Kaikz
Static IP network config fails to load
Thu Aug 29, 2013 4:04 am
I'm using the 22/7 Arch Arm build found on the downloads page here and I've got everything else I want working, besides my static IP network config.
This is the config I have:
[root@archpi netctl]# cat staticip
Description='A basic static ethernet connection'
Interface=eth0
Connection=ethernet
IP=static
Address=('192.168.2.7/24')
Gateway='192.168.2.1'
DNS=('8.8.8.8', '202.180.64.10', '202.180.64.11')
And this is the error I have:
[root@archpi ~]# netctl status staticip
netctl@staticip.service - A basic static ethernet connection
   Loaded: loaded (/etc/systemd/system/netctl@staticip.service; enabled)
   Active: failed (Result: exit-code) since Thu 1970-01-01 00:00:14 UTC; 43 years 7 months ago
     Docs: man:netctl.profile(5)
  Process: 118 ExecStart=/usr/lib/network/network start %I (code=exited, status=1/FAILURE)
Instead of loading this config at boot, it just gets a dynamic IP from the DHCP server. I don't have options in my router config to allocate an IP according to MAC address either.
Thanks.
drgeoff
Re: Static IP network config fails to load
Thu Aug 29, 2013 6:50 am
Remove the commas, leaving only spaces, between the addresses in the DNS list.
Quis custodiet ipsos custodes?
Kaikz
Thu Aug 29, 2013 7:13 am
drgeoff wrote:Remove the commas, leaving only spaces, between the addresses in the DNS list.
Just did that and I get a similar error and it still boots into a dynamic IP, not the IP specified in the config.
Kaikz
Thu Aug 29, 2013 7:36 am
http://www.raspberrypi.org/phpBB3/viewt ... 59#p358659
There is no netcfg and/or /etc/network.d/. Nothing in that thread helps with netctl.
drgeoff
Thu Aug 29, 2013 8:09 am
What are the current contents of the file 'staticip' ?
RaTTuS
Contact: Twitter YouTube
Thu Aug 29, 2013 8:22 am
probably bets to try the arch forum
but
looks completely wrong to me
Address=('192.168.2.7)
DNS=('8.8.8.8' '202.180.64.10' '202.180.64.11')
may be better
but IMO seriously set it to dhcp and have your router set a static address this makes the RPi more portable
Covfefe
Kaikz
Thu Aug 29, 2013 8:30 am
RaTTuS wrote:probably bets to try the arch forum
but
may be better
I've tried removing the /24 and removing the commas, still doesn't work. I've already said my router doesn't have options for that.
drgeoff wrote:What are the current contents of the file 'staticip' ?
It's in the OP, but I'll repeat it here with changes mentioned.
Interface=eth0
Connection=ethernet
IP=static
Address=('192.168.2.7')
#Routes=('192.168.0.0/24 via 192.168.1.2')
surfatwork
Fri Aug 30, 2013 8:41 pm
Check if your interface is actually named eth0 with
ls /sys/class/net
Arch, actually systemd/udev, changed the interface naming convention recently. For example, the ethernet interface on my Arch laptop is enp0s25
Kaikz
Fri Aug 30, 2013 11:28 pm
surfatwork wrote:Check if your interface is actually named eth0 with
ls /sys/class/net
[root@archpi ~]# ls /sys/class/net
eth0  ifb0  ifb1  lo
It wouldn't be ifb0 considering there's only one ethernet port, would it? I'm not sure what lo means either.
surfatwork
Sun Sep 01, 2013 12:13 am
Your ethernet interface is eth0. lo is the loopback interface.
Do you have any other config files in /etc/netctl for eth0?
Do you have netctl-ifplugd@eth0 enabled? check with
 # systemctl status netctl-ifplugd@eth0
If yes, then stop it with
 # systemctl stop netctl-ifplugd@eth0
Run
 # netctl stop-all
Edit your staticip file and remove the () around the address. It should read Address='192.168.1.23/24'
Then run
# systemctl start netctl@staticip
See if eth0 gets assigned the static IP.
Return to “Arch”
