Zachster1996
Tweeting Pictures
Tue Jan 28, 2014 12:55 am
I was wondering how you would tweet pictures on the Pi through Python. I can't use Twython for a reason that is too long to go into.
Thanks.
Re: Tweeting Pictures
Wed Jan 29, 2014 1:17 am
You can do it with Tweepy http://github.com/tweepy
#!/usr/bin/python
import os
import sys
import tweepy
Ckey = 'Consumer_Key_here'
Csec = 'Consumer_Secret_here'
Akey = 'Application_Key_here'
Asec = 'Application_Secret_here'
auth = tweepy.OAuthHandler(Ckey, Csec)
auth.set_access_token(Akey, Asec)
twapi = tweepy.API(auth)
fn = os.path.abspath(sys.argv[1])
status = sys.argv[2]
twapi.update_with_media(fn, status=status)
Parm#1 is the image filename
Parm#2 is the text for the status.
https://twitter.com/IMSlights/status/428334873859067905
alexeames
Thu Jan 30, 2014 11:08 pm
Just had a play with Dougie's code. Thanks for posting that :)
Two things to note.
1/ I had tweepy 2.1 installed and it doesn't support update_with_media()
Couldn't get the booger working until I updated tweepy (which I only installed in September 2013) to 2.2. Then it worked fine. :)
2/ Your text for your status update should be in quotes when you enter it on the command line. Otherwise it stops at the first space.
Other than that, excellent tip there Dougie. The documentation for tweepy is pretty out of date, which makes life difficult for beginners (and a lot of other people too).
Alex Eames RasPi.TV, RasP.iO
Thu Jan 30, 2014 11:37 pm
alexeames wrote: Couldn't get the booger working until I updated tweepy (which I only installed in September 2013) to 2.2. Then it worked fine.
I took ages finding a working version. V2.2 was the third one I tried. There was a old fork of tweepy code that didn't work with https.
Most of my machine generated tweets come from a Perl program use Net::Twitter. I'm not a big fan of python. I prefer the write once, debug never feature of Perl to the semantic white space feature of python.
alexeames
Fri Jan 31, 2014 8:15 am
DougieLawson wrote:Most of my machine generated tweets come from a Perl program use Net::Twitter. I'm not a big fan of python. I prefer the write once, debug never feature of Perl to the semantic white space feature of python.
I used to do back-end stuff for websites in PERL. I've got a shopping cart and banner ad server I wrote 10 years ago still working.
/*I learnt REXX during my pre-Uni year at IBM*/
/*The Systems Product Interpreter*/
I do like Python though - very much. Although I was happy with PERL's {}
Return to “Python”
