Davespice
Contact: Twitter
8086tiny
Tue Jan 28, 2014 2:14 pm
Hi folks;
Just doing a post about this emulator, written by Adrian Cable. It's an open source (MIT license) 8086 emulator and is less than 32K compiled, it obviously can't do as much as DosBox but it can run certain things. The source may help people to develop their own emulation projects maybe?
Anyway, this may be offered as a package in the Raspbian repo in the future but for now you can just download it and compile it out of the box.
Check out: http://www.megalith.co.uk/8086tiny/
How to
mkdir tiny
cd tiny
wget http://www.megalith.co.uk/8086tiny/downloads/8086tiny_103.tar.bz2
tar -xvf 8086tiny_103.tar.bz2
Check the above URL on their downloads page for new versions.
You'll need SDL 1.2 dev package installed in order to compile.
sudo apt-get install libsdl1.2-dev
To compile just run;
make
This won't take too long. Then to run the emulator just run;
./runme
This will boot from a floppy disk image, so you'll end up at A:/>_
To exit the emulator you type the following at the A drive prompt.
quitemu
Make a hard disk
So you'll probably need a way to get programs into the emulation environment to run. To do that we can make a blank disk image, use the emulator to partition and format it and then we can mount it under Linux to access its file system.
Use dd to make a blank image file full of zeros. If you name it hd.img the runme shell script will test for it.
dd if=/dev/zero of=./hd.img bs=1024K count=128
This will make a 128 MB disk, give it a moment or two to write the file to disk. Then go back into the emulator again.
./runme
The emulator will now complain about an illegal partition table but will still allow you to boot from the floppy disk image.
When you get to the A drive prompt run fdisk.
fdisk
Say no to large disk support: N
Enter 1 to create a DOS partition or logical drive
Enter 1 to create a primary DOS partition
Say yes to all available space and make active: Y
Escape
Escape
Now quit the emulator and restart it.
quitemu
./runme
You should now see the illegal partition warning is gone and that a line of info about C: is shown.
When you get to the A drive prompt enter the following to format the C drive.
format c: /s
Type Y E S and press enter. Give it a volume label, say DOS. The format will be quite quick.
When you're back at the A drive prompt you'll be able to go onto the C drive.
C:
dir
You should see KERNEL.SYS and COMMAND.COM.
Now close down the emulator and we'll mount the disk under Linux so that we can copy files onto it.
A:
quitemu
Run the following command to inspect the file.
fdisk -lu hd.img
The output should look something like this;
Disk hd.img: 134 MB, 134217728 bytes
4 heads, 63 sectors/track, 1040 cylinders, total 262144 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00000000
 Device Boot      Start         End      Blocks   Id  System
hd.img1   *          63      258047      128992+   6  FAT16
More info here, but we need to know the unit of sectors which is 512 and the start sector of the partition which is 63.
Then we can use loop-mounting to mount the disk and access it.
sudo losetup /dev/loop0 hd.img -o $((63 * 512))
sudo file -s /dev/loop0
sudo mount /dev/loop0 /mnt
We should now be able to copy files into /mnt to put them on the DOS hard disk. After doing this un-mount it before going back into the emulator.
sudo umount /mnt
sudo losetup -d /dev/loop0
Hope this helps! Enjoy :)
Dave
scruss
Re: 8086tiny
Tue Jan 28, 2014 3:04 pm
Gradely!
I had fun playing with the 4043 byte (= 8086 nybble; you absolute star, Adrian …) version. Should run Protext no trouble, complete with printer passthrough.
Pronouns: he/him
panik
Re: 8086tiny
Tue Jan 28, 2014 4:26 pm
scruss wrote:Gradely!
Jawdropping awesome. Had to climb down my chair to pick it up.
The rest of the entries to the ioccc contest over the years as well. The really early ones sadly don't compile anymore, but I had a lot of fun playing around with them just a couple of days ago. Someone posted a link to the same entry earlier. I think on another forum.
Beautiful, brilliant people. They do exist.
scruss
Re: 8086tiny
Wed Jan 29, 2014 12:35 am
There's the similarly small CP/M emulator from IOCCC. You have to be kind of old to have any interest in running it, but it's quite functional.
(you can tell I really want to build an N8VEM, but why I'd want to spend more money on slower computer than a Raspberry Pi …)
Pronouns: he/him
Re: 8086tiny
Wed Jan 29, 2014 10:09 am
scruss,
Your CP/M link does not work.
8086tiny is amazing. Perhaps I should try and get it running on my little STM32 F4 Discovery board.
It's kind of weird to watch a Raspi running that and remember how big, heavy and power hungry the original IBM PC was!
Davespice
Contact: Twitter
Re: 8086tiny
Wed Jan 29, 2014 11:54 am
Folks, this is now in the Raspbian repo. It comes with a ready to use 20 MB hard disk image, already formatted.
sudo apt-get update
sudo apt-get install 8086tiny
cd /opt/8086tiny
sudo ./runme
There are also a couple of shell scripts that allow you to mount and unmount the DOS hard disk.
To mount
cd /opt/8086tiny
sudo ./mount
cd /mnt
ls
To unmount
cd /opt/8086tiny
sudo ./unmount
ukscone
Re: 8086tiny
Tue Feb 04, 2014 2:33 pm
it's just my personal opinion but I always think that using bare /mnt as the mount point is bad form & can cause problems so I think the scripts to mount/unmount the hd image should use a subdir within /mnt rather than the bare /mnt
ukscone
Re: 8086tiny
Tue Feb 04, 2014 2:42 pm
scruss wrote:There's the similarly small CP/M emulator from IOCCC. You have to be kind of old to have any interest in running it, but it's quite functional.
I haven't built N8VEM for the raspberry pi but if you want CP/M then z80pack & YAZE work perfectly on the raspberry pi. they were about the 2nd or 3rd things I ever compiled for the raspberry pi
Davespice
Contact: Twitter
Re: 8086tiny
Tue Feb 04, 2014 2:43 pm
Fair point, I guess I can add this in for a future update :)
/mnt/8086tiny I guess would be better?
ukscone
Re: 8086tiny
Tue Feb 04, 2014 3:00 pm
Davespice wrote:Fair point, I guess I can add this in for a future update :)
yep, that'd work
Michael_O
Re: 8086tiny
Tue Feb 04, 2014 5:00 pm
Hi
This is fascinating, I have to look quickly and see did I really throw out my old DOS floppies the other day!
In the meantime I have a copy of AsEasyAs on a Windows share I can access from the Pi but I can't copy it into the mounted virtual disk. I don't know how to change the permissions to allow me to do this. I have tried 'sudo chmod 777 /mnt ' in a console using ssh but it doesn't work. Can you tell me what I should do please?
This is an amazing piece of work and the authors presentation of it to the judges should have won on its own!
solar3000
Re: 8086tiny
Wed Feb 05, 2014 6:22 pm
Nice.
But it looks like the only way to exit is kill -1 [PID].
Great job.
That Dave, what a great smile. Such a nice guy.
Antikythera
andrum99
Re: 8086tiny
Wed Feb 05, 2014 9:46 pm
solar3000 wrote:Nice.
That's what I thought, until I read the post above. It seems:
quitemu
exits the VM. This uses the quitemu.com executable in the default image. This can presumably be copied to any other disk image you might use.
andrum99
Re: 8086tiny
Thu Feb 06, 2014 5:07 pm
There seems to be a new version of 8086tiny in Raspbian now - I just updated to version 1.10 from 1.03. It seems to have moved out of /opt and I can't find the runme script - does anyone know what's up?
RaTTuS
Contact: Twitter YouTube
Re: 8086tiny
Thu Feb 06, 2014 5:16 pm
umm /mnt ?
Covfefe
duberry
Location: standing on a planet that's evolving. And revolving at nine hundred miles an hour
Re: 8086tiny
Thu Feb 06, 2014 6:15 pm
andrum99 wrote:I can't find the runme script
You could; let the computer find it for you ? using hxxp://en.wikipedia.org/wiki/Find
eg .
 sudo find / -name runme
lend me your arms, fast as thunderbolts, for a pillow on my journey.
If the environment was a bank, would it be too big to fail
so long; and thanks for all the pi
mob-i-l
Contact: Website Facebook Twitter YouTube
Re: 8086tiny
Sat Feb 08, 2014 11:27 am
Maybe 8086tiny could be made to emulate the Amstrad PC1512 (documented at http://www.seasip.info/AmstradXT/1512tech/ ). It had an extended CGA-mode with 16 simultaneous colors. PC1512 was my second computer but I soon replaced the Intel 8086 with a NEC V30 CPU (similar to 80186 but also with 8080-mode) and added 128KB RAM, 30MB HDD, 720KB FDD, and 1200BPS modem.
Have Pi0&1A&1B&1B+&2B&3B&4B w/ Raspbian. Started w/ BASIC on ABC80&ZX81 then Forth, Z80… https://scratch.mit.edu/users/mobluse/ https://github.com/mobluse/ https://twitter.com/mobluse/ https://YouTube.com/MOBiL4u/
mob-i-l
Re: 8086tiny
Sat Feb 08, 2014 1:15 pm
I did find a cashed version of the CP/M-site:
http://webcache.googleusercontent.com/s ... lator.html
and some more info:
http://www.embedded-it.de/en/bsp/demos/ ... ulator.php
scruss
Re: 8086tiny
Sat Feb 08, 2014 4:47 pm
mob-i-l wrote:I did find a cached version of the CP/M-site: …
Dunno why you'd need those, as the author's Toledo 8080 processor emulator site still works. Builds and runs fine on Raspberry Pi.
Pronouns: he/him
Davespice
Contact: Twitter
Re: 8086tiny
Sat Feb 08, 2014 9:24 pm
andrum99 wrote:There seems to be a new version of 8086tiny in Raspbian now - I just updated to version 1.10 from 1.03. It seems to have moved out of /opt and I can't find the runme script - does anyone know what's up?
Okay I need to update everyone on this. I've been getting to grips with the Debian packaging system as I've been going. So I'm sorry for the inconvenience of things moving around. A few people emailed in to complain that I wasn't following the standard packaging procedure so I've been doing my best to bring it in line. Here is a history of what has been going on.
  • 1.03 = cd /opt/8086tiny && sudo ./runme
    Problematic because /opt is not the right place and that sudo was needed to run the emulator (owing to the installed files acquiring root ownership during installation of the package).
  • 1.10 = cd /usr/share/8086tiny && ./runme
    Main emulator binary now installed to /usr/bin
    Everything else installed to /usr/share/8086tiny
    runme shell script copies bios file and disk images to ~/.8086tiny (so the pi user has ownership) and runs the emulator from there (the correct Linux way of doing it)
    Still problematic though because the user needs to cd to /usr/share/8086tiny before using runme
  • 1.11 = 8086tiny-run (from anywhere)
    Done away with the runme shell script but now installs a few extra shell script to /usr/bin which can be run from anywhere. There are;
    8086tiny-run
    8086tiny-mount (mounts to /mnt/8086tiny)
    8086tiny-unmount
    8086tiny-newimage
  • 1.20 = 8086tiny (from anywhere)
    Renamed the 8086tiny binary to 8086tiny.bin and renamed 8086tiny-run to 8086tiny. Users can now just type 8086tiny to run the emulator from anywhere. Disk images still live in ~/.8086tiny.
mob-i-l
Re: 8086tiny
Sat Feb 08, 2014 10:18 pm
That nanochess.org-link hasn't worked anytime when I tried it.
Edit: The site worked now and I got this CP/M-emulator to work. Very cool!
hene193
Re: 8086tiny
Sat Feb 08, 2014 10:32 pm
How do I change floppies? I've three floppy images.
andrum99
Re: 8086tiny
Sat Feb 08, 2014 10:37 pm
Thanks for the update. :-)
Davespice
Contact: Twitter
Re: 8086tiny
Sat Feb 08, 2014 11:42 pm
hene193 wrote:How do I change floppies? I've three floppy images.
Normally the shell scripts run the binary like so: 8086tiny fd.img hd.img, however you can also go 8086tiny myfloppy.img hd.img.
If you're using 1.10 or later check out the ~/.8086tiny folder.
hene193
Re: 8086tiny
Sun Feb 09, 2014 6:12 am
I know that but I'm trying to install MSDOS so I need to change it without relaunching whole program.
Edit: I was just thinking can I give the program physical andress? Then I just could mount those images on fly.
