If you can create your bridge, using Howdy's tutorial, i can put up some code on dropbox that you can try and tell me how it goes. Basically it's one daemon (and init.d script) to make sure connections are added to the bridge, and one interactive script to make pairing and trusting easy. Eventually I'll figure out GitHub.
Oh, it's still using python 2.7 and dbus - Did you get that sorted?
I'll see if I can get it posted tonight, meanwhile, see how it goes setting up the network bridge. To follow Howdy's tutorial, I believe you'll need to
sudo apt-get install bridge-utils
