jbnhf23
lsusb and wifi adapter
Mon Dec 09, 2013 3:15 pm
i am trying to setup my "sandberg micro wifi usb dongle".
When I perform a lsusb command the dongle is not listed.
Should the dongle always be listed when I perform a lsusb command?
- If yes, could it be a broken wifi adpater or ?
- if no, could someone give me some guidance that could lead me in the right direction :-)
I am pretty new in this linux world...
best regards....jesper
Onira
Re: lsusb and wifi adapter
Mon Dec 09, 2013 7:53 pm
show an output of:
$ sudo lsusb
Cogito ergo sum
shuckle
Mon Dec 09, 2013 7:57 pm
dmesg may also show something usefull. The end of it.
jbnhf23
Mon Dec 09, 2013 8:09 pm
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 012: ID 0930:6545 Toshiba Corp. Kingston DataTraveler 102 Flash Drive / HEMA Flash Drive 2 GB / PNY Attache 4GB Stick
I have plugged in a Kingston USB memory pen and my sandberg wifi adapter.
jdb
Mon Dec 09, 2013 11:08 pm
[14870.488784] usb 1-1.2: new full-speed USB device number 8 using dwc_otg
[14870.568810] usb 1-1.2: device descriptor read/64, error -32
[14870.758826] usb 1-1.2: device descriptor read/64, error -32
[14870.948864] usb 1-1.2: new full-speed USB device number 9 using dwc_otg
[14871.028882] usb 1-1.2: device descriptor read/64, error -32
[14871.218882] usb 1-1.2: device descriptor read/64, error -32
[14871.408905] usb 1-1.2: new full-speed USB device number 10 using dwc_otg
[14871.828689] usb 1-1.2: device not accepting address 10, error -32
[14871.908855] usb 1-1.2: new full-speed USB device number 11 using dwc_otg
[14872.328710] usb 1-1.2: device not accepting address 11, error -32
[14872.328909] hub 1-1:1.0: unable to enumerate USB device on port 2
This is why. Your adapter is not registering as it appears to be unreadable.
Does it work if you plug it into a PC USB port?
Rockets are loud.
https://astro-pi.org
jbnhf23
Mon Dec 09, 2013 11:10 pm
yes it is working in my windows 7 laptop
Mon Dec 09, 2013 11:16 pm
Starting at line # 183 in your dmesg on pastebin you'll see a bunch of error messages
[    3.211719] usb 1-1.2: new full-speed USB device number 4 using dwc_otg
[    3.301743] usb 1-1.2: device descriptor read/64, error -32
[    3.491741] usb 1-1.2: device descriptor read/64, error -32
[    3.681765] usb 1-1.2: new full-speed USB device number 5 using dwc_otg
[    3.771779] usb 1-1.2: device descriptor read/64, error -32
[    3.961937] usb 1-1.2: device descriptor read/64, error -32
[    4.151836] usb 1-1.2: new full-speed USB device number 6 using dwc_otg
[    4.581565] usb 1-1.2: device not accepting address 6, error -32
[    4.681785] usb 1-1.2: new full-speed USB device number 7 using dwc_otg
[    5.111575] usb 1-1.2: device not accepting address 7, error -32
[    5.131652] hub 1-1:1.0: unable to enumerate USB device on port 2
Then you'll notice it spots your USB Memory Stick
[14872.568942] usb 1-1.3: new high-speed USB device number 12 using dwc_otg
[14872.672241] usb 1-1.3: New USB device found, idVendor=0930, idProduct=6545
[14872.672272] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[14872.672289] usb 1-1.3: Product: DataTraveler 2.0
[14872.672303] usb 1-1.3: Manufacturer: Kingston
[14872.672319] usb 1-1.3: SerialNumber: 001372982FA1B911F6030459
[14872.684367] scsi0 : usb-storage 1-1.3:1.0
Is your device USB 1.1, USB 2.0 or USB 3.0?
Is your USB HUB 1.1 or USB 2.0 or USB 3.0?
This is a doctor free zone.
Mon Dec 09, 2013 11:21 pm
jbnhf23 wrote:yes it is working in my windows 7 laptop
Can you use the the Windows control panel/device manager (run devmgmt.msc) to find the Vendor ID and Device ID?
jbnhf23
Mon Dec 09, 2013 11:46 pm
I dont have a USB hub attached my rpi, both my kingston memory pen and usb dongle is attached directly into my rpi
rpi usb and wifi dongle is both usb2.0
here is dev and vender id's
USB\VID_0BDA&PID_8176&REV_0200
Mon Dec 09, 2013 11:51 pm
Thanks. That's a Realtek RTL8192US
http://www.raspberrypi.org/phpBB3/viewt ... =26&t=8672
Try sticking it in a powered USB hub.
Try gettting the latest firmware sudo rpi-update
jbnhf23
Sun Dec 15, 2013 10:41 am
I purchased a 2A power supply and now it is working :D
thanks for your help
