proj964
bmp085 driver package
Mon Jan 07, 2013 9:11 pm
does anyone know if there is a package for the bmp085 driver?
i found one version of the source at:
http://lxr.free-electrons.com/source/dr ... c/bmp085.c
ksangeelee
Re: bmp085 driver package
Mon Jan 07, 2013 9:46 pm
proj964 wrote:does anyone know if there is a package for the bmp085 driver?
There's code in this project (http://www.susa.net/wordpress/2012/08/r ... nd-rfm12b/) that drives a BMP085 directly using hardware registers, but it's written for a rev-1 board (BSC0, rather than BSC1).
Mark Sansom modified the code to use the kernel's I2C driver instead as follows (and hence for rev 2 boards. This works for him, but I've not tried it yet for myself). You may need to either remove the reference to "bcm2835.h", or include it from the original source at the link above (I don't see anything in the code that would need the header, but not having compiled it, I can't say for sure).
Note this is entirely user-land code it's not a kernel driver.
  * pcf8563_i2c_rtc.c - example of accessing a PCF8563 via the BSC0 (I2C) peripheral on a BCM2835 (Raspberry Pi)
  * Copyright 2012 Kevin Sangeelee.
  * Released as GPLv2, see <http://www.gnu.org/licenses/>
  * This is intended as an example of using Raspberry Pi hardware registers to drive an RTC chip. Use at your own risk or
  * not at all. As far as possible, I've omitted anything that doesn't relate to the RTC or the Raspi registers. There are more
  * conventional ways of doing this using kernel drivers, though these are harder to follow.
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <stdint.h>
#include <time.h>
#include <math.h>
#include <fcntl.h>
#include <sys/mman.h>
#include <linux/i2c-dev.h>
#include <sys/ioctl.h>
#include <fcntl.h>
#include "bcm2835.h"
#define HUM_ADDRESS        (0x77)
//  main()
char eeprom[22] = { 0, 0, };
char regaddr[3] = { 0, 0, };
short ac1, ac2, ac3, b1, b2, mb, mc, md;
unsigned short ac4, ac5, ac6;
float temperature_deg_c;
float pressure_hpa;
int read_bmp085(float altitude) {
    const char * devName = "/dev/i2c-1";
    // Open up the I2C bus
    int file = open(devName, O_RDWR);
    if (file == -1) {
        printf("Failed to open i2c-1 device\n");
        return -1;
    // Specify the address of the slave device.
    if (ioctl(file, I2C_SLAVE, HUM_ADDRESS) < 0) {
        printf("Failed to acquire bus access and/or talk to slave\n");
        return -1;
	// Read eeprom data if the array is empty
	// I2C Device Address 0x77 (hardwired into the chip, 0xEE & 0xEF)
	if((unsigned short)*eeprom == 0) {
		// Device 0x77, register 0xaa, read into buf, 22 bytes
		regaddr[0] = 0xaa;
		write(file, regaddr, 1);
		if (read(file, eeprom, 22) != 22) {
			printf("Error reading config data from sensor\n");
			return -1;
		ac1 = (short)eeprom[0] << 8 | eeprom[1];
		ac2 = (short)eeprom[2] << 8 | eeprom[3];
		ac3 = (short)eeprom[4] << 8 | eeprom[5];
		ac4 = (unsigned short)eeprom[6] << 8 | eeprom[7];
		ac5 = (unsigned short)eeprom[8] << 8 | eeprom[9];
		ac6 = (unsigned short)eeprom[10] << 8 | eeprom[11];
		b1 = (short)eeprom[12] << 8 | eeprom[13];
		b2 = (short)eeprom[14] << 8 | eeprom[15];
		mb = (short)eeprom[16] << 8 | eeprom[17];
		mc = (short)eeprom[18] << 8 | eeprom[19];
		md = (short)eeprom[20] << 8 | eeprom[21];
		// Test values
		//ac1 = 408, ac2 = -72, ac3 = -14383, ac4 = 32741, ac5 = 32757, ac6 = 23153;
		//b1 = 6190, b2 = 4, mb = -32768, mc = -8711, md = 2868;
		// Also include 'ut = 27898' , 'up = 23843', and 'oss = 0'
		//printf("%d %d %d %d %d %d\n", ac1, ac2, ac3, ac4, ac5, ac6);
		//printf("%d %d %d %d %d\n", b1, b2, mb, mc, md);
	char ut_buf[2];
	char up_buf[2];
	char cmd_up[] = {0x34, 0x74, 0xb4, 0xf4};
	int oss_delay[] = {4500, 7500, 13500, 25500};
	int oss = 1; // This is an index into the above array
	 * Get Uncompensated Temperature from BMP085
	 regaddr[0] = 0xf4;	// Control register
	 regaddr[1] = 0x2e;	// Start uncompensated temperature
	 write(file, regaddr, 2);
	usleep(4500); // just wait the maximum possible time for conversion
	regaddr[0] = 0xf6;	// Temperature data
	read(file, ut_buf, 2);
	long ut = (long)ut_buf[0] << 8 | ut_buf[1];
	// Temperature compensation algorithm (derived from datasheet)
	long x1 = ((ut - ac6) * ac5) >> 15;
	long x2 = (mc * (1 << 11)) / (x1 + md);
	long b5 = x1 + x2;
	long t = (b5 + 8)  >> 4;
	temperature_deg_c = (float)t / 10;
	printf("Temperature: %0.1fC\n", temperature_deg_c);
	int idx;
	float p0 = 0;
	for(idx=0; idx < 2; idx++) {
		 * Get Uncompensated Pressure from BMP085, based on the OverSampling Setting
		 * of (0, 1, 2, or 3). This determines accuracy, conversion delay, and power consumption.
		 regaddr[1] = cmd_up[oss];	// Start pressure reading
		usleep(oss_delay[oss]); // wait according to the chosen oss mode
		regaddr[0] = 0xf6;
		read(file, up_buf, 3);
		long up = (((long)up_buf[0] << 16) | ((long)up_buf[1] << 8) | up_buf[2]) >> (8 - oss);
		// Pressure compensation algorithm (derived from datasheet)
		long b6 = b5 - 4000;
		x1 = (b2 * (b6 * b6 >> 12)) >> 11;
		x2 = ac2 * b6 >> 11;
		long x3 = x1 + x2;
		long b3 = (((ac1 * 4 + x3) << oss) + 2) >> 2;
		x1 = ac3 * b6 >> 13;
		x2 = (b1 * (b6 * b6 >> 12)) >> 16;
		x3 = ((x1 + x2) + 2) >> 2;
		unsigned long b4 = ac4 * (unsigned long)(x3 + 32768) >>15;
		unsigned long b7 = ((unsigned long)up - b3) * (50000 >> oss);
		long p = b7 < 0x80000000 ? (b7 * 2) / b4 : (b7 / b4) * 2;
		x1 = (p >> 8) * (p >> 8);
		x1 = (x1 * 3038) >> 16;
		x2 = (-7357 * p) >> 16;
		p = p + (x1 + x2 + 3791) / 16;
		p0 += (float)p / powf(1.0f - (altitude / 44330), 5.255f);
		usleep(100000);
	p0 /= 2;
	pressure_hpa = p0 / 100;
	printf("Pressure p0 (sea level): %0.1f hPa\n", pressure_hpa);
	close(file);
	return 0;
proj964
Mon Jan 07, 2013 9:59 pm
I'll take a look. Thanks, Jon
Return to “Raspbian”
