I've now had this happen for a 3rd time "cannot find my data partition
I might have run before I can walk but I just went all out and got my Pi a week ago and got the XBMC media centre install up and running pretty quick. I then started again but used the Berryboot to format the SD card and installed XBMC as default and Puppy etc as one of the 3 options on the boot menu.
Each crash has happened while in XBMC, last time this happened I was adjusting the video resolution when it crashed. The crash point seems random!
Had no option after waiting 30 mins it was still hung up so done Ctrl Alt Del and it booted. Then it came up with the above "cannot find my data partition
Had everything working well before this. Wifi keyboard, wireless secure Network connection, various add-ons iPlayer all working well and liveTV, iTunes etc.
Last install lasted for a few days and was 100% stable until it crashed!
I used an add-on to do a backup which I was doing before I made any changes.
Will I be able to access this off the SD card to rebuild XBMC without Berryboot?
I did find a post about this but not much help; http://www.raspberrypi.org/phpBB3/viewt ... &start=175
I will add a photo I took of screen at the crash point and or any info off the SD card if that helps!
Any info or help on this problem is appreciated.
