gihankavinda
Ethernet communication to network
Tue Aug 06, 2013 2:15 pm
how to use Ethernet port to send data to a network ?
i want to know this to take data out from the raspberry pi to a network.
bltsandwich1
Re: Ethernet communication to network
Tue Aug 06, 2013 3:57 pm
you could easily enable SSH communications to your pi and then use a software like PuTTy or WinSCP to transfer the files. Is this the kind of operation you were talking about?
John Moosemiller
facebook.com/chicagoraspberryjam - join in the fun
Majoring in ChemE at the University of Houston.
itimpi
Wed Aug 07, 2013 9:17 am
gihankavinda wrote:how to use Ethernet port to send data to a network ?
You need to make it clearer what you are trying to achieve. For example:
  • Accessing your Pi from another machine on the network to act as Keyboard/mouse and/or display
  • Accessing another machine on your network with the Pi acting as keyboard/mouse and/or screen. If so what type of machine are you trying to access
  • Accessing files on another machine on the network
  • Accessing files on the Pi from another machine on the network
  • Something else not mentioned above
All of the first 4 listed are possible - but the answer on how to achieve it is different in each case so one needs to know the requirement better.
gihankavinda
Thu Aug 22, 2013 5:29 am
i want to send the readings taken by the raspberry pi to a sever through the Ethernet port of raspberry pi
ghans
Thu Aug 22, 2013 6:32 am
Where is the server located (LAN , internet) and which
protocol do you need to use ?
ghans
gihankavinda
Thu Aug 22, 2013 6:50 am
sever located in LAN and i try to use tcp/ip .how should it do ?
is there any other way rather than using tcp / ip.
RaTTuS
Contact: Twitter YouTube
Thu Aug 22, 2013 7:45 am
open a port on the server that is connected to a service you control
send the info to ip:port
Covfefe
