girish_kumar
Wifi Dongle : TP-Link TL-WN723N V3
Thu Sep 12, 2013 6:34 pm
I had purchased a WiFi Dongle for my Raspberry - Pi but it is not getting detected.
The device I am having is: TP-LINK: TL-WN723N V3
After attaching the device I did lsmod and I see the following output
pi@raspberrypi ~ $ lsusb
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 0bda:8179 Realtek Semiconductor Corp.
When I checked the wiki page : http://elinux.org/RPi_USB_Wi-Fi_Adapters I am can see :
TL-WN723N V3 USB ID: 0bda:8179; Needs custom driver on Raspbian wheezy.
Can anyone help me to get a custom driver on RAspbian Wheezy ?
More information:
When I did
pi@raspberrypi ~ $ sudo iwconfig wlan0 mode monitor
Error for wireless request "Set Mode" (8B06) :
SET failed on device wlan0 ; No such device.
Regards
Girish
MrEngman
Re: Wifi Dongle : TP-Link TL-WN723N V3
Sun Sep 15, 2013 9:19 pm
Your wifi device uses the same USB ID, ID 0bda:8179, as the TP-LINK TL-WN725N V2 so I would expect it to use the same driver, 8188eu.ko.
I have three different driver revisions. Which one you should use depends on the revision of raspbian you have installed. This you can find using command uname -a
My own RPi shows
Linux raspberrypi 3.6.11+ #541 PREEMPT Sat Sep 7 19:46:21 BST 2013 armv6l GNU/Linux
for 3.6.11+ #538 and #541 use 8188eu-20130830.tar.gz
for 3.6.11+ #524, #528 or #532 use 8188eu-20130815.tar.gz
for 3.6.11+ #371 up to #520 use 8188eu-20130209.tar.gz
Download and install the driver using the commands
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-2013xxyy.tar.gz  <--set data code for driver version
tar -zxvf 8188eu-2013xxyy.tar.gz                                          <--set data code for driver version
sudo install -p -m 644 8188eu.ko /lib/modules/3.6.11+/kernel/drivers/net/wireless
sudo insmod /lib/modules/3.6.11+/kernel/drivers/net/wireless/8188eu.ko
sudo depmod -a
After installing the driver you will need to configure the wifi. You can use the Wifi Config GUI in the graphical desktop, or manually edit files /etc/network/interfaces and/or /etc/wpa_supplicant/wpa_supplicant.conf depending how you want to set up your wifi. There is some basic information for setting up manually on http://www.fars-robotics.net
MrEngman
girish_kumar
Tue Sep 17, 2013 3:05 pm
Hi MrEngman
The dongle is really working now,
After installing the driver, the dongle did not work this was becuase, my Ethernet cable was connected to Raspberry Pi. The moment I removed the cable the Wifi Started to work.
I really appreciate your help.
Thanks a lot for providing detailed instructions !!!
Regards
Girish
buddylee7
Sat Feb 22, 2014 6:03 pm
I am attempting to install the drivers for TP-WN725N with no luck. Might you point me in the right direction? When attempting to stalling the latest drivers I get the following error:
"Error: could not insert module 8188eu.ko: Invalid module format"
Jessie
Sat Feb 22, 2014 6:41 pm
buddylee7 wrote:I am attempting to install the drivers for TP-WN725N with no luck. Might you point me in the right direction? When attempting to stalling the latest drivers I get the following error:
That error generally means that the driver is compiled for a different linux kernel version. This is one of the things that irritates me the most about Linux.
MrEngman
Sat Feb 22, 2014 6:47 pm
Take a look here for details of drivers available and installation info.
MrEngman
zestyapril
Tue May 27, 2014 5:26 pm
HI, what does (xxyy) mean ? (set data code for driver version) and where can I find it?
MrEngman
Tue May 27, 2014 6:14 pm
zestyapril wrote:HI, what does (xxyy) mean ? (set data code for driver version) and where can I find it?
This post is now rather out of data. I now use xyyzz. Where x is year, yy is month, zz is day.
Take a look at the post here with the drivers listed for different versions of raspbian. NOTE: they will only work with raspbian.
The instructions for installing on your currently running kernel version are
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-201xyyzz.tar.gz <--set data code for driver version above
tar -zxvf 8188eu-201xyyzz.tar.gz                                         <--set data code for driver version above
sudo install -p -m 644 8188eu.ko /lib/modules/$(uname -r)/kernel/drivers/net/wireless
sudo insmod /lib/modules/$(uname -r)/kernel/drivers/net/wireless/8188eu.ko
sudo depmod -a
You will need to change the first two instructions in the list above and replace xyyzz in the code 8188eu-201xyyzz.tar.gz with the correct date for the driver version you need.
If you look at the list of drivers they are for example like this
3.12.18+ #673, #677 - 8188eu-20140425.tar.gz
3.12.18+ #679, #680 - 8188eu-20140501.tar.gz
3.12.19+ #681, #682 - 8188eu-20140509.tar.gz
3.12.19+ #684       - 8188eu-20140509.tar.gz
3.12.20+ #685       - 8188eu-20140509.tar.gz
So if you are using kernel raspbian 3.12.20+ #685 this needs driver file 8188eu-20140509.tar.gz and you will need to replace xyyzz in 8188eu-201xyyzz.tar.gz in the install instructions with 40509 so the install commands will then be
wget https://dl.dropboxusercontent.com/u/80256631/8188eu-20140509.tar.gz
tar -zxvf 8188eu-20140509.tar.gz
sudo depmod -a
Of course the value you need will depend on the kernel version you are using and the driver it requires.
Hope that make sense for you.
MrEngman
zestyapril
Tue May 27, 2014 9:23 pm
MrEngman.. thank you so much, your links were very useful, it connects.
MrEngman
Tue May 27, 2014 9:31 pm
zestyapril wrote:MrEngman.. thank you so much, your links were very useful, it connects.
Glad to be able to help.
MrEngman
edwin6938
Wed Jun 04, 2014 5:00 pm
For me it doesn't work...
When i do:
"wget https://dl.dropboxusercontent.com/u/802 ... 509.tar.gz"...
I have the following error:
"wget: unable to resolve host adress `dl.dropboxusercontent.com"
Please help!
MrEngman
Wed Jun 04, 2014 5:32 pm
edwin6938 wrote:Hi,
When i do:
Please help!
Just tried using the link you post and it works OK for me. Can your Pi normally connect to the internet?
MrEngman
edwin6938
Wed Jun 04, 2014 6:33 pm
You're right... It was my mistake... I modified (i tried) the interfaces folder to configure wlan0 an i forgot to changed it...
Thank you a lot... I spent to much time!!
Nidhalo92
Mon Feb 22, 2016 7:58 am
Good morning
after lsusb tape i see this
Bus 001 Device 010: ID 0bda:8179 Realtek Semiconductor Corp
i need a driver on my raspbian is jessie
how can i solve that?
anyone can help me?
