Reasonable
Learning C
Tue May 20, 2014 8:09 am
Are there any good resources for learning C for Raspberry Pi? Any good book recommendations? I'm not a complete novice and understand the basics but never really dealt with C. I did some work with C++ but a very long time ago.
I've been looking at some tutorials and they are either along the lines of "hello world" or have hundreds lines of code with little explanation.
AndyD
Re: Learning C
Tue May 20, 2014 8:28 am
Assuming that you are using Raspbian, then any tutorial aimed at C programming on Linux should be applicable. I learned C a long time ago (1991), so I can't recommend any particular modern books or resources. I used the venerable book The C Programming Language by Kernighan and RItchie. If you already know some C++, then you have some knowledge of C as well. They have a lot in common. In fact most C programs will compile and run (correctly) using the C++ compiler.
ShiftPlusOne
Re: Learning C
Tue May 20, 2014 8:32 am
+1 for K&R
Then I recommend playing around with C and SDL.
Conrad Goodwin
Re: Learning C
Wed May 21, 2014 2:38 am
+1 more for K&R. I'm working on it now, and think it's a dandy.
Re: Learning C
Wed May 21, 2014 8:10 am
Only problem with K&R is the bracketing style. It's partly responsible for the Linux kernel coding style, which is evil...
“My wife said to me `...you’re not even listening`.
I thought, that’s an odd way to start a conversation.."
Re: Learning C
Wed May 21, 2014 9:23 am
jamesh wrote:Only problem with K&R is the bracketing style. It's partly responsible for the Linux kernel coding style, which is evil...
So why do you use it in the picamera code? Isn't 1TBS better?
Re: Learning C
Wed May 21, 2014 9:50 am
I don't. K&R uses 1TBS (well, 1TBS is a slight modificaiton of K&R), I'm an Allman fan. Raspistill/Vid uses Allman.
ShiftPlusOne
Re: Learning C
Wed May 21, 2014 11:11 am
What's wrong with 1TBS?
I started with Allman, since that's what the first C book I read used. I ended up switching to GNU and then settling on 1TBS since it seems to use space better, while retaining readability.
tenspot
Re: Learning C
Wed May 21, 2014 12:29 pm
I found the following resource useful for getting started with C.
http://cslibrary.stanford.edu/101/EssentialC.pdf
PeterO
Re: Learning C
Wed May 21, 2014 12:43 pm
AndyD wrote: I used the venerable book The C Programming Language by Kernighan and RItchie.
But did you use the 1st Edition ? ;)
PeterO
AndyD
Re: Learning C
Wed May 21, 2014 2:01 pm
PeterO
No, the second edition is Copyright 1988. I started programming in C in 1991.
tenspot wrote:Hi,
From a very brief look, there appears to be some very good information in that PDF.
Richard-TX
Re: Learning C
Wed May 21, 2014 2:13 pm
Learning any computer language is just like learning German, Italian, etc. It has it's own dictionary, grammar, and punctuation rules. In the very early days, when a person took a computer programming course ion college, the credits earned were under the heading of "Foreign Language" which is a fair assessment.
If you really want to learn about C, go talk to some college students. Some of the most brilliant programming I have ever seen came from 3rd year students.
Richard
Doing Unix since 1985.
williamhbell
Re: Learning C
Wed May 21, 2014 7:45 pm
Reasonable wrote:Are there any good resources for learning C for Raspberry Pi?
You could always try the C Cave series in The MagPi. The list of articles can be found by going to
http://magpiindex.steverigg.co.uk/index.php
and then selecting "Programming C/C++" from the category menu. The articles build from simple to complete concepts, in stages. All articles have working source code examples and problems to solve.
Kernighan and Ritchie's book is well worth having. However, it does not cover the non ANSI libraries that can be very useful on Linux. Some non-ANSI features are introduced in the C Cave, but these are highlighted as being such.
AndyD
Re: Learning C
Wed May 21, 2014 10:07 pm
williamhbell wrote:...
Kernighan and Ritchie's book is well worth having. However, it does not cover the non ANSI libraries that can be very useful on Linux. ...
Last century ( :) ) I used the book Advanced Programming in the UNIX Environment by the late W. Richard Stevens, as it covered a number of UNIX implementation details. There is a newer (3rd) edition published in 2013. However, the Internet is now a very useful resource.
Return to “C/C++”
