Fans blow, but they suck as well! Sure the light-up ones look pretty, but don't people realise fans just fill your computer with dust? Will these people ever learn?DougieLawson wrote:What is it with cases and cooling and f****** fans?
Once saw a great safety video on this some ~22 years ago. It was from the fire service. They had an example of where the power cable to the cooker was wound around the gas pipe. The owner was fed up replacing the fuse for the cooker, since it kept blowing, and installed a lump of copper instead. The result was that when the cooker next went wrong, the power cable melted through the gas pipe and blew up the house. Thankfully, no one was in the house at the time.BMS Doug wrote:fuses are there for a reason, if you bypass them then you could find out why they were there!!!!!
(and not enjoy the experience)
Cases have saved me a couple times so far.Ravenous wrote:Fans blow, but they suck as well! Sure the light-up ones look pretty, but don't people realise fans just fill your computer with dust? Will these people ever learn?DougieLawson wrote:What is it with cases and cooling and f****** fans?
That sucks anyway because they'll only have a few in the store, and when stocks run out it's fleecing time!bertwert wrote:This sucks!
I do not live in NYC!
http://www.popphoto.com/gear/2014/05/sw ... -youre-nyc
For the record, you are not one of those PGFs to which I referLong_Term_Lurker wrote:Indeed it does.
I wouldn't know, I suspect "much more lengthy" is considered more correct but it also sounds clumsier and is less "conversational English".Ravenous wrote:...or should I have said "much more lengthy" ?
You should of paid more attention during English classes.Long_Term_Lurker wrote: But then I'm only an engineer who barely scraped a pass in 'O' level English.![]()
Worry about Gove - no longer. He got kicked out of his education job today.r3d4 wrote:I have found with in this video "Dear Mr Gove... - Michael Rosen"
You are being ironic, right?drgeoff wrote:You should of paid more attention during English classes.Long_Term_Lurker wrote: But then I'm only an engineer who barely scraped a pass in 'O' level English.![]()
