New module, no problem connecting, but image is flipped.
Using raspistill -hf -o image.jpg shows a correct image.
Can the image be flipped to stay in correct orientation?
Thanks for the infoleol wrote:This is a known issue and I believe is fixed in the next release.
There is a rotate by 180 option...you can do 90, 180, or 270.jbeale wrote:depends how you hold the camera! It is always "mirror image" but may also be upside down, if for example as on my installation, the cable goes up instead of down. So I need to rotate the image 180 as well as flip left-right. There isn't a "rotate by 180" option, but both operations can be done in one go with the vertical flip.
