mcisely
Re: Gstreamer 1.0 for raspbian
Sun Mar 31, 2013 6:56 pm
ok, I have updated gstreamer to 1.0.6 and liborc to 0.4.17.
After updating the following pipeline should work:
CODE: SELECT ALL
gst-launch-1.0 filesrc location=big_buck_bunny_720p_H264_AAC_25fps_3400K.MP4 ! decodebin ! videoconvert ! ximagesink
Yes, that fixed it. Thanks. (However I see now that ximagesink is too slow for what I need but that's not a bug, just another example for why the GPU is needed to do this correctly.) Thanks again.
-Mike
Defiant
Sun Apr 07, 2013 6:57 am
Noticed that. Also the fbdevsink is too slow. Try the eglglessink after updating.
tomtaylor
Sun Apr 07, 2013 8:43 am
I'm using this build of gstreamer, but I can't get eglglessink to work correctly. When I attempt to pipe a video through, I see:
libEGL warning: DRI2: xcb_connect failed
libEGL warning: GLX: XOpenDisplay failed
And then eglglessink says it could not init the display connection, returned error 3000.
I'm guessing this is because I need to be in X to run eglglessink. Can it be used without X?
Defiant
Sun Apr 07, 2013 8:45 am
It runs without. Did you update?
denjell
Sun Apr 07, 2013 7:46 pm
i can confirm that it eglglessink is now "working" without X, but seems to be framedropping to keep up. it is definitely smoother, but by my estimate around 15fps. still not on par with omxplayer, but is starting to get better and better. :)
Defiant
Sun Apr 07, 2013 8:43 pm
Seems to be pipeline dependent.
videotestsrc ! eglglessink
also lagged for me, while the test pipeline
filesrc location=big_buck_bunny_720p_H264_AAC_25fps_3400K.MP4 ! qtdemux ! queue
max-size-bytes=10000000 ! h264parse ! omxh264dec ! queue max-size-buffers=4 ! eglglessink
does fine.
denjell
Mon Apr 08, 2013 9:30 am
wow! you're right. I was using videoconvert in my pipeline - which drops out. your video-only pipeline works fine at 720p - but still has framedropping issues at 1080p. (although this could be because of my slow SD card...)
here is my pipeline with audio:
gst-launch-1.0 filesrc location=big_buck_bunny_720p_H264_AAC_25fps_3400K_short.MP4 ! qtdemux name=demuxer \ demuxer. ! queue ! faad ! alsasink device=hw:0,0 sync=false \ demuxer. ! queue max-size-bytes=10000000 ! h264parse ! omxh264dec ! queue max-size-buffers=4  ! eglglessink
any idea why it drops frames at 1080p?
portets
Thu Apr 11, 2013 2:49 am
So if a video player that uses gstreamer, like Totem for example, were compiled against the version of gstreamer in this thread, would it be fully functional and hardware accelerated?
Defiant
Thu Apr 11, 2013 8:00 am
Should be. I guess someone has to to try..
But if a decodebin ! autovideosink pipeline works, so should totem.
10robinho
Thu Apr 11, 2013 1:31 pm
Defiant wrote:It runs without. Did you update?
Hi, what version of gst-plugins-bad did you used? Latest git?
Because I've tried with 1.0.6 and it doesn't work without X for me.
Defiant
Thu Apr 11, 2013 3:46 pm
The important part is on how you compile it. You need to do
LDFLAGS='-L/opt/vc/lib' CPPFLAGS='-I/opt/vc/include
-I/opt/vc/include/interface/vcos/pthreads -I/opt/vc/include/interface/vmcs_host/linux' ./autogen.sh
10robinho
Thu Apr 18, 2013 11:59 pm
Is this combo
omxh264dec ! eglglessink
rendering video with zero-copy?
sanv
Fri Apr 26, 2013 6:11 am
Hi.
I'm using this prebuild of gstreamer.
it works fine:
gst-launch-1.0 filesrc location=sema_h264.avi ! decodebin ! videoconvert ! eglglessink
It does not work:
gst-launch-1.0 filesrc location=sema_h264.avi ! qtdemux ! queue max-size-bytes=10000000 ! h264parse ! omxh264dec ! queue max-size-buffers=4 ! eglglessink
********* PAUSED…
**********(PREROLL)…
ERROR: из элемента /GstPipeline:pipeline0/GstQTDemux:demuxer: This file is invalid and can not be reproduced.
Дополнительная отладочная информация:
qtdemux.c(597): gst_qtdemux_pull_atom (): /GstPipeline:pipeline0/GstQTDemux:demuxer:
atom has bogus size 1380533830
ERROR: pipeline does not want (PREROLL).
Help,pls)
Defiant
Fri Apr 26, 2013 6:27 am
Is qtdemux the right demuxer for you? Your file with .avi extension doesn't look like a Quick Time video.
sanv
Fri Apr 26, 2013 10:09 am
I'm not sure... My goal is qml video(QtMultimedia).
Raspbian OMX player sees my file.I will now download and try
buck bunny.
sanv
Fri Apr 26, 2013 1:43 pm
How to run the qml application after installation of the prebuild of gstreamer(gst-omx)?
"./testvideo" or "./testvideo -?????"
Maybe I need to add a environment variable?
Defiant
Fri Apr 26, 2013 1:51 pm
This sounds like a question that should be addressed to the QT-People.
Gst-omx should automatically be used by decodebin.
Kentzo
Tue May 28, 2013 5:05 am
Hi everyone.
A few questions:
Neither ximagesink nor xvimagesink work on my pi (Raspbian).
xvinfo returns "Unable to open display".
How do you make the sinks above work?
When playing 1080p (h264) fps is low. Is it known issue or I miss some parameters in my pipeline?
filesrc location=./big_buck_bunny_1080p_H264_AAC_25fps_7200K.MP4 ! qtdemux ! h264parse ! omxh264dec ! eglglessink
Defiant
Tue May 28, 2013 5:52 am
You need to run a xserver to output to the x-sinks.
But egl is the better sink anyway.
Did you try the pipeline as it is shown here:
http://www.raspberrypi.org/phpBB3/viewt ... 71#p326571
Kentzo
Tue May 28, 2013 12:32 pm
Defiant wrote: Did you try the pipeline as it is shown here:
Thank you for the reply!
Yes, I tried it (except that I used 1080p version of this movie). I also tried to overclock pi to 1 GHz, but it didn't really help. I dedicated 256MB of memory to GPU.
Note that I'm using stable version of gst installed from http://vontaene.de/raspbian-updates
Defiant
Tue May 28, 2013 5:34 pm
I never tried the 1080p Version, maybe you should try to ask the gst-omx developers - I don't think they are reading this forum.
fbutler
Tue May 28, 2013 6:08 pm
Kentzo wrote:When playing 1080p (h264) fps is low. Is it known issue or I miss some parameters in my pipeline?
Could it be the throughput of your SD card that is causing a bottleneck?
Kentzo
Wed May 29, 2013 4:10 am
Unlikely. I'm using SD card class 10.
And omxplayer is very smooth on the same video.
I've filed a bug report regarding that issue.
Kentzo
Thu May 30, 2013 3:10 pm
I was able to fix the problem by compiling gstreamer from the sources.
I think maintainer of http://vontaene.de/raspbian-updates/ should update packages.
Defiant
Thu May 30, 2013 3:13 pm
thanks, will do.
Return to “Raspbian”
