jessie has now been added to the main raspbian archive.
Enjoy!
Re: jessie added to main raspbian archive
what is jessie??
Richard S.
Richard S.
jessie is the codename for the next version of debian/raspbian currently in "testing" (and will be for some time).
I can't wait. I will just pretend I didn't read this and come back in a few months.
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
So how can it be used? I bet apt-get update will not find it?
Edit your /etc/apt/sources.listshuckle wrote:So how can it be used? I bet apt-get update will not find it?
Change all lines that have "wheezy" to "jessie".
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
you can also use the 2 distributions at the same time thanks to apt pinning
in /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ wheezy main contrib non-free rpi
deb http://archive.raspbian.org/raspbian wheezy main contrib non-free rpi
# Source repository to add
deb-src http://archive.raspbian.org/raspbian wheezy main contrib non-free rpi
deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
deb http://archive.raspbian.org/raspbian jessie main contrib non-free rpi
deb-src http://archive.raspbian.org/raspbian jessie main contrib non-free rpi
create /etc/apt/preferences and, if you want to track jessie, put inside
Package: *
Pin: release n=jessie
Pin-Priority: 900
Package: *
Pin: release n=wheezy
Pin-Priority: 300
Package: *
Pin: release o=Raspbian
Pin-Priority: -10
Or, if you want to stick to wheezy
Package: *
Pin-Priority: 900
Package: *
Pin-Priority: 300
Package: *
Pin-Priority: -10
and then do apt-get upgrade
You will also be able to choose what version of a package you want by using:
apt-get install -t jessie <package>
Greetings all
Package: *
Pin-Priority: 900
Package: *
Pin-Priority: 300
Package: *
Pin-Priority: -10
Package: *
Pin-Priority: 900
Package: *
Pin-Priority: 300
Package: *
Pin-Priority: -10
Greetings all
So anyone running raspbian jessie yet?
I wasn't planning to switch over to Jessie yet. I'm giving it a chance to settle down, after the Debian release of Wheezy as Stable. I like to keep all my systems (PCs and Pis) on the same version.plugwash wrote:So anyone running raspbian jessie yet?
However, now that you've mentioned it, I will upgrade one Pi and see how it goes
Curious to see how it goes. Any real benefits over stable save for being bleeding edge?
Ok Pi upgraded.
I had a problem with python3-numpy, where it spat out a load of messages
This seems to have happened to a few people using Ubuntu too, os it's not a Raspbian specific problem.
Someone suggested deleting the contents of /usr/share/python3/debpython/__pycache__ so I did that and ran the dist-upgrade again and it worked.
Preparing to replace python3-numpy 1:1.6.2-1.2 (using .../python3-numpy_1%3a1.7.1-2_armhf.deb) ...
File "/usr/bin/py3clean", line 32, in <module>
from debpython import files as dpf
EOFError: EOF read where not expected
dpkg: warning: subprocess old pre-removal script returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: error processing /var/cache/apt/archives/python3-numpy_1%3a1.7.1-2_armhf.deb (--unpack):
subprocess new pre-removal script returned error exit status 1
File "/usr/bin/py3compile", line 34, in <module>
from debpython.version import SUPPORTED, debsorted, vrepr, \
dpkg: error while cleaning up:
subprocess installed post-installation script returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Say what? You can run Ubuntu on a Pi?rpdom wrote:Ok Pi upgraded.
I had a problem with python3-numpy, where it spat out a load of messagesThis seems to have happened to a few people using Ubuntu too, os it's not a Raspbian specific problem.Code: Select all
Preparing to replace python3-numpy 1:1.6.2-1.2 (using .../python3-numpy_1%3a1.7.1-2_armhf.deb) ... Traceback (most recent call last): File "/usr/bin/py3clean", line 32, in <module> from debpython import files as dpf EOFError: EOF read where not expected dpkg: warning: subprocess old pre-removal script returned error exit status 1 dpkg: trying script from the new package instead ... Traceback (most recent call last): File "/usr/bin/py3clean", line 32, in <module> from debpython import files as dpf EOFError: EOF read where not expected dpkg: error processing /var/cache/apt/archives/python3-numpy_1%3a1.7.1-2_armhf.deb (--unpack): subprocess new pre-removal script returned error exit status 1 Traceback (most recent call last): File "/usr/bin/py3compile", line 34, in <module> from debpython.version import SUPPORTED, debsorted, vrepr, \ EOFError: EOF read where not expected dpkg: error while cleaning up: subprocess installed post-installation script returned error exit status 1 Errors were encountered while processing: /var/cache/apt/archives/python3-numpy_1%3a1.7.1-2_armhf.deb E: Sub-process /usr/bin/dpkg returned an error code (1)
Not properly. But a few people seem to have managed to get it to work on a PCbmstrong wrote:Say what? You can run Ubuntu on a Pi?
So how has your Pi been running with the new image? Any noticeable improvements?rpdom wrote:Not properly. But a few people seem to have managed to get it to work on a PCbmstrong wrote:Say what? You can run Ubuntu on a Pi?, and they use python too...
If you want to test out jessie with a minimal install, raspbian-ua-netinst can certainly help you with that. It is not an official way to install Raspbian but should do the job quite well for power users who want less than the full SD image.
While jessie is currently not available in cdebootstrap suites it can still be used as the target release for raspbian-ua-netinst with clever scripting in the installer configuration script.
Example installer-config.txt to install the server preset jessie:
Please take note that the default apt sources list has the official raspberrypi.org repository which does not yet have jessie dist and will cause 404 errors on apt-get update. It should be possible to change the raspberrypi.org repo to use wheezy instead by manually adjusting /etc/apt/sources.list by hand.
For more information, full documentation and installer downloads,check out https://github.com/hifi/raspbian-ua-netinst
release=jessie
cat >>/usr/share/cdebootstrap-static/suites <<EOF
Suite: jessie
Config: generic
Keyring: debian-archive-keyring.gpg
EOF
BTW adding jessie to the main archive caused a massive traffic spike, I was expecting a spike but not one this big (the week after I added jessie to the main archive is marked as "week 26" on the graph.
Perhaps a lot of people had their sources.list pointing at "testing" instead of "wheezy" and upgraded without realising?plugwash wrote:BTW adding jessie to the main archive caused a massive traffic spike, I was expecting a spike but not one this big
- jackokring
- Contact: ICQ
Just started the upgrade. Looks like it will take a while.
Any news on Qt 5.1, and is it included as a built package? Just checking, as the packages from twolife.be uninstalled qtcreator.
Pi[NFA]=B256R0USB CL4SD8GB Raspbian Stock.
Pi[Work]=A+256 CL4SD8GB Raspbian Stock.
My favourite constant 1.65056745028
I suspect it was more that we just seem to have a crazy number of mirrors nowadays.rpdom wrote:Perhaps a lot of people had their sources.list pointing at "testing" instead of "wheezy" and upgraded without realising?
It looks like so far QT5 is still only in experimental.jackokring wrote:Any news on Qt 5.1
- jackokring
- Contact: ICQ
Ok with an external / and full SD /boot it works excepting the CTRL+D needed to get past the file not found error on /boot. Hopefully this is the start of a launch a different machine code file option.
EDIT: One more thing, the kernel firmware is still the rpi-update latest. So this may be related to the init ramdisk content.
EDIT2: False alarm, just needed a noauto in fstab on the unplugged media volume.
Jessie? It's big.
Jessie? It's big.
Latest raspbian-ua-netinst has full jessie support out of box now. You just need to set the release to jessie as described earlier but do not need the cat hack anymore.
Thanks to plugwash for patching the Raspbian cdebootstrap package until upstream (Debian) does it for theirs.
release=jessie
First really thanks to port Jessie on the Rpi. Second I didn't see any other thread talking about it then I post this "report" here.
It seems the last version of Perl is missing from the repository index.
When I wanted to do an upgrade with aptitude it tells me :
in the "Packages" file you can see it's saying 5.14, but when going manually on the server http://mirrordirector.raspbian.org/rasp ... in/p/perl/ I see that the 5.18 is available.
I also checked the debian repository : http://packages.debian.org/jessie/perl and it's clearly stating that the last version of perl is the 5.18 for Jessie.
Can you update the repository index to correct this ?
Thanks.
The following packages have unmet dependencies:
libnet-ssleay-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
Depends: perlapi-5.18.1 which is a virtual package.
liblocale-gettext-perl : PreDepends: perl-base (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
PreDepends: perlapi-5.18.1 which is a virtual package.
libalgorithm-diff-xs-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libhtml-parser-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libtext-charwidth-perl : Depends: perl-base (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libossp-uuid-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libxml-parser-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libsocket-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libtext-iconv-perl : Depends: perl-base (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libjson-xs-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
libclone-perl : Depends: perl (>= 5.18.1-3) but 5.14.2-21+rpi2 is installed.
Thanks.
Unfortunately due to design limitations in the tools that handle migration between jessie-staging and jessie some packages have migrated from jessie-staging to jessie before things were really ready.
The only real way out of this now is to complete the transition to the new perl but that is going to take a while. Rebuiling hundreds of packages simply takes time.
No problem, I completely understand. In every case, having the 5.14 or the 5.18 doesn't made any differences for me.
I just wanted to report the "wrong" index.
perl has now migrated from jessie-staging to jessie but you may still find some packages perl related packages are uninstallable for a few more days.
