supper
PiFBA works with a Wii remote so I see no reason why PiMAME4ALL would not as pudding wrote both (using standard SDL Linux Raw input). Have a search on the Forum/Web, you should find instructions for setting up a Wii Remote on the RPi.
Re: MAME4ALL for Pi
"The list of things I have heard now contains everything!"
Re: MAME4ALL for Pi
What happened to this project? The emulator isn't in the pi store now.
And ... I tried to find a recent post from "pudding" without lucky. What happened to him?
Re: MAME4ALL for Pi
Get it from here:
https://mame4all-pi.googlecode.com/arch ... 3b493f.zip
Re: MAME4ALL for Pi
I know that, the code google page is working but it's weird ...kalehrl wrote:Get it from here:
Re: MAME4ALL for Pi
Well I was able to solve my trouble with Spy Hunter. I didn't have an analog joystick to test so I went straight to the source code. I changed the steering wheel to AD Stick X and also changed the auto center code to immediately snap back to center once the controls are released. I also changed the peddle to AD Stick Y to have more control when you are driving in High gear. After those changes, Spy Hunter actually became playable with digital controls (as opposed to weaving around the road like a drunk).
Re: MAME4ALL for Pi
It looks like the WiFi check built into the PiMAME menu program.by biobern » Mon Dec 09, 2013 10:37 pm
I've built an installation for a MAME Bartop Machine that boots directly into mame4all. I'd like to have a boot process as silent as possible. I've already added "quiet" to "cmdline.txt" and removed "console=tty1". Also I removed the splash screens and the splash movie. The boot process is already pretty silent now, but I still get the error message "wlan0: error fetching interface information: Device not found".
I don't need any wlan, I just want to suppress the error message.
Any ideas?
Thanks.....
Try this - edit the file
/home/pi/pimame_files/menu.py
find the line that begins...
wlan = subprocess.check_output(.....etc
and add a # at the start of the line so that it reads...
#wlan = subprocess.check_output(.....etc
This will remove the WiFi check and should stop the message you're getting. Let me know if this works or not.
Re: MAME4ALL for Pi
Maybe I have a workaround for you: It seems that you have to remove your USB-Joystick (do you have one?) and reboot, then your Trackball will work out of the box.Husar wrote:I am finall up and running with my arcade controls. Now I need to get my trackball working.
How would a USB trackball be enabled to use in MAME4ALL? I have a Happ 3'' trackball that is USB. It works just like a mouse in X. In MAME4ALL I have looked in the mame.cfg for something like mouse=1 or 0 but that setting is not there like you would expect from the mame.ini file.
Is there something different I need to do to enable trackball support for games like centipede and missle command.
In case you use a keyboard encoder like "ultimarc i-pac" for your Joystick instead of a normal USB-Joystick, you should have Joystick and Trackball working at the same time.
Does this help?
Re: MAME4ALL for Pi
Thanks for that hint. I solved the problem in a different way, but I cannot remember how I did it at the moment. Stupid me! Thanks anyway!mikiec wrote:It looks like the WiFi check built into the PiMAME menu program.by biobern » Mon Dec 09, 2013 10:37 pm
Any ideas?
Thanks.....
Re: MAME4ALL for Pi
Anybody get Indiana Jones working? I have 4 different romset versions (all supposedly 37b5). They load the title screen and demo loop fine, but never register a coin.
Re: MAME4ALL for Pi
cacophony555
I have had the same issue (with the latestt rev), it definitely worked in a previous version!
Re: MAME4ALL for Pi
I tried this early version, but it still has the same issue:welshy wrote:cacophony555
http://code.google.com/p/mame4all-pi/so ... d0e06dbd9c
I wonder which version worked...
Or maybe you're thinking of AdvMame?
http://www.raspberrypi.org/forum/viewto ... 01#p432701
Re: MAME4ALL for Pi
Nope, it definitely worked in both, I was playing it on AdvMAME with my nephew and we were in hysterics because the samples sounded funny. So I loaded it in MAME4ALL but he decided it was much more hilarious with the speech distorted! I don't recall which version it was but it was back in August because he came to visit on school holidays. To be honest, it was still distorted in MAME4ALL.cacophony555 wrote:Or maybe you're thinking of AdvMame?
Re: MAME4ALL for Pi
Has anyone been able to get 'Toki' working with mame4all? I get garbled graphics with this one.
Re: MAME4ALL for Pi
Same here, Toki shows grabled graphics and stalls on the grabled title screen.KitchUK wrote:Has anyone been able to get 'Toki' working with mame4all? I get garbled graphics with this one.
Re: MAME4ALL for Pi
Been trying without success to get MAME4ALL to load ROMs from a network share.... My setup guide was here...
http://pimame.org/forum/discussion/731/ ... k-share/p1
It can see the share, ROMs are listed but when I got to load a game it says the the individual files in the zip are missing... If I copy the same ROM onto the SD card it loads fine.
The ROMs load fine in ADVANCEMAME.
This is the line from fstab..
//192.168.0.6/roms /media/roms cifs username=martin,password=password,uid=1000,gid=1000,iocharset=utf8 0 0
This is from my mame.cfg......
rompath=roms;/media/roms/MAME-37
ls -la gives
drwxr-xr-x 0 pi pi 0 Feb 14 13:30 MAME-37
Has anyone got any ideas ? The frustrating this is it did work briefly however after a reboot it started failing again...
Cheers Guys....
ls -la gives
Cheers Guys....
Re: MAME4ALL for Pi
I've got mame4all and I copied all my roms from my computer and put them in the pi's ROM folder and not all the games work like bubble Bobble and marvel vs Capcom and tekken tag tournament, other games have worked but the others don't what can I do?
Re: MAME4ALL for Pi
Try using PiFBA for these games (Capcom CPS1 & 2).manny wrote:I've got mame4all and I copied all my roms from my computer and put them in the pi's ROM folder and not all the games work like bubble Bobble and marvel vs Capcom and tekken tag tournament, other games have worked but the others don't what can I do?
Re: MAME4ALL for Pi
manny
Welcome to the Forum! Tekken TT will not run in PiMAME4ALL, for a full list of the Titles and their MAME Codes) which are compatible, Open a terminal, 'CD' into the Folder, then
Type: ./mame -listgames
If you are using MAME ROMS from another System (e.g. PC) the CORRECT ROM version MUST be used, for MAME4ALL you are looking for MAME version 0.37b5 or 0.37b11 ROMS. The MAME Code reveals the revision needed, i.e. if you want to run Asteroids the Code for MAME4ALL is 'asteroid', asteroids, asteroid1 etc. are different revisions of the ROM and wont work!
As KitchUK has suggested Marvel vs Capcom works in PiFBA, for a full list of compatible Titles, Open a terminal, 'CD' into the folder, then
Type: ./fba2x --gamelist
This creates a txt File in the Folder which you can view which again, lists all the compatible Titles with their MAME Codes
Hope that Helps!
Hope that Helps!
Re: MAME4ALL for Pi
I've fixed the issue with not loading over a windows network share, I've used this entry in my fstab and it works fine:
//192.168.0.6/roms /media/roms cifs username=martin,password=password,nounix,noserverino,defaults,users,auto 0 0
Info was borrowed from here:-
http://www.linuxquestions.org/questions ... re-944766/
Re: MAME4ALL for Pi
Anyone know if it's possible to force mame4all to run at 50hz. Currently have it running on a crt tv and the sound is quite choppy, found out how to do it for the other emulators by adding a line to retroarch.cfg but from what I've read about mame4all it is unaffected by this.
Re: MAME4ALL for Pi
resoncamper
Welcome to the Forum! MAME differs from other emulators as it replicates Arcade Cabs, it has no setting for PAL/NTSC due to their nature (they all run on 60Hz refresh rate Monitors irrespective of Country). The differences in display Fz only effected Systems connected to their native TV display encoding modulators, be it PAL: UK (50Hz), NTSC: USA/JAPAN (60Hz) or SECAM: EUR/AFRICA (50Hz). Some versions of MAME take account for this by having Option Settings for Cabs Built on CRT TV's with differing refresh rates (AdvMAME for instance), but as MAME4ALL was originally a fork for Handhelds where this wasn't an issue (PSP, GP32 etc.) it probably isn't present in the code as an Option. Depending on how old you PAL CRT they may be a solution, some later models had NTSC/60Hz compatibility but often only for RGB connection, not composite or RF, check the technical documentation for the display. OR you could force the RPi into 50Hz Mode, see if that helps See Here - http://elinux.org/RPiconfig
Re: MAME4ALL for Pi
How do I get this emulator to detect my joysticks? I hit TAB and go into the menus and it will detect any button just fine, but when I go to any section that asks for directional input it will not work with me. Almost like it expect analogue input. Is there a config file I can just edit somewhere with my jstest results?
Re: MAME4ALL for Pi
Jessie
There should be a config file in the requisite MAME4ALL_pi Folder (mame.cfg) utilising standard SDL input codes for Joystick and Keyboard which can be edited.
Re: MAME4ALL for Pi
I'll look in there again. Seems like there were no lines for input in that file but I will give it another look.welshy wrote:Jessie
Re: MAME4ALL for Pi
Jessie
Appologies, my error, the latest version auto detects joysticks then you should be able to defined inputs in the usual MAME manner thru Tab, Input (General) or Input (this Game).
