I get this every time when I try and shut down.
New install of the raspbian image, apt-get updated and rpi-update. No other configuration changes made other than installing links2 and rpi-update + required git.
On issuing "sudo shutdown -f now" I get the message noted in the subject, and the pi is left with root logged in: root@raspberrypi.
Do you know how to fix it? I'm not going to ask Jim....
TIA
Re: sulogin: root account is locked, starting shell
"-f" is not a valid option as far as I know. Do you get the same error with
sudo shutdown -h now
Why not use the aliases
sudo halt
sudo reboot
sudo halt
sudo reboot
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
Hi all, after installing xbmc following this guide http://www.raspberrypi.org/phpBB3/viewt ... 66&t=12455 I fall down in the piglet situation: sudo reboot, sudo shutdown -r now don't reboot the raspberry. The subject message appear..any hints?
I had the same problem today. In the messages it says run 'fsck' manually
Try
> fsck
This solved my problem
Try
> fsck
these commands worked for me, I kept shorting out the raspberry pi, and it kept hard rebooting causing the file-system to get corrupt.
sudo umount /boot
sudo fsck.fat -a /dev/mmcblk0p1
sudo fsck.fat -a /dev/mmcblk0p8
sudo reboot
- IgorGanapolsky
This doesn't solve anything for me. Just a blank blue screen.azeam wrote:"-f" is not a valid option as far as I know. Do you get the same error withCode: Select all
- IgorGanapolsky
sudo halt just puts in a blue screen. What is it supposed to do?techpaul wrote:Why not use the aliases
sudo halt
sudo reboot
- IgorGanapolsky
I get an error:rishad wrote:I had the same problem today. In the messages it says run 'fsck' manually
Try
> fsck
/dev/mmcblk0p2 is mounted
e2fsck: Cannot continue, aborting
I had the same problem mine was to do with drive mounting. I had a drive set to automatically mount and when it wasn't plugged in, it caused my pi to go in to safe mode all i had to do was plug the drive in at boot. Hope this helps anyone else.
Rpi b+ rpi 3. Python, java, c++, html.
If you have changed the /etc/fstab file then change it back as it was before. Since you messed up boot location. That caused for me the booting issue.
And how can I change the file if I can not have access?
I'm new with raspberry pi.
Thank you in advance,
