xnosek00
usb disk - data corruption - due to overclocking?
Wed Jan 09, 2013 10:36 am
I have RasPi v 2 with 512 MB. Overlocked 1GHz.
[email protected]:/home/pi# uname -a
Linux raspberrypi 3.6.11+ #348 PREEMPT Tue Jan 1 16:33:22 GMT 2013 armv6l GNU/Linux
in first USB port is connected powered usb swtich with DVB-T card.
in second USB port I have connected usb disk with own power suply.
usb disk is new and controled by badblocks.
Sometimes, I have error with data corruption and I don't know why - it's unstable. It's due to overlocking? I though, that overlocking cause only sd card corruption (sometimes it happends too).
[email protected] ~ $ dmesg
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.6.11+ ([email protected]) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #348 PREEMPT Tue Jan 1 16:33:22 GMT 2013
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 16 MiB at 17000000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 98304
[ 0.000000] free_area_init_node: node 0, pgdat c05397f4, node_mem_map c05e3000
[ 0.000000] Normal zone: 768 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 97536 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97536
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708.boardrev=0xf bcm2708.serial=0xbc6503d4 smsc95xx.macaddr=B8:27:EB:65:03:D4 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 sdhci-bcm2708.enable_llm=1 sdhci-bcm2708.sync_after_dma=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 384MB = 384MB total
[ 0.000000] Memory: 367248k/367248k available, 25968k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd8800000 - 0xff000000 ( 616 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd8000000 ( 384 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc04e43c0 (4977 kB)
[ 0.000000] .init : 0xc04e5000 - 0xc0505ddc ( 132 kB)
[ 0.000000] .data : 0xc0506000 - 0xc053a020 ( 209 kB)
[ 0.000000] .bss : 0xc053a044 - 0xc05e26b8 ( 674 kB)
[ 0.000000] NR_IRQS:330
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.000700] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.040095] pid_max: default: 32768 minimum: 301
[ 0.040330] Mount-cache hash table entries: 512
[ 0.040886] Initializing cgroup subsys cpuacct
[ 0.040926] Initializing cgroup subsys devices
[ 0.040948] Initializing cgroup subsys freezer
[ 0.040968] Initializing cgroup subsys blkio
[ 0.041035] CPU: Testing write buffer coherency: ok
[ 0.041278] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.041389] Setting up static identity map for 0x39c438 - 0x39c494
[ 0.042482] devtmpfs: initialized
[ 0.049495] NET: Registered protocol family 16
[ 0.053862] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.054758] bcm2708.uart_clock = 0
[ 0.055655] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.055692] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.055717] mailbox: Broadcom VideoCore Mailbox driver
[ 0.055784] bcm2708_vcio: mailbox at f200b880
[ 0.055849] bcm_power: Broadcom power driver
[ 0.055874] bcm_power_open() -> 0
[ 0.055890] bcm_power_request(0, 8)
[ 0.556474] bcm_mailbox_read -> 00000080, 0
[ 0.556502] bcm_power_request -> 0
[ 0.556521] Serial: AMBA PL011 UART driver
[ 0.556624] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.887168] console [ttyAMA0] enabled
[ 0.903918] bio: create slab <bio-0> at 0
[ 0.908596] SCSI subsystem initialized
[ 0.912507] usbcore: registered new interface driver usbfs
[ 0.918126] usbcore: registered new interface driver hub
[ 0.923610] usbcore: registered new device driver usb
[ 0.929689] Switching to clocksource stc
[ 0.933767] FS-Cache: Loaded
[ 0.936825] CacheFiles: Loaded
[ 0.947634] NET: Registered protocol family 2
[ 0.952581] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.960395] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.967287] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.973909] TCP: reno registered
[ 0.977156] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.983013] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.989557] NET: Registered protocol family 1
[ 0.994325] RPC: Registered named UNIX socket transport module.
[ 1.000263] RPC: Registered udp transport module.
[ 1.005029] RPC: Registered tcp transport module.
[ 1.009737] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.016747] bcm2708_dma: DMA manager at f2007000
[ 1.021431] bcm2708_gpio: bcm2708_gpio_probe c0513d58
[ 1.026781] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.035641] audit: initializing netlink socket (disabled)
[ 1.041090] type=2000 audit(0.880:1): initialized
[ 1.127955] VFS: Disk quotas dquot_6.5.2
[ 1.131957] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.138856] FS-Cache: Netfs 'nfs' registered for caching
[ 1.144465] NFS: Registering the id_resolver key type
[ 1.149601] Key type id_resolver registered
[ 1.153859] Key type id_legacy registered
[ 1.158120] msgmni has been set to 749
[ 1.163039] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.170731] io scheduler noop registered
[ 1.174735] io scheduler deadline registered (default)
[ 1.179903] io scheduler cfq registered
[ 1.215770] Console: switching to colour frame buffer device 160x64
[ 1.235595] kgdb: Registered I/O driver kgdboc.
[ 1.240686] vc-cma: Videocore CMA driver
[ 1.244741] vc-cma: vc_cma_base = 0x00000000
[ 1.249522] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.255026] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.266874] brd: module loaded
[ 1.273483] loop: module loaded
[ 1.277029] vchiq: vchiq_init_state: slot_zero = 0xd7000000, is_master = 0
[ 1.284660] Loading iSCSI transport class v2.0-870.
[ 1.290462] usbcore: registered new interface driver smsc95xx
[ 1.296619] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.507674] Core Release: 2.80a
[ 1.510920] Setting default values for core params
[ 1.515924] Finished setting default values for core params
[ 1.726654] Using Buffer DMA mode
[ 1.730067] Periodic Transfer Interrupt Enhancement - disabled
[ 1.736053] Multiprocessor Interrupt Enhancement - disabled
[ 1.741752] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.746240] Dedicated Tx FIFOs mode
[ 1.750761] dwc_otg: Microframe scheduler enabled
[ 1.751130] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.756270] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.763775] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.769449] Init: Port Power? op_state=1
[ 1.773455] Init: Power Port (0)
[ 1.776910] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.783994] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.791387] usb usb1: Product: DWC OTG Controller
[ 1.796244] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[ 1.802126] usb usb1: SerialNumber: bcm2708_usb
[ 1.813338] hub 1-0:1.0: USB hub found
[ 1.823041] hub 1-0:1.0: 1 port detected
[ 1.833198] dwc_otg: FIQ enabled
[ 1.833218] dwc_otg: NAK holdoff enabled
[ 1.833236] Module dwc_common_port init
[ 1.833484] Initializing USB Mass Storage driver...
[ 1.844429] usbcore: registered new interface driver usb-storage
[ 1.856265] USB Mass Storage support registered.
[ 1.866920] usbcore: registered new interface driver libusual
[ 1.878852] mousedev: PS/2 mouse device common for all mice
[ 1.891000] bcm2835-cpufreq: min=700000 max=1000000 cur=1000000
[ 1.897008] bcm2835-cpufreq: switching to governor powersavebcm2835-cpufreq: switching to governor powersave
[ 1.912975] cpuidle: using governor ladder
[ 1.930070] cpuidle: using governor menu
[ 1.940499] sdhci: Secure Digital Host Controller Interface driver
[ 1.953177] sdhci: Copyright(c) Pierre Ossman
[ 1.964111] sdhci: Enable low-latency mode
[ 2.013891] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.028238] Indeed it is in host mode hprt0 = 00021501
[ 2.045908] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.083818] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.104142] usbcore: registered new interface driver usbhid
[ 2.127812] mmc0: new high speed SDHC card at address aaaa
[ 2.139758] usbhid: USB HID core driver
[ 2.164879] TCP: cubic registered
[ 2.174701] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[ 2.194268] Initializing XFRM netlink socket
[ 2.205658] NET: Registered protocol family 17
[ 2.217009] mmcblk0: p1 p2
[ 2.226220] Key type dns_resolver registered
[ 2.238324] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.253383] registered taskstats version 1
[ 2.279406] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.294198] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.315349] devtmpfs: mounted
[ 2.325002] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.339123] Freeing init memory: 128K
[ 2.349784] Indeed it is in host mode hprt0 = 00001101
[ 2.564175] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.578699] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.593733] hub 1-1:1.0: USB hub found
[ 2.609172] hub 1-1:1.0: 3 ports detected
[ 2.894008] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.014389] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.042777] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.064101] smsc95xx v1.0.4
[ 3.138477] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:65:03:d4
[ 3.254152] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.395341] usb 1-1.2: New USB device found, idVendor=152d, idProduct=2329
[ 3.420962] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 3.451200] usb 1-1.2: Product: USB to ATA/ATAPI bridge
[ 3.479447] usb 1-1.2: Manufacturer: JMicron
[ 3.503274] usb 1-1.2: SerialNumber: DCAA030589FF
[ 3.534394] usb-storage 1-1.2:1.0: Quirks match for vid 152d pid 2329: 8020
[ 3.555670] scsi0 : usb-storage 1-1.2:1.0
[ 3.663982] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 3.804612] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101
[ 3.821278] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.835957] usb 1-1.3: Product: USB 2.0 Hub [MTT]
[ 3.854067] hub 1-1.3:1.0: USB hub found
[ 3.876909] hub 1-1.3:1.0: 4 ports detected
[ 4.001340] udevd[143]: starting version 175
[ 4.174063] usb 1-1.3.1: new high-speed USB device number 6 using dwc_otg
[ 4.321990] usb 1-1.3.1: New USB device found, idVendor=0db0, idProduct=5580
[ 4.322005] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.322015] usb 1-1.3.1: Product: DTV USB MINI
[ 4.322024] usb 1-1.3.1: Manufacturer: ULi Electronics
[ 4.403967] usb 1-1.3.4: new high-speed USB device number 7 using dwc_otg
[ 4.554587] usb 1-1.3.4: New USB device found, idVendor=1a40, idProduct=0101
[ 4.583911] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.612112] scsi 0:0:0:0: Direct-Access WDC WD20 EARX-00PASB0 PQ: 0 ANSI: 2 CCS
[ 4.653794] usb 1-1.3.4: Product: USB 2.0 Hub [MTT]
[ 4.685654] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 4.714767] hub 1-1.3.4:1.0: USB hub found
[ 4.734530] sd 0:0:0:0: [sda] Write Protect is off
[ 4.764056] hub 1-1.3.4:1.0: 4 ports detected
[ 4.783867] sd 0:0:0:0: [sda] Mode Sense: 28 00 00 00
[ 4.784775] sd 0:0:0:0: [sda] No Caching mode page present
[ 4.823964] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 4.872936] sd 0:0:0:0: [sda] No Caching mode page present
[ 4.914670] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 4.974367] sda: sda1
[ 5.007550] sd 0:0:0:0: [sda] No Caching mode page present
[ 5.053168] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 5.093785] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.540271] dvb-usb: found a 'MSI Mega Sky 580 DVB-T USB2.0' in warm state.
[ 5.704062] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 5.828869] Registered led device: led0
[ 5.837354] DVB: registering new adapter (MSI Mega Sky 580 DVB-T USB2.0)
[ 5.973556] DVB: Unable to find symbol mt352_attach()
[ 6.283778] dvb-usb: no frontend was attached by 'MSI Mega Sky 580 DVB-T USB2.0'
[ 6.574162] input: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.1/input/input0
[ 6.793807] dvb-usb: schedule remote query interval to 100 msecs.
[ 6.922867] dvb-usb: MSI Mega Sky 580 DVB-T USB2.0 successfully initialized and connected.
[ 7.105938] usbcore: registered new interface driver dvb_usb_m920x
[ 8.236476] device-mapper: ioctl: 4.23.0-ioctl (2012-07-25) initialised: [email protected]
[ 11.843930] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.325775] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 13.358067] bcm2835 ALSA card created!
[ 13.382314] bcm2835 ALSA chip created!
[ 13.399609] bcm2835 ALSA chip created!
[ 13.414280] bcm2835 ALSA chip created!
[ 13.428478] bcm2835 ALSA chip created!
[ 13.442490] bcm2835 ALSA chip created!
[ 13.456459] bcm2835 ALSA chip created!
[ 13.470421] bcm2835 ALSA chip created!
[ 19.898646] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 19.913629] mmc0: DMA IRQ 6 ignored - results were reset
[ 19.929515] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 19.944719] mmc0: DMA IRQ 6 ignored - results were reset
[ 24.027149] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 25.766493] bcm2835-cpufreq: switching to governor ondemand
[ 25.766525] bcm2835-cpufreq: switching to governor ondemand<6>[ 28.416671] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SS
[ 30.010346] warning: process `colord-sane' used the deprecated sysctl system call with 8.1.2.
[ 491.196423] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[ 491.208523] XFS (dm-7): Mounting Filesystem
[ 492.921059] XFS (dm-7): Ending clean mount
[ 493.258338] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
[ 493.460868] XFS (dm-9): Mounting Filesystem
[ 495.230752] XFS (dm-9): Ending clean mount
[ 495.454539] XFS (dm-10): Mounting Filesystem
[ 497.360749] XFS (dm-10): Ending clean mount
[ 497.694223] EXT4-fs (dm-11): mounted filesystem with ordered data mode. Opts: (null)
[ 497.954579] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null)
[12840.708864] usb 1-1.3.4.2: new high-speed USB device number 8 using dwc_otg
[12840.810990] usb 1-1.3.4.2: New USB device found, idVendor=04e8, idProduct=341b
[12840.811043] usb 1-1.3.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[12840.811060] usb 1-1.3.4.2: Product: SCX-4200 Series
[12840.811074] usb 1-1.3.4.2: Manufacturer: Samsung
[12840.811087] usb 1-1.3.4.2: SerialNumber: 8T21BAIQ403726P.
[39705.359443] m920x_read = error: -71
[39705.359460] dvb-usb: error while querying for an remote control event.
[39705.360225] hub 1-1:1.0: port 3 disabled by hub (EMI?), re-enabling...
[39705.360253] usb 1-1.3: USB disconnect, device number 5
[39705.360264] usb 1-1.3.1: USB disconnect, device number 6
[39705.363049] dvb-usb: MSI Mega Sky 580 DVB-T USB2.0 successfully deinitialized and disconnected.
[39705.363461] usb 1-1.3.4: USB disconnect, device number 7
[39705.363478] usb 1-1.3.4.2: USB disconnect, device number 8
[39705.599473] usb 1-1.3: new high-speed USB device number 9 using dwc_otg
[39705.699937] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101
[39705.699959] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[39705.699969] usb 1-1.3: Product: USB 2.0 Hub [MTT]
[39705.701043] hub 1-1.3:1.0: USB hub found
[39705.701459] hub 1-1.3:1.0: 4 ports detected
[39705.979485] usb 1-1.3.1: new high-speed USB device number 10 using dwc_otg
[39706.087128] usb 1-1.3.1: New USB device found, idVendor=0db0, idProduct=5580
[39706.087150] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[39706.087159] usb 1-1.3.1: Product: DTV USB MINI
[39706.087169] usb 1-1.3.1: Manufacturer: ULi Electronics
[39706.093031] dvb-usb: found a 'MSI Mega Sky 580 DVB-T USB2.0' in warm state.
[39706.093157] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[39706.093818] DVB: registering new adapter (MSI Mega Sky 580 DVB-T USB2.0)
[39706.135708] DVB: Unable to find symbol mt352_attach()
[39706.135730] dvb-usb: no frontend was attached by 'MSI Mega Sky 580 DVB-T USB2.0'
[39706.136016] input: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.1/input/input1
[39706.136537] dvb-usb: schedule remote query interval to 100 msecs.
[39706.136559] dvb-usb: MSI Mega Sky 580 DVB-T USB2.0 successfully initialized and connected.
[39706.269378] usb 1-1.3.4: new high-speed USB device number 11 using dwc_otg
[39706.370023] usb 1-1.3.4: New USB device found, idVendor=1a40, idProduct=0101
[39706.370045] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[39706.370055] usb 1-1.3.4: Product: USB 2.0 Hub [MTT]
[39706.370719] hub 1-1.3.4:1.0: USB hub found
[39706.370906] hub 1-1.3.4:1.0: 4 ports detected
[39706.649449] usb 1-1.3.4.2: new high-speed USB device number 12 using dwc_otg
[39706.751184] usb 1-1.3.4.2: New USB device found, idVendor=04e8, idProduct=341b
[39706.751206] usb 1-1.3.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[39706.751216] usb 1-1.3.4.2: Product: SCX-4200 Series
[39706.751225] usb 1-1.3.4.2: Manufacturer: Samsung
[39706.751234] usb 1-1.3.4.2: SerialNumber: 8T21BAIQ403726P.
[43620.351959] m920x_read = error: -71
[43620.351977] dvb-usb: error while querying for an remote control event.
[43620.411150] usb 1-1.3.1: USB disconnect, device number 10
[43620.414405] dvb-usb: MSI Mega Sky 580 DVB-T USB2.0 successfully deinitialized and disconnected.
[45686.846027] usb 1-1.3.1: new high-speed USB device number 13 using dwc_otg
[45686.951051] usb 1-1.3.1: New USB device found, idVendor=0db0, idProduct=5580
[45686.951074] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[45686.951086] usb 1-1.3.1: Product: DTV USB MINI
[45686.951096] usb 1-1.3.1: Manufacturer: DTV USB MINI
[45686.954373] dvb-usb: found a 'MSI Mega Sky 580 DVB-T USB2.0' in cold state, will try to load a firmware
[45687.086879] dvb-usb: downloading firmware from file 'dvb-usb-megasky-02.fw'
[45688.097292] usb 1-1.3.1: USB disconnect, device number 13
[45688.336000] usb 1-1.3.1: new high-speed USB device number 14 using dwc_otg
[45688.443752] usb 1-1.3.1: New USB device found, idVendor=0db0, idProduct=5580
[45688.443773] usb 1-1.3.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[45688.443783] usb 1-1.3.1: Product: DTV USB MINI
[45688.443792] usb 1-1.3.1: Manufacturer: ULi Electronics
[45688.446781] dvb-usb: found a 'MSI Mega Sky 580 DVB-T USB2.0' in warm state.
[45688.446925] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[45688.447483] DVB: registering new adapter (MSI Mega Sky 580 DVB-T USB2.0)
[45688.473057] DVB: Unable to find symbol mt352_attach()
[45688.473078] dvb-usb: no frontend was attached by 'MSI Mega Sky 580 DVB-T USB2.0'
[45688.473359] input: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.1/input/input2
[45688.473610] dvb-usb: schedule remote query interval to 100 msecs.
[45688.473650] dvb-usb: MSI Mega Sky 580 DVB-T USB2.0 successfully initialized and connected.
[45805.668035] usb 1-1.3.1: USB disconnect, device number 14
[45805.672853] dvb-usb: MSI Mega Sky 580 DVB-T USB2.0 successfully deinitialized and disconnected.
[45814.869316] usb 1-1.3.3: new high-speed USB device number 15 using dwc_otg
[45814.970313] usb 1-1.3.3: New USB device found, idVendor=0413, idProduct=6f00
[45814.970336] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[45814.970347] usb 1-1.3.3: Product: STK7700
[45814.970357] usb 1-1.3.3: Manufacturer: DIBCOM
[45814.970366] usb 1-1.3.3: SerialNumber: 0000000001
[45815.209153] dvb-usb: found a 'Leadtek Winfast DTV Dongle (STK7700P based)' in cold state, will try to load a firmware
[45815.304340] dvb-usb: downloading firmware from file 'dvb-usb-dib0700-1.20.fw'
[45815.610957] dib0700: firmware started successfully.
[45816.119378] dvb-usb: found a 'Leadtek Winfast DTV Dongle (STK7700P based)' in warm state.
[45816.121746] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[45816.129852] DVB: registering new adapter (Leadtek Winfast DTV Dongle (STK7700P based))
[45816.429423] dib7000pc_detection: driver disabled by Kconfig
[45816.475554] DVB: Unable to find symbol dib7000p_attach()
[45816.475576] dvb-usb: no frontend was attached by 'Leadtek Winfast DTV Dongle (STK7700P based)'
[45816.559190] Registered IR keymap rc-dib0700-rc5
[45816.559691] input: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.3/rc/rc0/input3
[45816.562517] rc0: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.3/rc/rc0
[45816.569885] dvb-usb: schedule remote query interval to 50 msecs.
[45816.569912] dvb-usb: Leadtek Winfast DTV Dongle (STK7700P based) successfully initialized and connected.
[45816.570372] usbcore: registered new interface driver dvb_usb_dib0700
[99156.834926] usb 1-1.3.4.2: reset high-speed USB device number 12 using dwc_otg
[99334.429602] usb 1-1.3.4.2: reset high-speed USB device number 12 using dwc_otg
[100354.976409] usb 1-1.3.4.2: reset high-speed USB device number 12 using dwc_otg
[100554.111831] usb 1-1.3.4.2: reset high-speed USB device number 12 using dwc_otg
[100701.495606] usb 1-1.3.4.2: reset high-speed USB device number 12 using dwc_otg
[100847.509318] usb 1-1.3.4.2: reset high-speed USB device number 12 using dwc_otg
[101019.333788] usb 1-1.3.4.2: reset high-speed USB device number 12 using dwc_otg
[162129.351751] sd 0:0:0:0: [sda] Unhandled sense code
[162129.351784] sd 0:0:0:0: [sda]
[162129.351796] Result: hostbyte=0x07 driverbyte=0x08
[162129.351809] sd 0:0:0:0: [sda]
[162129.351817] Sense Key : 0x4 [current]
[162129.351839] sd 0:0:0:0: [sda]
[162129.351849] ASC=0x0 ASCQ=0x0
[162129.351863] sd 0:0:0:0: [sda] CDB:
[162129.351871] cdb[0]=0x2a: 2a 00 2d f9 c1 0f 00 00 08 00
[162129.351910] end_request: I/O error, dev sda, sector 771342607
[162129.351956] Buffer I/O error on device dm-12, logical block 3355930
[162129.352011] EXT4-fs warning (device dm-12): ext4_end_bio:250: I/O error writing to inode 794893 (offset 0 size 4096 starting block 3355930)
[162129.352145] JBD2: Detected IO errors while flushing file data on dm-12-8
[162149.072929] sd 0:0:0:0: [sda] Unhandled sense code
[162149.072963] sd 0:0:0:0: [sda]
[162149.072975] Result: hostbyte=0x07 driverbyte=0x08
[162149.072987] sd 0:0:0:0: [sda]
[162149.072995] Sense Key : 0x4 [current]
[162149.073016] sd 0:0:0:0: [sda]
[162149.073026] ASC=0x0 ASCQ=0x0
[162149.073041] sd 0:0:0:0: [sda] CDB:
[162149.073049] cdb[0]=0x2a: 2a 00 2d 66 f5 27 00 00 08 00
[162149.073088] end_request: I/O error, dev sda, sector 761722151
[162168.833100] sd 0:0:0:0: [sda] Unhandled sense code
[162168.833133] sd 0:0:0:0: [sda]
[162168.833145] Result: hostbyte=0x07 driverbyte=0x08
[162168.833157] sd 0:0:0:0: [sda]
[162168.833165] Sense Key : 0x4 [current]
[162168.833185] sd 0:0:0:0: [sda]
[162168.833194] ASC=0x0 ASCQ=0x0
[162168.833208] sd 0:0:0:0: [sda] CDB:
[162168.833217] cdb[0]=0x2a: 2a 00 2d 66 f5 2f 00 00 30 00
[162168.833257] end_request: I/O error, dev sda, sector 761722159
[162168.833457] Aborting journal on device dm-12-8.
[162168.833567] EXT4-fs error (device dm-12) in ext4_reserve_inode_write:4550: Journal has aborted
[162168.851692] EXT4-fs error (device dm-12) in ext4_reserve_inode_write:4550: Journal has aborted
[162188.593300] sd 0:0:0:0: [sda] Unhandled sense code
[162188.593332] sd 0:0:0:0: [sda]
[162188.593343] Result: hostbyte=0x07 driverbyte=0x08
[162188.593355] sd 0:0:0:0: [sda]
[162188.593363] Sense Key : 0x4 [current]
[162188.593384] sd 0:0:0:0: [sda]
[162188.593394] ASC=0x0 ASCQ=0x0
[162188.593409] sd 0:0:0:0: [sda] CDB:
[162188.593418] cdb[0]=0x2a: 2a 00 2d 64 18 3f 00 00 08 00
[162188.593456] end_request: I/O error, dev sda, sector 761534527
[162188.593498] Buffer I/O error on device dm-12, logical block 2129920
[162188.593509] lost page write due to I/O error on dm-12
[162188.593615] JBD2: Error -5 detected when updating journal superblock for dm-12-8.
[162208.314355] sd 0:0:0:0: [sda] Unhandled sense code
[162208.314389] sd 0:0:0:0: [sda]
[162208.314399] Result: hostbyte=0x07 driverbyte=0x08
[162208.314411] sd 0:0:0:0: [sda]
[162208.314420] Sense Key : 0x4 [current]
[162208.314440] sd 0:0:0:0: [sda]
[162208.314450] ASC=0x0 ASCQ=0x0
[162208.314464] sd 0:0:0:0: [sda] CDB:
[162208.314472] cdb[0]=0x2a: 2a 00 2c 60 18 3f 00 00 08 00
[162208.314510] end_request: I/O error, dev sda, sector 744495167
[162208.314554] Buffer I/O error on device dm-12, logical block 0
[162208.314566] lost page write due to I/O error on dm-12
[162208.314677] EXT4-fs error (device dm-12) in ext4_dirty_inode:4669: Journal has aborted
[162208.332557] ------------[ cut here ]------------
[162208.332665] WARNING: at fs/buffer.c:1106 mark_buffer_dirty+0xb8/0xdc()
[162208.332773] Modules linked in: rc_dib0700_rc5 dvb_usb_dib0700 dib3000mc dibx000_common xfs aes_generic xts gf128mul snd_bcm2835 snd_pcm snd_page_alloc snd_seq snd_seq_device snd_timer snd dm_crypt dm_mod evdev leds_gpio led_class dvb_usb_m920x dvb_usb dvb_core rc_core
[162208.332936] [<c0013a7c>] (unwind_backtrace+0x0/0xf0) from [<c001e2b4>] (warn_slowpath_common+0x4c/0x64)
[162208.332968] [<c001e2b4>] (warn_slowpath_common+0x4c/0x64) from [<c001e2e8>] (warn_slowpath_null+0x1c/0x24)
[162208.332994] [<c001e2e8>] (warn_slowpath_null+0x1c/0x24) from [<c00ebabc>] (mark_buffer_dirty+0xb8/0xdc)
[162208.333026] [<c00ebabc>] (mark_buffer_dirty+0xb8/0xdc) from [<c01405d0>] (ext4_commit_super+0xe0/0x1cc)
[162208.333051] [<c01405d0>] (ext4_commit_super+0xe0/0x1cc) from [<c0141488>] (__ext4_std_error+0xa0/0xb8)
[162208.333074] [<c0141488>] (__ext4_std_error+0xa0/0xb8) from [<c014151c>] (__ext4_journal_stop+0x7c/0x88)
[162208.333106] [<c014151c>] (__ext4_journal_stop+0x7c/0x88) from [<c00e2fb0>] (__mark_inode_dirty+0x2c/0x220)
[162208.333138] [<c00e2fb0>] (__mark_inode_dirty+0x2c/0x220) from [<c00d8c40>] (update_time+0xac/0xbc)
[162208.333161] [<c00d8c40>] (update_time+0xac/0xbc) from [<c00d8e48>] (touch_atime+0x108/0x180)
[162208.333202] [<c00d8e48>] (touch_atime+0x108/0x180) from [<c008fdac>] (generic_file_aio_read+0x5fc/0x77c)
[162208.333241] [<c008fdac>] (generic_file_aio_read+0x5fc/0x77c) from [<c00c00f4>] (do_sync_read+0x90/0xd4)
[162208.333267] [<c00c00f4>] (do_sync_read+0x90/0xd4) from [<c00c0b78>] (vfs_read+0x98/0x16c)
[162208.333289] [<c00c0b78>] (vfs_read+0x98/0x16c) from [<c00c0c84>] (sys_read+0x38/0x70)
[162208.333320] [<c00c0c84>] (sys_read+0x38/0x70) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[162208.333332] ---[ end trace a5b165f78310082a ]---
[162228.074654] sd 0:0:0:0: [sda] Unhandled sense code
[162228.074686] sd 0:0:0:0: [sda]
[162228.074697] Result: hostbyte=0x07 driverbyte=0x08
[162228.074708] sd 0:0:0:0: [sda]
[162228.074716] Sense Key : 0x4 [current]
[162228.074737] sd 0:0:0:0: [sda]
[162228.074745] ASC=0x0 ASCQ=0x0
[162228.074760] sd 0:0:0:0: [sda] CDB:
[162228.074769] cdb[0]=0x2a: 2a 00 2c 60 18 3f 00 00 08 00
[162228.074807] end_request: I/O error, dev sda, sector 744495167
[162228.074849] Buffer I/O error on device dm-12, logical block 0
[162228.074860] lost page write due to I/O error on dm-12
[162228.074983] EXT4-fs error (device dm-12) in ext4_dirty_inode:4669: Journal has aborted
[162247.837223] sd 0:0:0:0: [sda] Unhandled sense code
[162247.837255] sd 0:0:0:0: [sda]
[162247.837267] Result: hostbyte=0x07 driverbyte=0x08
[162247.837279] sd 0:0:0:0: [sda]
[162247.837287] Sense Key : 0x4 [current]
[162247.837308] sd 0:0:0:0: [sda]
[162247.837318] ASC=0x0 ASCQ=0x0
[162247.837332] sd 0:0:0:0: [sda] CDB:
[162247.837340] cdb[0]=0x2a: 2a 00 2c 60 18 3f 00 00 08 00
[162247.837378] end_request: I/O error, dev sda, sector 744495167
[162247.837422] Buffer I/O error on device dm-12, logical block 0
[162247.837434] lost page write due to I/O error on dm-12
[162247.837808] EXT4-fs (dm-12): previous I/O error to superblock detected
xnosek00
Re: usb disk - data corruption - due to overlocking?
Fri Jan 11, 2013 5:46 pm
next fail. Still overlocked 1GHz. Yesterday I had SD card corruption. Today I have USB disk (sdb) mount: page allocation failure.
[ 0.000703] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.040093] pid_max: default: 32768 minimum: 301
[ 0.040328] Mount-cache hash table entries: 512
[ 0.040928] Initializing cgroup subsys devices
[ 0.040949] Initializing cgroup subsys freezer
[ 0.040969] Initializing cgroup subsys blkio
[ 0.041036] CPU: Testing write buffer coherency: ok
[ 0.041281] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.041392] Setting up static identity map for 0x39c438 - 0x39c494
[ 0.042491] devtmpfs: initialized
[ 0.049526] NET: Registered protocol family 16
[ 0.053894] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.054789] bcm2708.uart_clock = 0
[ 0.055688] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.055725] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.055749] mailbox: Broadcom VideoCore Mailbox driver
[ 0.055816] bcm2708_vcio: mailbox at f200b880
[ 0.055880] bcm_power: Broadcom power driver
[ 0.055906] bcm_power_open() -> 0
[ 0.055922] bcm_power_request(0, 8)
[ 0.556505] bcm_mailbox_read -> 00000080, 0
[ 0.556532] bcm_power_request -> 0
[ 0.556549] Serial: AMBA PL011 UART driver
[ 0.556652] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.887194] console [ttyAMA0] enabled
[ 0.903940] bio: create slab <bio-0> at 0
[ 0.908616] SCSI subsystem initialized
[ 0.912528] usbcore: registered new interface driver usbfs
[ 0.918147] usbcore: registered new interface driver hub
[ 0.923627] usbcore: registered new device driver usb
[ 0.929709] Switching to clocksource stc
[ 0.933785] FS-Cache: Loaded
[ 0.936845] CacheFiles: Loaded
[ 0.947676] NET: Registered protocol family 2
[ 0.952621] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.960437] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.967327] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.973949] TCP: reno registered
[ 0.977195] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.983050] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.989595] NET: Registered protocol family 1
[ 0.994364] RPC: Registered named UNIX socket transport module.
[ 1.000301] RPC: Registered udp transport module.
[ 1.005067] RPC: Registered tcp transport module.
[ 1.009775] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.016786] bcm2708_dma: DMA manager at f2007000
[ 1.021469] bcm2708_gpio: bcm2708_gpio_probe c0513d58
[ 1.026818] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.035681] audit: initializing netlink socket (disabled)
[ 1.041130] type=2000 audit(0.880:1): initialized
[ 1.127989] VFS: Disk quotas dquot_6.5.2
[ 1.131992] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.138889] FS-Cache: Netfs 'nfs' registered for caching
[ 1.144501] NFS: Registering the id_resolver key type
[ 1.149632] Key type id_resolver registered
[ 1.153889] Key type id_legacy registered
[ 1.158149] msgmni has been set to 749
[ 1.163063] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.170751] io scheduler noop registered
[ 1.174755] io scheduler deadline registered (default)
[ 1.179923] io scheduler cfq registered
[ 1.215510] Console: switching to colour frame buffer device 160x64
[ 1.235342] kgdb: Registered I/O driver kgdboc.
[ 1.240430] vc-cma: Videocore CMA driver
[ 1.244483] vc-cma: vc_cma_base = 0x00000000
[ 1.249264] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.254767] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.266600] brd: module loaded
[ 1.273213] loop: module loaded
[ 1.276760] vchiq: vchiq_init_state: slot_zero = 0xd7000000, is_master = 0
[ 1.284379] Loading iSCSI transport class v2.0-870.
[ 1.290191] usbcore: registered new interface driver smsc95xx
[ 1.296346] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.507388] Core Release: 2.80a
[ 1.510635] Setting default values for core params
[ 1.515640] Finished setting default values for core params
[ 1.726371] Using Buffer DMA mode
[ 1.729783] Periodic Transfer Interrupt Enhancement - disabled
[ 1.735768] Multiprocessor Interrupt Enhancement - disabled
[ 1.741467] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.745957] Dedicated Tx FIFOs mode
[ 1.750472] dwc_otg: Microframe scheduler enabled
[ 1.750849] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.755991] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.763460] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.769180] Init: Port Power? op_state=1
[ 1.773200] Init: Power Port (0)
[ 1.776641] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.783593] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.791111] usb usb1: Product: DWC OTG Controller
[ 1.795973] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[ 1.801853] usb usb1: SerialNumber: bcm2708_usb
[ 1.813062] hub 1-0:1.0: USB hub found
[ 1.822766] hub 1-0:1.0: 1 port detected
[ 1.832932] dwc_otg: FIQ enabled
[ 1.832952] dwc_otg: NAK holdoff enabled
[ 1.832970] Module dwc_common_port init
[ 1.833218] Initializing USB Mass Storage driver...
[ 1.844156] usbcore: registered new interface driver usb-storage
[ 1.855990] USB Mass Storage support registered.
[ 1.866644] usbcore: registered new interface driver libusual
[ 1.878598] mousedev: PS/2 mouse device common for all mice
[ 1.890753] bcm2835-cpufreq: min=700000 max=1000000 cur=1000000
[ 1.896764] bcm2835-cpufreq: switching to governor powersavebcm2835-cpufreq: switching to governor powersave
[ 1.912755] cpuidle: using governor ladder
[ 1.929867] cpuidle: using governor menu
[ 1.940295] sdhci: Secure Digital Host Controller Interface driver
[ 1.952974] sdhci: Copyright(c) Pierre Ossman
[ 1.963909] sdhci: Enable low-latency mode
[ 2.013910] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.028263] Indeed it is in host mode hprt0 = 00021501
[ 2.045940] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.083838] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.104161] usbcore: registered new interface driver usbhid
[ 2.133701] usbhid: USB HID core driver
[ 2.155940] mmc0: could read SD Status register (SSR) at the 3th attempt
[ 2.169426] TCP: cubic registered
[ 2.193833] Initializing XFRM netlink socket
[ 2.205897] NET: Registered protocol family 17
[ 2.217381] Key type dns_resolver registered
[ 2.228344] mmc0: new high speed SDHC card at address aaaa
[ 2.240817] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.255926] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[ 2.268029] registered taskstats version 1
[ 2.280561] mmcblk0: p1 p2
[ 2.305426] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.320359] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.333174] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.346946] Indeed it is in host mode hprt0 = 00001101
[ 2.366326] devtmpfs: mounted
[ 2.384686] Freeing init memory: 128K
[ 2.574116] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.588332] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.604911] hub 1-1:1.0: USB hub found
[ 2.615693] hub 1-1:1.0: 3 ports detected
[ 2.904007] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.034388] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.060946] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.093267] smsc95xx v1.0.4
[ 3.169199] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:65:03:d4
[ 3.284065] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.395476] usb 1-1.2: New USB device found, idVendor=152d, idProduct=2329
[ 3.421546] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 3.451988] usb 1-1.2: Product: USB to ATA/ATAPI bridge
[ 3.480950] usb 1-1.2: Manufacturer: JMicron
[ 3.503817] usb 1-1.2: SerialNumber: DCAA030589FF
[ 3.534428] usb-storage 1-1.2:1.0: Quirks match for vid 152d pid 2329: 8020
[ 3.564021] scsi0 : usb-storage 1-1.2:1.0
[ 3.664112] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 3.794754] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101
[ 3.820448] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.836029] usb 1-1.3: Product: USB 2.0 Hub [MTT]
[ 3.849630] hub 1-1.3:1.0: USB hub found
[ 3.862053] hub 1-1.3:1.0: 4 ports detected
[ 4.067611] udevd[144]: starting version 175
[ 4.154057] usb 1-1.3.3: new high-speed USB device number 6 using dwc_otg
[ 4.286477] usb 1-1.3.3: New USB device found, idVendor=0413, idProduct=6f00
[ 4.323820] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.371252] usb 1-1.3.3: Product: STK7700
[ 4.393517] usb 1-1.3.3: Manufacturer: DIBCOM
[ 4.421295] usb 1-1.3.3: SerialNumber: 0000000001
[ 4.543971] usb 1-1.3.4: new high-speed USB device number 7 using dwc_otg
[ 4.616690] scsi 0:0:0:0: Direct-Access WDC WD20 EARX-00PASB0 PQ: 0 ANSI: 2 CCS
[ 4.663667] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 4.679860] usb 1-1.3.4: New USB device found, idVendor=1a40, idProduct=0101
[ 4.719921] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.744541] sd 0:0:0:0: [sda] Write Protect is off
[ 4.783884] sd 0:0:0:0: [sda] Mode Sense: 28 00 00 00
[ 4.784076] usb 1-1.3.4: Product: USB 2.0 Hub [MTT]
[ 4.797191] sd 0:0:0:0: [sda] No Caching mode page present
[ 4.833790] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 4.848564] hub 1-1.3.4:1.0: USB hub found
[ 4.883857] hub 1-1.3.4:1.0: 4 ports detected
[ 4.906046] sd 0:0:0:0: [sda] No Caching mode page present
[ 4.946393] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 5.214102] usb 1-1.3.4.2: new high-speed USB device number 8 using dwc_otg
[ 5.365958] usb 1-1.3.4.2: New USB device found, idVendor=04e8, idProduct=341b
[ 5.385166] sda: sda1
[ 5.404839] usb 1-1.3.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.422989] sd 0:0:0:0: [sda] No Caching mode page present
[ 5.449795] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 5.468809] usb 1-1.3.4.2: Product: SCX-4200 Series
[ 5.493802] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.506149] usb 1-1.3.4.2: Manufacturer: Samsung
[ 5.533821] usb 1-1.3.4.2: SerialNumber: 8T21BAIQ403726P.
[ 5.772745] dvb-usb: found a 'Leadtek Winfast DTV Dongle (STK7700P based)' in warm state.
[ 5.949210] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 5.977510] Registered led device: led0
[ 6.050365] DVB: registering new adapter (Leadtek Winfast DTV Dongle (STK7700P based))
[ 6.504009] dib7000pc_detection: driver disabled by Kconfig
[ 6.749189] DVB: Unable to find symbol dib7000p_attach()
[ 6.932913] dvb-usb: no frontend was attached by 'Leadtek Winfast DTV Dongle (STK7700P based)'
[ 7.135281] Registered IR keymap rc-dib0700-rc5
[ 7.214447] input: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.3/rc/rc0/input0
[ 7.345423] rc0: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.3/rc/rc0
[ 7.429951] dvb-usb: schedule remote query interval to 50 msecs.
[ 7.458783] dvb-usb: Leadtek Winfast DTV Dongle (STK7700P based) successfully initialized and connected.
[ 7.476889] dib0700: rc submit urb failed
[ 7.476889]
[ 7.501042] usbcore: registered new interface driver dvb_usb_dib0700
[ 8.608732] device-mapper: ioctl: 4.23.0-ioctl (2012-07-25) initialised: [email protected]
[ 12.255318] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.725870] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 13.784406] bcm2835 ALSA card created!
[ 13.810436] bcm2835 ALSA chip created!
[ 13.827981] bcm2835 ALSA chip created!
[ 13.842577] bcm2835 ALSA chip created!
[ 13.857062] bcm2835 ALSA chip created!
[ 13.871476] bcm2835 ALSA chip created!
[ 13.885906] bcm2835 ALSA chip created!
[ 13.900332] bcm2835 ALSA chip created!
[ 24.171197] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 26.361512] bcm2835-cpufreq: switching to governor ondemand
[ 26.361546] bcm2835-cpufreq: switching to governor ondemand<6>[ 28.965557] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SS
[ 32.024566] warning: process `colord-sane' used the deprecated sysctl system call with 8.1.2.
[ 253.280040] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[ 253.301093] XFS (dm-7): Mounting Filesystem
[ 255.530073] XFS (dm-7): Ending clean mount
[ 255.800644] mount: page allocation failure: order:5, mode:0xd0
[ 255.800694] [<c0013a7c>] (unwind_backtrace+0x0/0xf0) from [<c00926dc>] (warn_alloc_failed+0xc4/0x11c)
[ 255.800717] [<c00926dc>] (warn_alloc_failed+0xc4/0x11c) from [<c00949ec>] (__alloc_pages_nodemask+0x3e0/0x63c)
[ 255.800740] [<c00949ec>] (__alloc_pages_nodemask+0x3e0/0x63c) from [<c00bbf48>] (cache_alloc_refill+0x338/0x6a0)
[ 255.800757] [<c00bbf48>] (cache_alloc_refill+0x338/0x6a0) from [<c00bc374>] (__kmalloc+0xc4/0x11c)
[ 255.800776] [<c00bc374>] (__kmalloc+0xc4/0x11c) from [<c013fe50>] (ext4_kvzalloc+0x14/0x3c)
[ 255.800795] [<c013fe50>] (ext4_kvzalloc+0x14/0x3c) from [<c0145460>] (ext4_fill_super+0x22dc/0x26c8)
[ 255.800812] [<c0145460>] (ext4_fill_super+0x22dc/0x26c8) from [<c00c3680>] (mount_bdev+0x1a4/0x1e0)
[ 255.800828] [<c00c3680>] (mount_bdev+0x1a4/0x1e0) from [<c013e6ec>] (ext4_mount+0x14/0x20)
[ 255.800842] [<c013e6ec>] (ext4_mount+0x14/0x20) from [<c00c40e8>] (mount_fs+0x14/0xd0)
[ 255.800856] [<c00c40e8>] (mount_fs+0x14/0xd0) from [<c00dc688>] (vfs_kern_mount+0x4c/0xc0)
[ 255.800870] [<c00dc688>] (vfs_kern_mount+0x4c/0xc0) from [<c00dc754>] (do_kern_mount+0x34/0xd0)
[ 255.800886] [<c00dc754>] (do_kern_mount+0x34/0xd0) from [<c00de25c>] (do_mount+0x114/0x708)
[ 255.800901] [<c00de25c>] (do_mount+0x114/0x708) from [<c00de8d4>] (sys_mount+0x84/0xc4)
[ 255.800921] [<c00de8d4>] (sys_mount+0x84/0xc4) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[ 255.800927] Mem-info:
[ 255.800932] Normal per-cpu:
[ 255.800939] CPU 0: hi: 186, btch: 31 usd: 0
[ 255.800956] active_anon:20046 inactive_anon:20100 isolated_anon:0
[ 255.800956] active_file:13366 inactive_file:26776 isolated_file:32
[ 255.800956] unevictable:463 dirty:0 writeback:11 unstable:0
[ 255.800956] free:8131 slab_reclaimable:1514 slab_unreclaimable:1882
[ 255.800956] mapped:12757 shmem:166 pagetables:645 bounce:0
[ 255.800992] Normal free:32524kB min:8192kB low:10240kB high:12288kB active_anon:80184kB inactive_anon:80400kB active_file:53464kB inactive_file:107104kB unevictable:1852kB isolated(anon):0kB isolated(file):128kB present:390144kB mlocked:1852kB dirty:0kB writeback:44kB mapped:51028kB shmem:664kB slab_reclaimable:6056kB slab_unreclaimable:7528kB kernel_stack:2520kB pagetables:2580kB unstable:0kB bounce:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[ 255.800999] lowmem_reserve[]: 0 0
[ 255.801011] Normal: 2855*4kB 1228*8kB 363*16kB 133*32kB 17*64kB 1*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 32524kB
[ 255.801039] 40701 total pagecache pages
[ 255.801045] 0 pages in swap cache
[ 255.801051] Swap cache stats: add 0, delete 0, find 0/0
[ 255.801055] Free swap = 102396kB
[ 255.801060] Total swap = 102396kB
[ 255.854599] 98304 pages of RAM
[ 255.854615] 8886 free pages
[ 255.854620] 2364 reserved pages
[ 255.854625] 3396 slab pages
[ 255.854629] 297826 pages shared
[ 255.854634] 0 pages swap cached
[ 255.854643] SLAB: Unable to allocate memory on node 0 (gfp=0xd0)
[ 255.854653] cache: size-131072, object size: 131072, order: 5
[ 255.854661] node 0: slabs: 0/0, objs: 0/0, free: 0
[ 255.924511] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
[ 256.185592] XFS (dm-9): Mounting Filesystem
[ 258.696944] XFS (dm-9): Ending clean mount
[ 258.925005] XFS (dm-10): Mounting Filesystem
[ 260.887149] XFS (dm-10): Ending clean mount
[ 261.217692] EXT4-fs (dm-11): mounted filesystem with ordered data mode. Opts: (null)
[ 261.483958] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null)
[52694.280196] usb 1-1.3.4.2: reset high-speed USB device number 8 using dwc_otg
[56529.672122] hub 1-1:1.0: port 2 disabled by hub (EMI?), re-enabling...
[56529.672161] usb 1-1.2: USB disconnect, device number 4
[56529.924764] usb 1-1.2: new high-speed USB device number 9 using dwc_otg
[56530.046363] usb 1-1.2: New USB device found, idVendor=152d, idProduct=2329
[56530.046383] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[56530.046393] usb 1-1.2: Product: USB to ATA/ATAPI bridge
[56530.046402] usb 1-1.2: Manufacturer: JMicron
[56530.046411] usb 1-1.2: SerialNumber: DCAA030589FF
[56530.053194] usb-storage 1-1.2:1.0: Quirks match for vid 152d pid 2329: 8020
[56530.055400] scsi1 : usb-storage 1-1.2:1.0
[56530.056772] hub 1-1:1.0: port 3 disabled by hub (EMI?), re-enabling...
[56530.056800] usb 1-1.3: USB disconnect, device number 5
[56530.056811] usb 1-1.3.3: USB disconnect, device number 6
[56530.072619] dvb-usb: Leadtek Winfast DTV Dongle (STK7700P based) successfully deinitialized and disconnected.
[56530.073000] usb 1-1.3.4: USB disconnect, device number 7
[56530.073008] usb 1-1.3.4.2: USB disconnect, device number 8
[56530.324821] usb 1-1.3: new high-speed USB device number 10 using dwc_otg
[56530.425326] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101
[56530.425347] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[56530.425357] usb 1-1.3: Product: USB 2.0 Hub [MTT]
[56530.427884] hub 1-1.3:1.0: USB hub found
[56530.428098] hub 1-1.3:1.0: 4 ports detected
[56530.704874] usb 1-1.3.3: new high-speed USB device number 11 using dwc_otg
[56530.806395] usb 1-1.3.3: New USB device found, idVendor=0413, idProduct=6f00
[56530.806415] usb 1-1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[56530.806425] usb 1-1.3.3: Product: STK7700
[56530.806433] usb 1-1.3.3: Manufacturer: DIBCOM
[56530.806441] usb 1-1.3.3: SerialNumber: 0000000001
[56530.809527] dvb-usb: found a 'Leadtek Winfast DTV Dongle (STK7700P based)' in warm state.
[56530.809671] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[56530.809970] DVB: registering new adapter (Leadtek Winfast DTV Dongle (STK7700P based))
[56531.014981] dib7000pc_detection: driver disabled by Kconfig
[56531.049971] DVB: Unable to find symbol dib7000p_attach()
[56531.050002] dvb-usb: no frontend was attached by 'Leadtek Winfast DTV Dongle (STK7700P based)'
[56531.050036] Registered IR keymap rc-dib0700-rc5
[56531.050801] input: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.3/rc/rc1/input1
[56531.051724] rc1: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.3/rc/rc1
[56531.052240] dvb-usb: schedule remote query interval to 50 msecs.
[56531.052272] dvb-usb: Leadtek Winfast DTV Dongle (STK7700P based) successfully initialized and connected.
[56531.052472] dib0700: rc submit urb failed
[56531.052472]
[56531.144995] usb 1-1.3.4: new high-speed USB device number 12 using dwc_otg
[56531.246016] usb 1-1.3.4: New USB device found, idVendor=1a40, idProduct=0101
[56531.246047] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[56531.246062] usb 1-1.3.4: Product: USB 2.0 Hub [MTT]
[56531.247029] hub 1-1.3.4:1.0: USB hub found
[56531.248410] hub 1-1.3.4:1.0: 4 ports detected
[56531.524852] usb 1-1.3.4.2: new high-speed USB device number 13 using dwc_otg
[56531.626699] usb 1-1.3.4.2: New USB device found, idVendor=04e8, idProduct=341b
[56531.626720] usb 1-1.3.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[56531.626730] usb 1-1.3.4.2: Product: SCX-4200 Series
[56531.626740] usb 1-1.3.4.2: Manufacturer: Samsung
[56531.626748] usb 1-1.3.4.2: SerialNumber: 8T21BAIQ403726P.
[56533.088388] scsi 1:0:0:0: Direct-Access WDC WD20 EARX-00PASB0 PQ: 0 ANSI: 2 CCS
[56538.455045] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[56538.456239] sd 1:0:0:0: [sdb] Write Protect is off
[56538.456275] sd 1:0:0:0: [sdb] Mode Sense: 28 00 00 00
[56538.457376] sd 1:0:0:0: [sdb] No Caching mode page present
[56538.457409] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[56538.464112] sd 1:0:0:0: [sdb] No Caching mode page present
[56538.464147] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[56538.474607] sdb: sdb1
[56538.485851] sd 1:0:0:0: [sdb] No Caching mode page present
[56538.485884] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[56538.485902] sd 1:0:0:0: [sdb] Attached SCSI disk
RobHenry
Fri Jan 11, 2013 9:13 pm
I have eliminated ext4 corruption by use of a usb drive for the rootfs. I hope it's not overclocking that has caused your problem because I'd assumed that it only affected the sd card.
Have you tried scaling back the oc to see if that resolves the issue?
xnosek00
Sat Jan 12, 2013 12:00 pm
Thank you for a tip about eliminating ext4 corruption.
But now about my problem. I'm trying to run RasPi at 700 MHz right now. I will write a report, after a week.
xnosek00
Re: usb disk - data corruption - due to overclocking?
Fri Jan 18, 2013 1:57 pm
NOT OVERLOCKED, but still unstable.
What's wrong? It can be so unstable.
[ 0.000000] Linux version 3.6.11+ ([email protected]) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #358 PREEMPT Tue Jan 15 00:45:33 GMT 2013
[ 0.000000] free_area_init_node: node 0, pgdat c053b834, node_mem_map c05e5000
[ 0.000000] Memory: 367240k/367240k available, 25976k reserved, 0K highmem
[ 0.000000] .text : 0xc0008000 - 0xc04e5460 (4982 kB)
[ 0.000000] .init : 0xc04e6000 - 0xc0506f24 ( 132 kB)
[ 0.000000] .data : 0xc0508000 - 0xc053c060 ( 209 kB)
[ 0.000000] .bss : 0xc053c084 - 0xc05e4738 ( 674 kB)
[ 0.001034] Calibrating delay loop... 464.48 BogoMIPS (lpj=2322432)
[ 0.060062] pid_max: default: 32768 minimum: 301
[ 0.060414] Mount-cache hash table entries: 512
[ 0.061183] Initializing cgroup subsys cpuacct
[ 0.061237] Initializing cgroup subsys devices
[ 0.061271] Initializing cgroup subsys freezer
[ 0.061301] Initializing cgroup subsys blkio
[ 0.061392] CPU: Testing write buffer coherency: ok
[ 0.061729] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.061871] Setting up static identity map for 0x39d198 - 0x39d1f4
[ 0.063379] devtmpfs: initialized
[ 0.074394] NET: Registered protocol family 16
[ 0.080954] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.082179] bcm2708.uart_clock = 0
[ 0.083519] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.083573] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.083609] mailbox: Broadcom VideoCore Mailbox driver
[ 0.083703] bcm2708_vcio: mailbox at f200b880
[ 0.083803] bcm_power: Broadcom power driver
[ 0.083841] bcm_power_open() -> 0
[ 0.083866] bcm_power_request(0, 8)
[ 0.584557] bcm_mailbox_read -> 00000080, 0
[ 0.584598] bcm_power_request -> 0
[ 0.584624] Serial: AMBA PL011 UART driver
[ 0.584769] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.915591] console [ttyAMA0] enabled
[ 0.939173] bio: create slab <bio-0> at 0
[ 0.944058] SCSI subsystem initialized
[ 0.948152] usbcore: registered new interface driver usbfs
[ 0.953736] usbcore: registered new interface driver hub
[ 0.959331] usbcore: registered new device driver usb
[ 0.965806] Switching to clocksource stc
[ 0.970053] FS-Cache: Loaded
[ 0.973191] CacheFiles: Loaded
[ 0.988017] NET: Registered protocol family 2
[ 0.993298] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.001035] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 1.007826] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.014431] TCP: reno registered
[ 1.017684] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.023582] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.030155] NET: Registered protocol family 1
[ 1.035023] RPC: Registered named UNIX socket transport module.
[ 1.041067] RPC: Registered udp transport module.
[ 1.045790] RPC: Registered tcp transport module.
[ 1.050533] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.057774] bcm2708_dma: DMA manager at f2007000
[ 1.062560] bcm2708_gpio: bcm2708_gpio_probe c0515d98
[ 1.068022] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.077203] audit: initializing netlink socket (disabled)
[ 1.082803] type=2000 audit(0.930:1): initialized
[ 1.205937] VFS: Disk quotas dquot_6.5.2
[ 1.210080] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.217039] FS-Cache: Netfs 'nfs' registered for caching
[ 1.222784] NFS: Registering the id_resolver key type
[ 1.227946] Key type id_resolver registered
[ 1.232240] Key type id_legacy registered
[ 1.236610] msgmni has been set to 749
[ 1.242126] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.249834] io scheduler noop registered
[ 1.253881] io scheduler deadline registered (default)
[ 1.259077] io scheduler cfq registered
[ 1.298138] Console: switching to colour frame buffer device 160x64
[ 1.319555] kgdb: Registered I/O driver kgdboc.
[ 1.324911] vc-cma: Videocore CMA driver
[ 1.328952] vc-cma: vc_cma_base = 0x00000000
[ 1.333817] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.339339] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.353962] brd: module loaded
[ 1.362154] loop: module loaded
[ 1.365759] vchiq: vchiq_init_state: slot_zero = 0xd7000000, is_master = 0
[ 1.373614] Loading iSCSI transport class v2.0-870.
[ 1.379505] usbcore: registered new interface driver smsc95xx
[ 1.385676] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.596785] Core Release: 2.80a
[ 1.600116] Setting default values for core params
[ 1.605058] Finished setting default values for core params
[ 1.815861] Using Buffer DMA mode
[ 1.819274] Periodic Transfer Interrupt Enhancement - disabled
[ 1.825267] Multiprocessor Interrupt Enhancement - disabled
[ 1.830997] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.835463] Dedicated Tx FIFOs mode
[ 1.840057] dwc_otg: Microframe scheduler enabled
[ 1.840474] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.845548] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.853081] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.858763] Init: Port Power? op_state=1
[ 1.862881] Init: Power Port (0)
[ 1.866306] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.873300] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.880722] usb usb1: Product: DWC OTG Controller
[ 1.885544] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[ 1.891446] usb usb1: SerialNumber: bcm2708_usb
[ 1.902147] hub 1-0:1.0: USB hub found
[ 1.911279] hub 1-0:1.0: 1 port detected
[ 1.920760] dwc_otg: FIQ enabled
[ 1.920780] dwc_otg: NAK holdoff enabled
[ 1.920802] Module dwc_common_port init
[ 1.921032] Initializing USB Mass Storage driver...
[ 1.931436] usbcore: registered new interface driver usb-storage
[ 1.942681] USB Mass Storage support registered.
[ 1.952635] usbcore: registered new interface driver libusual
[ 1.963909] mousedev: PS/2 mouse device common for all mice
[ 1.975508] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 1.981373] bcm2835-cpufreq: switching to governor powersavebcm2835-cpufreq: switching to governor powersave
[ 1.996656] cpuidle: using governor ladder
[ 2.011467] cpuidle: using governor menu
[ 2.020890] sdhci: Secure Digital Host Controller Interface driver
[ 2.032491] sdhci: Copyright(c) Pierre Ossman
[ 2.042286] sdhci: Enable low-latency mode
[ 2.090104] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.103520] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.116978] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.130288] Indeed it is in host mode hprt0 = 00021501
[ 2.144578] usbcore: registered new interface driver usbhid
[ 2.160477] usbhid: USB HID core driver
[ 2.190677] TCP: cubic registered
[ 2.209931] Initializing XFRM netlink socket
[ 2.225008] NET: Registered protocol family 17
[ 2.237981] mmc0: new high speed SDHC card at address aaaa
[ 2.260122] Key type dns_resolver registered
[ 2.270622] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[ 2.290257] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.305091] mmcblk0: p1 p2
[ 2.315972] registered taskstats version 1
[ 2.340454] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.354286] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.374106] devtmpfs: mounted
[ 2.383105] Freeing init memory: 128K
[ 2.430011] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.442826] Indeed it is in host mode hprt0 = 00001101
[ 2.660353] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.673447] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.688140] hub 1-1:1.0: USB hub found
[ 2.697815] hub 1-1:1.0: 3 ports detected
[ 2.980256] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.100728] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.113472] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.130771] smsc95xx v1.0.4
[ 3.204797] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:65:03:d4
[ 3.330251] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.481398] usb 1-1.2: New USB device found, idVendor=152d, idProduct=2329
[ 3.510041] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 3.532651] usb 1-1.2: Product: USB to ATA/ATAPI bridge
[ 3.544051] usb 1-1.2: Manufacturer: JMicron
[ 3.554221] usb 1-1.2: SerialNumber: DCAA030589FF
[ 3.568247] usb-storage 1-1.2:1.0: Quirks match for vid 152d pid 2329: 8020
[ 3.581578] scsi0 : usb-storage 1-1.2:1.0
[ 3.690177] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 3.830925] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101
[ 3.855835] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.869428] usb 1-1.3: Product: USB 2.0 Hub [MTT]
[ 3.890934] hub 1-1.3:1.0: USB hub found
[ 3.910067] hub 1-1.3:1.0: 4 ports detected
[ 4.018961] udevd[143]: starting version 175
[ 4.210246] usb 1-1.3.4: new high-speed USB device number 6 using dwc_otg
[ 4.350993] usb 1-1.3.4: New USB device found, idVendor=1a40, idProduct=0101
[ 4.388086] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.439988] usb 1-1.3.4: Product: USB 2.0 Hub [MTT]
[ 4.463155] hub 1-1.3.4:1.0: USB hub found
[ 4.493092] hub 1-1.3.4:1.0: 4 ports detected
[ 4.632704] scsi 0:0:0:0: Direct-Access WDC WD20 EARX-00PASB0 PQ: 0 ANSI: 2 CCS
[ 4.671731] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 4.715717] sd 0:0:0:0: [sda] Write Protect is off
[ 4.746799] sd 0:0:0:0: [sda] Mode Sense: 28 00 00 00
[ 4.747857] sd 0:0:0:0: [sda] No Caching mode page present
[ 4.788595] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 4.801432] usb 1-1.3.4.1: new high-speed USB device number 7 using dwc_otg
[ 4.843216] sd 0:0:0:0: [sda] No Caching mode page present
[ 4.879231] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 4.942633] usb 1-1.3.4.1: New USB device found, idVendor=0413, idProduct=6f00
[ 4.980035] usb 1-1.3.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.028474] usb 1-1.3.4.1: Product: STK7700
[ 5.058612] usb 1-1.3.4.1: Manufacturer: DIBCOM
[ 5.087950] usb 1-1.3.4.1: SerialNumber: 0000000001
[ 5.210289] usb 1-1.3.4.2: new high-speed USB device number 8 using dwc_otg
[ 5.319633] sda: sda1
[ 5.342229] usb 1-1.3.4.2: New USB device found, idVendor=04e8, idProduct=341b
[ 5.358547] sd 0:0:0:0: [sda] No Caching mode page present
[ 5.380033] usb 1-1.3.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.394418] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 5.419738] usb 1-1.3.4.2: Product: SCX-4200 Series
[ 5.436698] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.457470] usb 1-1.3.4.2: Manufacturer: Samsung
[ 5.476549] usb 1-1.3.4.2: SerialNumber: 8T21BAIQ403726P.
[ 5.800683] Registered led device: led0
[ 7.739694] dvb-usb: found a 'Leadtek Winfast DTV Dongle (STK7700P based)' in warm state.
[ 7.768629] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 7.784133] DVB: registering new adapter (Leadtek Winfast DTV Dongle (STK7700P based))
[ 8.207632] DVB: registering adapter 0 frontend 0 (DiBcom 7000MA/MB/PA/PB/MC)...
[ 8.247592] device-mapper: ioctl: 4.23.0-ioctl (2012-07-25) initialised: [email protected]
[ 8.322236] MT2060: successfully identified (IF1 = 1220)
[ 8.979918] Registered IR keymap rc-dib0700-rc5
[ 9.000015] input: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.4/1-1.3.4.1/rc/rc0/input0
[ 9.025153] rc0: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.4/1-1.3.4.1/rc/rc0
[ 9.044190] dvb-usb: schedule remote query interval to 50 msecs.
[ 9.062992] dvb-usb: Leadtek Winfast DTV Dongle (STK7700P based) successfully initialized and connected.
[ 9.092670] dib0700: rc submit urb failed
[ 9.092670]
[ 9.128396] usbcore: registered new interface driver dvb_usb_dib0700
[ 13.495444] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 13.947548] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 14.981606] bcm2835 ALSA card created!
[ 15.005106] bcm2835 ALSA chip created!
[ 15.021184] bcm2835 ALSA chip created!
[ 15.034299] bcm2835 ALSA chip created!
[ 15.047424] bcm2835 ALSA chip created!
[ 15.060550] bcm2835 ALSA chip created!
[ 15.073448] bcm2835 ALSA chip created!
[ 15.086370] bcm2835 ALSA chip created!
[ 21.264866] mmc0: missed completion of cmd 18 DMA (512/512 [1]/[1]) - ignoring it
[ 21.278885] mmc0: DMA IRQ 6 ignored - results were reset
[ 25.300883] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 26.981692] bcm2835-cpufreq: switching to governor ondemand
[ 26.981723] bcm2835-cpufreq: switching to governor ondemand<6>[ 30.675071] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SS
[ 33.781250] warning: process `colord-sane' used the deprecated sysctl system call with 8.1.2.
[ 391.066990] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[ 391.101378] XFS (dm-7): Mounting Filesystem
[ 394.002216] XFS (dm-7): Ending clean mount
[ 394.524420] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
[ 394.861907] XFS (dm-9): Mounting Filesystem
[ 397.831301] XFS (dm-9): Ending clean mount
[ 398.170063] XFS (dm-10): Mounting Filesystem
[ 401.062310] XFS (dm-10): Ending clean mount
[ 401.477118] EXT4-fs (dm-11): mounted filesystem with ordered data mode. Opts: (null)
[ 401.942053] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null)
[ 1722.417452] smsc95xx 1-1.1:1.0: eth0: link down
[ 1730.188896] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 1731.194655] smsc95xx 1-1.1:1.0: eth0: link down
[ 1732.733229] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[23950.152112] mmc0: Timeout waiting for hardware interrupt - cmd18.
[23950.153434] mmcblk0: error -110 transferring data, sector 13719632, nr 48, cmd response 0x900, card status 0x0
[23950.153456] mmcblk0: retrying using single block read
[23950.174587] mmc0: Controller never released inhibit bit(s).
[23950.175869] mmcblk0: unknown error -5 sending read/write command, card status 0xb00
[23950.175912] end_request: I/O error, dev mmcblk0, sector 13719633
[23950.175936] end_request: I/O error, dev mmcblk0, sector 13719640
[23950.175953] end_request: I/O error, dev mmcblk0, sector 13719648
[23950.175966] end_request: I/O error, dev mmcblk0, sector 13719656
[23950.175981] end_request: I/O error, dev mmcblk0, sector 13719664
[23950.176006] end_request: I/O error, dev mmcblk0, sector 13719672
[23950.182336] mmc0: resetting ongoing cmd 18DMA before 4096/4096 [1]/[6] complete
[23950.183786] mmcblk0: error -84 transferring data, sector 13719688, nr 48, cmd response 0x900, card status 0x0
[23950.183810] mmcblk0: retrying using single block read
[23950.184127] mmc0: DMA IRQ E ignored - results were reset
[23950.184185] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.184571] mmc0: DMA IRQ E ignored - results were reset
[23950.184629] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.185012] mmc0: DMA IRQ E ignored - results were reset
[23950.185063] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.185434] mmc0: DMA IRQ E ignored - results were reset
[23950.185488] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.185853] mmc0: DMA IRQ E ignored - results were reset
[23950.185928] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.186302] mmc0: DMA IRQ E ignored - results were reset
[23950.186353] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.186724] mmc0: DMA IRQ E ignored - results were reset
[23950.186787] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.187161] mmc0: DMA IRQ E ignored - results were reset
[23950.187214] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.187684] mmc0: DMA IRQ E ignored - results were reset
[23950.187738] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.188208] mmc0: DMA IRQ E ignored - results were reset
[23950.188267] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.188736] mmc0: DMA IRQ E ignored - results were reset
[23950.188797] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.189263] mmc0: DMA IRQ E ignored - results were reset
[23950.189312] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.189780] mmc0: DMA IRQ E ignored - results were reset
[23950.189829] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.190289] mmc0: DMA IRQ E ignored - results were reset
[23950.190341] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.190816] mmc0: DMA IRQ E ignored - results were reset
[23950.190881] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.191339] mmc0: DMA IRQ E ignored - results were reset
[23950.191405] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.191766] mmc0: DMA IRQ E ignored - results were reset
[23950.191813] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.192429] mmc0: DMA IRQ E ignored - results were reset
[23950.192484] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.193012] mmc0: DMA IRQ E ignored - results were reset
[23950.193064] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.193441] mmc0: DMA IRQ E ignored - results were reset
[23950.193503] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.193861] mmc0: DMA IRQ E ignored - results were reset
[23950.193934] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.194307] mmc0: DMA IRQ E ignored - results were reset
[23950.194366] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.194761] mmc0: DMA IRQ E ignored - results were reset
[23950.194812] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.195180] mmc0: DMA IRQ E ignored - results were reset
[23950.195227] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.195673] mmc0: DMA IRQ E ignored - results were reset
[23950.195724] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.196173] mmc0: DMA IRQ E ignored - results were reset
[23950.196223] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.196672] mmc0: DMA IRQ E ignored - results were reset
[23950.196724] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.197174] mmc0: DMA IRQ E ignored - results were reset
[23950.197226] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.197675] mmc0: DMA IRQ E ignored - results were reset
[23950.197726] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.198188] mmc0: DMA IRQ E ignored - results were reset
[23950.198259] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.198726] mmc0: DMA IRQ E ignored - results were reset
[23950.198791] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.199263] mmc0: DMA IRQ E ignored - results were reset
[23950.199315] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.199681] mmc0: DMA IRQ E ignored - results were reset
[23950.199731] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.200094] mmc0: DMA IRQ E ignored - results were reset
[23950.200152] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.205384] mmc0: DMA IRQ E ignored - results were reset
[23950.205447] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.205838] mmc0: DMA IRQ E ignored - results were reset
[23950.205899] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.206262] mmc0: DMA IRQ E ignored - results were reset
[23950.206315] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.206681] mmc0: DMA IRQ E ignored - results were reset
[23950.206729] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.207090] mmc0: DMA IRQ E ignored - results were reset
[23950.207153] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.207514] mmc0: DMA IRQ E ignored - results were reset
[23950.207562] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.208009] mmc0: DMA IRQ E ignored - results were reset
[23950.208068] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.208510] mmc0: DMA IRQ E ignored - results were reset
[23950.208562] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.209009] mmc0: DMA IRQ E ignored - results were reset
[23950.209062] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.209509] mmc0: DMA IRQ E ignored - results were reset
[23950.209557] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.210005] mmc0: DMA IRQ E ignored - results were reset
[23950.210056] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.210506] mmc0: DMA IRQ E ignored - results were reset
[23950.210555] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.210992] mmc0: DMA IRQ E ignored - results were reset
[23950.211054] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.211502] mmc0: DMA IRQ E ignored - results were reset
[23950.211554] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23950.212313] mmc0: DMA IRQ E ignored - results were reset
[23960.231947] mmc0: Timeout waiting for hardware interrupt - cmd18.
[23960.232004] mmc0: resetting ongoing cmd 18DMA before 4096/4096 [16]/[16] complete
[23960.233195] mmcblk0: error -110 transferring data, sector 14807936, nr 128, cmd response 0x900, card status 0x0
[23960.233218] mmcblk0: retrying using single block read
[23960.233695] mmc0: DMA IRQ E ignored - results were reset
[23960.233755] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.234204] mmc0: DMA IRQ E ignored - results were reset
[23960.234263] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.234705] mmc0: DMA IRQ E ignored - results were reset
[23960.234763] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.235211] mmc0: DMA IRQ E ignored - results were reset
[23960.235282] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.235729] mmc0: DMA IRQ E ignored - results were reset
[23960.235785] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.236224] mmc0: DMA IRQ E ignored - results were reset
[23960.236280] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.236717] mmc0: DMA IRQ E ignored - results were reset
[23960.236775] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.237214] mmc0: DMA IRQ E ignored - results were reset
[23960.237271] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.237714] mmc0: DMA IRQ E ignored - results were reset
[23960.237772] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.238214] mmc0: DMA IRQ E ignored - results were reset
[23960.238603] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.239056] mmc0: DMA IRQ E ignored - results were reset
[23960.239115] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.239544] mmc0: DMA IRQ E ignored - results were reset
[23960.239589] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.240024] mmc0: DMA IRQ E ignored - results were reset
[23960.240073] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.240510] mmc0: DMA IRQ E ignored - results were reset
[23960.240561] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.241002] mmc0: DMA IRQ E ignored - results were reset
[23960.241051] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.241492] mmc0: DMA IRQ E ignored - results were reset
[23960.241541] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.241994] mmc0: DMA IRQ E ignored - results were reset
[23960.242045] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.246936] mmc0: DMA IRQ E ignored - results were reset
[23960.247009] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.247489] mmc0: DMA IRQ E ignored - results were reset
[23960.247536] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.247980] mmc0: DMA IRQ E ignored - results were reset
[23960.248036] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.248719] mmc0: DMA IRQ E ignored - results were reset
[23960.248782] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.249260] mmc0: DMA IRQ E ignored - results were reset
[23960.249313] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.249766] mmc0: DMA IRQ E ignored - results were reset
[23960.249816] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.250258] mmc0: DMA IRQ E ignored - results were reset
[23960.250306] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.250663] mmc0: DMA IRQ E ignored - results were reset
[23960.250713] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.251070] mmc0: DMA IRQ E ignored - results were reset
[23960.251143] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.251514] mmc0: DMA IRQ E ignored - results were reset
[23960.251564] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.251953] mmc0: DMA IRQ E ignored - results were reset
[23960.252016] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.252396] mmc0: DMA IRQ E ignored - results were reset
[23960.252446] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.252820] mmc0: DMA IRQ E ignored - results were reset
[23960.252884] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.253261] mmc0: DMA IRQ E ignored - results were reset
[23960.253313] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.253685] mmc0: DMA IRQ E ignored - results were reset
[23960.253748] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.254214] mmc0: DMA IRQ E ignored - results were reset
[23960.254283] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.254757] mmc0: DMA IRQ E ignored - results were reset
[23960.254809] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.255270] mmc0: DMA IRQ E ignored - results were reset
[23960.255329] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.255795] mmc0: DMA IRQ E ignored - results were reset
[23960.255849] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.256323] mmc0: DMA IRQ E ignored - results were reset
[23960.256391] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.256877] mmc0: DMA IRQ E ignored - results were reset
[23960.256930] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.257395] mmc0: DMA IRQ E ignored - results were reset
[23960.257451] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.257917] mmc0: DMA IRQ E ignored - results were reset
[23960.257969] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.258348] mmc0: DMA IRQ E ignored - results were reset
[23960.258413] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.259104] mmc0: DMA IRQ E ignored - results were reset
[23960.259177] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.259582] mmc0: DMA IRQ E ignored - results were reset
[23960.259652] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.260041] mmc0: DMA IRQ E ignored - results were reset
[23960.260104] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.260486] mmc0: DMA IRQ E ignored - results were reset
[23960.260549] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.260932] mmc0: DMA IRQ E ignored - results were reset
[23960.260998] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.261383] mmc0: DMA IRQ E ignored - results were reset
[23960.261435] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.261814] mmc0: DMA IRQ E ignored - results were reset
[23960.261877] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.262420] mmc0: DMA IRQ E ignored - results were reset
[23960.262476] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.262938] mmc0: DMA IRQ E ignored - results were reset
[23960.262998] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.263481] mmc0: DMA IRQ E ignored - results were reset
[23960.263543] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.264012] mmc0: DMA IRQ E ignored - results were reset
[23960.264067] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.264530] mmc0: DMA IRQ E ignored - results were reset
[23960.264581] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.265042] mmc0: DMA IRQ E ignored - results were reset
[23960.265095] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.265556] mmc0: DMA IRQ E ignored - results were reset
[23960.265622] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.266071] mmc0: DMA IRQ E ignored - results were reset
[23960.266137] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.266524] mmc0: DMA IRQ E ignored - results were reset
[23960.266576] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.266956] mmc0: DMA IRQ E ignored - results were reset
[23960.267023] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.267420] mmc0: DMA IRQ E ignored - results were reset
[23960.267476] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.267851] mmc0: DMA IRQ E ignored - results were reset
[23960.267925] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.268303] mmc0: DMA IRQ E ignored - results were reset
[23960.268356] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.268732] mmc0: DMA IRQ E ignored - results were reset
[23960.268800] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.269608] mmc0: DMA IRQ E ignored - results were reset
[23960.269678] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.270074] mmc0: DMA IRQ E ignored - results were reset
[23960.270139] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.270636] mmc0: DMA IRQ E ignored - results were reset
[23960.270693] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.271178] mmc0: DMA IRQ E ignored - results were reset
[23960.271231] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.271715] mmc0: DMA IRQ E ignored - results were reset
[23960.271785] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.272364] mmc0: DMA IRQ E ignored - results were reset
[23960.272429] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.272922] mmc0: DMA IRQ E ignored - results were reset
[23960.272980] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.273497] mmc0: DMA IRQ E ignored - results were reset
[23960.273549] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.274041] mmc0: DMA IRQ E ignored - results were reset
[23960.274097] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.274592] mmc0: DMA IRQ E ignored - results were reset
[23960.274655] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.275037] mmc0: DMA IRQ E ignored - results were reset
[23960.275089] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.275479] mmc0: DMA IRQ E ignored - results were reset
[23960.275543] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.275919] mmc0: DMA IRQ E ignored - results were reset
[23960.275978] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.276355] mmc0: DMA IRQ E ignored - results were reset
[23960.276421] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.276810] mmc0: DMA IRQ E ignored - results were reset
[23960.276876] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.277261] mmc0: DMA IRQ E ignored - results were reset
[23960.277312] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.277689] mmc0: DMA IRQ E ignored - results were reset
[23960.277751] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.278135] mmc0: DMA IRQ E ignored - results were reset
[23960.278188] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.278675] mmc0: DMA IRQ E ignored - results were reset
[23960.278730] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.279216] mmc0: DMA IRQ E ignored - results were reset
[23960.279286] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.280082] mmc0: DMA IRQ E ignored - results were reset
[23960.280152] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.280824] mmc0: DMA IRQ E ignored - results were reset
[23960.280891] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.281386] mmc0: DMA IRQ E ignored - results were reset
[23960.281441] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.281958] mmc0: DMA IRQ E ignored - results were reset
[23960.282025] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.282527] mmc0: DMA IRQ E ignored - results were reset
[23960.282583] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.283076] mmc0: DMA IRQ E ignored - results were reset
[23960.283154] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.283552] mmc0: DMA IRQ E ignored - results were reset
[23960.283609] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.284003] mmc0: DMA IRQ E ignored - results were reset
[23960.284063] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.284443] mmc0: DMA IRQ E ignored - results were reset
[23960.284501] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.284889] mmc0: DMA IRQ E ignored - results were reset
[23960.284940] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.285318] mmc0: DMA IRQ E ignored - results were reset
[23960.285386] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.285766] mmc0: DMA IRQ E ignored - results were reset
[23960.285814] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.286194] mmc0: DMA IRQ E ignored - results were reset
[23960.286260] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.286642] mmc0: DMA IRQ E ignored - results were reset
[23960.286692] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.287150] mmc0: DMA IRQ E ignored - results were reset
[23960.287205] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.287668] mmc0: DMA IRQ E ignored - results were reset
[23960.287722] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.288192] mmc0: DMA IRQ E ignored - results were reset
[23960.288261] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.288734] mmc0: DMA IRQ E ignored - results were reset
[23960.288797] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.289263] mmc0: DMA IRQ E ignored - results were reset
[23960.289317] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.290178] mmc0: DMA IRQ E ignored - results were reset
[23960.290237] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.290894] mmc0: DMA IRQ E ignored - results were reset
[23960.290952] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.291429] mmc0: DMA IRQ E ignored - results were reset
[23960.291484] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.291863] mmc0: DMA IRQ E ignored - results were reset
[23960.291988] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.292399] mmc0: DMA IRQ E ignored - results were reset
[23960.292453] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.292823] mmc0: DMA IRQ E ignored - results were reset
[23960.292876] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.293258] mmc0: DMA IRQ E ignored - results were reset
[23960.293310] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.293683] mmc0: DMA IRQ E ignored - results were reset
[23960.293751] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.294125] mmc0: DMA IRQ E ignored - results were reset
[23960.294177] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.294560] mmc0: DMA IRQ E ignored - results were reset
[23960.294628] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.295012] mmc0: DMA IRQ E ignored - results were reset
[23960.295060] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.295518] mmc0: DMA IRQ E ignored - results were reset
[23960.295573] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.296037] mmc0: DMA IRQ E ignored - results were reset
[23960.296089] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.296552] mmc0: DMA IRQ E ignored - results were reset
[23960.296611] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.297090] mmc0: DMA IRQ E ignored - results were reset
[23960.297152] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.297613] mmc0: DMA IRQ E ignored - results were reset
[23960.297677] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.298139] mmc0: DMA IRQ E ignored - results were reset
[23960.298195] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.298660] mmc0: DMA IRQ E ignored - results were reset
[23960.298713] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.299178] mmc0: DMA IRQ E ignored - results were reset
[23960.299234] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.299647] mmc0: DMA IRQ E ignored - results were reset
[23960.299702] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.300378] mmc0: DMA IRQ E ignored - results were reset
[23960.300438] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.301018] mmc0: DMA IRQ E ignored - results were reset
[23960.301077] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.301460] mmc0: DMA IRQ E ignored - results were reset
[23960.301522] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.301967] mmc0: DMA IRQ E ignored - results were reset
[23960.302037] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.302419] mmc0: DMA IRQ E ignored - results were reset
[23960.302469] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.302843] mmc0: DMA IRQ E ignored - results were reset
[23960.302908] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.303277] mmc0: DMA IRQ E ignored - results were reset
[23960.303327] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23960.303762] mmc0: DMA IRQ E ignored - results were reset
[23970.312627] mmc0: Timeout waiting for hardware interrupt - cmd18.
[23970.312669] mmc0: resetting ongoing cmd 18DMA before 4096/4096 [1]/[1] complete
[23970.313828] mmcblk0: error -110 transferring data, sector 13719632, nr 8, cmd response 0x900, card status 0x0
[23970.313864] mmcblk0: retrying using single block read
[23970.314333] mmc0: DMA IRQ E ignored - results were reset
[23970.314407] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23970.314867] mmc0: DMA IRQ E ignored - results were reset
[23970.314916] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23970.315358] mmc0: DMA IRQ E ignored - results were reset
[23970.315408] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23970.315842] mmc0: DMA IRQ E ignored - results were reset
[23970.315899] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23970.316326] mmc0: DMA IRQ E ignored - results were reset
[23970.316396] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23970.316836] mmc0: DMA IRQ E ignored - results were reset
[23970.316894] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23970.317323] mmc0: DMA IRQ E ignored - results were reset
[23970.317382] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23970.317795] mmc0: DMA IRQ E ignored - results were reset
[23970.317846] mmc0: resetting ongoing cmd 18DMA before 512/512 [1]/[1] complete
[23970.317957] mmc0: DMA IRQ E ignored - results were reset
[23980.332503] mmc0: Timeout waiting for hardware interrupt - cmd25.
[23980.332545] mmc0: resetting ongoing cmd 25DMA before 4096/4096 [11]/[11] complete
[23980.333767] mmcblk0: error -110 transferring data, sector 1740280, nr 88, cmd response 0x900, card status 0x0
[23980.334804] mmc0: DMA IRQ 6 ignored - results were reset
[23980.401788] mmc0: Controller never released inhibit bit(s).
[23980.404312] mmcblk0: unknown error -5 sending read/write command, card status 0xb00
[23980.404361] end_request: I/O error, dev mmcblk0, sector 123912
[23980.404385] Buffer I/O error on device mmcblk0p2, logical block 129
[23980.404397] lost page write due to I/O error on mmcblk0p2
[23983.565843] ------------[ cut here ]------------
[23983.565906] WARNING: at fs/buffer.c:1106 mark_buffer_dirty+0xb8/0xdc()
[23983.565932] Modules linked in: xfs aes_generic xts gf128mul snd_bcm2835 snd_pcm snd_page_alloc snd_seq snd_seq_device snd_timer snd dm_crypt evdev rc_dib0700_rc5 mt2060 dm_mod dvb_usb_dib0700 dib9000 dib8000 dib7000m dib0090 dib0070 dib7000p dib3000mc dibx000_common dvb_usb dvb_core rc_core leds_gpio led_class
[23983.566091] [<c0013a7c>] (unwind_backtrace+0x0/0xf0) from [<c001e2c8>] (warn_slowpath_common+0x4c/0x64)
[23983.566120] [<c001e2c8>] (warn_slowpath_common+0x4c/0x64) from [<c001e2fc>] (warn_slowpath_null+0x1c/0x24)
[23983.566146] [<c001e2fc>] (warn_slowpath_null+0x1c/0x24) from [<c00ec754>] (mark_buffer_dirty+0xb8/0xdc)
[23983.566194] [<c00ec754>] (mark_buffer_dirty+0xb8/0xdc) from [<c01612e0>] (__jbd2_journal_unfile_buffer+0xc/0x20)
[23983.566227] [<c01612e0>] (__jbd2_journal_unfile_buffer+0xc/0x20) from [<c01649bc>] (jbd2_journal_commit_transaction+0xeac/0x18bc)
[23983.566257] [<c01649bc>] (jbd2_journal_commit_transaction+0xeac/0x18bc) from [<c0168448>] (kjournald2+0xbc/0x298)
[23983.566324] [<c0168448>] (kjournald2+0xbc/0x298) from [<c003a7c8>] (kthread+0x88/0x94)
[23983.566364] [<c003a7c8>] (kthread+0x88/0x94) from [<c000e9fc>] (kernel_thread_exit+0x0/0x8)
[23983.566378] ---[ end trace f7dbf476d8ff8a83 ]---
[23991.781449] EXT4-fs error (device mmcblk0p2): ext4_free_inode:319: comm cron: bit already cleared for inode 2983
xnosek00
Fri Jan 18, 2013 2:09 pm
confirmed. Raspberry pi is not overlocked and data on my SD card are corupted. USB disk looks like without corruption.
My it be caused by usb hub? Or TV card? Or USB disk? Or is Raspberry Pi so unstable on SD card?
It's a big problem for me. Raspi is not usable for me, if it damages filesystem after a week.
MAA1612
Fri Jan 18, 2013 2:16 pm
xnosek00 wrote:NOT OVERLOCKED, but still unstable.
Have you already tried a different SD card? My RPi is overclocked to 900 Mhz, and I am using a Samsung MB-SP8GA SD card. No issues with that card so far, and it has good performance for the price: 19.4 MB/s read throuput and 19.8 MB/s write throuput ...
RaTTuS
Contact: Twitter YouTube
Fri Jan 18, 2013 2:23 pm
what is the power as measured from tp1 / tp2
Covfefe
xnosek00
Fri Jan 18, 2013 2:32 pm
Thank you for a tip. I will borrow device to measure power supply and I can test another SD card.
The thruth is, that I have another RasPi, without USB hub, without TV card and it is running 19 days without data corruption. And is overlocked to 800 MHz. On the other had - if I overlock this another RasPi more than 800 MHz, sd card is corrupted after boot.
On the power supply is written 5V, 2A, but I will try to measure it on RasPi.
I'm confused about unstable file system on both RasPi's. SD card is Sandisk 8GB.
xnosek00
Fri Feb 01, 2013 3:35 pm
There is 5,10V between TP1 and TP2
I followed these instructions: http://elinux.org/R-Pi_Troubleshooting
the F3 polyfuse has been tested too. Voltage different was 0.03V.
I think, that is not problem with power supply. Any other idea, why could be RasPi unstable? Can active USB hub cause data corruption on SD card? But there is only TV card in USB hub. USB disk is connected directly into RasPi.
xnosek00
Fri Feb 01, 2013 5:15 pm
a new error reporting - it's about TV card: 2 hours after last reboot. SD card is not corrupted right now.
[email protected]:/home/pi# dmesg
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.6.11+ ([email protected]) (gcc version 4.7.2 20120731 (prerelease) (crosstool-NG linaro-1.13.1+bzr2458 - Linaro GCC 2012.08) ) #366 PREEMPT Wed Jan 30 12:59:10 GMT 2013
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: CMA: reserved 16 MiB at 17000000
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] On node 0 totalpages: 98304
[ 0.000000] Normal zone: 768 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 97536 pages, LIFO batch:31
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97536
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1280 bcm2708_fb.fbheight=1024 bcm2708.boardrev=0xf bcm2708.serial=0xbc6503d4 smsc95xx.macaddr=B8:27:EB:65:03:D4 sdhci-bcm2708.emmc_clock_freq=100000000 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 sdhci-bcm2708.enable_llm=1 sdhci-bcm2708.sync_after_dma=0 smsc95xx.turbo_mode=N dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 384MB = 384MB total
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd8800000 - 0xff000000 ( 616 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd8000000 ( 384 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] NR_IRQS:330
[ 0.000000] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 4294967ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] console [tty1] enabled
[ 0.001038] Calibrating delay loop... 464.48 BogoMIPS (lpj=2322432)
[ 0.060061] pid_max: default: 32768 minimum: 301
[ 0.060416] Mount-cache hash table entries: 512
[ 0.061186] Initializing cgroup subsys cpuacct
[ 0.061240] Initializing cgroup subsys devices
[ 0.061274] Initializing cgroup subsys freezer
[ 0.061303] Initializing cgroup subsys blkio
[ 0.061394] CPU: Testing write buffer coherency: ok
[ 0.061726] hw perfevents: enabled with v6 PMU driver, 3 counters available
[ 0.061868] Setting up static identity map for 0x39d198 - 0x39d1f4
[ 0.063369] devtmpfs: initialized
[ 0.074364] NET: Registered protocol family 16
[ 0.080910] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.082132] bcm2708.uart_clock = 0
[ 0.083470] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.083525] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.083561] mailbox: Broadcom VideoCore Mailbox driver
[ 0.083655] bcm2708_vcio: mailbox at f200b880
[ 0.083755] bcm_power: Broadcom power driver
[ 0.083794] bcm_power_open() -> 0
[ 0.083819] bcm_power_request(0, 8)
[ 0.584518] bcm_mailbox_read -> 00000080, 0
[ 0.584561] bcm_power_request -> 0
[ 0.584588] Serial: AMBA PL011 UART driver
[ 0.584729] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83) is a PL011 rev3
[ 0.915555] console [ttyAMA0] enabled
[ 0.939131] bio: create slab <bio-0> at 0
[ 0.944013] SCSI subsystem initialized
[ 0.948104] usbcore: registered new interface driver usbfs
[ 0.953691] usbcore: registered new interface driver hub
[ 0.959287] usbcore: registered new device driver usb
[ 0.965757] Switching to clocksource stc
[ 0.970003] FS-Cache: Loaded
[ 0.973141] CacheFiles: Loaded
[ 0.987947] NET: Registered protocol family 2
[ 0.993223] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.000962] TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
[ 1.007754] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.014358] TCP: reno registered
[ 1.017611] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.023510] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.030080] NET: Registered protocol family 1
[ 1.034948] RPC: Registered named UNIX socket transport module.
[ 1.040995] RPC: Registered udp transport module.
[ 1.045719] RPC: Registered tcp transport module.
[ 1.050467] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.057704] bcm2708_dma: DMA manager at f2007000
[ 1.062491] bcm2708_gpio: bcm2708_gpio_probe c0515d98
[ 1.067958] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.077136] audit: initializing netlink socket (disabled)
[ 1.082738] type=2000 audit(0.930:1): initialized
[ 1.205872] VFS: Disk quotas dquot_6.5.2
[ 1.210012] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.216964] FS-Cache: Netfs 'nfs' registered for caching
[ 1.222710] NFS: Registering the id_resolver key type
[ 1.227874] Key type id_resolver registered
[ 1.232169] Key type id_legacy registered
[ 1.236536] msgmni has been set to 749
[ 1.242052] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 1.249760] io scheduler noop registered
[ 1.253808] io scheduler deadline registered (default)
[ 1.259004] io scheduler cfq registered
[ 1.299450] Console: switching to colour frame buffer device 160x64
[ 1.320884] kgdb: Registered I/O driver kgdboc.
[ 1.326173] vc-cma: Videocore CMA driver
[ 1.330274] vc-cma: vc_cma_base = 0x00000000
[ 1.335090] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.340638] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.355242] brd: module loaded
[ 1.363446] loop: module loaded
[ 1.367038] vchiq: vchiq_init_state: slot_zero = 0xd7000000, is_master = 0
[ 1.374901] Loading iSCSI transport class v2.0-870.
[ 1.380858] usbcore: registered new interface driver smsc95xx
[ 1.386982] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.598117] Core Release: 2.80a
[ 1.601452] Setting default values for core params
[ 1.606395] Finished setting default values for core params
[ 1.817201] Using Buffer DMA mode
[ 1.820647] Periodic Transfer Interrupt Enhancement - disabled
[ 1.826615] Multiprocessor Interrupt Enhancement - disabled
[ 1.832340] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.836805] Dedicated Tx FIFOs mode
[ 1.841366] dwc_otg: Microframe scheduler enabled
[ 1.841768] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.846844] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.854379] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.860167] Init: Port Power? op_state=1
[ 1.864191] Init: Power Port (0)
[ 1.867604] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.874600] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.882021] usb usb1: Product: DWC OTG Controller
[ 1.886842] usb usb1: Manufacturer: Linux 3.6.11+ dwc_otg_hcd
[ 1.892750] usb usb1: SerialNumber: bcm2708_usb
[ 1.903445] hub 1-0:1.0: USB hub found
[ 1.912592] hub 1-0:1.0: 1 port detected
[ 1.922076] dwc_otg: FIQ enabled
[ 1.922096] dwc_otg: NAK holdoff enabled
[ 1.922117] Module dwc_common_port init
[ 1.922347] Initializing USB Mass Storage driver...
[ 1.932768] usbcore: registered new interface driver usb-storage
[ 1.944020] USB Mass Storage support registered.
[ 1.953987] usbcore: registered new interface driver libusual
[ 1.965273] mousedev: PS/2 mouse device common for all mice
[ 1.976885] bcm2835-cpufreq: min=700000 max=700000 cur=700000
[ 1.982752] bcm2835-cpufreq: switching to governor powersavebcm2835-cpufreq: switching to governor powersave
[ 1.998021] cpuidle: using governor ladder
[ 2.012862] cpuidle: using governor menu
[ 2.022297] sdhci: Secure Digital Host Controller Interface driver
[ 2.033919] sdhci: Copyright(c) Pierre Ossman
[ 2.043720] sdhci: Enable low-latency mode
[ 2.090053] mmc0: SDHCI controller on BCM2708_Arasan [platform] using platform's DMA
[ 2.103478] mmc0: BCM2708 SDHC host at 0x20300000 DMA 2 IRQ 77
[ 2.116941] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.130244] Indeed it is in host mode hprt0 = 00021501
[ 2.144531] usbcore: registered new interface driver usbhid
[ 2.160418] usbhid: USB HID core driver
[ 2.190634] TCP: cubic registered
[ 2.209879] Initializing XFRM netlink socket
[ 2.224942] NET: Registered protocol family 17
[ 2.238014] mmc0: new high speed SDHC card at address aaaa
[ 2.260065] Key type dns_resolver registered
[ 2.270567] mmcblk0: mmc0:aaaa SU08G 7.40 GiB
[ 2.290204] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 2.305058] mmcblk0: p1 p2
[ 2.315958] registered taskstats version 1
[ 2.340812] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.354637] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.374466] devtmpfs: mounted
[ 2.383493] Freeing init memory: 128K
[ 2.429936] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.442294] Indeed it is in host mode hprt0 = 00001101
[ 2.660413] usb 1-1: New USB device found, idVendor=0424, idProduct=9512
[ 2.673605] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.688297] hub 1-1:1.0: USB hub found
[ 2.698970] hub 1-1:1.0: 3 ports detected
[ 2.980104] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.080629] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 3.103593] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.126574] smsc95xx v1.0.4
[ 3.204849] smsc95xx 1-1.1:1.0: eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:65:03:d4
[ 3.320189] usb 1-1.2: new high-speed USB device number 4 using dwc_otg
[ 3.431470] usb 1-1.2: New USB device found, idVendor=152d, idProduct=2329
[ 3.455393] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[ 3.489969] usb 1-1.2: Product: USB to ATA/ATAPI bridge
[ 3.509999] usb 1-1.2: Manufacturer: JMicron
[ 3.527021] usb 1-1.2: SerialNumber: DCAA030589FF
[ 3.556104] usb-storage 1-1.2:1.0: Quirks match for vid 152d pid 2329: 8020
[ 3.580172] scsi0 : usb-storage 1-1.2:1.0
[ 3.680218] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[ 3.810836] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101
[ 3.837339] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.863217] usb 1-1.3: Product: USB 2.0 Hub [MTT]
[ 3.876143] hub 1-1.3:1.0: USB hub found
[ 3.886380] hub 1-1.3:1.0: 4 ports detected
[ 4.047351] udevd[143]: starting version 175
[ 4.170162] usb 1-1.3.4: new high-speed USB device number 6 using dwc_otg
[ 4.290785] usb 1-1.3.4: New USB device found, idVendor=1a40, idProduct=0101
[ 4.329979] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 4.375942] usb 1-1.3.4: Product: USB 2.0 Hub [MTT]
[ 4.401498] hub 1-1.3.4:1.0: USB hub found
[ 4.415363] hub 1-1.3.4:1.0: 4 ports detected
[ 4.642749] scsi 0:0:0:0: Direct-Access WDC WD20 EARX-00PASB0 PQ: 0 ANSI: 2 CCS
[ 4.681665] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 4.710246] usb 1-1.3.4.1: new high-speed USB device number 7 using dwc_otg
[ 4.750947] sd 0:0:0:0: [sda] Write Protect is off
[ 4.789949] sd 0:0:0:0: [sda] Mode Sense: 28 00 00 00
[ 4.790897] sd 0:0:0:0: [sda] No Caching mode page present
[ 4.824405] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 4.852410] usb 1-1.3.4.1: New USB device found, idVendor=0413, idProduct=6f00
[ 4.881392] sd 0:0:0:0: [sda] No Caching mode page present
[ 4.908794] usb 1-1.3.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 4.929947] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 4.961984] usb 1-1.3.4.1: Product: STK7700
[ 4.993193] usb 1-1.3.4.1: Manufacturer: DIBCOM
[ 5.029987] usb 1-1.3.4.1: SerialNumber: 0000000001
[ 5.150198] usb 1-1.3.4.2: new high-speed USB device number 8 using dwc_otg
[ 5.292043] usb 1-1.3.4.2: New USB device found, idVendor=04e8, idProduct=341b
[ 5.319969] usb 1-1.3.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 5.349949] usb 1-1.3.4.2: Product: SCX-4200 Series
[ 5.361951] sda: sda1
[ 5.380376] usb 1-1.3.4.2: Manufacturer: Samsung
[ 5.394101] sd 0:0:0:0: [sda] No Caching mode page present
[ 5.419970] usb 1-1.3.4.2: SerialNumber: 8T21BAIQ403726P.
[ 5.431952] sd 0:0:0:0: [sda] Assuming drive cache: write through
[ 5.455057] sd 0:0:0:0: [sda] Attached SCSI disk
[ 5.796634] Registered led device: led0
[ 7.804788] dvb-usb: found a 'Leadtek Winfast DTV Dongle (STK7700P based)' in warm state.
[ 7.836914] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[ 7.853807] DVB: registering new adapter (Leadtek Winfast DTV Dongle (STK7700P based))
[ 8.286174] DVB: registering adapter 0 frontend 0 (DiBcom 7000MA/MB/PA/PB/MC)...
[ 8.321827] device-mapper: ioctl: 4.23.0-ioctl (2012-07-25) initialised: [email protected]
[ 8.374416] MT2060: successfully identified (IF1 = 1220)
[ 9.029860] Registered IR keymap rc-dib0700-rc5
[ 9.049965] input: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.4/1-1.3.4.1/rc/rc0/input0
[ 9.075221] rc0: IR-receiver inside an USB DVB receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3.4/1-1.3.4.1/rc/rc0
[ 9.094236] dvb-usb: schedule remote query interval to 50 msecs.
[ 9.112880] dvb-usb: Leadtek Winfast DTV Dongle (STK7700P based) successfully initialized and connected.
[ 9.142592] dib0700: rc submit urb failed
[ 9.142592]
[ 9.178335] usbcore: registered new interface driver dvb_usb_dib0700
[ 12.539555] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 12.985307] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 14.031458] bcm2835 ALSA card created!
[ 14.053727] bcm2835 ALSA chip created!
[ 14.071710] bcm2835 ALSA chip created!
[ 14.087195] bcm2835 ALSA chip created!
[ 14.101797] bcm2835 ALSA chip created!
[ 14.115033] bcm2835 ALSA chip created!
[ 14.128501] bcm2835 ALSA chip created!
[ 14.141408] bcm2835 ALSA chip created!
[ 24.461078] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 26.013595] bcm2835-cpufreq: switching to governor ondemand
[ 26.013627] bcm2835-cpufreq: switching to governor ondemand<6>[ 30.270224] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SS
[ 33.510214] warning: process `colord-sane' used the deprecated sysctl system call with 8.1.2.
[ 254.439494] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[ 254.456324] XFS (dm-7): Mounting Filesystem
[ 258.176935] XFS (dm-7): Ending clean mount
[ 258.718196] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
[ 259.103971] XFS (dm-9): Mounting Filesystem
[ 262.742271] XFS (dm-9): Ending clean mount
[ 263.169571] XFS (dm-10): Mounting Filesystem
[ 266.793964] XFS (dm-10): Ending clean mount
[ 267.292683] EXT4-fs (dm-11): mounted filesystem with ordered data mode. Opts: (null)
[ 267.886769] EXT4-fs (dm-12): mounted filesystem with ordered data mode. Opts: (null)
[ 0.000000] free_area_init_node: node 0, pgdat c053b834, node_mem_map c05e5000
[ 0.000000] Memory: 367240k/367240k available, 25976k reserved, 0K highmem
[ 0.000000] .text : 0xc0008000 - 0xc04e5460 (4982 kB)
[ 0.000000] .init : 0xc04e6000 - 0xc0506f24 ( 132 kB)
[ 0.000000] .data : 0xc0508000 - 0xc053c060 ( 209 kB)
[ 0.000000] .bss : 0xc053c084 - 0xc05e4738 ( 674 kB)
[ 9.142592]
[ 2814.418818] hub 1-1:1.0: port 3 disabled by hub (EMI?), re-enabling...
[ 2814.418881] usb 1-1.3: USB disconnect, device number 5
[ 2814.418902] usb 1-1.3.4: USB disconnect, device number 6
[ 2814.418917] usb 1-1.3.4.1: USB disconnect, device number 7
[ 2814.420115] mt2060 I2C write failed
[ 3001.269158] INFO: task khubd:14 blocked for more than 120 seconds.
[ 3001.269185] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3001.269200] khubd D c0398198 0 14 2 0x00000000
[ 3001.269438] [<c0398198>] (__schedule+0x2c4/0x5b0) from [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core])
[ 3001.269587] [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core]) from [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb])
[ 3001.269662] [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb]) from [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb])
[ 3001.269714] [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb]) from [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb])
[ 3001.269772] [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb]) from [<c0277944>] (usb_unbind_interface+0x48/0x108)
[ 3001.269805] [<c0277944>] (usb_unbind_interface+0x48/0x108) from [<c02371bc>] (__device_release_driver+0x58/0xb0)
[ 3001.269832] [<c02371bc>] (__device_release_driver+0x58/0xb0) from [<c0237230>] (device_release_driver+0x1c/0x28)
[ 3001.269869] [<c0237230>] (device_release_driver+0x1c/0x28) from [<c0236d38>] (bus_remove_device+0xc4/0xe4)
[ 3001.269906] [<c0236d38>] (bus_remove_device+0xc4/0xe4) from [<c0234ed8>] (device_del+0xf8/0x17c)
[ 3001.269935] [<c0234ed8>] (device_del+0xf8/0x17c) from [<c0276020>] (usb_disable_device+0xa0/0x1c8)
[ 3001.269985] [<c0276020>] (usb_disable_device+0xa0/0x1c8) from [<c026f2c0>] (usb_disconnect+0x7c/0x124)
[ 3001.270012] [<c026f2c0>] (usb_disconnect+0x7c/0x124) from [<c026f2a8>] (usb_disconnect+0x64/0x124)
[ 3121.272233] INFO: task khubd:14 blocked for more than 120 seconds.
[ 3121.272280] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3121.272297] khubd D c0398198 0 14 2 0x00000000
[ 3121.272559] [<c0398198>] (__schedule+0x2c4/0x5b0) from [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core])
[ 3121.272716] [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core]) from [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb])
[ 3121.272798] [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb]) from [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb])
[ 3121.272849] [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb]) from [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb])
[ 3121.272901] [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb]) from [<c0277944>] (usb_unbind_interface+0x48/0x108)
[ 3121.272947] [<c0277944>] (usb_unbind_interface+0x48/0x108) from [<c02371bc>] (__device_release_driver+0x58/0xb0)
[ 3121.272976] [<c02371bc>] (__device_release_driver+0x58/0xb0) from [<c0237230>] (device_release_driver+0x1c/0x28)
[ 3121.273001] [<c0237230>] (device_release_driver+0x1c/0x28) from [<c0236d38>] (bus_remove_device+0xc4/0xe4)
[ 3121.273052] [<c0236d38>] (bus_remove_device+0xc4/0xe4) from [<c0234ed8>] (device_del+0xf8/0x17c)
[ 3121.273080] [<c0234ed8>] (device_del+0xf8/0x17c) from [<c0276020>] (usb_disable_device+0xa0/0x1c8)
[ 3121.273120] [<c0276020>] (usb_disable_device+0xa0/0x1c8) from [<c026f2c0>] (usb_disconnect+0x7c/0x124)
[ 3121.273161] [<c026f2c0>] (usb_disconnect+0x7c/0x124) from [<c026f2a8>] (usb_disconnect+0x64/0x124)
[ 3241.275297] INFO: task khubd:14 blocked for more than 120 seconds.
[ 3241.275344] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3241.275362] khubd D c0398198 0 14 2 0x00000000
[ 3241.275636] [<c0398198>] (__schedule+0x2c4/0x5b0) from [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core])
[ 3241.275806] [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core]) from [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb])
[ 3241.275880] [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb]) from [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb])
[ 3241.275931] [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb]) from [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb])
[ 3241.276038] [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb]) from [<c0277944>] (usb_unbind_interface+0x48/0x108)
[ 3241.276089] [<c0277944>] (usb_unbind_interface+0x48/0x108) from [<c02371bc>] (__device_release_driver+0x58/0xb0)
[ 3241.276119] [<c02371bc>] (__device_release_driver+0x58/0xb0) from [<c0237230>] (device_release_driver+0x1c/0x28)
[ 3241.276142] [<c0237230>] (device_release_driver+0x1c/0x28) from [<c0236d38>] (bus_remove_device+0xc4/0xe4)
[ 3241.276181] [<c0236d38>] (bus_remove_device+0xc4/0xe4) from [<c0234ed8>] (device_del+0xf8/0x17c)
[ 3241.276221] [<c0234ed8>] (device_del+0xf8/0x17c) from [<c0276020>] (usb_disable_device+0xa0/0x1c8)
[ 3241.276262] [<c0276020>] (usb_disable_device+0xa0/0x1c8) from [<c026f2c0>] (usb_disconnect+0x7c/0x124)
[ 3241.276289] [<c026f2c0>] (usb_disconnect+0x7c/0x124) from [<c026f2a8>] (usb_disconnect+0x64/0x124)
[ 3361.278297] INFO: task khubd:14 blocked for more than 120 seconds.
[ 3361.278323] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3361.278337] khubd D c0398198 0 14 2 0x00000000
[ 3361.278573] [<c0398198>] (__schedule+0x2c4/0x5b0) from [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core])
[ 3361.278725] [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core]) from [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb])
[ 3361.278798] [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb]) from [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb])
[ 3361.278849] [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb]) from [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb])
[ 3361.278910] [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb]) from [<c0277944>] (usb_unbind_interface+0x48/0x108)
[ 3361.278943] [<c0277944>] (usb_unbind_interface+0x48/0x108) from [<c02371bc>] (__device_release_driver+0x58/0xb0)
[ 3361.278967] [<c02371bc>] (__device_release_driver+0x58/0xb0) from [<c0237230>] (device_release_driver+0x1c/0x28)
[ 3361.278991] [<c0237230>] (device_release_driver+0x1c/0x28) from [<c0236d38>] (bus_remove_device+0xc4/0xe4)
[ 3361.279040] [<c0236d38>] (bus_remove_device+0xc4/0xe4) from [<c0234ed8>] (device_del+0xf8/0x17c)
[ 3361.279068] [<c0234ed8>] (device_del+0xf8/0x17c) from [<c0276020>] (usb_disable_device+0xa0/0x1c8)
[ 3361.279106] [<c0276020>] (usb_disable_device+0xa0/0x1c8) from [<c026f2c0>] (usb_disconnect+0x7c/0x124)
[ 3361.279144] [<c026f2c0>] (usb_disconnect+0x7c/0x124) from [<c026f2a8>] (usb_disconnect+0x64/0x124)
[ 3481.281204] INFO: task khubd:14 blocked for more than 120 seconds.
[ 3481.281228] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3481.281241] khubd D c0398198 0 14 2 0x00000000
[ 3481.281459] [<c0398198>] (__schedule+0x2c4/0x5b0) from [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core])
[ 3481.281607] [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core]) from [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb])
[ 3481.281680] [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb]) from [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb])
[ 3481.281742] [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb]) from [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb])
[ 3481.281789] [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb]) from [<c0277944>] (usb_unbind_interface+0x48/0x108)
[ 3481.281833] [<c0277944>] (usb_unbind_interface+0x48/0x108) from [<c02371bc>] (__device_release_driver+0x58/0xb0)
[ 3481.281860] [<c02371bc>] (__device_release_driver+0x58/0xb0) from [<c0237230>] (device_release_driver+0x1c/0x28)
[ 3481.281883] [<c0237230>] (device_release_driver+0x1c/0x28) from [<c0236d38>] (bus_remove_device+0xc4/0xe4)
[ 3481.281918] [<c0236d38>] (bus_remove_device+0xc4/0xe4) from [<c0234ed8>] (device_del+0xf8/0x17c)
[ 3481.281955] [<c0234ed8>] (device_del+0xf8/0x17c) from [<c0276020>] (usb_disable_device+0xa0/0x1c8)
[ 3481.281994] [<c0276020>] (usb_disable_device+0xa0/0x1c8) from [<c026f2c0>] (usb_disconnect+0x7c/0x124)
[ 3481.282020] [<c026f2c0>] (usb_disconnect+0x7c/0x124) from [<c026f2a8>] (usb_disconnect+0x64/0x124)
[ 3601.284060] INFO: task khubd:14 blocked for more than 120 seconds.
[ 3601.284087] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3601.284112] khubd D c0398198 0 14 2 0x00000000
[ 3601.284339] [<c0398198>] (__schedule+0x2c4/0x5b0) from [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core])
[ 3601.284485] [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core]) from [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb])
[ 3601.284558] [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb]) from [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb])
[ 3601.284609] [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb]) from [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb])
[ 3601.284670] [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb]) from [<c0277944>] (usb_unbind_interface+0x48/0x108)
[ 3601.284704] [<c0277944>] (usb_unbind_interface+0x48/0x108) from [<c02371bc>] (__device_release_driver+0x58/0xb0)
[ 3601.284743] [<c02371bc>] (__device_release_driver+0x58/0xb0) from [<c0237230>] (device_release_driver+0x1c/0x28)
[ 3601.284767] [<c0237230>] (device_release_driver+0x1c/0x28) from [<c0236d38>] (bus_remove_device+0xc4/0xe4)
[ 3601.284803] [<c0236d38>] (bus_remove_device+0xc4/0xe4) from [<c0234ed8>] (device_del+0xf8/0x17c)
[ 3601.284827] [<c0234ed8>] (device_del+0xf8/0x17c) from [<c0276020>] (usb_disable_device+0xa0/0x1c8)
[ 3601.284876] [<c0276020>] (usb_disable_device+0xa0/0x1c8) from [<c026f2c0>] (usb_disconnect+0x7c/0x124)
[ 3601.284904] [<c026f2c0>] (usb_disconnect+0x7c/0x124) from [<c026f2a8>] (usb_disconnect+0x64/0x124)
[ 3721.287853] INFO: task khubd:14 blocked for more than 120 seconds.
[ 3721.287879] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3721.287893] khubd D c0398198 0 14 2 0x00000000
[ 3721.288135] [<c0398198>] (__schedule+0x2c4/0x5b0) from [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core])
[ 3721.288283] [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core]) from [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb])
[ 3721.288357] [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb]) from [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb])
[ 3721.288410] [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb]) from [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb])
[ 3721.288472] [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb]) from [<c0277944>] (usb_unbind_interface+0x48/0x108)
[ 3721.288506] [<c0277944>] (usb_unbind_interface+0x48/0x108) from [<c02371bc>] (__device_release_driver+0x58/0xb0)
[ 3721.288544] [<c02371bc>] (__device_release_driver+0x58/0xb0) from [<c0237230>] (device_release_driver+0x1c/0x28)
[ 3721.288570] [<c0237230>] (device_release_driver+0x1c/0x28) from [<c0236d38>] (bus_remove_device+0xc4/0xe4)
[ 3721.288605] [<c0236d38>] (bus_remove_device+0xc4/0xe4) from [<c0234ed8>] (device_del+0xf8/0x17c)
[ 3721.288629] [<c0234ed8>] (device_del+0xf8/0x17c) from [<c0276020>] (usb_disable_device+0xa0/0x1c8)
[ 3721.288679] [<c0276020>] (usb_disable_device+0xa0/0x1c8) from [<c026f2c0>] (usb_disconnect+0x7c/0x124)
[ 3721.288707] [<c026f2c0>] (usb_disconnect+0x7c/0x124) from [<c026f2a8>] (usb_disconnect+0x64/0x124)
[ 3841.291331] INFO: task khubd:14 blocked for more than 120 seconds.
[ 3841.291377] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3841.291395] khubd D c0398198 0 14 2 0x00000000
[ 3841.291654] [<c0398198>] (__schedule+0x2c4/0x5b0) from [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core])
[ 3841.291830] [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core]) from [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb])
[ 3841.291905] [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb]) from [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb])
[ 3841.291957] [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb]) from [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb])
[ 3841.292022] [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb]) from [<c0277944>] (usb_unbind_interface+0x48/0x108)
[ 3841.292058] [<c0277944>] (usb_unbind_interface+0x48/0x108) from [<c02371bc>] (__device_release_driver+0x58/0xb0)
[ 3841.292098] [<c02371bc>] (__device_release_driver+0x58/0xb0) from [<c0237230>] (device_release_driver+0x1c/0x28)
[ 3841.292124] [<c0237230>] (device_release_driver+0x1c/0x28) from [<c0236d38>] (bus_remove_device+0xc4/0xe4)
[ 3841.292163] [<c0236d38>] (bus_remove_device+0xc4/0xe4) from [<c0234ed8>] (device_del+0xf8/0x17c)
[ 3841.292190] [<c0234ed8>] (device_del+0xf8/0x17c) from [<c0276020>] (usb_disable_device+0xa0/0x1c8)
[ 3841.292246] [<c0276020>] (usb_disable_device+0xa0/0x1c8) from [<c026f2c0>] (usb_disconnect+0x7c/0x124)
[ 3841.292275] [<c026f2c0>] (usb_disconnect+0x7c/0x124) from [<c026f2a8>] (usb_disconnect+0x64/0x124)
[ 3961.294812] INFO: task khubd:14 blocked for more than 120 seconds.
[ 3961.294838] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 3961.294852] khubd D c0398198 0 14 2 0x00000000
[ 3961.295088] [<c0398198>] (__schedule+0x2c4/0x5b0) from [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core])
[ 3961.295243] [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core]) from [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb])
[ 3961.295317] [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb]) from [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb])
[ 3961.295368] [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb]) from [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb])
[ 3961.295427] [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb]) from [<c0277944>] (usb_unbind_interface+0x48/0x108)
[ 3961.295460] [<c0277944>] (usb_unbind_interface+0x48/0x108) from [<c02371bc>] (__device_release_driver+0x58/0xb0)
[ 3961.295485] [<c02371bc>] (__device_release_driver+0x58/0xb0) from [<c0237230>] (device_release_driver+0x1c/0x28)
[ 3961.295509] [<c0237230>] (device_release_driver+0x1c/0x28) from [<c0236d38>] (bus_remove_device+0xc4/0xe4)
[ 3961.295556] [<c0236d38>] (bus_remove_device+0xc4/0xe4) from [<c0234ed8>] (device_del+0xf8/0x17c)
[ 3961.295584] [<c0234ed8>] (device_del+0xf8/0x17c) from [<c0276020>] (usb_disable_device+0xa0/0x1c8)
[ 3961.295623] [<c0276020>] (usb_disable_device+0xa0/0x1c8) from [<c026f2c0>] (usb_disconnect+0x7c/0x124)
[ 3961.295659] [<c026f2c0>] (usb_disconnect+0x7c/0x124) from [<c026f2a8>] (usb_disconnect+0x64/0x124)
[ 4081.298303] INFO: task khubd:14 blocked for more than 120 seconds.
[ 4081.298342] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 4081.298357] khubd D c0398198 0 14 2 0x00000000
[ 4081.298579] [<c0398198>] (__schedule+0x2c4/0x5b0) from [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core])
[ 4081.298727] [<bf019fec>] (dvb_unregister_frontend+0xac/0x104 [dvb_core]) from [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb])
[ 4081.298801] [<bf035510>] (dvb_usb_adapter_frontend_exit+0x34/0x54 [dvb_usb]) from [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb])
[ 4081.298863] [<bf03436c>] (dvb_usb_exit+0x40/0xac [dvb_usb]) from [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb])
[ 4081.298910] [<bf034418>] (dvb_usb_device_exit+0x40/0x60 [dvb_usb]) from [<c0277944>] (usb_unbind_interface+0x48/0x108)
[ 4081.298942] [<c0277944>] (usb_unbind_interface+0x48/0x108) from [<c02371bc>] (__device_release_driver+0x58/0xb0)
[ 4081.298980] [<c02371bc>] (__device_release_driver+0x58/0xb0) from [<c0237230>] (device_release_driver+0x1c/0x28)
[ 4081.299006] [<c0237230>] (device_release_driver+0x1c/0x28) from [<c0236d38>] (bus_remove_device+0xc4/0xe4)
[ 4081.299041] [<c0236d38>] (bus_remove_device+0xc4/0xe4) from [<c0234ed8>] (device_del+0xf8/0x17c)
[ 4081.299080] [<c0234ed8>] (device_del+0xf8/0x17c) from [<c0276020>] (usb_disable_device+0xa0/0x1c8)
[ 4081.299119] [<c0276020>] (usb_disable_device+0xa0/0x1c8) from [<c026f2c0>] (usb_disconnect+0x7c/0x124)
[ 4081.299147] [<c026f2c0>] (usb_disconnect+0x7c/0x124) from [<c026f2a8>] (usb_disconnect+0x64/0x124)
Dilligaf
Re: usb disk - data corruption - due to overclocking?
Fri Feb 01, 2013 5:36 pm
Are you sure you're booting off usb? in all your pastes I see this:
Which states root=/dev/mmcblk0p2 and not /dev/sda* which would be a usb drive. When posting logs try to use the code tags, they make reading much easier.
The wiki page about checking F3 fuse is wrong, you need the system powered with everything plugged in when checking for volt drop, not with everything unplugged as written in the instructions. Please recheck it with the system powered, also check the TP voltage with the system powered
Dilligaf
Fri Feb 01, 2013 5:53 pm
Just realized that you never said you were booting of the usb devices, check power while loaded
xnosek00
Fri Feb 01, 2013 6:09 pm
no, I'm not booting from USB disk. I'm booting from usb card. I have only data on USB disk (films and other files). Disk is connected through USB port.
I check F3 fuse again with powered system with everything plugged in. Voltage distance is good - 0.12V.
xnosek00
Fri Feb 01, 2013 6:32 pm
TP1 / TP2
when booting RasPi - multimeter shows me 5.28V, then 5.24V
After a while multimeter shows me average 5.19 V
stupid_boy
Fri Feb 01, 2013 6:45 pm
logs says your disk is also attached to your hub,along with DVB stick.
logs says there are some resets of USB hub.
try without DVB dongle. usually they are very power hungry, and not all of them are (fully) supported on RPI. next remove USB hub at all.
make sure your disk is really powered by its power supply and that it work stable for long time on some PC for example. if you can, add more USB devices to that PC while you test disk ( idea is to suck extra power from PC usbs and to leave disk only on its own ).
make sure there is no back-powering across 3 mentioned power supplies. also if one of them fail from time to time, entire system will try to compensate by using others, which can get overloaded too. 3 power supplies across virtually one wire is not easy task and hard to track for problems. eventually thing about eliminating 2 of them.
xnosek00
Mon Feb 25, 2013 9:55 pm
tested without DVB-T Dongle, with USB disk. It was stable for a week (700MHz).
Now overlocked to 950 MHz, without DVB-T dongle and with USB disk. Everything seems stable now. I will wait for a week.
After a week, I will try to connect another DVB-T dongle.
xnosek00
Mon Feb 25, 2013 10:47 pm
after turning on printer, I can see this:
[73599.964853] usb 1-1.3.4.2: new high-speed USB device number 7 using dwc_otg
[73600.066947] usb 1-1.3.4.2: New USB device found, idVendor=04e8, idProduct=341b
[73600.066976] usb 1-1.3.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[73600.066990] usb 1-1.3.4.2: Product: SCX-4200 Series
[73600.067001] usb 1-1.3.4.2: Manufacturer: Samsung
[73600.067011] usb 1-1.3.4.2: SerialNumber: 8T21BAIQ403726P.
[73837.921178] usb 1-1.3.4.2: reset high-speed USB device number 7 using dwc_otg
is it problem?
USB disk is connected directly to the RasPi. Printer is connected into the powered usb hub.
xnosek00
Wed Feb 27, 2013 11:23 pm
nothing happened on yesterday. My printer is connected and turned on 2 days.
Today, I can see this under the last posted lines:
[281441.043786] smsc95xx 1-1.1:1.0: eth0: link down
[281519.252780] hub 1-1:1.0: port 3 disabled by hub (EMI?), re-enabling...
[281519.252820] usb 1-1.3: USB disconnect, device number 5
[281519.252835] usb 1-1.3.4: USB disconnect, device number 6
[281519.252846] usb 1-1.3.4.2: USB disconnect, device number 7
[281519.489698] usb 1-1.3: new high-speed USB device number 8 using dwc_otg
[281519.590709] usb 1-1.3: New USB device found, idVendor=1a40, idProduct=0101
[281519.590738] usb 1-1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[281519.590752] usb 1-1.3: Product: USB 2.0 Hub [MTT]
[281519.594975] hub 1-1.3:1.0: USB hub found
[281519.595247] hub 1-1.3:1.0: 4 ports detected
[281519.869905] usb 1-1.3.4: new high-speed USB device number 9 using dwc_otg
[281519.970752] usb 1-1.3.4: New USB device found, idVendor=1a40, idProduct=0101
[281519.970779] usb 1-1.3.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[281519.970791] usb 1-1.3.4: Product: USB 2.0 Hub [MTT]
[281519.974574] hub 1-1.3.4:1.0: USB hub found
[281519.974911] hub 1-1.3.4:1.0: 4 ports detected
[281520.249794] usb 1-1.3.4.2: new high-speed USB device number 10 using dwc_otg
[281520.351824] usb 1-1.3.4.2: New USB device found, idVendor=04e8, idProduct=341b
[281520.351853] usb 1-1.3.4.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[281520.351867] usb 1-1.3.4.2: Product: SCX-4200 Series
[281520.351877] usb 1-1.3.4.2: Manufacturer: Samsung
[281520.351887] usb 1-1.3.4.2: SerialNumber: 8T21BAIQ403726P.
what is happening? My LAN was disconnected for a while. But what is happening with my USB hub?
(USB disk is connected directly to the RasPi).
kaiwan
Thu Jul 18, 2013 8:03 am
Not sure if this helps, but FYI, I have recently written a tutorial on debugging kernel issues on the Raspberry Pi using the popular KDB and KGDB tools:
http://kaiwantech.wordpress.com/2013/07 ... nux-board/
HTH,
Kaiwan.
xnosek00
Tue Jul 23, 2013 8:39 pm
1 month OK, today - disk not mounted. Dmesg says:
[  190.430929] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[  190.444294] XFS (dm-5): Mounting Filesystem
[  191.916478] XFS (dm-5): Starting recovery (logdev: internal)
[  192.726238] XFS (dm-5): Ending recovery (logdev: internal)
[  193.422838] EXT4-fs (dm-6): recovery complete
[  193.424726] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
[  193.813432] XFS (dm-7): Mounting Filesystem
[  195.276876] XFS (dm-7): Ending clean mount
[  195.695626] EXT4-fs (dm-8): recovery complete
[  195.697250] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
[  198.682944] EXT4-fs (dm-9): recovery complete
[  198.684531] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null)
[43637.679769] usb 1-1.2.2: USB disconnect, device number 13
[43637.689000] scsi 4:0:0:0: rejecting I/O to offline device
[43637.689031] scsi 4:0:0:0: killing request
[43641.908880] usb 1-1.2.2: new high-speed USB device number 14 using dwc_otg
[43642.011209] usb 1-1.2.2: New USB device found, idVendor=12d1, idProduct=1520
[43642.011256] usb 1-1.2.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[43642.011275] usb 1-1.2.2: Product: HUAWEI Mobile
[43642.011288] usb 1-1.2.2: Manufacturer: HUAWEI Technology
[43642.028808] scsi5 : usb-storage 1-1.2.2:1.0
[43643.030198] scsi 5:0:0:0: CD-ROM            Vodafone CD ROM (Huawei)  2.31 PQ: 0 ANSI: 2
[43643.035817] sr0: scsi-1 drive
[43643.036707] sr 5:0:0:0: Attached scsi CD-ROM sr0
[43655.694602] dwc_otg bcm2708_usb: dev 1.2.2 ep1in scatterlist error -104/-121
[43655.694760] dwc_otg bcm2708_usb: dev 1.2.2 ep1in scatterlist error -104/-121
[43716.899736] usb 1-1.2.2: reset high-speed USB device number 14 using dwc_otg
[43716.920547] sr 5:0:0:0: Device offlined - not ready after error recovery
[43716.921254] sr 5:0:0:0: rejecting I/O to offline device
[43716.922322] sr 5:0:0:0: rejecting I/O to offline device
[43716.922387] sr 5:0:0:0: rejecting I/O to offline device
[43716.922928] usb 1-1.2.2: USB disconnect, device number 14
[43717.159739] usb 1-1.2.2: new high-speed USB device number 15 using dwc_otg
[43717.262303] usb 1-1.2.2: New USB device found, idVendor=12d1, idProduct=1520
[43717.262351] usb 1-1.2.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[43717.262369] usb 1-1.2.2: Product: HUAWEI Mobile
[43717.262382] usb 1-1.2.2: Manufacturer: HUAWEI Technology
[43717.279521] scsi6 : usb-storage 1-1.2.2:1.0
[43718.281152] scsi 6:0:0:0: CD-ROM            Vodafone CD ROM (Huawei)  2.31 PQ: 0 ANSI: 2
[43718.287540] sr0: scsi-1 drive
[43718.288581] sr 6:0:0:0: Attached scsi CD-ROM sr0
[46088.594392] usb 1-1.2.2: USB disconnect, device number 15
[46092.928613] usb 1-1.2.2: new high-speed USB device number 16 using dwc_otg
[46093.030829] usb 1-1.2.2: New USB device found, idVendor=12d1, idProduct=1520
[46093.030876] usb 1-1.2.2: New USB device strings: Mfr=3, Product=2, SerialNumber=0
[46093.030895] usb 1-1.2.2: Product: HUAWEI Mobile
[46093.030909] usb 1-1.2.2: Manufacturer: HUAWEI Technology
[46093.039910] scsi7 : usb-storage 1-1.2.2:1.0
[46094.041432] scsi 7:0:0:0: CD-ROM            Vodafone CD ROM (Huawei)  2.31 PQ: 0 ANSI: 2
[46094.047180] sr0: scsi-1 drive
[46094.048316] sr 7:0:0:0: Attached scsi CD-ROM sr0
[46154.849573] usb 1-1.2.2: reset high-speed USB device number 16 using dwc_otg
[46215.970375] usb 1-1.2.2: reset high-speed USB device number 16 using dwc_otg
[46276.930898] usb 1-1.2.2: reset high-speed USB device number 16 using dwc_otg
[666343.502611] sd 0:0:0:0: [sda] Unhandled sense code
[666343.502645] sd 0:0:0:0: [sda]
[666343.502657] Result: hostbyte=0x07 driverbyte=0x08
[666343.502672] sd 0:0:0:0: [sda]
[666343.502694] Sense Key : 0x4 [current]
[666343.502718] sd 0:0:0:0: [sda]
[666343.502727] ASC=0x0 ASCQ=0x0
[666343.502741] sd 0:0:0:0: [sda] CDB:
[666343.502749] cdb[0]=0x2a: 2a 00 02 c9 c2 8f 00 00 f0 00
[666343.502786] end_request: I/O error, dev sda, sector 46776975
[666363.249531] sd 0:0:0:0: [sda] Unhandled sense code
[666363.249565] sd 0:0:0:0: [sda]
[666363.249577] Result: hostbyte=0x07 driverbyte=0x08
[666363.249590] sd 0:0:0:0: [sda]
[666363.249599] Sense Key : 0x4 [current]
[666363.249635] sd 0:0:0:0: [sda]
[666363.249645] ASC=0x0 ASCQ=0x0
[666363.249661] sd 0:0:0:0: [sda] CDB:
[666363.249670] cdb[0]=0x2a: 2a 00 02 c9 c3 7f 00 00 f0 00
[666363.249707] end_request: I/O error, dev sda, sector 46777215
[666382.969962] sd 0:0:0:0: [sda] Unhandled sense code
[666382.969996] sd 0:0:0:0: [sda]
[666382.970007] Result: hostbyte=0x07 driverbyte=0x08
[666382.970019] sd 0:0:0:0: [sda]
[666382.970028] Sense Key : 0x4 [current]
[666382.970065] sd 0:0:0:0: [sda]
[666382.970075] ASC=0x0 ASCQ=0x0
[666382.970089] sd 0:0:0:0: [sda] CDB:
[666382.970098] cdb[0]=0x2a: 2a 00 02 c9 c4 6f 00 00 f0 00
[666382.970135] end_request: I/O error, dev sda, sector 46777455
[666402.690769] sd 0:0:0:0: [sda] Unhandled sense code
[666402.690803] sd 0:0:0:0: [sda]
[666402.690815] Result: hostbyte=0x07 driverbyte=0x08
[666402.690828] sd 0:0:0:0: [sda]
[666402.690838] Sense Key : 0x4 [current]
[666402.690872] sd 0:0:0:0: [sda]
[666402.690883] ASC=0x0 ASCQ=0x0
[666402.690898] sd 0:0:0:0: [sda] CDB:
[666402.690907] cdb[0]=0x2a: 2a 00 02 c9 c5 5f 00 00 f0 00
[666402.690945] end_request: I/O error, dev sda, sector 46777695
[666422.450441] sd 0:0:0:0: [sda] Unhandled sense code
[666422.450474] sd 0:0:0:0: [sda]
[666422.450486] Result: hostbyte=0x07 driverbyte=0x08
[666422.450499] sd 0:0:0:0: [sda]
[666422.450508] Sense Key : 0x4 [current]
[666422.450543] sd 0:0:0:0: [sda]
[666422.450554] ASC=0x0 ASCQ=0x0
[666422.450569] sd 0:0:0:0: [sda] CDB:
[666422.450578] cdb[0]=0x2a: 2a 00 02 c9 c6 4f 00 00 f0 00
[666422.450615] end_request: I/O error, dev sda, sector 46777935
[666442.171801] sd 0:0:0:0: [sda] Unhandled sense code
[666442.171857] sd 0:0:0:0: [sda]
[666442.171872] Result: hostbyte=0x07 driverbyte=0x08
[666442.171886] sd 0:0:0:0: [sda]
[666442.171895] Sense Key : 0x4 [current]
[666442.171916] sd 0:0:0:0: [sda]
[666442.171925] ASC=0x0 ASCQ=0x0
[666442.171939] sd 0:0:0:0: [sda] CDB:
[666442.171947] cdb[0]=0x2a: 2a 00 02 c9 c7 3f 00 00 f0 00
[666442.172009] end_request: I/O error, dev sda, sector 46778175
[666461.931188] sd 0:0:0:0: [sda] Unhandled sense code
[666461.931221] sd 0:0:0:0: [sda]
[666461.931234] Result: hostbyte=0x07 driverbyte=0x08
[666461.931246] sd 0:0:0:0: [sda]
[666461.931256] Sense Key : 0x4 [current]
[666461.931292] sd 0:0:0:0: [sda]
[666461.931302] ASC=0x0 ASCQ=0x0
[666461.931318] sd 0:0:0:0: [sda] CDB:
[666461.931360] cdb[0]=0x2a: 2a 00 02 c9 c8 2f 00 00 f0 00
[666461.931414] end_request: I/O error, dev sda, sector 46778415
[666481.664991] sd 0:0:0:0: [sda] Unhandled sense code
[666481.665025] sd 0:0:0:0: [sda]
[666481.665037] Result: hostbyte=0x07 driverbyte=0x08
[666481.665049] sd 0:0:0:0: [sda]
[666481.665058] Sense Key : 0x4 [current]
[666481.665094] sd 0:0:0:0: [sda]
[666481.665104] ASC=0x0 ASCQ=0x0
[666481.665118] sd 0:0:0:0: [sda] CDB:
[666481.665127] cdb[0]=0x2a: 2a 00 02 c9 c9 1f 00 00 f0 00
[666481.665165] end_request: I/O error, dev sda, sector 46778655
[666488.997669] INFO: task tvheadend:20550 blocked for more than 120 seconds.
[666488.997707] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[666488.997721] tvheadend       D c0398690     0 20550      1 0x00000000
[666488.997800] [<c0398690>] (__schedule+0x2c4/0x5b0) from [<c0398f18>] (io_schedule+0x88/0xe4)
[666488.997861] [<c0398f18>] (io_schedule+0x88/0xe4) from [<c008e0d8>] (sleep_on_page+0x8/0x10)
[666488.997894] [<c008e0d8>] (sleep_on_page+0x8/0x10) from [<c0397528>] (__wait_on_bit+0x7c/0xb4)
[666488.997921] [<c0397528>] (__wait_on_bit+0x7c/0xb4) from [<c008e2fc>] (wait_on_page_bit+0xa0/0xb8)
[666488.997950] [<c008e2fc>] (wait_on_page_bit+0xa0/0xb8) from [<c008ea8c>] (grab_cache_page_write_begin+0xa0/0xc4)
[666488.998294] [<c008ea8c>] (grab_cache_page_write_begin+0xa0/0xc4) from [<bf113324>] (xfs_vm_write_begin+0x2c/0x164 [xfs])
[666488.998531] [<bf113324>] (xfs_vm_write_begin+0x2c/0x164 [xfs]) from [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c)
[666488.998763] [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c) from [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs])
[666488.999139] [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs]) from [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs])
[666488.999377] [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs]) from [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc)
[666488.999428] [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc) from [<c00c1de8>] (do_readv_writev+0xa8/0x178)
[666488.999468] [<c00c1de8>] (do_readv_writev+0xa8/0x178) from [<c00c1f04>] (vfs_writev+0x4c/0x70)
[666488.999494] [<c00c1f04>] (vfs_writev+0x4c/0x70) from [<c00c2090>] (sys_writev+0x38/0xc8)
[666488.999527] [<c00c2090>] (sys_writev+0x38/0xc8) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[666501.411802] sd 0:0:0:0: [sda] Unhandled sense code
[666501.411836] sd 0:0:0:0: [sda]
[666501.411848] Result: hostbyte=0x07 driverbyte=0x08
[666501.411861] sd 0:0:0:0: [sda]
[666501.411870] Sense Key : 0x4 [current]
[666501.411915] sd 0:0:0:0: [sda]
[666501.411926] ASC=0x0 ASCQ=0x0
[666501.411942] sd 0:0:0:0: [sda] CDB:
[666501.411951] cdb[0]=0x2a: 2a 00 02 c9 ca 0f 00 00 f0 00
[666501.411989] end_request: I/O error, dev sda, sector 46778895
[666521.132347] sd 0:0:0:0: [sda] Unhandled sense code
[666521.132380] sd 0:0:0:0: [sda]
[666521.132392] Result: hostbyte=0x07 driverbyte=0x08
[666521.132404] sd 0:0:0:0: [sda]
[666521.132413] Sense Key : 0x4 [current]
[666521.132449] sd 0:0:0:0: [sda]
[666521.132460] ASC=0x0 ASCQ=0x0
[666521.132475] sd 0:0:0:0: [sda] CDB:
[666521.132484] cdb[0]=0x2a: 2a 00 02 c9 ca ff 00 00 f0 00
[666521.132522] end_request: I/O error, dev sda, sector 46779135
[666540.892286] sd 0:0:0:0: [sda] Unhandled sense code
[666540.892319] sd 0:0:0:0: [sda]
[666540.892331] Result: hostbyte=0x07 driverbyte=0x08
[666540.892344] sd 0:0:0:0: [sda]
[666540.892353] Sense Key : 0x4 [current]
[666540.892389] sd 0:0:0:0: [sda]
[666540.892399] ASC=0x0 ASCQ=0x0
[666540.892414] sd 0:0:0:0: [sda] CDB:
[666540.892423] cdb[0]=0x2a: 2a 00 02 c9 cb ef 00 00 f0 00
[666540.892461] end_request: I/O error, dev sda, sector 46779375
[666560.652476] sd 0:0:0:0: [sda] Unhandled sense code
[666560.652510] sd 0:0:0:0: [sda]
[666560.652523] Result: hostbyte=0x07 driverbyte=0x08
[666560.652535] sd 0:0:0:0: [sda]
[666560.652544] Sense Key : 0x4 [current]
[666560.652580] sd 0:0:0:0: [sda]
[666560.652590] ASC=0x0 ASCQ=0x0
[666560.652605] sd 0:0:0:0: [sda] CDB:
[666560.652614] cdb[0]=0x2a: 2a 00 02 c9 cc df 00 00 f0 00
[666560.652652] end_request: I/O error, dev sda, sector 46779615
[666580.373032] sd 0:0:0:0: [sda] Unhandled sense code
[666580.373065] sd 0:0:0:0: [sda]
[666580.373078] Result: hostbyte=0x07 driverbyte=0x08
[666580.373091] sd 0:0:0:0: [sda]
[666580.373101] Sense Key : 0x4 [current]
[666580.373135] sd 0:0:0:0: [sda]
[666580.373146] ASC=0x0 ASCQ=0x0
[666580.373161] sd 0:0:0:0: [sda] CDB:
[666580.373171] cdb[0]=0x2a: 2a 00 02 c9 cd cf 00 00 f0 00
[666580.373207] end_request: I/O error, dev sda, sector 46779855
[666600.132705] sd 0:0:0:0: [sda] Unhandled sense code
[666600.132738] sd 0:0:0:0: [sda]
[666600.132749] Result: hostbyte=0x07 driverbyte=0x08
[666600.132762] sd 0:0:0:0: [sda]
[666600.132771] Sense Key : 0x4 [current]
[666600.132805] sd 0:0:0:0: [sda]
[666600.132816] ASC=0x0 ASCQ=0x0
[666600.132832] sd 0:0:0:0: [sda] CDB:
[666600.132840] cdb[0]=0x2a: 2a 00 02 c9 ce bf 00 00 f0 00
[666600.132879] end_request: I/O error, dev sda, sector 46780095
[666608.999119] INFO: task tvheadend:20550 blocked for more than 120 seconds.
[666608.999165] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[666608.999180] tvheadend       D c0398690     0 20550      1 0x00000000
[666608.999261] [<c0398690>] (__schedule+0x2c4/0x5b0) from [<c0398f18>] (io_schedule+0x88/0xe4)
[666608.999322] [<c0398f18>] (io_schedule+0x88/0xe4) from [<c008e0d8>] (sleep_on_page+0x8/0x10)
[666608.999354] [<c008e0d8>] (sleep_on_page+0x8/0x10) from [<c0397528>] (__wait_on_bit+0x7c/0xb4)
[666608.999382] [<c0397528>] (__wait_on_bit+0x7c/0xb4) from [<c008e2fc>] (wait_on_page_bit+0xa0/0xb8)
[666608.999423] [<c008e2fc>] (wait_on_page_bit+0xa0/0xb8) from [<c008ea8c>] (grab_cache_page_write_begin+0xa0/0xc4)
[666608.999753] [<c008ea8c>] (grab_cache_page_write_begin+0xa0/0xc4) from [<bf113324>] (xfs_vm_write_begin+0x2c/0x164 [xfs])
[666608.999972] [<bf113324>] (xfs_vm_write_begin+0x2c/0x164 [xfs]) from [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c)
[666609.000202] [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c) from [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs])
[666609.000591] [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs]) from [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs])
[666609.000833] [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs]) from [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc)
[666609.000885] [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc) from [<c00c1de8>] (do_readv_writev+0xa8/0x178)
[666609.000926] [<c00c1de8>] (do_readv_writev+0xa8/0x178) from [<c00c1f04>] (vfs_writev+0x4c/0x70)
[666609.000953] [<c00c1f04>] (vfs_writev+0x4c/0x70) from [<c00c2090>] (sys_writev+0x38/0xc8)
[666609.000985] [<c00c2090>] (sys_writev+0x38/0xc8) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[666619.853392] sd 0:0:0:0: [sda] Unhandled sense code
[666619.853425] sd 0:0:0:0: [sda]
[666619.853436] Result: hostbyte=0x07 driverbyte=0x08
[666619.853449] sd 0:0:0:0: [sda]
[666619.853458] Sense Key : 0x4 [current]
[666619.853494] sd 0:0:0:0: [sda]
[666619.853504] ASC=0x0 ASCQ=0x0
[666619.853519] sd 0:0:0:0: [sda] CDB:
[666619.853528] cdb[0]=0x2a: 2a 00 02 c9 cf af 00 00 f0 00
[666619.853566] end_request: I/O error, dev sda, sector 46780335
[666639.613205] sd 0:0:0:0: [sda] Unhandled sense code
[666639.613238] sd 0:0:0:0: [sda]
[666639.613251] Result: hostbyte=0x07 driverbyte=0x08
[666639.613263] sd 0:0:0:0: [sda]
[666639.613274] Sense Key : 0x4 [current]
[666639.613310] sd 0:0:0:0: [sda]
[666639.613320] ASC=0x0 ASCQ=0x0
[666639.613335] sd 0:0:0:0: [sda] CDB:
[666639.613344] cdb[0]=0x2a: 2a 00 02 c9 d0 9f 00 00 f0 00
[666639.613382] end_request: I/O error, dev sda, sector 46780575
[666659.373394] sd 0:0:0:0: [sda] Unhandled sense code
[666659.373428] sd 0:0:0:0: [sda]
[666659.373440] Result: hostbyte=0x07 driverbyte=0x08
[666659.373452] sd 0:0:0:0: [sda]
[666659.373475] Sense Key : 0x4 [current]
[666659.373497] sd 0:0:0:0: [sda]
[666659.373507] ASC=0x0 ASCQ=0x0
[666659.373521] sd 0:0:0:0: [sda] CDB:
[666659.373530] cdb[0]=0x2a: 2a 00 02 c9 d1 8f 00 00 f0 00
[666659.373567] end_request: I/O error, dev sda, sector 46780815
[666679.093806] sd 0:0:0:0: [sda] Unhandled sense code
[666679.093840] sd 0:0:0:0: [sda]
[666679.093852] Result: hostbyte=0x07 driverbyte=0x08
[666679.093865] sd 0:0:0:0: [sda]
[666679.093874] Sense Key : 0x4 [current]
[666679.093909] sd 0:0:0:0: [sda]
[666679.093920] ASC=0x0 ASCQ=0x0
[666679.093935] sd 0:0:0:0: [sda] CDB:
[666679.093943] cdb[0]=0x2a: 2a 00 02 c9 d2 7f 00 00 f0 00
[666679.093981] end_request: I/O error, dev sda, sector 46781055
[666698.814498] sd 0:0:0:0: [sda] Unhandled sense code
[666698.814533] sd 0:0:0:0: [sda]
[666698.814544] Result: hostbyte=0x07 driverbyte=0x08
[666698.814556] sd 0:0:0:0: [sda]
[666698.814565] Sense Key : 0x4 [current]
[666698.814602] sd 0:0:0:0: [sda]
[666698.814613] ASC=0x0 ASCQ=0x0
[666698.814628] sd 0:0:0:0: [sda] CDB:
[666698.814638] cdb[0]=0x2a: 2a 00 02 c9 d3 6f 00 00 f0 00
[666698.814675] end_request: I/O error, dev sda, sector 46781295
[666718.574439] sd 0:0:0:0: [sda] Unhandled sense code
[666718.574472] sd 0:0:0:0: [sda]
[666718.574483] Result: hostbyte=0x07 driverbyte=0x08
[666718.574496] sd 0:0:0:0: [sda]
[666718.574518] Sense Key : 0x4 [current]
[666718.574541] sd 0:0:0:0: [sda]
[666718.574550] ASC=0x0 ASCQ=0x0
[666718.574566] sd 0:0:0:0: [sda] CDB:
[666718.574574] cdb[0]=0x2a: 2a 00 02 c9 d4 5f 00 00 f0 00
[666718.574611] end_request: I/O error, dev sda, sector 46781535
[666729.000484] INFO: task tvheadend:20550 blocked for more than 120 seconds.
[666729.000508] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[666729.000520] tvheadend       D c0398690     0 20550      1 0x00000000
[666729.000613] [<c0398690>] (__schedule+0x2c4/0x5b0) from [<c0398f18>] (io_schedule+0x88/0xe4)
[666729.000659] [<c0398f18>] (io_schedule+0x88/0xe4) from [<c008e0d8>] (sleep_on_page+0x8/0x10)
[666729.000706] [<c008e0d8>] (sleep_on_page+0x8/0x10) from [<c0397528>] (__wait_on_bit+0x7c/0xb4)
[666729.000738] [<c0397528>] (__wait_on_bit+0x7c/0xb4) from [<c008e2fc>] (wait_on_page_bit+0xa0/0xb8)
[666729.000766] [<c008e2fc>] (wait_on_page_bit+0xa0/0xb8) from [<c008ea8c>] (grab_cache_page_write_begin+0xa0/0xc4)
[666729.001095] [<c008ea8c>] (grab_cache_page_write_begin+0xa0/0xc4) from [<bf113324>] (xfs_vm_write_begin+0x2c/0x164 [xfs])
[666729.001314] [<bf113324>] (xfs_vm_write_begin+0x2c/0x164 [xfs]) from [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c)
[666729.001547] [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c) from [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs])
[666729.001939] [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs]) from [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs])
[666729.002178] [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs]) from [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc)
[666729.002230] [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc) from [<c00c1de8>] (do_readv_writev+0xa8/0x178)
[666729.002258] [<c00c1de8>] (do_readv_writev+0xa8/0x178) from [<c00c1f04>] (vfs_writev+0x4c/0x70)
[666729.002283] [<c00c1f04>] (vfs_writev+0x4c/0x70) from [<c00c2090>] (sys_writev+0x38/0xc8)
[666729.002316] [<c00c2090>] (sys_writev+0x38/0xc8) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[666738.334397] sd 0:0:0:0: [sda] Unhandled sense code
[666738.334431] sd 0:0:0:0: [sda]
[666738.334459] Result: hostbyte=0x07 driverbyte=0x08
[666738.334474] sd 0:0:0:0: [sda]
[666738.334484] Sense Key : 0x4 [current]
[666738.334505] sd 0:0:0:0: [sda]
[666738.334514] ASC=0x0 ASCQ=0x0
[666738.334528] sd 0:0:0:0: [sda] CDB:
[666738.334537] cdb[0]=0x2a: 2a 00 02 c9 d5 4f 00 00 c8 00
[666738.334588] end_request: I/O error, dev sda, sector 46781775
[666738.334772] Buffer I/O error on device dm-5, logical block 5846346
[666738.334788] lost page write due to I/O error on dm-5
[666738.334814] Buffer I/O error on device dm-5, logical block 5846347
[666738.334839] lost page write due to I/O error on dm-5
[666738.334856] Buffer I/O error on device dm-5, logical block 5846348
[666738.334865] lost page write due to I/O error on dm-5
[666738.334878] Buffer I/O error on device dm-5, logical block 5846349
[666738.334886] lost page write due to I/O error on dm-5
[666738.334899] Buffer I/O error on device dm-5, logical block 5846350
[666738.334908] lost page write due to I/O error on dm-5
[666738.334920] Buffer I/O error on device dm-5, logical block 5846351
[666738.334928] lost page write due to I/O error on dm-5
[666738.334953] Buffer I/O error on device dm-5, logical block 5846352
[666738.334963] lost page write due to I/O error on dm-5
[666738.334977] Buffer I/O error on device dm-5, logical block 5846353
[666738.334986] lost page write due to I/O error on dm-5
[666738.334999] Buffer I/O error on device dm-5, logical block 5846354
[666738.335007] lost page write due to I/O error on dm-5
[666738.335020] Buffer I/O error on device dm-5, logical block 5846355
[666738.335028] lost page write due to I/O error on dm-5
[666759.273586] sd 0:0:0:0: [sda] Unhandled sense code
[666759.273619] sd 0:0:0:0: [sda]
[666759.273631] Result: hostbyte=0x07 driverbyte=0x08
[666759.273644] sd 0:0:0:0: [sda]
[666759.273653] Sense Key : 0x4 [current]
[666759.273690] sd 0:0:0:0: [sda]
[666759.273700] ASC=0x0 ASCQ=0x0
[666759.273715] sd 0:0:0:0: [sda] CDB:
[666759.273724] cdb[0]=0x2a: 2a 00 02 c9 d6 0f 00 00 80 00
[666759.273762] end_request: I/O error, dev sda, sector 46781967
[666759.273913] quiet_error: 615 callbacks suppressed
[666759.273948] Buffer I/O error on device dm-5, logical block 5846970
[666759.273960] lost page write due to I/O error on dm-5
[666759.273985] Buffer I/O error on device dm-5, logical block 5846971
[666759.273994] lost page write due to I/O error on dm-5
[666759.274007] Buffer I/O error on device dm-5, logical block 5846972
[666759.274015] lost page write due to I/O error on dm-5
[666759.274027] Buffer I/O error on device dm-5, logical block 5846973
[666759.274049] lost page write due to I/O error on dm-5
[666759.274064] Buffer I/O error on device dm-5, logical block 5846974
[666759.274073] lost page write due to I/O error on dm-5
[666759.274086] Buffer I/O error on device dm-5, logical block 5846975
[666759.274094] lost page write due to I/O error on dm-5
[666759.274106] Buffer I/O error on device dm-5, logical block 5846976
[666759.274115] lost page write due to I/O error on dm-5
[666759.274126] Buffer I/O error on device dm-5, logical block 5846977
[666759.274134] lost page write due to I/O error on dm-5
[666759.274146] Buffer I/O error on device dm-5, logical block 5846978
[666759.274156] lost page write due to I/O error on dm-5
[666759.274178] Buffer I/O error on device dm-5, logical block 5846979
[666759.274188] lost page write due to I/O error on dm-5
[666778.994134] sd 0:0:0:0: [sda] Unhandled sense code
[666778.994167] sd 0:0:0:0: [sda]
[666778.994178] Result: hostbyte=0x07 driverbyte=0x08
[666778.994191] sd 0:0:0:0: [sda]
[666778.994199] Sense Key : 0x4 [current]
[666778.994235] sd 0:0:0:0: [sda]
[666778.994245] ASC=0x0 ASCQ=0x0
[666778.994260] sd 0:0:0:0: [sda] CDB:
[666778.994268] cdb[0]=0x2a: 2a 00 06 40 49 05 00 00 21 00
[666778.994308] end_request: I/O error, dev sda, sector 104876293
[666778.994442] XFS (dm-5): metadata I/O error: block 0x64030c6 ("xlog_iodone") error 5 numblks 64
[666779.007681] XFS (dm-5): xfs_do_force_shutdown(0x2) called from line 1074 of file fs/xfs/xfs_log.c.  Return address = 0xbf161278
[666779.008238] XFS (dm-5): Log I/O Error Detected.  Shutting down filesystem
[666779.018409] XFS (dm-5): xfs_log_force: error 5 returned.
[666779.018709] XFS (dm-5): Please umount the filesystem and rectify the problem(s)
[666969.003313] INFO: task tvheadend:20550 blocked for more than 120 seconds.
[666969.003337] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[666969.003350] tvheadend       D c0398690     0 20550      1 0x00000000
[666969.003429] [<c0398690>] (__schedule+0x2c4/0x5b0) from [<c0399b58>] (__down_write_nested+0xbc/0x110)
[666969.003818] [<c0399b58>] (__down_write_nested+0xbc/0x110) from [<bf11b860>] (xfs_ilock+0x50/0x60 [xfs])
[666969.004210] [<bf11b860>] (xfs_ilock+0x50/0x60 [xfs]) from [<bf112c20>] (__xfs_get_blocks+0x264/0x5c8 [xfs])
[666969.004566] [<bf112c20>] (__xfs_get_blocks+0x264/0x5c8 [xfs]) from [<bf112fd4>] (xfs_get_blocks+0x24/0x2c [xfs])
[666969.004784] [<bf112fd4>] (xfs_get_blocks+0x24/0x2c [xfs]) from [<c00ed4ac>] (__block_write_begin+0x214/0x4e8)
[666969.005004] [<c00ed4ac>] (__block_write_begin+0x214/0x4e8) from [<bf113344>] (xfs_vm_write_begin+0x4c/0x164 [xfs])
[666969.005234] [<bf113344>] (xfs_vm_write_begin+0x4c/0x164 [xfs]) from [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c)
[666969.005464] [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c) from [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs])
[666969.005857] [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs]) from [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs])
[666969.006345] [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs]) from [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc)
[666969.006411] [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc) from [<c00c1de8>] (do_readv_writev+0xa8/0x178)
[666969.006454] [<c00c1de8>] (do_readv_writev+0xa8/0x178) from [<c00c1f04>] (vfs_writev+0x4c/0x70)
[666969.006481] [<c00c1f04>] (vfs_writev+0x4c/0x70) from [<c00c2090>] (sys_writev+0x38/0xc8)
[666969.006514] [<c00c2090>] (sys_writev+0x38/0xc8) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[666969.006579] INFO: task kworker/0:0:20383 blocked for more than 120 seconds.
[666969.006590] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[666969.006600] kworker/0:0     D c0398690     0 20383      2 0x00000000
[666969.006661] [<c0398690>] (__schedule+0x2c4/0x5b0) from [<c03973d0>] (schedule_timeout+0x158/0x1e0)
[666969.006705] [<c03973d0>] (schedule_timeout+0x158/0x1e0) from [<c0398b3c>] (wait_for_common+0xcc/0x198)
[666969.006930] [<c0398b3c>] (wait_for_common+0xcc/0x198) from [<bf115e98>] (xfs_buf_iowait+0x1c/0x24 [xfs])
[666969.007308] [<bf115e98>] (xfs_buf_iowait+0x1c/0x24 [xfs]) from [<bf116008>] (xfs_buf_read_map+0x58/0x78 [xfs])
[666969.007866] [<bf116008>] (xfs_buf_read_map+0x58/0x78 [xfs]) from [<bf167b54>] (xfs_trans_read_buf_map+0x174/0x27c [xfs])
[666969.008457] [<bf167b54>] (xfs_trans_read_buf_map+0x174/0x27c [xfs]) from [<bf13fe54>] (xfs_btree_read_buf_block.constprop.2+0x58/0xac [xfs])
[666969.008978] [<bf13fe54>] (xfs_btree_read_buf_block.constprop.2+0x58/0xac [xfs]) from [<bf13ff28>] (xfs_btree_lookup_get_block+0x80/0xc8 [xfs])
[666969.009539] [<bf13ff28>] (xfs_btree_lookup_get_block+0x80/0xc8 [xfs]) from [<bf142c48>] (xfs_btree_lookup+0xb0/0x3f8 [xfs])
[666969.010044] [<bf142c48>] (xfs_btree_lookup+0xb0/0x3f8 [xfs]) from [<bf12b688>] (xfs_alloc_ag_vextent_size+0x64/0x544 [xfs])
[666969.010506] [<bf12b688>] (xfs_alloc_ag_vextent_size+0x64/0x544 [xfs]) from [<bf12c484>] (xfs_alloc_ag_vextent+0xa4/0x10c [xfs])
[666969.010969] [<bf12c484>] (xfs_alloc_ag_vextent+0xa4/0x10c [xfs]) from [<bf12d200>] (__xfs_alloc_vextent+0x4e0/0x5f4 [xfs])
[666969.011431] [<bf12d200>] (__xfs_alloc_vextent+0x4e0/0x5f4 [xfs]) from [<bf12d340>] (xfs_alloc_vextent_worker+0x2c/0x54 [xfs])
[666969.011715] [<bf12d340>] (xfs_alloc_vextent_worker+0x2c/0x54 [xfs]) from [<c0035010>] (process_one_work+0x150/0x40c)
[666969.011820] [<c0035010>] (process_one_work+0x150/0x40c) from [<c00355f0>] (worker_thread+0x150/0x498)
[666969.011859] [<c00355f0>] (worker_thread+0x150/0x498) from [<c003a7b4>] (kthread+0x88/0x94)
[666969.011894] [<c003a7b4>] (kthread+0x88/0x94) from [<c000e9fc>] (kernel_thread_exit+0x0/0x8)
[666969.011928] INFO: task flush-254:5:20551 blocked for more than 120 seconds.
[666969.011939] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[666969.011949] flush-254:5     D c0398690     0 20551      2 0x00000000
[666969.012004] [<c0398690>] (__schedule+0x2c4/0x5b0) from [<c03973d0>] (schedule_timeout+0x158/0x1e0)
[666969.012034] [<c03973d0>] (schedule_timeout+0x158/0x1e0) from [<c0398b3c>] (wait_for_common+0xcc/0x198)
[666969.012311] [<c0398b3c>] (wait_for_common+0xcc/0x198) from [<bf12d3d0>] (xfs_alloc_vextent+0x68/0x84 [xfs])
[666969.012789] [<bf12d3d0>] (xfs_alloc_vextent+0x68/0x84 [xfs]) from [<bf138eb4>] (xfs_bmap_btalloc+0x3a4/0x764 [xfs])
[666969.013279] [<bf138eb4>] (xfs_bmap_btalloc+0x3a4/0x764 [xfs]) from [<bf139c28>] (xfs_bmapi_allocate+0xb0/0x29c [xfs])
[666969.035542] [<bf139c28>] (xfs_bmapi_allocate+0xb0/0x29c [xfs]) from [<bf13c574>] (xfs_bmapi_write+0x430/0x6b4 [xfs])
[666969.036893] [<bf13c574>] (xfs_bmapi_write+0x430/0x6b4 [xfs]) from [<bf11f820>] (xfs_iomap_write_allocate+0x190/0x3b4 [xfs])
[666969.037301] [<bf11f820>] (xfs_iomap_write_allocate+0x190/0x3b4 [xfs]) from [<bf113688>] (xfs_map_blocks+0x198/0x1b8 [xfs])
[666969.037670] [<bf113688>] (xfs_map_blocks+0x198/0x1b8 [xfs]) from [<bf11400c>] (xfs_vm_writepage+0x21c/0x5c4 [xfs])
[666969.037888] [<bf11400c>] (xfs_vm_writepage+0x21c/0x5c4 [xfs]) from [<c009600c>] (__writepage+0x14/0x40)
[666969.037936] [<c009600c>] (__writepage+0x14/0x40) from [<c00966e0>] (write_cache_pages+0x1d0/0x3c8)
[666969.037962] [<c00966e0>] (write_cache_pages+0x1d0/0x3c8) from [<c0096918>] (generic_writepages+0x40/0x5c)
[666969.037987] [<c0096918>] (generic_writepages+0x40/0x5c) from [<c00979d0>] (do_writepages+0x24/0x38)
[666969.038025] [<c00979d0>] (do_writepages+0x24/0x38) from [<c00e3f5c>] (__writeback_single_inode.isra.20+0x28/0x11c)
[666969.038069] [<c00e3f5c>] (__writeback_single_inode.isra.20+0x28/0x11c) from [<c00e4284>] (writeback_sb_inodes+0x234/0x40c)
[666969.038097] [<c00e4284>] (writeback_sb_inodes+0x234/0x40c) from [<c00e44cc>] (__writeback_inodes_wb+0x70/0xac)
[666969.038123] [<c00e44cc>] (__writeback_inodes_wb+0x70/0xac) from [<c00e46e4>] (wb_writeback+0x1dc/0x204)
[666969.038148] [<c00e46e4>] (wb_writeback+0x1dc/0x204) from [<c00e509c>] (wb_do_writeback+0x134/0x1fc)
[666969.038188] [<c00e509c>] (wb_do_writeback+0x134/0x1fc) from [<c00e51e0>] (bdi_writeback_thread+0x7c/0x150)
[666969.038227] [<c00e51e0>] (bdi_writeback_thread+0x7c/0x150) from [<c003a7b4>] (kthread+0x88/0x94)
[666969.038263] [<c003a7b4>] (kthread+0x88/0x94) from [<c000e9fc>] (kernel_thread_exit+0x0/0x8)
[667089.034709] INFO: task tvheadend:20550 blocked for more than 120 seconds.
[667089.034748] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[667089.034763] tvheadend       D c0398690     0 20550      1 0x00000000
[667089.034841] [<c0398690>] (__schedule+0x2c4/0x5b0) from [<c0399b58>] (__down_write_nested+0xbc/0x110)
[667089.035211] [<c0399b58>] (__down_write_nested+0xbc/0x110) from [<bf11b860>] (xfs_ilock+0x50/0x60 [xfs])
[667089.035601] [<bf11b860>] (xfs_ilock+0x50/0x60 [xfs]) from [<bf112c20>] (__xfs_get_blocks+0x264/0x5c8 [xfs])
[667089.035949] [<bf112c20>] (__xfs_get_blocks+0x264/0x5c8 [xfs]) from [<bf112fd4>] (xfs_get_blocks+0x24/0x2c [xfs])
[667089.036178] [<bf112fd4>] (xfs_get_blocks+0x24/0x2c [xfs]) from [<c00ed4ac>] (__block_write_begin+0x214/0x4e8)
[667089.036422] [<c00ed4ac>] (__block_write_begin+0x214/0x4e8) from [<bf113344>] (xfs_vm_write_begin+0x4c/0x164 [xfs])
[667089.036880] [<bf113344>] (xfs_vm_write_begin+0x4c/0x164 [xfs]) from [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c)
[667089.037124] [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c) from [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs])
[667089.037515] [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs]) from [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs])
[667089.037751] [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs]) from [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc)
[667089.037801] [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc) from [<c00c1de8>] (do_readv_writev+0xa8/0x178)
[667089.037828] [<c00c1de8>] (do_readv_writev+0xa8/0x178) from [<c00c1f04>] (vfs_writev+0x4c/0x70)
[667089.037868] [<c00c1f04>] (vfs_writev+0x4c/0x70) from [<c00c2090>] (sys_writev+0x38/0xc8)
[667089.037903] [<c00c2090>] (sys_writev+0x38/0xc8) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
[667089.037957] INFO: task kworker/0:0:20383 blocked for more than 120 seconds.
[667089.037977] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[667089.037990] kworker/0:0     D c0398690     0 20383      2 0x00000000
[667089.038050] [<c0398690>] (__schedule+0x2c4/0x5b0) from [<c03973d0>] (schedule_timeout+0x158/0x1e0)
[667089.038079] [<c03973d0>] (schedule_timeout+0x158/0x1e0) from [<c0398b3c>] (wait_for_common+0xcc/0x198)
[667089.038309] [<c0398b3c>] (wait_for_common+0xcc/0x198) from [<bf115e98>] (xfs_buf_iowait+0x1c/0x24 [xfs])
[667089.038687] [<bf115e98>] (xfs_buf_iowait+0x1c/0x24 [xfs]) from [<bf116008>] (xfs_buf_read_map+0x58/0x78 [xfs])
[667089.039247] [<bf116008>] (xfs_buf_read_map+0x58/0x78 [xfs]) from [<bf167b54>] (xfs_trans_read_buf_map+0x174/0x27c [xfs])
[667089.039839] [<bf167b54>] (xfs_trans_read_buf_map+0x174/0x27c [xfs]) from [<bf13fe54>] (xfs_btree_read_buf_block.constprop.2+0x58/0xac [xfs])
[667089.040358] [<bf13fe54>] (xfs_btree_read_buf_block.constprop.2+0x58/0xac [xfs]) from [<bf13ff28>] (xfs_btree_lookup_get_block+0x80/0xc8 [xfs])
[667089.040886] [<bf13ff28>] (xfs_btree_lookup_get_block+0x80/0xc8 [xfs]) from [<bf142c48>] (xfs_btree_lookup+0xb0/0x3f8 [xfs])
[667089.041407] [<bf142c48>] (xfs_btree_lookup+0xb0/0x3f8 [xfs]) from [<bf12b688>] (xfs_alloc_ag_vextent_size+0x64/0x544 [xfs])
[667089.041867] [<bf12b688>] (xfs_alloc_ag_vextent_size+0x64/0x544 [xfs]) from [<bf12c484>] (xfs_alloc_ag_vextent+0xa4/0x10c [xfs])
[667089.042330] [<bf12c484>] (xfs_alloc_ag_vextent+0xa4/0x10c [xfs]) from [<bf12d200>] (__xfs_alloc_vextent+0x4e0/0x5f4 [xfs])
[667089.042789] [<bf12d200>] (__xfs_alloc_vextent+0x4e0/0x5f4 [xfs]) from [<bf12d340>] (xfs_alloc_vextent_worker+0x2c/0x54 [xfs])
[667089.043052] [<bf12d340>] (xfs_alloc_vextent_worker+0x2c/0x54 [xfs]) from [<c0035010>] (process_one_work+0x150/0x40c)
[667089.043100] [<c0035010>] (process_one_work+0x150/0x40c) from [<c00355f0>] (worker_thread+0x150/0x498)
[667089.043146] [<c00355f0>] (worker_thread+0x150/0x498) from [<c003a7b4>] (kthread+0x88/0x94)
[667089.043180] [<c003a7b4>] (kthread+0x88/0x94) from [<c000e9fc>] (kernel_thread_exit+0x0/0x8)
[667089.043198] INFO: task flush-254:5:20551 blocked for more than 120 seconds.
[667089.043206] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[667089.043226] flush-254:5     D c0398690     0 20551      2 0x00000000
[667089.043283] [<c0398690>] (__schedule+0x2c4/0x5b0) from [<c03973d0>] (schedule_timeout+0x158/0x1e0)
[667089.043521] [<c03973d0>] (schedule_timeout+0x158/0x1e0) from [<c0398b3c>] (wait_for_common+0xcc/0x198)
[667089.043805] [<c0398b3c>] (wait_for_common+0xcc/0x198) from [<bf12d3d0>] (xfs_alloc_vextent+0x68/0x84 [xfs])
[667089.044300] [<bf12d3d0>] (xfs_alloc_vextent+0x68/0x84 [xfs]) from [<bf138eb4>] (xfs_bmap_btalloc+0x3a4/0x764 [xfs])
[667089.044814] [<bf138eb4>] (xfs_bmap_btalloc+0x3a4/0x764 [xfs]) from [<bf139c28>] (xfs_bmapi_allocate+0xb0/0x29c [xfs])
[667089.048872] [<bf139c28>] (xfs_bmapi_allocate+0xb0/0x29c [xfs]) from [<bf13c574>] (xfs_bmapi_write+0x430/0x6b4 [xfs])
[667089.049385] [<bf13c574>] (xfs_bmapi_write+0x430/0x6b4 [xfs]) from [<bf11f820>] (xfs_iomap_write_allocate+0x190/0x3b4 [xfs])
[667089.049794] [<bf11f820>] (xfs_iomap_write_allocate+0x190/0x3b4 [xfs]) from [<bf113688>] (xfs_map_blocks+0x198/0x1b8 [xfs])
[667089.050167] [<bf113688>] (xfs_map_blocks+0x198/0x1b8 [xfs]) from [<bf11400c>] (xfs_vm_writepage+0x21c/0x5c4 [xfs])
[667089.051683] [<bf11400c>] (xfs_vm_writepage+0x21c/0x5c4 [xfs]) from [<c009600c>] (__writepage+0x14/0x40)
[667089.051780] [<c009600c>] (__writepage+0x14/0x40) from [<c00966e0>] (write_cache_pages+0x1d0/0x3c8)
[667089.051809] [<c00966e0>] (write_cache_pages+0x1d0/0x3c8) from [<c0096918>] (generic_writepages+0x40/0x5c)
[667089.051835] [<c0096918>] (generic_writepages+0x40/0x5c) from [<c00979d0>] (do_writepages+0x24/0x38)
[667089.051900] [<c00979d0>] (do_writepages+0x24/0x38) from [<c00e3f5c>] (__writeback_single_inode.isra.20+0x28/0x11c)
[667089.051947] [<c00e3f5c>] (__writeback_single_inode.isra.20+0x28/0x11c) from [<c00e4284>] (writeback_sb_inodes+0x234/0x40c)
[667089.051989] [<c00e4284>] (writeback_sb_inodes+0x234/0x40c) from [<c00e44cc>] (__writeback_inodes_wb+0x70/0xac)
[667089.052018] [<c00e44cc>] (__writeback_inodes_wb+0x70/0xac) from [<c00e46e4>] (wb_writeback+0x1dc/0x204)
[667089.052045] [<c00e46e4>] (wb_writeback+0x1dc/0x204) from [<c00e509c>] (wb_do_writeback+0x134/0x1fc)
[667089.052070] [<c00e509c>] (wb_do_writeback+0x134/0x1fc) from [<c00e51e0>] (bdi_writeback_thread+0x7c/0x150)
[667089.052132] [<c00e51e0>] (bdi_writeback_thread+0x7c/0x150) from [<c003a7b4>] (kthread+0x88/0x94)
[667089.052172] [<c003a7b4>] (kthread+0x88/0x94) from [<c000e9fc>] (kernel_thread_exit+0x0/0x8)
[667209.046128] INFO: task tvheadend:20550 blocked for more than 120 seconds.
[667209.046165] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[667209.046180] tvheadend       D c0398690     0 20550      1 0x00000000
[667209.046258] [<c0398690>] (__schedule+0x2c4/0x5b0) from [<c0399b58>] (__down_write_nested+0xbc/0x110)
[667209.046631] [<c0399b58>] (__down_write_nested+0xbc/0x110) from [<bf11b860>] (xfs_ilock+0x50/0x60 [xfs])
[667209.047015] [<bf11b860>] (xfs_ilock+0x50/0x60 [xfs]) from [<bf112c20>] (__xfs_get_blocks+0x264/0x5c8 [xfs])
[667209.047371] [<bf112c20>] (__xfs_get_blocks+0x264/0x5c8 [xfs]) from [<bf112fd4>] (xfs_get_blocks+0x24/0x2c [xfs])
[667209.047583] [<bf112fd4>] (xfs_get_blocks+0x24/0x2c [xfs]) from [<c00ed4ac>] (__block_write_begin+0x214/0x4e8)
[667209.047795] [<c00ed4ac>] (__block_write_begin+0x214/0x4e8) from [<bf113344>] (xfs_vm_write_begin+0x4c/0x164 [xfs])
[667209.048030] [<bf113344>] (xfs_vm_write_begin+0x4c/0x164 [xfs]) from [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c)
[667209.048593] [<c008d978>] (generic_file_buffered_write+0x1a4/0x26c) from [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs])
[667209.048996] [<bf119498>] (xfs_file_buffered_aio_write+0xf0/0x154 [xfs]) from [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs])
[667209.049239] [<bf1195dc>] (xfs_file_aio_write+0xe0/0x16c [xfs]) from [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc)
[667209.049298] [<c00c1b44>] (do_sync_readv_writev+0x94/0xdc) from [<c00c1de8>] (do_readv_writev+0xa8/0x178)
[667209.049327] [<c00c1de8>] (do_readv_writev+0xa8/0x178) from [<c00c1f04>] (vfs_writev+0x4c/0x70)
[667209.049351] [<c00c1f04>] (vfs_writev+0x4c/0x70) from [<c00c2090>] (sys_writev+0x38/0xc8)
[667209.049383] [<c00c2090>] (sys_writev+0x38/0xc8) from [<c000da60>] (ret_fast_syscall+0x0/0x30)
do you have a tip, why is USB disk unstable?
xnosek00
Tue Jul 23, 2013 8:53 pm
I tried reboot raspi:
sudo reboot
but nothing happened. It looks like, that disk worked. I tried power off usb disk. After that, sudo reboot works.
After reboot, dmesg ok. I tried mount disk partitions. After serveral seconds:
[    7.438781] usbcore: registered new interface driver it913x
[    7.948299] sr0: scsi-1 drive
[    7.970154] cdrom: Uniform CD-ROM driver Revision: 3.20
[    8.002253] sr 0:0:0:0: Attached scsi CD-ROM sr0
[    8.176333] dwc_otg bcm2708_usb: dev 1.2.2 ep1in scatterlist error -104/-121
[    8.185967] dwc_otg bcm2708_usb: dev 1.2.2 ep1in scatterlist error -104/-121
[   16.890315] usb 1-1.3: new high-speed USB device number 8 using dwc_otg
[   17.011911] usb 1-1.3: New USB device found, idVendor=152d, idProduct=2329
[   17.021185] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=5
[   17.030746] usb 1-1.3: Product: USB to ATA/ATAPI bridge
[   17.038111] usb 1-1.3: Manufacturer: JMicron
[   17.044519] usb 1-1.3: SerialNumber: DCAA030589FF
[   17.066271] usb-storage 1-1.3:1.0: Quirks match for vid 152d pid 2329: 8020
[   17.088218] scsi1 : usb-storage 1-1.3:1.0
[   18.132889] scsi 1:0:0:0: Direct-Access     WDC WD20 EARX-00PASB0          PQ: 0 ANSI: 2 CCS
[   18.151658] sd 1:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[   18.180206] sd 1:0:0:0: [sda] Write Protect is off
[   18.187159] sd 1:0:0:0: [sda] Mode Sense: 28 00 00 00
[   18.200193] sd 1:0:0:0: [sda] No Caching mode page present
[   18.207746] sd 1:0:0:0: [sda] Assuming drive cache: write through
[   18.229279] sd 1:0:0:0: [sda] No Caching mode page present
[   18.238902] sd 1:0:0:0: [sda] Assuming drive cache: write through
[   18.286629]  sda: sda1
[   18.300803] sd 1:0:0:0: [sda] No Caching mode page present
[   18.308286] sd 1:0:0:0: [sda] Assuming drive cache: write through
[   18.317485] sd 1:0:0:0: [sda] Attached SCSI disk
[   18.903377] device-mapper: ioctl: 4.23.0-ioctl (2012-07-25) initialised: [email protected]edhat.com
[   68.390347] usb 1-1.2.2: reset high-speed USB device number 6 using dwc_otg
[   68.541322] dwc_otg bcm2708_usb: dev 1.2.2 ep1in scatterlist error -104/-121
[   68.550752] dwc_otg bcm2708_usb: dev 1.2.2 ep1in scatterlist error -104/-121
[  128.649739] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[  129.078847] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[  140.930952] smsc95xx 1-1.1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[  142.014744] bcm2835-cpufreq: switching to governor ondemand
[  142.014774] bcm2835-cpufreq: switching to governor ondemand
[  146.198050] Adding 102396k swap on /var/swap.  Priority:-1 extents:1 across:102396k SS
[  241.201244] INFO: task usb-storage:172 blocked for more than 120 seconds.
[  241.201268] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[  241.201296] usb-storage     D c0398690     0   172      2 0x00000000
[  241.201377] [<c0398690>] (__schedule+0x2c4/0x5b0) from [<c03973d0>] (schedule_timeout+0x158/0x1e0)
[  241.201411] [<c03973d0>] (schedule_timeout+0x158/0x1e0) from [<c0398b3c>] (wait_for_common+0xcc/0x198)
[  241.201463] [<c0398b3c>] (wait_for_common+0xcc/0x198) from [<c0275538>] (usb_sg_wait+0x144/0x198)
[  241.201497] [<c0275538>] (usb_sg_wait+0x144/0x198) from [<c02a2040>] (usb_stor_bulk_transfer_sglist.part.4+0xa4/0xf8)
[  241.201524] [<c02a2040>] (usb_stor_bulk_transfer_sglist.part.4+0xa4/0xf8) from [<c02a22e8>] (usb_stor_bulk_srb+0x48/0x50)
[  241.201562] [<c02a22e8>] (usb_stor_bulk_srb+0x48/0x50) from [<c02a23fc>] (usb_stor_Bulk_transport+0x10c/0x2f8)
[  241.201586] [<c02a23fc>] (usb_stor_Bulk_transport+0x10c/0x2f8) from [<c02a291c>] (usb_stor_invoke_transport+0x2c/0x4fc)
[  241.201612] [<c02a291c>] (usb_stor_invoke_transport+0x2c/0x4fc) from [<c02a3d5c>] (usb_stor_control_thread+0x19c/0x28c)
[  241.201649] [<c02a3d5c>] (usb_stor_control_thread+0x19c/0x28c) from [<c003a7b4>] (kthread+0x88/0x94)
[  241.201698] [<c003a7b4>] (kthread+0x88/0x94) from [<c000e9fc>] (kernel_thread_exit+0x0/0x8)
[  259.650199] SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
[  259.666379] XFS (dm-5): Mounting Filesystem
[  262.004843] XFS (dm-5): Starting recovery (logdev: internal)
[  262.942065] XFS (dm-5): Ending recovery (logdev: internal)
[  263.701170] EXT4-fs (dm-6): recovery complete
[  263.704447] EXT4-fs (dm-6): mounted filesystem with ordered data mode. Opts: (null)
[  264.063589] XFS (dm-7): Mounting Filesystem
[  265.666070] XFS (dm-7): Ending clean mount
[  266.101884] EXT4-fs (dm-8): recovery complete
[  266.101941] EXT4-fs (dm-8): mounted filesystem with ordered data mode. Opts: (null)
[  266.656349] EXT4-fs (dm-9): recovery complete
[  266.656406] EXT4-fs (dm-9): mounted filesystem with ordered data mode. Opts: (null)
this code is problem. If you see this code in dmesg and you will do something on the disk, nothing will saved after reboot. Filesystem seems, that everything is ok. Only dmesg reproduce this error.
I will try next reboot.
xnosek00
Tue Jul 23, 2013 9:02 pm
after next reboot, it works, disk is mounted. No error in dmesg.
Plug and pray.
[email protected] ~ $ uname -a
Linux raspberrypi 3.6.11+ #474 PREEMPT Thu Jun 13 17:14:42 BST 2013 armv6l GNU/Linux
