just found this post and registered to the forum
I have an Audi S5 with a Hybrid TV tuner. Therefore there are 2 optional AV inputs which can be easily connected by just putting some Cinch cables to the red 12 or 20 pin connector. What could be better than using a Pi with these connections?
I bought original cables (look better than just soldering around) and could connect a DVD player but not my loved Pi. Audio works for both. So I guess it can be only the output voltage of the Pi (too low) or the resolution. I guess I have the wrong resolution set on the composite out. Nevertheless I could connect the Pi to two television screen without any problem (with the composite out of course).
I've seen that there might be a solution in editing the /boot/config.txt but I tried a bit but without success. I wonder if somebody has an idea how I could run the Raspberry Pi in my Audi with an probably special or not normal TV screen (all my other screens at home work well with the Pi).
best regards
Rolf
