SirLagz
Re: Raspbian Server Edition?
Fri Mar 29, 2013 4:06 pm
I do...on my blog haha.
The blog will be coming back up in a few days if you can wait.
If you can't then shoot me a PM.
My Blog - http://www.sirlagz.net
Visit my blog for Tips, Tricks, Guides and More !
WiFi Issues ? Have a look at this post ! http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=44044
SirLagz
Sun Mar 31, 2013 3:18 pm
Woo blog is back ! :)
SirLagz
Mon Apr 01, 2013 2:16 pm
Can someone please try downloading RSE now and see if it works ?
Thanks all !
tonyhughes
Tue Apr 02, 2013 12:52 am
I DD'ed the 1GB RSE 2.3, but it doesnt appear in my DHCP table, and I dont have access to HDMI or composite at the moment.
Using a Rev1 Model B.
Any ideas?
SirLagz
Tue Apr 02, 2013 1:14 am
It's the exact same image as the 2GB one, except shortened...
Try reflashing ?
Otherwise I'm not too sure =/
highway
Sat Apr 06, 2013 3:06 am
for hosting: create an account at linux tracker dot org and posting the link here . . . should be a good way to help with bandwith :P
might have to give this a spin! im trying to setup a pi server . . .
Airstream
Sat Apr 06, 2013 5:32 am
Search for Geek101 and see Tony Hughes' and related posts. Also look for 'baked raspberry pi mod' which makes installation of server components and changes very easy. (No affliation, disclaimer etc)
SirLagz
Wed Jun 12, 2013 4:06 pm
kalehrl
Wed Jun 12, 2013 5:51 pm
Error 404 - Not Found
Sorry, the page that you are looking for does not exist.
SirLagz
Thu Jun 13, 2013 1:44 am
Derp
Pasted the wrong link into my page :oops:
Fixed now.
SirLagz
Thu Jun 13, 2013 2:52 pm
Would anyone be interested in a Raspbian Server Edition for Hard Drives ?
Comes in a zip file, with the boot directory separate to the HD image.
copy files in boot directory to SD card
dd if=RSE2.4.HD.img of=/dev/sdx1 bs=1M to dd the image onto a hard drive or USB stick.
Yes ? no ?
Hiradur
Thu Jun 13, 2013 4:13 pm
I would!
SirLagz
Thu Jun 13, 2013 6:15 pm
Hiradur wrote:I would!
Well, It's up now so go ahead and give it a shot
http://sirlagz.net/2013/06/14/raspbian- ... ition-2-4/
Hiradur
Fri Jun 14, 2013 2:22 pm
Thanks! I'll try it this weekend.
SirLagz
Thu Jul 18, 2013 5:37 pm
RSE 2.5 is out @ http://sirlagz.net/2013/07/19/raspbian- ... ition-2-5/
Pre-Upgraded to Jessie, apart from that though not much of a change
SirLagz
Sat Aug 03, 2013 3:43 pm
For the people who were after the scripts I use to generate RSE, they can be found here
mro
Thu Aug 15, 2013 1:31 pm
Hi SirLagz,
your server seems to be down - can you mirror the scripts e.g. on github?
Thx,
M
SirLagz
Fri Aug 16, 2013 1:54 am
Hmm you seem to be correct.
I'll get them up somewhere when I get home.
*Edit*
Site is back up now. No idea what went wrong there =/
mro
Fri Aug 16, 2013 10:56 am
awesome, thx!
P.S.: I would recommend keeping ifplugd.
SirLagz
Fri Aug 16, 2013 3:22 pm
mro wrote:awesome, thx!
Out of curiosity why keep ifplugd ?
I don't really see a point in it when servers will most likely have hardwire networks and configured with a static IP
mro
Sat Aug 17, 2013 1:52 am
SirLagz wrote:Out of curiosity why keep ifplugd ?
Short answer: I shot into my foot and had to figure out how to manually configure ifconfig (didn't do it for 10 years or so).
Longer answer: a stripped down raspi might travel and be plugged into various networks over time.
And avoids redundant config settings (e.g. in DHCP environments).
But it's just my 2ct.
Hiradur
Fri Oct 25, 2013 2:26 pm
Do you still work on this?
btw: I agree with mro.
SirLagz
Fri Oct 25, 2013 2:54 pm
Occasionally...
There's quite a few other minimal Raspbian Distros out there now though which other people seem fond of so I haven't put much work into this of late.
Do people want a version based off the new Raspbian Distro ?
Hiradur
Fri Oct 25, 2013 3:33 pm
Oh I must have missed that since I haven't been active in the scene for quite a while. Can you recommend one that is similar to RSE? I found MINIBIAN and some others that have preinstalled apache packages and stuff. But I only need a minimal Raspbian distro focused on performance and small memory footprint rather than a small image.
I'm still running RSE 2.4 and I like your work. However if there already are stripped down versions of recent Raspbian there is no need for you to do it again I guess.
SirLagz
Mon Oct 28, 2013 1:22 am
Return to “Raspberry Pi OS”
