Hi
I designed a new enclosure model adapted to the new versions of boards
Raspberry Pi 2 and PiFace Digital 2.
Birch ply is made from laminations of birch veneer. It is light but strong, among the strongest and most dimensionally-stable plywoods.
Made of birch plywood this case keeps the Pi secure, has a hinged top for connector access, and even has little feet cut into the sides so that it stands up above your desk.
You can use all of the connectors on the edges of the Pi: HDMI, Audio/Video, microSD slot, micro USB power, Ethernet and the 4 USB ports.
There's also a cut out to allow a 40-pin IDC cable to the GPIO breakout pins on the Pi and pass it though the case and 2 rectangular openings for PiFACE board ports.
For more advanced hacking, the enclosure is designed so that you can lift or remove the top piece and plug any sort of cables you wish into the breakouts in the middle.
The case is airy enough that no additional vents or cooling is required - we tested the enclosed Pi over a 24 hour period at full load with no significant increase in temperature.
Sales on ETSY
https://goo.gl/MEFZTO and eBay sites...
