Starting program: /usr/bin/Xorg -verbose -keeptty
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
_XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/raspberrypi:0
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
X.Org X Server 1.12.3.902 (1.12.4 RC 2)
Release Date: 2012-08-19
X Protocol Version 11, Revision 0
Build Operating System: Linux 3.2.27+ armv6l Debian
Current Operating System: Linux raspberrypi 3.6.11+ #348 PREEMPT Tue Jan 1 16:33:22 GMT 2013 armv6l
Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1360 bcm2708_fb.fbheight=768 bcm2708.boardrev=0xf bcm2708.serial=0x22fc8e8a smsc95xx.macaddr=B8:27:EB:FC:8E:8A bcm2708_fb.fbdepth=32 sdhci-bcm2708.emmc_clock_freq=100000000 vc-cma-mem=0/[email protected] [email protected] [email protected] vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait discard data=writeback dwc_otg.speed=1
Build Date: 30 September 2012 11:33:39AM
xorg-server 2:1.12.3.902-1 (Julien Cristau <[email protected]>)
Current version of pixman: 0.26.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Jan 5 00:02:56 2013
(==) Using system config directory "/usr/share/X11/xorg.conf.d"
(==) No Layout section. Using the first Screen section.
(==) No screen section available. Using defaults.
(**) |-->Screen "Default Screen Section" (0)
(**) | |-->Monitor "<default monitor>"
(==) No device specified for screen "Default Screen Section".
Using the first device section listed.
(**) | |-->Device "Card0"
(==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
built-ins
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
(II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.12.3.902, module version = 1.0.0
(II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading /usr/lib/xorg/modules/extensions/libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading /usr/lib/xorg/modules/extensions/librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.12.3.902, module version = 1.13.0
(II) Loading /usr/lib/xorg/modules/extensions/libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
compiled for 1.12.3.902, module version = 1.2.0
(II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so
(II) Module fbdev: vendor="X.Org Foundation"
compiled for 1.12.3.902, module version = 0.4.2
(II) FBDEV_RPI: driver for framebuffer: fbdev
(--) using VT number 7
(WW) Falling back to old probe method for fbdev
(II) Loading /usr/lib/xorg/modules/libfbdevhw.so
(II) Module fbdevhw: vendor="X.Org Foundation"
compiled for 1.12.3.902, module version = 0.0.2
(II) FBDEV_RPI(0): using default device
(WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
(II) FBDEV_RPI(0): Raspberry Pi Xorg driver build date Jan 3 2013 build time 22:54:08
(II) FBDEV_RPI(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
(==) FBDEV_RPI(0): Depth 24, (==) framebuffer bpp 32
(==) FBDEV_RPI(0): RGB weight 888
(==) FBDEV_RPI(0): Default visual is TrueColor
(==) FBDEV_RPI(0): Using gamma correction (1.0, 1.0, 1.0)
(II) FBDEV_RPI(0): hardware: BCM2708 FB (video memory: 4080kB)
(II) Loading /usr/lib/xorg/modules/libfb.so
(II) Module fb: vendor="X.Org Foundation"
(II) FBDEV_RPI(0): kernel interface initialised
(**) FBDEV_RPI(0): Using EXA acceleration
(II) Loading /usr/lib/xorg/modules/libexa.so
(II) Module exa: vendor="X.Org Foundation"
compiled for 1.12.3.902, module version = 2.5.0
(**) FBDEV_RPI(0): Using 20971520 bytes (20.00 MB) of memory as offscreen
(**) FBDEV_RPI(0): Attempting to open VCIO mailbox
(**) FBDEV_RPI(0): Attempting to load VPU code
(**) FBDEV_RPI(0): Loaded VPU binary /usr/share/X11/vpu_offload_asm.bin at offset 0
(II) FBDEV_RPI(0): Symbol table dump
(II) FBDEV_RPI(0): 0: c TRUE Identify
(II) FBDEV_RPI(0): 1: 14 TRUE GetVersion
(II) FBDEV_RPI(0): 2: 20 FALSE vpu_over_a8r8g8b8_x8b8g8r8_invalid_nonvarying
(II) FBDEV_RPI(0): 3: 2a0 FALSE vpu_over_a8r8g8b8_x8b8g8r8_invalid_normal
(II) FBDEV_RPI(0): 4: 440 TRUE vpu_over_a8r8g8b8_x8b8g8r8_invalid
(II) FBDEV_RPI(0): 5: 500 FALSE vpu_over_a8r8g8b8_x8b8g8r8_a8_valid_nonvarying
(II) FBDEV_RPI(0): 6: 790 FALSE vpu_over_a8r8g8b8_x8b8g8r8_a8_valid_normal
(II) FBDEV_RPI(0): 7: a24 TRUE vpu_over_a8r8g8b8_x8b8g8r8_a8_valid
(II) FBDEV_RPI(0): 8: b00 FALSE vpu_over_a8r8g8b8_a8r8g8b8_invalid_nonvarying
(II) FBDEV_RPI(0): 9: d94 FALSE vpu_over_a8r8g8b8_a8r8g8b8_invalid_normal
(II) FBDEV_RPI(0): 10: f64 TRUE vpu_over_a8r8g8b8_a8r8g8b8_invalid
(II) FBDEV_RPI(0): 11: 1020 FALSE vpu_over_a8r8g8b8_a8r8g8b8_a8_valid_nonvarying
(II) FBDEV_RPI(0): 12: 12c4 FALSE vpu_over_a8r8g8b8_a8r8g8b8_a8_valid_normal
(II) FBDEV_RPI(0): 13: 1588 TRUE vpu_over_a8r8g8b8_a8r8g8b8_a8_valid
(II) FBDEV_RPI(0): 14: 1660 FALSE vpu_over_x8r8g8b8_x8r8g8b8_invalid_nonvarying
(II) FBDEV_RPI(0): 15: 18c8 FALSE vpu_over_x8r8g8b8_x8r8g8b8_invalid_normal
(II) FBDEV_RPI(0): 16: 1a70 TRUE vpu_over_x8r8g8b8_x8r8g8b8_invalid
(II) FBDEV_RPI(0): 17: 1b20 FALSE vpu_over_x8r8g8b8_x8r8g8b8_a8_valid_nonvarying
(II) FBDEV_RPI(0): 18: 1d98 FALSE vpu_over_x8r8g8b8_x8r8g8b8_a8_valid_normal
(II) FBDEV_RPI(0): 19: 2034 TRUE vpu_over_x8r8g8b8_x8r8g8b8_a8_valid
(II) FBDEV_RPI(0): 20: 2100 FALSE vpu_over_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid_nonvarying
(II) FBDEV_RPI(0): 21: 2378 FALSE vpu_over_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid_normal
(II) FBDEV_RPI(0): 22: 2614 TRUE vpu_over_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid
(II) FBDEV_RPI(0): 23: 2700 FALSE vpu_over_x8b8g8r8_x8b8g8r8_invalid_nonvarying
(II) FBDEV_RPI(0): 24: 2968 FALSE vpu_over_x8b8g8r8_x8b8g8r8_invalid_normal
(II) FBDEV_RPI(0): 25: 2b10 TRUE vpu_over_x8b8g8r8_x8b8g8r8_invalid
(II) FBDEV_RPI(0): 26: 2bc0 FALSE vpu_over_x8b8g8r8_x8b8g8r8_a8_valid_nonvarying
(II) FBDEV_RPI(0): 27: 2e38 FALSE vpu_over_x8b8g8r8_x8b8g8r8_a8_valid_normal
(II) FBDEV_RPI(0): 28: 30d4 TRUE vpu_over_x8b8g8r8_x8b8g8r8_a8_valid
(II) FBDEV_RPI(0): 29: 31a0 FALSE vpu_over_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid_nonvarying
(II) FBDEV_RPI(0): 30: 3418 FALSE vpu_over_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid_normal
(II) FBDEV_RPI(0): 31: 36b4 TRUE vpu_over_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid
(II) FBDEV_RPI(0): 32: 37a0 FALSE vpu_add_a8r8g8b8_x8b8g8r8_invalid_nonvarying
(II) FBDEV_RPI(0): 33: 397c FALSE vpu_add_a8r8g8b8_x8b8g8r8_invalid_normal
(II) FBDEV_RPI(0): 34: 3a78 TRUE vpu_add_a8r8g8b8_x8b8g8r8_invalid
(II) FBDEV_RPI(0): 35: 3b40 FALSE vpu_add_a8r8g8b8_x8b8g8r8_a8_valid_nonvarying
(II) FBDEV_RPI(0): 36: 3d30 FALSE vpu_add_a8r8g8b8_x8b8g8r8_a8_valid_normal
(II) FBDEV_RPI(0): 37: 3f24 TRUE vpu_add_a8r8g8b8_x8b8g8r8_a8_valid
(II) FBDEV_RPI(0): 38: 4000 FALSE vpu_add_a8r8g8b8_a8r8g8b8_invalid_nonvarying
(II) FBDEV_RPI(0): 39: 41c0 FALSE vpu_add_a8r8g8b8_a8r8g8b8_invalid_normal
(II) FBDEV_RPI(0): 40: 42bc TRUE vpu_add_a8r8g8b8_a8r8g8b8_invalid
(II) FBDEV_RPI(0): 41: 4380 FALSE vpu_add_a8r8g8b8_a8r8g8b8_a8_valid_nonvarying
(II) FBDEV_RPI(0): 42: 4550 FALSE vpu_add_a8r8g8b8_a8r8g8b8_a8_valid_normal
(II) FBDEV_RPI(0): 43: 4744 TRUE vpu_add_a8r8g8b8_a8r8g8b8_a8_valid
(II) FBDEV_RPI(0): 44: 4820 FALSE vpu_add_x8r8g8b8_x8r8g8b8_invalid_nonvarying
(II) FBDEV_RPI(0): 45: 49e4 FALSE vpu_add_x8r8g8b8_x8r8g8b8_invalid_normal
(II) FBDEV_RPI(0): 46: 4aec TRUE vpu_add_x8r8g8b8_x8r8g8b8_invalid
(II) FBDEV_RPI(0): 47: 4ba0 FALSE vpu_add_x8r8g8b8_x8r8g8b8_a8_valid_nonvarying
(II) FBDEV_RPI(0): 48: 4d78 FALSE vpu_add_x8r8g8b8_x8r8g8b8_a8_valid_normal
(II) FBDEV_RPI(0): 49: 4f74 TRUE vpu_add_x8r8g8b8_x8r8g8b8_a8_valid
(II) FBDEV_RPI(0): 50: 5040 FALSE vpu_add_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid_nonvarying
(II) FBDEV_RPI(0): 51: 5218 FALSE vpu_add_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid_normal
(II) FBDEV_RPI(0): 52: 5414 TRUE vpu_add_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid
(II) FBDEV_RPI(0): 53: 5500 FALSE vpu_add_x8b8g8r8_x8b8g8r8_invalid_nonvarying
(II) FBDEV_RPI(0): 54: 56c4 FALSE vpu_add_x8b8g8r8_x8b8g8r8_invalid_normal
(II) FBDEV_RPI(0): 55: 57cc TRUE vpu_add_x8b8g8r8_x8b8g8r8_invalid
(II) FBDEV_RPI(0): 56: 5880 FALSE vpu_add_x8b8g8r8_x8b8g8r8_a8_valid_nonvarying
(II) FBDEV_RPI(0): 57: 5a58 FALSE vpu_add_x8b8g8r8_x8b8g8r8_a8_valid_normal
(II) FBDEV_RPI(0): 58: 5c54 TRUE vpu_add_x8b8g8r8_x8b8g8r8_a8_valid
(II) FBDEV_RPI(0): 59: 5d20 FALSE vpu_add_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid_nonvarying
(II) FBDEV_RPI(0): 60: 5ef8 FALSE vpu_add_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid_normal
(II) FBDEV_RPI(0): 61: 60f4 TRUE vpu_add_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid
(II) FBDEV_RPI(0): 62: 61e0 FALSE vpu_add_a8r8g8b8_a8_a8_valid_nonvarying
(II) FBDEV_RPI(0): 63: 6300 FALSE vpu_add_a8r8g8b8_a8_a8_valid_normal
(II) FBDEV_RPI(0): 64: 6440 TRUE vpu_add_a8r8g8b8_a8_a8_valid
(II) FBDEV_RPI(0): 65: 6500 FALSE vpu_add_a8r8g8b8_a8_invalid_nonvarying
(II) FBDEV_RPI(0): 66: 660c FALSE vpu_add_a8r8g8b8_a8_invalid_normal
(II) FBDEV_RPI(0): 67: 66ec TRUE vpu_add_a8r8g8b8_a8_invalid
(II) FBDEV_RPI(0): 68: 67a0 TRUE VpuComposite
(II) FBDEV_RPI(0): End symbol table dump
(**) FBDEV_RPI(0): 30510 bytes of GPU-visible memory needed for VPU code
(**) FBDEV_RPI(0): Virtually contiguous physically contiguous memory via /dev/dmaer_4k and VideoCore interface selected
(**) FBDEV_RPI(0): Either from static memory allocation or CMA
(II) FBDEV_RPI(0): VPU code uploaded to bus address 4b841000
(II) FBDEV_RPI(0): NOTE: if it hangs at the next line, ctrl-z, sync and reboot your Raspberry Pi
(II) FBDEV_RPI(0): Checking that it works...
(II) FBDEV_RPI(0): Identified correctly
(II) FBDEV_RPI(0): Using version 1.2 of binary
(II) FBDEV_RPI(0): checking modes against framebuffer device...
(II) FBDEV_RPI(0): checking modes against monitor...
(--) FBDEV_RPI(0): Virtual size is 1360x768 (pitch 1360)
(**) FBDEV_RPI(0): Built-in mode "current"
(==) FBDEV_RPI(0): DPI set to (96, 96)
(==) Depth 24 pixmap format is 32 bpp
(EE) FBDEV_RPI(0): FBIOBLANK: Operation not permitted
(**) FBDEV_RPI(0): max AXI burst suggested: 10
(**) FBDEV_RPI(0): Experimental self-managed memory
(II) EXA(0): Driver allocated offscreen pixmaps
(II) EXA(0): Driver registered support for the following operations:
(II) Solid
(II) Copy
(II) Composite (RENDER acceleration)
(II) UploadToScreen
(II) DownloadFromScreen
(==) FBDEV_RPI(0): Backing store disabled
(==) FBDEV_RPI(0): DPMS enabled
(==) RandR enabled
(II) SELinux: Disabled on system
(II) AIGLX: Screen 0 is not DRI2 capable
(II) AIGLX: Screen 0 is not DRI capable
(II) AIGLX: Loaded and initialized swrast
(II) GLX: Initialized DRISWRAST GL provider for screen 0
I got that by launching it via the debug method. I think it might be because executing Xorg doesn't actually start a desktop. If you want to actually use the driver, just startx as you normally would. Not sure how to get debug info from that though yet.juppiter89 wrote:Hi Simon, thank you very much for your great work![]()
I followed your instructions until I stopped at "Running it" section: i can get after the "Checking that it works...", but it does hang up with a "FBDEV_RPI(0): FBIOBLANK: Operation not permitted" error. What can i do? Thank you again and sorry for my English![]()
Full run command log:Code: Select all
Starting program: /usr/bin/Xorg -verbose -keeptty [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1". _XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6 _XSERVTransOpen: transport open failed for inet6/raspberrypi:0 _XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6 X.Org X Server 1.12.3.902 (1.12.4 RC 2) Release Date: 2012-08-19 X Protocol Version 11, Revision 0 Build Operating System: Linux 3.2.27+ armv6l Debian Current Operating System: Linux raspberrypi 3.6.11+ #348 PREEMPT Tue Jan 1 16:33:22 GMT 2013 armv6l Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1360 bcm2708_fb.fbheight=768 bcm2708.boardrev=0xf bcm2708.serial=0x22fc8e8a smsc95xx.macaddr=B8:27:EB:FC:8E:8A bcm2708_fb.fbdepth=32 sdhci-bcm2708.emmc_clock_freq=100000000 vc-cma-mem=0/[email protected] [email protected] [email protected] vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait discard data=writeback dwc_otg.speed=1 Build Date: 30 September 2012 11:33:39AM xorg-server 2:1.12.3.902-1 (Julien Cristau <[email protected]>) Current version of pixman: 0.26.0 Before reporting problems, check http://wiki.x.org to make sure that you have the latest version. Markers: (--) probed, (**) from config file, (==) default setting, (++) from command line, (!!) notice, (II) informational, (WW) warning, (EE) error, (NI) not implemented, (??) unknown. (==) Log file: "/var/log/Xorg.0.log", Time: Sat Jan 5 00:02:56 2013 (==) Using system config directory "/usr/share/X11/xorg.conf.d" (==) No Layout section. Using the first Screen section. (==) No screen section available. Using defaults. (**) |-->Screen "Default Screen Section" (0) (**) | |-->Monitor "<default monitor>" (==) No device specified for screen "Default Screen Section". Using the first device section listed. (**) | |-->Device "Card0" (==) No monitor specified for screen "Default Screen Section". Using a default monitor configuration. (==) Automatically adding devices (==) Automatically enabling devices (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist. Entry deleted from font path. (WW) The directory "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" does not exist. Entry deleted from font path. (==) FontPath set to: /usr/share/fonts/X11/misc, /usr/share/fonts/X11/100dpi/:unscaled, /usr/share/fonts/X11/75dpi/:unscaled, /usr/share/fonts/X11/Type1, /usr/share/fonts/X11/100dpi, /usr/share/fonts/X11/75dpi, built-ins (==) ModulePath set to "/usr/lib/xorg/modules" (II) The server relies on udev to provide the list of input devices. If no devices become available, reconfigure udev or disable AutoAddDevices. (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so (II) Module extmod: vendor="X.Org Foundation" compiled for 1.12.3.902, module version = 1.0.0 (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so (II) Module dbe: vendor="X.Org Foundation" compiled for 1.12.3.902, module version = 1.0.0 (II) Loading /usr/lib/xorg/modules/extensions/libglx.so (II) Module glx: vendor="X.Org Foundation" compiled for 1.12.3.902, module version = 1.0.0 (==) AIGLX enabled (II) Loading /usr/lib/xorg/modules/extensions/librecord.so (II) Module record: vendor="X.Org Foundation" compiled for 1.12.3.902, module version = 1.13.0 (II) Loading /usr/lib/xorg/modules/extensions/libdri.so (II) Module dri: vendor="X.Org Foundation" compiled for 1.12.3.902, module version = 1.0.0 (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so (II) Module dri2: vendor="X.Org Foundation" compiled for 1.12.3.902, module version = 1.2.0 (II) Loading /usr/lib/xorg/modules/drivers/fbdev_drv.so (II) Module fbdev: vendor="X.Org Foundation" compiled for 1.12.3.902, module version = 0.4.2 (II) FBDEV_RPI: driver for framebuffer: fbdev (--) using VT number 7 (WW) Falling back to old probe method for fbdev (II) Loading /usr/lib/xorg/modules/libfbdevhw.so (II) Module fbdevhw: vendor="X.Org Foundation" compiled for 1.12.3.902, module version = 0.0.2 (II) FBDEV_RPI(0): using default device (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support (II) FBDEV_RPI(0): Raspberry Pi Xorg driver build date Jan 3 2013 build time 22:54:08 (II) FBDEV_RPI(0): Creating default Display subsection in Screen section "Default Screen Section" for depth/fbbpp 24/32 (==) FBDEV_RPI(0): Depth 24, (==) framebuffer bpp 32 (==) FBDEV_RPI(0): RGB weight 888 (==) FBDEV_RPI(0): Default visual is TrueColor (==) FBDEV_RPI(0): Using gamma correction (1.0, 1.0, 1.0) (II) FBDEV_RPI(0): hardware: BCM2708 FB (video memory: 4080kB) (II) Loading /usr/lib/xorg/modules/libfb.so (II) Module fb: vendor="X.Org Foundation" compiled for 1.12.3.902, module version = 1.0.0 (II) FBDEV_RPI(0): kernel interface initialised (**) FBDEV_RPI(0): Using EXA acceleration (II) Loading /usr/lib/xorg/modules/libexa.so (II) Module exa: vendor="X.Org Foundation" compiled for 1.12.3.902, module version = 2.5.0 (**) FBDEV_RPI(0): Using 20971520 bytes (20.00 MB) of memory as offscreen (**) FBDEV_RPI(0): Attempting to open VCIO mailbox (**) FBDEV_RPI(0): Attempting to load VPU code (**) FBDEV_RPI(0): Loaded VPU binary /usr/share/X11/vpu_offload_asm.bin at offset 0 (II) FBDEV_RPI(0): Symbol table dump (II) FBDEV_RPI(0): 0: c TRUE Identify (II) FBDEV_RPI(0): 1: 14 TRUE GetVersion (II) FBDEV_RPI(0): 2: 20 FALSE vpu_over_a8r8g8b8_x8b8g8r8_invalid_nonvarying (II) FBDEV_RPI(0): 3: 2a0 FALSE vpu_over_a8r8g8b8_x8b8g8r8_invalid_normal (II) FBDEV_RPI(0): 4: 440 TRUE vpu_over_a8r8g8b8_x8b8g8r8_invalid (II) FBDEV_RPI(0): 5: 500 FALSE vpu_over_a8r8g8b8_x8b8g8r8_a8_valid_nonvarying (II) FBDEV_RPI(0): 6: 790 FALSE vpu_over_a8r8g8b8_x8b8g8r8_a8_valid_normal (II) FBDEV_RPI(0): 7: a24 TRUE vpu_over_a8r8g8b8_x8b8g8r8_a8_valid (II) FBDEV_RPI(0): 8: b00 FALSE vpu_over_a8r8g8b8_a8r8g8b8_invalid_nonvarying (II) FBDEV_RPI(0): 9: d94 FALSE vpu_over_a8r8g8b8_a8r8g8b8_invalid_normal (II) FBDEV_RPI(0): 10: f64 TRUE vpu_over_a8r8g8b8_a8r8g8b8_invalid (II) FBDEV_RPI(0): 11: 1020 FALSE vpu_over_a8r8g8b8_a8r8g8b8_a8_valid_nonvarying (II) FBDEV_RPI(0): 12: 12c4 FALSE vpu_over_a8r8g8b8_a8r8g8b8_a8_valid_normal (II) FBDEV_RPI(0): 13: 1588 TRUE vpu_over_a8r8g8b8_a8r8g8b8_a8_valid (II) FBDEV_RPI(0): 14: 1660 FALSE vpu_over_x8r8g8b8_x8r8g8b8_invalid_nonvarying (II) FBDEV_RPI(0): 15: 18c8 FALSE vpu_over_x8r8g8b8_x8r8g8b8_invalid_normal (II) FBDEV_RPI(0): 16: 1a70 TRUE vpu_over_x8r8g8b8_x8r8g8b8_invalid (II) FBDEV_RPI(0): 17: 1b20 FALSE vpu_over_x8r8g8b8_x8r8g8b8_a8_valid_nonvarying (II) FBDEV_RPI(0): 18: 1d98 FALSE vpu_over_x8r8g8b8_x8r8g8b8_a8_valid_normal (II) FBDEV_RPI(0): 19: 2034 TRUE vpu_over_x8r8g8b8_x8r8g8b8_a8_valid (II) FBDEV_RPI(0): 20: 2100 FALSE vpu_over_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid_nonvarying (II) FBDEV_RPI(0): 21: 2378 FALSE vpu_over_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid_normal (II) FBDEV_RPI(0): 22: 2614 TRUE vpu_over_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid (II) FBDEV_RPI(0): 23: 2700 FALSE vpu_over_x8b8g8r8_x8b8g8r8_invalid_nonvarying (II) FBDEV_RPI(0): 24: 2968 FALSE vpu_over_x8b8g8r8_x8b8g8r8_invalid_normal (II) FBDEV_RPI(0): 25: 2b10 TRUE vpu_over_x8b8g8r8_x8b8g8r8_invalid (II) FBDEV_RPI(0): 26: 2bc0 FALSE vpu_over_x8b8g8r8_x8b8g8r8_a8_valid_nonvarying (II) FBDEV_RPI(0): 27: 2e38 FALSE vpu_over_x8b8g8r8_x8b8g8r8_a8_valid_normal (II) FBDEV_RPI(0): 28: 30d4 TRUE vpu_over_x8b8g8r8_x8b8g8r8_a8_valid (II) FBDEV_RPI(0): 29: 31a0 FALSE vpu_over_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid_nonvarying (II) FBDEV_RPI(0): 30: 3418 FALSE vpu_over_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid_normal (II) FBDEV_RPI(0): 31: 36b4 TRUE vpu_over_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid (II) FBDEV_RPI(0): 32: 37a0 FALSE vpu_add_a8r8g8b8_x8b8g8r8_invalid_nonvarying (II) FBDEV_RPI(0): 33: 397c FALSE vpu_add_a8r8g8b8_x8b8g8r8_invalid_normal (II) FBDEV_RPI(0): 34: 3a78 TRUE vpu_add_a8r8g8b8_x8b8g8r8_invalid (II) FBDEV_RPI(0): 35: 3b40 FALSE vpu_add_a8r8g8b8_x8b8g8r8_a8_valid_nonvarying (II) FBDEV_RPI(0): 36: 3d30 FALSE vpu_add_a8r8g8b8_x8b8g8r8_a8_valid_normal (II) FBDEV_RPI(0): 37: 3f24 TRUE vpu_add_a8r8g8b8_x8b8g8r8_a8_valid (II) FBDEV_RPI(0): 38: 4000 FALSE vpu_add_a8r8g8b8_a8r8g8b8_invalid_nonvarying (II) FBDEV_RPI(0): 39: 41c0 FALSE vpu_add_a8r8g8b8_a8r8g8b8_invalid_normal (II) FBDEV_RPI(0): 40: 42bc TRUE vpu_add_a8r8g8b8_a8r8g8b8_invalid (II) FBDEV_RPI(0): 41: 4380 FALSE vpu_add_a8r8g8b8_a8r8g8b8_a8_valid_nonvarying (II) FBDEV_RPI(0): 42: 4550 FALSE vpu_add_a8r8g8b8_a8r8g8b8_a8_valid_normal (II) FBDEV_RPI(0): 43: 4744 TRUE vpu_add_a8r8g8b8_a8r8g8b8_a8_valid (II) FBDEV_RPI(0): 44: 4820 FALSE vpu_add_x8r8g8b8_x8r8g8b8_invalid_nonvarying (II) FBDEV_RPI(0): 45: 49e4 FALSE vpu_add_x8r8g8b8_x8r8g8b8_invalid_normal (II) FBDEV_RPI(0): 46: 4aec TRUE vpu_add_x8r8g8b8_x8r8g8b8_invalid (II) FBDEV_RPI(0): 47: 4ba0 FALSE vpu_add_x8r8g8b8_x8r8g8b8_a8_valid_nonvarying (II) FBDEV_RPI(0): 48: 4d78 FALSE vpu_add_x8r8g8b8_x8r8g8b8_a8_valid_normal (II) FBDEV_RPI(0): 49: 4f74 TRUE vpu_add_x8r8g8b8_x8r8g8b8_a8_valid (II) FBDEV_RPI(0): 50: 5040 FALSE vpu_add_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid_nonvarying (II) FBDEV_RPI(0): 51: 5218 FALSE vpu_add_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid_normal (II) FBDEV_RPI(0): 52: 5414 TRUE vpu_add_x8r8g8b8_x8r8g8b8_a8b8g8r8_valid (II) FBDEV_RPI(0): 53: 5500 FALSE vpu_add_x8b8g8r8_x8b8g8r8_invalid_nonvarying (II) FBDEV_RPI(0): 54: 56c4 FALSE vpu_add_x8b8g8r8_x8b8g8r8_invalid_normal (II) FBDEV_RPI(0): 55: 57cc TRUE vpu_add_x8b8g8r8_x8b8g8r8_invalid (II) FBDEV_RPI(0): 56: 5880 FALSE vpu_add_x8b8g8r8_x8b8g8r8_a8_valid_nonvarying (II) FBDEV_RPI(0): 57: 5a58 FALSE vpu_add_x8b8g8r8_x8b8g8r8_a8_valid_normal (II) FBDEV_RPI(0): 58: 5c54 TRUE vpu_add_x8b8g8r8_x8b8g8r8_a8_valid (II) FBDEV_RPI(0): 59: 5d20 FALSE vpu_add_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid_nonvarying (II) FBDEV_RPI(0): 60: 5ef8 FALSE vpu_add_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid_normal (II) FBDEV_RPI(0): 61: 60f4 TRUE vpu_add_x8b8g8r8_x8b8g8r8_a8r8g8b8_valid (II) FBDEV_RPI(0): 62: 61e0 FALSE vpu_add_a8r8g8b8_a8_a8_valid_nonvarying (II) FBDEV_RPI(0): 63: 6300 FALSE vpu_add_a8r8g8b8_a8_a8_valid_normal (II) FBDEV_RPI(0): 64: 6440 TRUE vpu_add_a8r8g8b8_a8_a8_valid (II) FBDEV_RPI(0): 65: 6500 FALSE vpu_add_a8r8g8b8_a8_invalid_nonvarying (II) FBDEV_RPI(0): 66: 660c FALSE vpu_add_a8r8g8b8_a8_invalid_normal (II) FBDEV_RPI(0): 67: 66ec TRUE vpu_add_a8r8g8b8_a8_invalid (II) FBDEV_RPI(0): 68: 67a0 TRUE VpuComposite (II) FBDEV_RPI(0): End symbol table dump (**) FBDEV_RPI(0): 30510 bytes of GPU-visible memory needed for VPU code (**) FBDEV_RPI(0): Virtually contiguous physically contiguous memory via /dev/dmaer_4k and VideoCore interface selected (**) FBDEV_RPI(0): Either from static memory allocation or CMA (II) FBDEV_RPI(0): VPU code uploaded to bus address 4b841000 (II) FBDEV_RPI(0): NOTE: if it hangs at the next line, ctrl-z, sync and reboot your Raspberry Pi (II) FBDEV_RPI(0): Checking that it works... (II) FBDEV_RPI(0): Identified correctly (II) FBDEV_RPI(0): Using version 1.2 of binary (II) FBDEV_RPI(0): checking modes against framebuffer device... (II) FBDEV_RPI(0): checking modes against monitor... (--) FBDEV_RPI(0): Virtual size is 1360x768 (pitch 1360) (**) FBDEV_RPI(0): Built-in mode "current" (==) FBDEV_RPI(0): DPI set to (96, 96) (==) Depth 24 pixmap format is 32 bpp (EE) FBDEV_RPI(0): FBIOBLANK: Operation not permitted (**) FBDEV_RPI(0): max AXI burst suggested: 10 (**) FBDEV_RPI(0): Experimental self-managed memory (II) EXA(0): Driver allocated offscreen pixmaps (II) EXA(0): Driver registered support for the following operations: (II) Solid (II) Copy (II) Composite (RENDER acceleration) (II) UploadToScreen (II) DownloadFromScreen (==) FBDEV_RPI(0): Backing store disabled (==) FBDEV_RPI(0): DPMS enabled (==) RandR enabled (II) SELinux: Disabled on system (II) AIGLX: Screen 0 is not DRI2 capable (II) AIGLX: Screen 0 is not DRI capable (II) AIGLX: Loaded and initialized swrast (II) GLX: Initialized DRISWRAST GL provider for screen 0 (EE) FBDEV_RPI(0): FBIOBLANK: Operation not permitted
I didn't try that.yaggi wrote:This is where I got stuck before as well before.
You should be logged into the RPi with SSH and running the last 'running it' commands (Not locally on your Pi).
Then open up another SSH and run the command startlxde and you should get your X windows.
I think that should do it, however if its not the same issue then I got nothing.
I am pretty sure you're right.rymate1234 wrote:I got that by launching it via the debug method. I think it might be because executing Xorg doesn't actually start a desktop. If you want to actually use the driver, just startx as you normally would. Not sure how to get debug info from that though yet.juppiter89 wrote:Hi Simon, thank you very much for your great work![]()
Typing startx will startup another xorg session. You don't really want thatyaggi wrote:I am pretty sure you're right.rymate1234 wrote:I got that by launching it via the debug method. I think it might be because executing Xorg doesn't actually start a desktop. If you want to actually use the driver, just startx as you normally would. Not sure how to get debug info from that though yet.juppiter89 wrote:Hi Simon, thank you very much for your great work![]()
Running this doesn't launch the desktop, so all he needs to do is run startlxde or startx and it should work just fine at that point.
This is fine too, and nothing to worry about.(EE) FBDEV_RPI(0): FBIOBLANK: Operation not permitted
handle SIGPIPE nostop
handle SIGUSR1 nostop
/usr/bin/startxfce4: Starting X server
Fatal server error:
Server is already active for display 0
If this server is no longer running, remove /tmp/.X0-lock
and start again.
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
[email protected] ~ $ XIO: fatal IO error 11 (Resource temporarily unavailable) on X server ":0"
after 7 requests (7 known processed) with 0 events remaining.
[email protected] ~ $ export DISPLAY=:0
[email protected] ~ $ startxfce4
/usr/bin/startxfce4: X server already running on display :0
Agent pid 2337
xfdesktop[2355]: starting up
(xfce4-settings-helper:2374): xfce4-settings-helper-WARNING **: Failed to get the _NET_NUMBER_OF_DESKTOPS property.
Only that you get to see more debug info if it fails. Also if it crashes you can make a core file that you can send to me.juppiter89 wrote:Well thanks again for the answer Simon![]()
I tried that but when i ran startxfce4 i got stuck at "/usr/bin/startxfce4: X server already running on display :0"
Instead, if I run first Xorg normally, with just sudo Xorg in first terminal, and then export DISPLAY=:0, startxfce4 in second terminal it works.
Is there any difference between running "sudo gdb Xorg, set args -verbose -keeptty, handle SIGPIPE nostop, run" and just running "sudo Xorg"?
Yep - however the CPU time spent in X is not necessarily 'busy', it's in the kernel just waiting for a co-processor to finish working. Also the faster it services requests the faster the applications sends new onesjuppiter89 wrote:Ok, if I can just run it with sudo Xorg, I can now test the driver itself.
I noticed though that when I drag windows, scrolling and so on, the cpu load is still near 100%. Is it normal?
Cool, thanks for your help.diereinegier wrote:Just yesterday a HDMI-DVI adapter and additional SD cards and for the first time I used my raspi directly. Formerly I was just using it "remotely" via SSH and XDMCP. I surely will dedicate a SD card to this test.
Scratch as you say has its own troubles. This uses a high amount of CPU power all to itself. Completely removing X from the equation doesn't do a great deal to improve performance! Someone else has been working on this.To the question which application usage patterns to observe:
1) Scratch, python and the graphics lib provided to the children should be an important target. Despite the fact that Scratch is a terrible performance hog in itelf...
I've added a lot of support for the commands that come from Iceweasel, but I need more... Chromium sends stuff that I can't accelerate easily...but I think with small changes to its source it could automatically use the Iceweasel optimisations.2) Chromium and Iceweasel used on twitter, facebook, Xing, etc. maybe the two applications that have the most impact on the new user experience.
I've never used emacs before but if you give me an example of how you use it (eg in a terminal? a special X program? etc) I can work with that.3) For me: scrolling in a syntax highlighting emacs
I'd completely forgotten about network. As I said in the OP we were seeing large slowdowns with a 6 us overhead (per DMA CB). The same thing must be hideous over a network!I want to add something to the rant part. Most programmers assume that their program runs at the same machine as their display and do not care about roundtrips and sync points any more. And frameworks do not care either. Have you ever tried to dsable all the silly effects like mouse over in Qt menus to make it work decently over the network? When it comes to font rendering it get's even worse.
Yeah, I ran top and I saw that maximum Xorg cpu load during dragging was 50-60% and the remaning load was the application itself (thunar in my case). So is it working as expected, true?teh_orph wrote:Yep - however the CPU time spent in X is not necessarily 'busy', it's in the kernel just waiting for a co-processor to finish working. Also the faster it services requests the faster the applications sends new onesjuppiter89 wrote:Ok, if I can just run it with sudo Xorg, I can now test the driver itself.
I noticed though that when I drag windows, scrolling and so on, the cpu load is still near 100%. Is it normal?Hence smoother scrolling. Remember also that applications often do their own rendering "client-side" on scrolling eg computing what to draw before sending it to the driver. This is definitely not free!
Something I forgot to mention is that the desktop should now be generally more interactive when CPU time is contended for by other applications. Even when the X server is pre-empted by another application graphical progress is still made at the same rate assuming the CPU is not the piece of hardware doing the actual drawing. The DMA and VPU will stay working in the background.
That said the X server will still need CPU time in order to service these requests and generate data for this external hardware. If the X server never gets any CPU time then things will lurch.
Sounds right. We saw Gearny (the text editor) taking 60% CPU time to itself simply when you were typing in an empty text file! Guhhhhhjuppiter89 wrote:Yeah, I ran top and I saw that maximum Xorg cpu load during dragging was 50-60% and the remaning load was the application itself (thunar in my case). So is it working as expected, true?
I'll continue testing
Obt-Message: Xinerama extension is not present on the server
Openbox-Message: Unable to find a valid menu file "/usr/share/lxde/openbox/menu.xml
(WW) FBDEV_RPI(0): composite would have overread in X by 1108 pixels
--repeated 10 times--
