* linux/arch/arm/mach-bcm2708/bcm2708.c
* Copyright (C) 2010 Broadcom
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
* This program is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU General Public License for more details.
* You should have received a copy of the GNU General Public License
* along with this program; if not, write to the Free Software
* Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
#include <linux/init.h>
#include <linux/device.h>
#include <linux/dma-mapping.h>
#include <linux/serial_8250.h>
#include <linux/platform_device.h>
#include <linux/syscore_ops.h>
#include <linux/interrupt.h>
#include <linux/amba/bus.h>
#include <linux/amba/clcd.h>
#include <linux/clockchips.h>
#include <linux/cnt32_to_63.h>
#include <linux/io.h>
#include <linux/module.h>
#include <linux/spi/spi.h>
#include <linux/w1-gpio.h>
#include <linux/version.h>
#include <linux/clkdev.h>
#include <asm/system.h>
#include <mach/hardware.h>
#include <asm/irq.h>
#include <linux/leds.h>
#include <asm/mach-types.h>
#include <asm/sched_clock.h>
#include <asm/mach/arch.h>
#include <asm/mach/flash.h>
#include <asm/mach/irq.h>
#include <asm/mach/time.h>
#include <asm/mach/map.h>
#include <mach/timex.h>
#include <mach/dma.h>
#include <mach/vcio.h>
#include <mach/system.h>
#include <linux/delay.h>
#include "bcm2708.h"
#include "armctrl.h"
#include "clock.h"
#include <linux/fbtft.h>
#ifdef CONFIG_BCM_VC_CMA
#include <linux/broadcom/vc_cma.h>
#endif
/* Effectively we have an IOMMU (ARM<->VideoCore map) that is set up to
* give us IO access only to 64Mbytes of physical memory (26 bits). We could
* represent this window by setting our dmamasks to 26 bits but, in fact
* we're not going to use addresses outside this range (they're not in real
* memory) so we don't bother.
* In the future we might include code to use this IOMMU to remap other
* physical addresses onto VideoCore memory then the use of 32-bits would be
* more legitimate.
#define DMA_MASK_BITS_COMMON 32
// use GPIO 4 for the one-wire GPIO pin, if enabled
#define W1_GPIO 4
/* command line parameters */
static unsigned boardrev, serial;
static unsigned uart_clock;
static unsigned reboot_part = 0;
static void __init bcm2708_init_led(void);
void __init bcm2708_init_irq(void)
armctrl_init(__io_address(ARMCTRL_IC_BASE), 0, 0, 0);
static struct map_desc bcm2708_io_desc[] __initdata = {
.virtual = IO_ADDRESS(ARMCTRL_BASE),
.pfn = __phys_to_pfn(ARMCTRL_BASE),
.length = SZ_4K,
.type = MT_DEVICE},
.virtual = IO_ADDRESS(UART0_BASE),
.pfn = __phys_to_pfn(UART0_BASE),
.length = SZ_4K,
.type = MT_DEVICE},
.virtual = IO_ADDRESS(UART1_BASE),
.pfn = __phys_to_pfn(UART1_BASE),
.length = SZ_4K,
.type = MT_DEVICE},
#ifdef CONFIG_MMC_BCM2708 /* broadcom legacy SD */
.virtual = IO_ADDRESS(MMCI0_BASE),
.pfn = __phys_to_pfn(MMCI0_BASE),
.length = SZ_4K,
.type = MT_DEVICE},
#endif
.virtual = IO_ADDRESS(DMA_BASE),
.pfn = __phys_to_pfn(DMA_BASE),
.length = SZ_4K,
.type = MT_DEVICE},
.virtual = IO_ADDRESS(MCORE_BASE),
.pfn = __phys_to_pfn(MCORE_BASE),
.length = SZ_4K,
.type = MT_DEVICE},
.virtual = IO_ADDRESS(ST_BASE),
.pfn = __phys_to_pfn(ST_BASE),
.length = SZ_4K,
.type = MT_DEVICE},
.virtual = IO_ADDRESS(USB_BASE),
.pfn = __phys_to_pfn(USB_BASE),
.length = SZ_128K,
.type = MT_DEVICE},
.virtual = IO_ADDRESS(PM_BASE),
.pfn = __phys_to_pfn(PM_BASE),
.length = SZ_4K,
.type = MT_DEVICE},
.virtual = IO_ADDRESS(GPIO_BASE),
.pfn = __phys_to_pfn(GPIO_BASE),
.length = SZ_4K,
.type = MT_DEVICE}
void __init bcm2708_map_io(void)
iotable_init(bcm2708_io_desc, ARRAY_SIZE(bcm2708_io_desc));
/* The STC is a free running counter that increments at the rate of 1MHz */
#define STC_FREQ_HZ 1000000
static inline uint32_t timer_read(void)
/* STC: a free running counter that increments at the rate of 1MHz */
return readl(__io_address(ST_BASE + 0x04));
#ifdef ARCH_HAS_READ_CURRENT_TIMER
int read_current_timer(unsigned long *timer_val)
*timer_val = timer_read();
return 0;
EXPORT_SYMBOL(read_current_timer);
#endif
static u32 notrace bcm2708_read_sched_clock(void)
return timer_read();
static cycle_t clksrc_read(struct clocksource *cs)
static struct clocksource clocksource_stc = {
.name = "stc",
.rating = 300,
.read = clksrc_read,
.mask = CLOCKSOURCE_MASK(32),
.flags = CLOCK_SOURCE_IS_CONTINUOUS,
unsigned long frc_clock_ticks32(void)
static void __init bcm2708_clocksource_init(void)
if (clocksource_register_hz(&clocksource_stc, STC_FREQ_HZ)) {
printk(KERN_ERR "timer: failed to initialize clock "
"source %s\n", clocksource_stc.name);
* These are fixed clocks.
static struct clk ref24_clk = {
.rate = UART0_CLOCK, /* The UART is clocked at 3MHz via APB_CLK */
static struct clk osc_clk = {
#ifdef CONFIG_ARCH_BCM2708_CHIPIT
.rate = 27000000,
#else
.rate = 500000000, /* ARM clock is set from the VideoCore booter */
#endif
/* warning - the USB needs a clock > 34MHz */
static struct clk sdhost_clk = {
.rate = 4000000, /* 4MHz */
#else
.rate = 250000000, /* 250MHz */
#endif
static struct clk_lookup lookups[] = {
{ /* UART0 */
.dev_id = "dev:f1",
.clk = &ref24_clk,
{ /* USB */
.dev_id = "bcm2708_usb",
.clk = &osc_clk,
{ /* MCI */
.dev_id = "bcm2708_mci.0",
.clk = &sdhost_clk,
#endif
}, { /* SPI */
.dev_id = "bcm2708_spi.0",
.clk = &sdhost_clk,
}, { /* BSC0 */
.dev_id = "bcm2708_i2c.0",
.clk = &sdhost_clk,
}, { /* BSC1 */
.dev_id = "bcm2708_i2c.1",
.clk = &sdhost_clk,
#define UART0_IRQ { IRQ_UART, 0 /*NO_IRQ*/ }
#define UART0_DMA { 15, 14 }
AMBA_DEVICE(uart0, "dev:f1", UART0, NULL);
static struct amba_device *amba_devs[] __initdata = {
&uart0_device,
static struct resource bcm2708_dmaman_resources[] = {
.start = DMA_BASE,
.end = DMA_BASE + SZ_4K - 1,
.flags = IORESOURCE_MEM,
static struct platform_device bcm2708_dmaman_device = {
.name = BCM_DMAMAN_DRIVER_NAME,
.id = 0, /* first bcm2708_dma */
.resource = bcm2708_dmaman_resources,
.num_resources = ARRAY_SIZE(bcm2708_dmaman_resources),
static struct resource bcm2708_mci_resources[] = {
.start = MMCI0_BASE,
.end = MMCI0_BASE + SZ_4K - 1,
.start = IRQ_SDIO,
.end = IRQ_SDIO,
.flags = IORESOURCE_IRQ,
static struct platform_device bcm2708_mci_device = {
.name = "bcm2708_mci",
.id = 0, /* first bcm2708_mci */
.resource = bcm2708_mci_resources,
.num_resources = ARRAY_SIZE(bcm2708_mci_resources),
.dev = {
.coherent_dma_mask = DMA_BIT_MASK(DMA_MASK_BITS_COMMON),
#endif /* CONFIG_MMC_BCM2708 */
#if defined(CONFIG_W1_MASTER_GPIO) || defined(CONFIG_W1_MASTER_GPIO_MODULE)
static struct w1_gpio_platform_data w1_gpio_pdata = {
.pin = W1_GPIO,
.is_open_drain = 0,
static struct platform_device w1_device = {
.name = "w1-gpio",
.id = -1,
.dev.platform_data = &w1_gpio_pdata,
#endif
static u64 fb_dmamask = DMA_BIT_MASK(DMA_MASK_BITS_COMMON);
static struct platform_device bcm2708_fb_device = {
.name = "bcm2708_fb",
.id = -1, /* only one bcm2708_fb */
.resource = NULL,
.num_resources = 0,
.dev = {
.dma_mask = &fb_dmamask,
static struct plat_serial8250_port bcm2708_uart1_platform_data[] = {
.mapbase = UART1_BASE + 0x40,
.irq = IRQ_AUX,
.uartclk = 125000000,
.regshift = 2,
.iotype = UPIO_MEM,
.flags = UPF_FIXED_TYPE | UPF_IOREMAP | UPF_SKIP_TEST,
.type = PORT_8250,
static struct platform_device bcm2708_uart1_device = {
.name = "serial8250",
.id = PLAT8250_DEV_PLATFORM,
.dev = {
.platform_data = bcm2708_uart1_platform_data,
static struct resource bcm2708_usb_resources[] = {
[0] = {
.start = USB_BASE,
.end = USB_BASE + SZ_128K - 1,
[1] = {
.start = MPHI_BASE,
.end = MPHI_BASE + SZ_4K - 1,
[2] = {
.start = IRQ_HOSTPORT,
.end = IRQ_HOSTPORT,
bool fiq_fix_enable = true;
static struct resource bcm2708_usb_resources_no_fiq_fix[] = {
[0] = {
.start = USB_BASE,
[1] = {
.start = IRQ_USB,
.end = IRQ_USB,
static u64 usb_dmamask = DMA_BIT_MASK(DMA_MASK_BITS_COMMON);
static struct platform_device bcm2708_usb_device = {
.name = "bcm2708_usb",
.id = -1, /* only one bcm2708_usb */
.resource = bcm2708_usb_resources,
.num_resources = ARRAY_SIZE(bcm2708_usb_resources),
.dev = {
.dma_mask = &usb_dmamask,
static struct resource bcm2708_vcio_resources[] = {
[0] = { /* mailbox/semaphore/doorbell access */
.start = MCORE_BASE,
.end = MCORE_BASE + SZ_4K - 1,
static u64 vcio_dmamask = DMA_BIT_MASK(DMA_MASK_BITS_COMMON);
static struct platform_device bcm2708_vcio_device = {
.name = BCM_VCIO_DRIVER_NAME,
.id = -1, /* only one VideoCore I/O area */
.resource = bcm2708_vcio_resources,
.num_resources = ARRAY_SIZE(bcm2708_vcio_resources),
.dev = {
.dma_mask = &vcio_dmamask,
#ifdef CONFIG_BCM2708_GPIO
#define BCM_GPIO_DRIVER_NAME "bcm2708_gpio"
static struct resource bcm2708_gpio_resources[] = {
[0] = { /* general purpose I/O */
.start = GPIO_BASE,
.end = GPIO_BASE + SZ_4K - 1,
static u64 gpio_dmamask = DMA_BIT_MASK(DMA_MASK_BITS_COMMON);
static struct platform_device bcm2708_gpio_device = {
.name = BCM_GPIO_DRIVER_NAME,
.resource = bcm2708_gpio_resources,
.num_resources = ARRAY_SIZE(bcm2708_gpio_resources),
.dev = {
.dma_mask = &gpio_dmamask,
#endif
static struct resource bcm2708_systemtimer_resources[] = {
[0] = { /* system timer access */
.start = ST_BASE,
.end = ST_BASE + SZ_4K - 1,
.start = IRQ_TIMER3,
.end = IRQ_TIMER3,
static u64 systemtimer_dmamask = DMA_BIT_MASK(DMA_MASK_BITS_COMMON);
static struct platform_device bcm2708_systemtimer_device = {
.name = "bcm2708_systemtimer",
.resource = bcm2708_systemtimer_resources,
.num_resources = ARRAY_SIZE(bcm2708_systemtimer_resources),
.dev = {
.dma_mask = &systemtimer_dmamask,
#ifdef CONFIG_MMC_SDHCI_BCM2708 /* Arasan emmc SD */
static struct resource bcm2708_emmc_resources[] = {
[0] = {
.start = EMMC_BASE,
.end = EMMC_BASE + SZ_256 - 1, /* we only need this area */
/* the memory map actually makes SZ_4K available */
[1] = {
.start = IRQ_ARASANSDIO,
.end = IRQ_ARASANSDIO,
static u64 bcm2708_emmc_dmamask = 0xffffffffUL;
struct platform_device bcm2708_emmc_device = {
.name = "bcm2708_sdhci",
.id = 0,
.num_resources = ARRAY_SIZE(bcm2708_emmc_resources),
.resource = bcm2708_emmc_resources,
.dev = {
.dma_mask = &bcm2708_emmc_dmamask,
.coherent_dma_mask = 0xffffffffUL},
#endif /* CONFIG_MMC_SDHCI_BCM2708 */
static struct resource bcm2708_powerman_resources[] = {
[0] = {
.start = PM_BASE,
.end = PM_BASE + SZ_256 - 1,
static u64 powerman_dmamask = DMA_BIT_MASK(DMA_MASK_BITS_COMMON);
struct platform_device bcm2708_powerman_device = {
.name = "bcm2708_powerman",
.id = 0,
.num_resources = ARRAY_SIZE(bcm2708_powerman_resources),
.resource = bcm2708_powerman_resources,
.dev = {
.dma_mask = &powerman_dmamask,
static struct platform_device bcm2708_alsa_devices[] = {
[0] = {
.name = "bcm2835_AUD0",
.id = 0, /* first audio device */
.resource = 0,
.num_resources = 0,
[1] = {
.name = "bcm2835_AUD1",
.id = 1, /* second audio device */
.resource = 0,
.num_resources = 0,
[2] = {
.name = "bcm2835_AUD2",
.id = 2, /* third audio device */
.resource = 0,
.num_resources = 0,
[3] = {
.name = "bcm2835_AUD3",
.id = 3, /* forth audio device */
.resource = 0,
.num_resources = 0,
[4] = {
.name = "bcm2835_AUD4",
.id = 4, /* fifth audio device */
.resource = 0,
.num_resources = 0,
[5] = {
.name = "bcm2835_AUD5",
.id = 5, /* sixth audio device */
.resource = 0,
.num_resources = 0,
[6] = {
.name = "bcm2835_AUD6",
.id = 6, /* seventh audio device */
.resource = 0,
.num_resources = 0,
[7] = {
.name = "bcm2835_AUD7",
.id = 7, /* eighth audio device */
.resource = 0,
.num_resources = 0,
static struct resource bcm2708_spi_resources[] = {
.start = SPI0_BASE,
.end = SPI0_BASE + SZ_256 - 1,
.start = IRQ_SPI,
.end = IRQ_SPI,
static struct platform_device bcm2708_spi_device = {
.name = "bcm2708_spi",
.id = 0,
.num_resources = ARRAY_SIZE(bcm2708_spi_resources),
.resource = bcm2708_spi_resources,
#ifdef CONFIG_BCM2708_SPIDEV
static struct spi_board_info bcm2708_spi_devices[] = {
.modalias = "fb_ili9341",
.max_speed_hz = 32000000,
.bus_num = 0,
.chip_select = 0,
.mode = SPI_MODE_0,
.platform_data = &(struct fbtft_platform_data) {
.display = {
.buswidth = 8,
.backlight = 1,
.bgr = true,
.gpios = (const struct fbtft_gpio []) {
{ "reset", 23 },
{ "led", 24 },
{ "dc", 25 },
.modalias = "spidev",
.max_speed_hz = 500000,
.bus_num = 0,
.chip_select = 1,
.mode = SPI_MODE_0,
#endif
static struct resource bcm2708_bsc0_resources[] = {
.start = BSC0_BASE,
.end = BSC0_BASE + SZ_256 - 1,
.start = INTERRUPT_I2C,
.end = INTERRUPT_I2C,
static struct platform_device bcm2708_bsc0_device = {
.name = "bcm2708_i2c",
.id = 0,
.num_resources = ARRAY_SIZE(bcm2708_bsc0_resources),
.resource = bcm2708_bsc0_resources,
static struct resource bcm2708_bsc1_resources[] = {
.start = BSC1_BASE,
.end = BSC1_BASE + SZ_256 - 1,
static struct platform_device bcm2708_bsc1_device = {
.id = 1,
.num_resources = ARRAY_SIZE(bcm2708_bsc1_resources),
.resource = bcm2708_bsc1_resources,
static struct platform_device bcm2835_hwmon_device = {
.name = "bcm2835_hwmon",
static struct platform_device bcm2835_thermal_device = {
.name = "bcm2835_thermal",
int __init bcm_register_device(struct platform_device *pdev)
int ret;
ret = platform_device_register(pdev);
if (ret)
pr_debug("Unable to register platform device '%s': %d\n",
pdev->name, ret);
return ret;
int calc_rsts(int partition)
return 0x5a000000 |
((partition & (1 << 0)) << 0) |
((partition & (1 << 1)) << 1) |
((partition & (1 << 2)) << 2) |
((partition & (1 << 3)) << 3) |
((partition & (1 << 4)) << 4) |
((partition & (1 << 5)) << 5);
static void bcm2708_restart(char mode, const char *cmd)
uint32_t pm_rstc, pm_wdog;
uint32_t timeout = 10;
uint32_t pm_rsts = 0;
if(mode == 'q')
// NOOBS < 1.3 booting with reboot=q
pm_rsts = readl(__io_address(PM_RSTS));
pm_rsts = PM_PASSWORD | pm_rsts | PM_RSTS_HADWRQ_SET;
else if(mode == 'p')
// NOOBS < 1.3 halting
pm_rsts = PM_PASSWORD | pm_rsts | PM_RSTS_HADWRH_SET;
else
pm_rsts = calc_rsts(reboot_part);
writel(pm_rsts, __io_address(PM_RSTS));
/* Setup watchdog for reset */
pm_rstc = readl(IO_ADDRESS(PM_RSTC));
pm_wdog = PM_PASSWORD | (timeout & PM_WDOG_TIME_SET); // watchdog timer = timer clock / 16; need password (31:16) + value (11:0)
pm_rstc = PM_PASSWORD | (pm_rstc & PM_RSTC_WRCFG_CLR) | PM_RSTC_WRCFG_FULL_RESET;
writel(pm_wdog, IO_ADDRESS(PM_WDOG));
writel(pm_rstc, IO_ADDRESS(PM_RSTC));
/* We can't really power off, but if we do the normal reset scheme, and indicate to bootcode.bin not to reboot, then most of the chip will be powered off */
static void bcm2708_power_off(void)
extern char reboot_mode;
if(reboot_mode == 'q')
// NOOBS < v1.3
bcm2708_restart('p', "");
else
/* partition 63 is special code for HALT the bootloader knows not to boot*/
reboot_part = 63;
/* continue with normal reset mechanism */
bcm2708_restart(0, "");
void __init bcm2708_init(void)
int i;
#if defined(CONFIG_BCM_VC_CMA)
vc_cma_early_init();
#endif
printk("bcm2708.uart_clock = %d\n", uart_clock);
pm_power_off = bcm2708_power_off;
if (uart_clock)
lookups[0].clk->rate = uart_clock;
for (i = 0; i < ARRAY_SIZE(lookups); i++)
clkdev_add(&lookups[i]);
bcm_register_device(&bcm2708_dmaman_device);
bcm_register_device(&bcm2708_vcio_device);
bcm_register_device(&bcm2708_gpio_device);
#endif
platform_device_register(&w1_device);
#endif
bcm_register_device(&bcm2708_systemtimer_device);
bcm_register_device(&bcm2708_mci_device);
#endif
bcm_register_device(&bcm2708_fb_device);
if (!fiq_fix_enable)
bcm2708_usb_device.resource = bcm2708_usb_resources_no_fiq_fix;
bcm2708_usb_device.num_resources = ARRAY_SIZE(bcm2708_usb_resources_no_fiq_fix);
bcm_register_device(&bcm2708_usb_device);
bcm_register_device(&bcm2708_uart1_device);
bcm_register_device(&bcm2708_powerman_device);
bcm_register_device(&bcm2708_emmc_device);
#endif
bcm2708_init_led();
for (i = 0; i < ARRAY_SIZE(bcm2708_alsa_devices); i++)
bcm_register_device(&bcm2708_alsa_devices[i]);
bcm_register_device(&bcm2708_spi_device);
bcm_register_device(&bcm2708_bsc0_device);
bcm_register_device(&bcm2708_bsc1_device);
bcm_register_device(&bcm2835_hwmon_device);
bcm_register_device(&bcm2835_thermal_device);
for (i = 0; i < ARRAY_SIZE(amba_devs); i++) {
struct amba_device *d = amba_devs[i];
amba_device_register(d, &iomem_resource);
system_rev = boardrev;
system_serial_low = serial;
spi_register_board_info(bcm2708_spi_devices,
ARRAY_SIZE(bcm2708_spi_devices));
#endif
#define TIMER_PERIOD DIV_ROUND_CLOSEST(STC_FREQ_HZ, HZ)
static void timer_set_mode(enum clock_event_mode mode,
struct clock_event_device *clk)
switch (mode) {
case CLOCK_EVT_MODE_ONESHOT: /* Leave the timer disabled, .set_next_event will enable it */
case CLOCK_EVT_MODE_SHUTDOWN:
break;
case CLOCK_EVT_MODE_PERIODIC:
case CLOCK_EVT_MODE_UNUSED:
case CLOCK_EVT_MODE_RESUME:
default:
printk(KERN_ERR "timer_set_mode: unhandled mode:%d\n",
(int)mode);
break;
static int timer_set_next_event(unsigned long cycles,
struct clock_event_device *unused)
unsigned long stc;
stc = readl(__io_address(ST_BASE + 0x04));
writel(stc + cycles, __io_address(ST_BASE + 0x18)); /* stc3 */
return 0;
static struct clock_event_device timer0_clockevent = {
.name = "timer0",
.shift = 32,
.features = CLOCK_EVT_FEAT_ONESHOT,
.set_mode = timer_set_mode,
.set_next_event = timer_set_next_event,
* IRQ handler for the timer
static irqreturn_t bcm2708_timer_interrupt(int irq, void *dev_id)
struct clock_event_device *evt = &timer0_clockevent;
writel(1 << 3, __io_address(ST_BASE + 0x00)); /* stcs clear timer int */
evt->event_handler(evt);
return IRQ_HANDLED;
static struct irqaction bcm2708_timer_irq = {
.name = "BCM2708 Timer Tick",
.flags = IRQF_DISABLED | IRQF_TIMER | IRQF_IRQPOLL,
.handler = bcm2708_timer_interrupt,
* Set up timer interrupt, and return the current time in seconds.
static void __init bcm2708_timer_init(void)
/* init high res timer */
bcm2708_clocksource_init();
* Initialise to a known state (all timers off)
writel(0, __io_address(ARM_T_CONTROL));
* Make irqs happen for the system timer
setup_irq(IRQ_TIMER3, &bcm2708_timer_irq);
setup_sched_clock(bcm2708_read_sched_clock, 32, STC_FREQ_HZ);
timer0_clockevent.mult =
div_sc(STC_FREQ_HZ, NSEC_PER_SEC, timer0_clockevent.shift);
timer0_clockevent.max_delta_ns =
clockevent_delta2ns(0xffffffff, &timer0_clockevent);
timer0_clockevent.min_delta_ns =
clockevent_delta2ns(0xf, &timer0_clockevent);
timer0_clockevent.cpumask = cpumask_of(0);
clockevents_register_device(&timer0_clockevent);
struct sys_timer bcm2708_timer = {
.init = bcm2708_timer_init,
#if defined(CONFIG_LEDS_GPIO) || defined(CONFIG_LEDS_GPIO_MODULE)
static struct gpio_led bcm2708_leds[] = {
[0] = {
.gpio = 16,
.name = "led0",
.default_trigger = "mmc0",
.active_low = 1,
static struct gpio_led_platform_data bcm2708_led_pdata = {
.num_leds = ARRAY_SIZE(bcm2708_leds),
.leds = bcm2708_leds,
static struct platform_device bcm2708_led_device = {
.name = "leds-gpio",
.id = -1,
.dev = {
.platform_data = &bcm2708_led_pdata,
platform_device_register(&bcm2708_led_device);
#else
static inline void bcm2708_init_led(void)
#endif
/* The assembly versions in delay.S don't account for core freq changing in cpufreq driver */
/* Use 1MHz system timer for busy waiting */
static void bcm2708_udelay(unsigned long usecs)
unsigned long start = timer_read();
unsigned long now;
do {
now = timer_read();
} while ((long)(now - start) <= usecs);
static void bcm2708_const_udelay(unsigned long scaled_usecs)
/* want /107374, this is about 3% bigger. We know usecs is less than 2000, so shouldn't overflow */
const unsigned long usecs = scaled_usecs * 10 >> 20;
unsigned long now;
do {
now = timer_read();
extern void bcm2708_delay(unsigned long cycles);
struct arm_delay_ops arm_delay_ops = {
.delay = bcm2708_delay,
.const_udelay = bcm2708_const_udelay,
.udelay = bcm2708_udelay,
void __init bcm2708_init_early(void)
* Some devices allocate their coherent buffers from atomic
* context. Increase size of atomic coherent pool to make sure such
* the allocations won't fail.
init_dma_coherent_pool_size(SZ_4M);
static void __init board_reserve(void)
vc_cma_reserve();
#endif
MACHINE_START(BCM2708, "BCM2708")
/* Maintainer: Broadcom Europe Ltd. */
.map_io = bcm2708_map_io,
.init_irq = bcm2708_init_irq,
.timer =&bcm2708_timer,
.init_machine = bcm2708_init,
.init_early = bcm2708_init_early,
.reserve = board_reserve,
.restart = bcm2708_restart,
MACHINE_END
module_param(boardrev, uint, 0644);
module_param(serial, uint, 0644);
module_param(uart_clock, uint, 0644);
module_param(reboot_part, uint, 0644);
The thing I did was just add the #include <linux/fbtft.h> line in the header and then find the struct spi_board_info bcm2708_spi_devices and changed it to my needs.
Do you have experience in compiling a kernel. Why do you need to use this in kernel boot time. For me it was cause I wanted to do this but if you don't really have experience then you might just want to load the drivers as a module on boot.
Now for my question. I have found that SDL should be compatible with framebuffers. Still I think retropi needs something else... It might be gpu related. I have assigned enough RAM to it but I don't know if fb1 is able to access this. Still if you can load X you should be able to load up something like RetroPi not???
