redhawk
How to disable onboard audio??
Mon Mar 24, 2014 10:32 pm
I would like to disable the analogue audio on the Pi and that includes the PWM engine.
I understand blacklisting the audio module should be possible but is it enough to prevent the PWM engine from starting up on boot??
What's the best procedure for this??
Richard S.
ReBoot
Re: How to disable onboard audio??
Tue Mar 25, 2014 4:14 pm
What exactly do you want to achieve? Disabling Audio isn't a Goal in itself, you follow a Goal and the way would be to disable Audio. What's the actual Goal?
redhawk
Tue Mar 25, 2014 4:45 pm
The onboard audio PWM is generating frequencies in the RF region it's also active at all times whether I like it or not.
I believe this maybe causing interference with one of my I2C radio modules but to find out for sure I need some way of turning it off.
This was possible with the old "click-pop" audio firmware but not anymore. :(
Edit: okay I've found a solution thanks to another post, you need to add the following line to the boot config.txt file force_pwm_open=0
Richard S.
Return to “Raspberry Pi OS”
