takenoha
about camera module
Wed Sep 11, 2013 7:29 am
I have taken the following at the camera module of raspberry pi
I think it's basic commands.
However, an image that is visible between the display for 5 seconds, an image actually shot are different.
For example, an object that is to be displayed in full screen during the 5 seconds, looking at the image that was actually shot, I feel the object is displayed in a small size in the image.
Should this happen? Failure?
I'm having problems when not know have been examined causes
# I think it also be due because you change the focal length
Is there a way to fix this? Or Is there such as a command to capture an image that is displayed for five seconds?
takenoha
JoeDaStudd
Re: about camera module
Wed Sep 11, 2013 8:11 am
The standard command displays preview window for 5 seconds.
I believe this is so you can line up the camera before it takes the shot.
You can remove the preview window by using the parameter -n.
Do you mean capture the 5 seconds of video, take the photo then display it for 5 seconds or something else?
EDIT: Here's a link to the documentation pdf.
Wed Sep 11, 2013 8:21 am
takenoha wrote:Hi,
takenoha
The preview code uses a video mode so that it can run at 30fps, when the capture is made, the mode used is a high resolution one, which uses a larger part of the sensor.
This is on my list of bugs to fix (ie new video mode that works at full frame)
takenoha
Wed Sep 11, 2013 12:21 pm
Thanks for reply
Sorry, I did not write English well
I want to take a photo, not video.
I hit the command as follows:
After hit command, preview is displayed on the display ( for 5 seconds ).
After 5 seconds, photo is taken and saved.
But, one image displayed in the preview image and the stored is different.
The stored image represents the wider range than an image displayed by a preview.
I do not know why this happens.
I want to save a displayed photo in the preview.
help me.
takenoha
RaTTuS
Contact: Twitter YouTube
Wed Sep 11, 2013 12:55 pm
what jamesh fixes the preview code this will happen
as it is now
the preview is a smaller image than the actual image
Covfefe
Wed Sep 11, 2013 1:49 pm
Try the --fp option, which reduces the frame rate of the preview but does use the full field of view.
takenoha
Wed Sep 11, 2013 4:11 pm
I tried --fp option, but I did not took a photo which displayed in the preview (no --fp option).
I want to take a photo which displayed in the preview.
Why preview window is smaller than actually taken photo?
I trouble to adjust the distance between the object and the camera.
If I can take same photo (preview and actually), it is easy to adjust distance.
To take the same image as the look of the preview, what would I should do?
Sorry for my poor English sentence, but please advice for my trouble.
takenoha
Wed Sep 11, 2013 4:44 pm
takenoha wrote:I tried --fp option, but I did not took a photo which displayed in the preview (no --fp option).
takenoha
See my post above. The preview uses a different camera mode that uses a smaller part of the sensor. I need to develop a new mode that works at 30fps but uses the whole sensor - I haven't had time to do that.
What is the problem with -fp? That should do what you want, but at a lower preview frame rate.
takenoha
Thu Sep 12, 2013 2:35 am
Does not mean there is a problem with the --fp.
It is only different --fp and what I want to do
That, when I want to adjust the distance of a object and camera to take a photo in the entire picture size, do I need to check the saved photos?
Is it impossible to adjust while watching the preview?
If so, I accept that it is a kind of settings.
Return to “Camera board”
