main.c
#include <common.h>
#include <exports.h>
#include "v6.h"
#include "addition.h"
int main() {
printf("\nhello\n");
asm volatile ("mvn r1, #0");
enableAbortException();
setVBAR(0x18000);
disableHighVecs();
unsigned int reg_value;
asm volatile ("mov %0, r1" : "=r" (reg_value) );
PRN_REG(reg_value, "reg_val")
asm volatile ("mov %0, r8" : "=r" (reg_value) );
printf("\ntry to generate exception...\n");
asm volatile ("ldr r0, [r1]");
asm volatile ("mov %0,r0" : "=r" (reg_value) );
for(;;) {}
return 0;
.global enableAbortException
.global enableAbortExceptionSize
.type enableAbortException, %function
enableAbortException:
.fnstart
.cantunwind
CPSIE a
BX lr
.fnend
.size enableAbortException, . - enableAbortException
.global disableHighVecs
.global disableHighVecsSize
@ void invalidateCaches(void);
.type disableHighVecs, %function
disableHighVecs:
.fnstart
.cantunwind
MRC p15, 0, r0, c1, c0, 0 @ Read Control Register
BIC r0, r0, #(1 << 13) @ Set the V bit (bit 13)
MCR p15, 0, r0, c1, c0, 0 @ Write Control Register
BX lr
.fnend
.size disableHighVecs, . - disableHighVecs
#define GPFSEL1 0x20200004
#define GPSET0 0x2020001C
#define GPCLR0 0x20200028
void blink() {
unsigned int ra;
ra=GET32(GPFSEL1);
ra&=~(7<<18);
ra|=1<<18;
PUT32(GPFSEL1,ra);
while(1)
PUT32(GPSET0,1<<16);
for(ra=0;ra<0x100000;ra++) _dummy(ra);
PUT32(GPCLR0,1<<16);
.global PUT32
PUT32:
str r1, [r0]
bx lr
.global GET32
GET32:
ldr r0, [r0]
bx lr
.global _dummy
_dummy:
nop
bx lr
#include <common.h>
/*#include <exports.h>*/
void prnSCR(){
int ret;
asm("mrc p15, 0, %0, c1, c1, 0" : "=r" (ret) );
#ifdef DEBUG
PRN_REG(ret, "SCR")
#endif
void prnSCTLR(){
int ret;
asm("mrc p15, 0, %0, c1, c0, 0" : "=r" (ret) );
#ifdef DEBUG
PRN_REG(ret, "SCTLR")
#endif
void prnCPSR(){
int ret;
asm("mrs %0, CPSR" : "=r" (ret));
#ifdef DEBUG
PRN_REG(ret, "CPSR")
#endif
void prnCPACR(){
int ret;
asm("mrc p15, 0, %0, c1, c0, 2" : "=r" (ret) );
#ifdef DEBUG
PRN_REG(ret, "CPACR")
#endif
void prnACTLR(){
int ret;
asm("mrc p15, 0, %0, c1, c0, 1" : "=r" (ret) );
#ifdef DEBUG
PRN_REG(ret, "ACTLR")
#endif
void prnVBAR(){
int ret;
asm("MRC p15,0,%0,c12,c0,0" : "=r" (ret) );
#ifdef DEBUG
PRN_REG(ret, "VBAR")
#endif
void prnCLIDR(){
int ret;
asm("MRC p15,1,%0,c0,c0,1" : "=r" (ret) );
#ifdef DEBUG
PRN_REG(ret, "CLIDR")
#endif
unsigned int getSCR(){
unsigned int ret;
#ifdef DEBUG
PRN_REG(ret, "SCR")
#endif
return ret;
unsigned int getSCTLR(){
unsigned int ret;
#ifdef DEBUG
#endif
return ret;
unsigned int getCPSR(){
unsigned int ret;
#ifdef DEBUG
#endif
return ret;
unsigned int getCPACR(){
unsigned int ret;
#ifdef DEBUG
#endif
return ret;
unsigned int getACTLR(){
unsigned int ret;
#ifdef DEBUG
#endif
return ret;
unsigned int getVBAR(){
unsigned int ret;
#ifdef DEBUG
#endif
return ret;
///////////////// Register Set Functions //////////////////
void setVBAR(unsigned int var){
asm("MCR p15,0,%0,c12,c0,0" : :"r" (var) );
