thradtke
Where's wolfram-engine? Messed up sources.list?
Fri Nov 22, 2013 3:57 pm
Hi *,
tried & failed to locate package 'wolfram-engine' in archive.raspbian.org. Is there a trick?
Update lists and upgrade system worked afaict. Help, please :-).
Thanks,
Thomas
Rocket Scientist.
MoosePi
Re: Where's wolfram-engine? Messed up sources.list?
Fri Nov 22, 2013 5:50 pm
You need to have the Raspberry Pi Foundations Raspbian Wheezy ARMHF installed, there has been other posts regards this issue in the Matmetica Forum:
http://www.raspberrypi.org/phpBB3/viewforum.php?f=94
Pi Forum Search and Google yields answers to many questions
thradtke
Fri Nov 22, 2013 6:04 pm
I have Raspbian, i.e. hardfloat Wheezy, since it came out.
My system is kind of messy. Still use the first image, updated regularly by my offline repos and the Github firmware. Today I have the opportunity to directly connect to the internet, so I thought I could give updating a try, and it seemingly worked ... otoh, I can't even locate the package wolfram-engine by looking through archive.raspbian.org (searched main, contrib, nonfree). You know where it is located?
What am I missing here?
Rocket Scientist.
MoosePi
Fri Nov 22, 2013 6:42 pm
Did you read the other posts at the link I posted ?? :?
My sources list is listed here: http://www.raspberrypi.org/phpBB3/viewt ... 95&t=61489
This is my output on latest debian wheezy fully updated:
nano /etc/apt/sources.list
/deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free r$
dennisw
Fri Nov 22, 2013 9:14 pm
It appears to be in raspberrypi.org's repository but not in raspbian's.
Try: http://archive.raspberrypi.org/debian/p ... am-engine/
My sources.list:
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
raspberrypi.stackexchange.com --- mathematica.stackexchange.com
thradtke
Sat Nov 23, 2013 6:50 am
MoosePi wrote:Did you read the other posts at the link I posted ?? :?
Yes, thanks. I hope nothing slipped my attention.
Rocket Scientist.
thradtke
Sat Nov 23, 2013 6:54 am
dennisw wrote:It appears to be in raspberrypi.org's repository but not in raspbian's.
My sources.list:
Great, thanks :-). It's beyond me why mirrordirector.raspbian.org points you to archive.raspberrypi.org. I guess you have an entry in /etc/apt/sources.list.d? I don't, but I'll try to create one.
Edit: That did the trick ... d/l'ing 400+ MiBs now :D
Rocket Scientist.
geev03
Sat Nov 23, 2013 8:09 am
Here it is a 207 MB download..
:D
<p>
Mathematica on 'headless' RasPi
thradtke
Sat Nov 23, 2013 11:53 am
Enjoy Wolfram ... as much as I do :-).
Rocket Scientist.
dennisw
Sat Nov 23, 2013 12:14 pm
Yes,
$ cat /etc/apt/sources.list.d/wolfram.list
# Wolfram Research, Inc. APT Repository (for WolframEngine)
deb http://repository.wolfram.com/raspbian/ stable non-free
$ cat /etc/apt/sources.list.d/raspi.list
deb http://archive.raspberrypi.org/debian/ wheezy main
thradtke
Sat Nov 23, 2013 12:50 pm
Thanks again for your effort, Dennis. This is very helpful.
Rocket Scientist.
geev03
Sat Nov 23, 2013 1:26 pm
thradtke wrote:Enjoy Wolfram ... as much as I do :-).
Yes, even on a mobile phone...Image
thradtke
Sun Nov 24, 2013 9:28 am
It appears Java cannot be started from Mathematica on 256MB models, correct?
Output from trying W|A queries (just one out of many error messages quoted):
During evaluation of In[1]:= LinkObject::linkn: Argument LinkObject['/opt/Wolfram/WolframEngine/10.0/SystemFiles/Java/Linux-ARM/bin/java' -classpath "/opt/Wolfram/WolframEngine/10.0/SystemFiles/Links/… -Djava.util.prefs.PreferencesFactory=com.wolfram.jlink.DisabledPreferencesFactory com.wolfram.jlink.Install -init "/tmp/m00000130571",73,4] in LinkReadyQ[LinkObject['/opt/Wolfram/WolframEngine/10.0/SystemFiles/Java/Linux-ARM/bin/java' -classpath "/opt/Wolfram/WolframEngine/10.0/SystemFiles/… .util.prefs.PreferencesFactory=com.wolfram.jlink.DisabledPreferencesFactory com.wolfram.jlink.Install -init "/tmp/m00000130571",73,4]] has an invalid LinkObject number; the link may be closed.
Of course, the Oracle JDK is installed.
Time to update to a 512MB model :-/.
Rocket Scientist.
mob-i-l
Contact: Website Facebook Twitter YouTube
Sun Nov 24, 2013 1:55 pm
I use Raspbian from the latest NOOBS and it is most updated and upgraded, and yet sudo apt-get install can only find mathematica-fonts. I think the repositories should be fixed automatically.
I succeeded in getting it to run by downloading:
wget http://repository.wolfram.com/raspbian/ ... _armhf.deb
And installing:
sudo dpkg -i wolfram-
engine_10.0.0+2013112003_armhf.deb
The menus are correctly installed and I tried both the GUI and CLI versions.
Have Pi0&1A&1B&1B+&2B&3B&4B w/ Raspbian. Started w/ BASIC on ABC80&ZX81 then Forth, Z80… https://scratch.mit.edu/users/mobluse/ https://github.com/mobluse/ https://twitter.com/mobluse/ https://YouTube.com/MOBiL4u/
Return to “Mathematica”
