DaveTheWalker
No more memory available
Wed Nov 27, 2013 10:43 am
I'm trying a relatively simple WeatherData request on my Model B (256MB) - I've set the memory split to only give 16MB to the graphics, but I get this error.
Any ideas?
In[1]:= WeatherData["Harwell"]
Installing data from Wolfram Research data server ....
Initializing WeatherData indices ....
Initializing CityData indices ....
No more memory available.
Mathematica kernel has shut down.
Try quitting other applications and then retry.
edit: I'm using the command-line version of wolfram, and NOT running "x"
duberry
Location: standing on a planet that's evolving. And revolving at nine hundred miles an hour
Re: No more memory available
Fri Nov 29, 2013 12:08 pm
lend me your arms, fast as thunderbolts, for a pillow on my journey.
If the environment was a bank, would it be too big to fail
so long; and thanks for all the pi
alexatwri
Fri Nov 29, 2013 3:25 pm
I understand why this particular function is using a lot of memory, but in this case I can't say for certain that it's ever going to work well on a Raspberry Pi Model A. For the moment, if you find yourself running out of resources, you can always have us do the calculation:
weather = WolframAlpha["weather in Oxfordshire"]
That should give you a set of "subpods" that you can iterate over. You can find more information about WolframAlpha[] here:
http://reference.wolfram.com/language/r ... Alpha.html
I will look into this and see if we can make this operation less gluttonous.
For reference, this is what I got when running the operation on a much more resource rich ARM system:
In[4]:= WeatherData["Harwell"]
WeatherData::notent:
   "Harwell" is not a known entity, class, or tag for WeatherData. Use WeatherData
    [] for a list of entities.
Out[4]= WeatherData[Harwell]
In[5]:=
I used "Oxfordshire" (I don't know if this is correct) because Wolfram Alpha doesn't seem to know what Harwell is, either.
madler
Sat Nov 30, 2013 12:45 am
Same thing happened to me on a 512 MB RPi when trying to use
AstronomicalData[]
. The kernel up and died after several minutes of trying to initialize indices.
Arnoud
Mon Dec 02, 2013 10:57 pm
AstronomicalData[] (with no semi-colon) will download and try to print out about 156,770 names of astronomical objects.
AstronomicalData[]; (with a semi-colon) will download and cache the data (off-line) locally on your Raspberry Pi.
I would not expect "AstronomicalData[]" to work (I did not try it), but "AstronomicalData[];" works for me (to create a local cache of the data).
sandheaver
Tue Dec 17, 2013 5:08 pm
If you want weather for a specific city, use:
WeatherData[{"City", "State or Country"}, "Temperature"]
for example, for me, I would use:
WeatherData[{"Moline", "IL"}, "Temperature"]
Any city will work; (edit: Except, apparently, Harwell) if there's no weather available for the location you provide, the nearest location with known data will be chosen. Part of why this takes so long the first time you run it is because it downloads a list of cities, and the locations of each city, then the list of weather stations and then finds the nearest one to you. It's very robust, but resource-intensive.
edit: Harwell doesn't work for some reason. It is not a known city, I guess. Your best bet would be to try Abingdon, instead.
WeatherData[{"Abingdon", "Oxfordshire", "UK"}, "Temperature"]
You may be able to omit the Oxfordshire bit.
DaveTheWalker
Wed Dec 18, 2013 9:13 am
Thanks for your help... I still get this, though:
  • In[1]:= WeatherData[{"Abingdon","Oxfordshire","UK"},"Temperature"]
madler
Wed Dec 25, 2013 8:13 am
I was referring to the function
AstronomicalData[]
, not what I typed. I typed
AstronomicalData["Properties"]
, which should produce a relatively short list. Instead it resulted in the indices message followed by the Mathematica kernel running out of memory and quitting.
Return to “Wolfram Language”
Who is online
Users browsing this forum: No registered users and 0 guests
