Minimal LXDE install
XBMC (Frodo 12.2)
RetroPie (boots into EmulationStation)
Quake III Arena (just add pak files)
You boot into EmulationStation. From there you can choose what you want to do. Want to watch media? Load up XBMC. Want to switch to something else? Just quit out of XBMC and you are thrown back into EmulationStation. Want to surf the web? Load up LXDE. Logout and you are thrown back into EmulationStation. No rom's are included for legal reasons. Feel free to add your own to the correct directories (/home/pi/RetroPie/roms/). I compiled Quake III Arena myself, with a custom patch to disable AA, for more FPS. Just add your PAK files to the proper directory (/home/pi/q3a/baseq3).
LIRC is enabled on boot. Just add your own lircd.conf to (/etc/lirc/).
You will need atleast a 4GB card to use this image.
Download - Ultimate Raspbian [700MB]
The first thing you need to do after mapping keys for EmulationStation on first boot, is to hit F4 to exit it. Run "sudo raspi-config" to expand your file system, set regional settings, etc..
Username = pi
Password = raspberry
Gpu memory is set to 128, and it is OC'ed to 900/450/450/2). If you do not want the overclock, then edit (/boot/config.txt).
Enjoy!
