Hi Max!
2 questions:
1:how could one donate to back this awesome work up?
2:does the latest version take advantage of the newer model's 512mb RAM?
Re: Berryboot v1.1 - Boot menu / OS installer
Same here, my PI is in the room next to me, only power and ethernet are attached to it. I don't have a monitor, so every time I need a reboot I must attach it to the TV.troubadixx wrote:Hi Max,
thanks for the quick answer.
The thing is: I'm sitting right next to my Pi. Just don't want to connect more than power and ethernet.
Why don't you reboot via ssh?
It can be rebooted via ssh, however you can't enter the LUKS password through it in order to boot it again.
It seems that is possible through dropbear.
http://www.debian-administration.org/articles/579
it is possible to connect with ssh without password.
have a look on :
http://www.linuxproblem.org/art_9.html
But for this you need a static address for RPi.
That's done in /etc/network/interface.
Many explanations how to do that anywhere.
have a look on :
This option was already discussed here http://www.raspberrypi.org/phpBB3/viewt ... 09#p269109Axilot wrote:It seems that is possible through dropbear.
Public key authentication has nothing to do with the LUKS password.totoharibo wrote:it is possible to connect with ssh without password.
have a look on :
OK, took a while longer than hoped, but today I managed to give Berryboot a try. It is about the best piece of software I ever had the fortune to use. It works great! The static IP configuration was a breeze and downloading the various OS was a snap. I hooked up an external 40GB hard drive via USB hub to the Pi and that worked flawlessly, all OS files are on the external drive which seems to perform better than having everything on the SD card.
Looking through the posts and the Berryterminal web site only revealed that "Max" created this excellent tool. With that, thank you so much Max! This is just phantabulous!
Our Pi Blog - http://weusepis.wordpress.com/
I have been using BerryBoot for a few weeks now, and I was very pleased at how easy it was to install an image and that I have the option of adding additional operating systems in the future. For now, though, I only have one OS, and my only displeasure with the BerryBoot is having to wait ten seconds for the OS selection screen to automatically boot my default OS (since my current application will use the RPi without a monitor, mouse, or keyboard). Is there a way to adjust this time (or eliminate it altogether) that BerryBoot waits before booting? Thanks for your help.
It's explained previous in this thread.
You can now enter a custom boot menu timeout duration. Click the "advanced configuration" button, go to the "cmdline.txt" tab and
add "bootmenutimeout=<number of seconds>" or use "nobootmenutimeout" to not boot the default OS automatically.
I'm trying to use an alternate kernel that I built but simply replacing the kernel uImage in berryboot isn't the right way to do it. You end up with errors after "Mounting RW data directory on top" with devices unable to mount and a fatal switch_root error.
What is the right way to add/replace a kernel when using Berryboot??
Do you have to rebuild the OS image?
Ack! I'm still fighting with this.What is the right way to add/replace a kernel when using Berryboot??
It looks like the kernel itself has to be built a specific way?
Any help is appreciated.
Hi Max,
Just wanted to let you know about a potential problem with BB that seems to be solved:
http://www.raspberrypi.org/phpBB3/viewt ... 40#p306440
help.
I have installed berryboot with debian raspian.
But i end up with a trouble with my external hdd. when i start the Pi some time mi usbhdd and my usbkey get swapped (sda and sdb). i tried by reediting the /etc/fstab and putting the mount point of my external hdd from sda to sdb (like i said some time the drive device get swapped).
Now i restarted the pi and the boot failed with some errors about not finding all the dir.
I decided to revert back the fstab. I mounted the usbkey on my kubuntu and then i mounted (sudo mount ~/Debian_Wheezy_Raspbian_2012.12.img192 /media/fs/ -t squashfs -o loop,ro ) the image inside it (Debian_Wheezy_Raspbian_2012.12.img192) but inside this file i can't find my data.
I put back the usbkey on the PI and lauched the filesystem check in the berryboot menu that have found a loot of errors. At the end i managed to boot on the Pi but all my data is erased...the user password is the default one (raspberry).
Long story short how i can recover my data ?
I have a problem using VNC.
I can use VNC to do the initial setup and download an OS, when I reboot I cannot connect with VNC again. If I connect a monitor it shows a mmessage to use VNC.. If I remove the vnc install option it is booting correctly. Is there any thing special I need to do to use VNC to select the os to boot.
what is the minimum SD card size for BerryBoot?
I want to install the SOs on an external hard disk.
Thanks.
Thanks.
Hello
I have tried the last version of berryboot, and my question is: why not it includes more links for other operanting systems? or a link to a repository?
Writing Two 8 Gigabyte Images to one 16 Gigabyte SD Card
I have two 8 gigabyte SD Cards each with a separate image. one SD Card is for RASPBMC and the other is Wheezy. I have an image backup for each. Can I simply take a 16 Gigabyte SD Card and Partition it to two 8 Gigabyte partitions and write both 8 gigabyte images to the same SD Card to its own respective partition? Then upon boot be asked which OS I want to boot up at? Basically what I am trying to do is have the ability to use one SD Card to write both my images to so that if I want to go from RASPBMC to Wheezy or vice-verse all I need to do is a reboot.
Perhaps we can work around it by using a LUKS keyfile on a flash drive?Max wrote:No.troubadixx wrote: Question: Can I log in remotely to Berryboot in order to enter the disk encryption password? I. e., without the need for keyboard and monitor to be connected to the RadpberryPi?
There are some practical safety issues with that, in particular with ensuring that the computer you are sending your password to over the Internet is actually your Pi, and that your Pi has not been tampered with.
What is the best method to update OE to 2.99.5 as the auto-update does not seem to work. I have a dual boot with OE 2.99.4 and Debian. I have made the necessary adjustments so that I can now ssh into OE using winscp. Do I copy all 4 files into .update or just the 2 system files. On reboot will it then perform the update?
Sid
Sorry please ignore, found earlier post and now sorted.
Sid
hello
I have installed berry boot and would like to add chameleon to the boot selection.
I am using windows7, downloaded the image,moved it to a usb stick and placed into the pi.
when i hold the add os button in the menu and choose usb, the image does not appear as a selection.
do i have to format the usb stick a paritular way before i place the image onto it or do i have to use linux to put the image onto the stick?
thanks
Wes
thanks
Wes
After few second holding the button "add os" you should see a new line in the drop down menù "copy OS from Usb stick", remenber that you have to convert your file system image to SquashFS format first.
As explained here
http://www.berryterminal.com/doku.php/b ... tributions
As explained here
I'm trying to make a kali linux image for berryboot as I've already successfully do with arch linux,
but it seems that only one partition loop0p1 is present in the image, is it possible?
the image is "kali-linux-1.0-armhf.img.gz"
http://archive-4.kali.org/kali-images/k ... mhf.img.gz
are there images of xbian and raspbmc fro berryboot?
thanks
thanks
