Yamahanytro
No overclock option in raspi-config
Sat Jan 12, 2013 6:04 am
When I go to raspi-config there is no overclock feature, or update. All I see is Info, Configure_keyboard, Change_Pass, Change_Locale, Change_Timezone, SSH, Boot_Behaviour.
Im not sure whats wrong. Its running off a 80GB external HDD, With Raspbian installed. 8GB PNY premium SD card.
Not sure how to replicate it? Just started it and there is options missing from the menu. It showed up on all the other SD cards I run. I haven't done anything different on how I installed it.
BrickTopUK
Re: No overclock option in raspi-config
Sat Jan 12, 2013 11:30 pm
Hey man, If you are still having this issue, I found that I didn't have the correct repositories listed in my /etc/apt/sources.list file. I added this to the file and then it updated fine!
deb http://archive.raspbian.org/raspbian wheezy main contrib non-free
deb-src http://archive.raspbian.org/raspbian wheezy main contrib non-free
Hope it works!
Yamahanytro
Sat Jan 12, 2013 11:43 pm
So where is the file in the site you gave?
drgeoff
Sun Jan 13, 2013 1:36 am
Yamahanytro wrote:So where is the file in the site you gave?
You add the two lines:
to the file /etc/apt/sources.list on your RPi.
malakai
Sun Jan 13, 2013 1:50 am
Where did the image come from was it pre-loaded?
Have you tried
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install raspi-config libraspberrypi*
reboot and see what is there.
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
Yamahanytro
Sun Jan 13, 2013 1:52 am
I added those then rebooted and ran
apt-get update && apt-get upgrade
This is what I got: http://gyazo.com/1ed70c6510a3726537758d22fccdb366
Yamahanytro
malakai wrote:Where did the image come from was it pre-loaded?
Have you tried
I installed raspbian with BerryBoot
I will try
right now.
Edit: Just tried it. Said its the latest version.
malakai
Sun Jan 13, 2013 1:56 am
Berryboot won't have an overclock setting in raspi-config. I forget how to do it would have to read up on it. It boots differently than the main OS by itself so there is a way just not in raspi-config
Yamahanytro
Sun Jan 13, 2013 2:02 am
malakai wrote:Berryboot won't have an overclock setting in raspi-config. I forget how to do it would have to read up on it. It boots differently than the main OS by itself so there is a way just not in raspi-config
The other SD cards I have that I installed using BerryBoot had the Raspi-Config in them, with the overclock feature.
malakai
Sun Jan 13, 2013 2:11 am
http://www.raspberrypi.org/phpBB3/viewt ... 59#p249559
Hi, I have installed raspbian and openelec with "berryboot-20121230" but when I type sudo rasp-config there's no option to overclock, raspi-update, etc...
Max the author wrote:
Firmware has to be updated through the Berryboot GUI, not using rpi-update.
If you know what you are doing, you can set overclock settings through the Berryboot GUI (advanced settings -> config.txt tab). I would not recommend anyone to overclock though.
No need to change memory split manually anymore, Long live CMA.
I would ping him in that thread or rename this if possible as it won't possibly hit his attention. But it looks like if it was there it isn't anymore.
Yamahanytro
Sun Jan 13, 2013 2:18 am
Would this allow me to overclock without voiding my warranty?
malakai
Sun Jan 13, 2013 2:23 am
That's a tough question the wiki on it is here:
http://elinux.org/RPiconfig#Overclocking
Yamahanytro
Sun Jan 13, 2013 2:33 am
malakai wrote:That's a tough question the wiki on it is here:
I want to use the Raspi-config Overclocking so it does not void the warranty. But that option is not on the config! But if I use another one of my SD cards I have Rasbian installed on The options is there. Im trying to find out how to get that option back.
dgately
Fri Jan 25, 2013 5:05 am
Try:
sudo apt-get -y remove raspi-config
sudo apt-get -y install raspi-config
Even when apt-get stated that I had the latest version of raspi-config, it was running an older version. The remove and install seems to correct the problem for me. I also used berryboot, so this should help you...
dgately
netninja
Thu Apr 04, 2013 12:17 pm
dgately wrote:Try:
dgately
This worked for me... Using 03/2013 berryboot and 12/2012 raspbian distro. Thanks for the tip!
strasharo
Wed Apr 24, 2013 12:46 pm
You'll have also to mount manually your boot partition in Berryboot prior using raspi-config, so it can write to /boot/config.txt
mount -t auto /dev/mmcblk0p1 /boot
