jyavenard
System Instability
Sun Jan 20, 2013 10:39 pm
Hello
The raspberry pi i got crashes often and require a power cycle at regular interval.. The best uptime I've got has been 24 hours so far.
I use the power supply from Element14 raspberry site, a 1A power supply.
The unit is connected via ethernet port and has two pl2303 usb/serial adapters connected to it.
I tried limiting the USB port to USB 1.1 by adding dwc_otg.speed=1 to /boot/cmdline.txt as read in various blogs. Made no difference, Pi crashed after only a few hours.
I read about the need to use a powered USB hub. The 1A power supply should be sufficient I think. The PL2303 each draws less than 20mA), so adding that to the 750mA recommended for the Pi I'm well below the rating of my power supply.
Though I will try with a powered hub, just in case... A bit of a pity if you're not able to use the built-in USB if that's indeed the case..
As I reported in an earlier thread:
http://www.raspberrypi.org/phpBB3/viewt ... =30025&e=0
I can consistently crash the unit by doing:
udevadm info -a -p $(udevadm info -q path -n /dev/ttyUSB0)
/dev/ttyUSB0 being one PL2303.
What are you guys doing with a similar setup so it doesn't crash as often?
Any hint, tricks etc???
I run the wheezy distribution found at http://downloads.raspberrypi.org/images ... spbian.zip
jyavenard
Re: System Instability
Mon Jan 21, 2013 3:40 am
I had access to the Pi just then, and the board didn't actually crash, it had filled /var/log/syslog quite happily all this time.
I query the PL2303 /dev/ttyUSB0 device every 10s.
The last record I had in my log occurred on:
2013-01-21 03:26:19.
At this time, in /var/log/syslog I get:
Jan 21 03:26:24 raspberrypi kernel: [30419.046427] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000114
Jan 21 03:26:24 raspberrypi kernel: [30419.566360] ------------[ cut here ]-----
Jan 21 03:26:24 raspberrypi kernel: [30419.566422] WARNING: at net/sched/sch_generic.c:255 dev_watchdog+0x2a0/0x2c0()
Jan 21 03:26:24 raspberrypi kernel: [30419.566440] NETDEV WATCHDOG: eth0 (smsc95xx): transmit queue 0 timed out
Jan 21 03:26:24 raspberrypi kernel: [30419.566452] Modules linked in: snd_bcm2835 snd_pcm snd_seq snd_timer snd_seq_device snd snd_page_alloc pl2303 usbserial
Jan 21 03:26:24 raspberrypi kernel: [30419.566543] [<c0013e1c>] (unwind_backtrace+0x0/0xf0) from [<c0028b24>] (warn_slowpath_common+0x4c/0x64)Jan 21 03:26:24 raspberrypi kernel: [30419.566578] [<c0028b24>] (warn_slowpath_common+0x4c/0x64) from [<c0028bd0>] (warn_slowpath_fmt+0x30/0x40)
Jan 21 03:26:24 raspberrypi kernel: [30419.566610] [<c0028bd0>] (warn_slowpath_fmt+0x30/0x40) from [<c02eb38c>] (dev_watchdog+0x2a0/0x2c0)
Jan 21 03:26:24 raspberrypi kernel: [30419.566658] [<c02eb38c>] (dev_watchdog+0x2a0/0x2c0) from [<c0033fe8>] (run_timer_softirq+0x114/0x2a4)
Jan 21 03:26:24 raspberrypi kernel: [30419.566692] [<c0033fe8>] (run_timer_softirq+0x114/0x2a4) from [<c002e62c>] (__do_softirq+0x90/0x128)
Jan 21 03:26:24 raspberrypi kernel: [30419.566722] [<c002e62c>] (__do_softirq+0x90/0x128) from [<c002eaec>] (irq_exit+0x90/0x98)
Jan 21 03:26:24 raspberrypi kernel: [30419.566759] [<c002eaec>] (irq_exit+0x90/0x98) from [<c000e880>] (handle_IRQ+0x34/0x84)
Jan 21 03:26:24 raspberrypi kernel: [30419.566796] [<c000e880>] (handle_IRQ+0x34/0x84) from [<c037c974>] (__irq_svc+0x34/0xc8)
Jan 21 03:26:24 raspberrypi kernel: [30419.566829] [<c037c974>] (__irq_svc+0x34/0xc8) from [<c000e990>] (default_idle+0x24/0x28)
Jan 21 03:26:24 raspberrypi kernel: [30419.566858] [<c000e990>] (default_idle+0x24/0x28) from [<c000eb78>] (cpu_idle+0x9c/0xc4)
Jan 21 03:26:24 raspberrypi kernel: [30419.566897] [<c000eb78>] (cpu_idle+0x9c/0xc4) from [<c04c1718>] (start_kernel+0x280/0x2c8)
Jan 21 03:26:24 raspberrypi kernel: [30419.566916] ---[ end trace 456c082a0dfb0ee9 ]---
Jan 21 03:26:29 raspberrypi kernel: [30424.046627] smsc95xx 1-1.1:1.0: eth0: Failed to write register index 0x00000114
Jan 21 03:26:34 raspberrypi kernel: [30429.046820] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000114
Jan 21 03:26:39 raspberrypi kernel: [30434.047044] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000118
Jan 21 03:26:44 raspberrypi kernel: [30439.047232] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000114
Jan 21 03:26:49 raspberrypi kernel: [30444.047433] smsc95xx 1-1.1:1.0: eth0: Failed to write register index 0x00000114
Jan 21 03:26:54 raspberrypi kernel: [30449.047635] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000114
Jan 21 03:26:59 raspberrypi ifplugd(eth0)[1380]: Link beat lost.
Jan 21 03:26:59 raspberrypi kernel: [30454.047865] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000118
Jan 21 03:27:05 raspberrypi kernel: [30460.148099] smsc95xx 1-1.1:1.0: eth0: Failed to read register index 0x00000114
Hope this will help someone...
Return to “Raspberry Pi OS”
