Hi all
I'm wonder if the Raspi can launch the remake of Street Of Rage ?
i have do some search and the games seems to works very well in Ubuuntu :
http://www.n00bsonubuntu.net/content/ho ... ntu-11-10/
The shell commands seem's to be not works , maybe because Sega asked to remove it ....
i know this game has been made with SDL so maybe that's should works with no wine usage ?
Re: Street Of Rage Remake
No sources = no port.
Theres always openbor will need so tweaking I guess but it works great on the gp32
I've done a little more work today on beats of rage for the PI. And managed to get it working
clone from https://github.com/rofl0r/openbor.git
follow the instructions to compile , I used NO_GL=1 BUILD_DEBUG=1 while making
copy over a Pak file to the relevant folder.
once compiled before executing, I used
fbset -xres 512 -yres 384 -depth 16
then
SDL_FB_BROKEN_MODES=1 ./OpenBOR
and finally I got a display
I did have one or two problems with the Paks I downloaded , after a little reading I realised the compression used on my Paks was obsolete , I unpacked them into a folder and bingo I could play BOR at a good speed
Good luck
CodenameV
then
Good luck
CodenameV
On my system if I use
fbset -xres 384 -yres 256 -depth 16
I get a much bigger play area , people will probably have to try different combos for different displays
CodenameV
CodenameV
How would I compile OpenBor for Raspberry Pi? This there a step by step guide for this? Or is there a compiled version already that could be uploaded here?
Thank You
InsertCoin25
P.S. Sorry if this is a double post.
Thank You
InsertCoin25
Not allways... Use an emulator! Like a DS rom using Desmume.Vanfanel wrote:No sources = no port.
I'm happy to help.
https://www.raspberrypi.org/forums/viewtopic.php?f=78&t=51794 - List of games that work on the Pi.
Ok...this make no sense. CodenameV got OpenBor compiled to work on Raspberry Pi and was wondering how he did it.
Thank You
InsertCoin25
Thank You
InsertCoin25
- duberry
- Location: standing on a planet that's evolving. And revolving at nine hundred miles an hour
no allways. !!!mrpi64 wrote:Not allways... Use an emulator! Like a DS rom using Desmume.Vanfanel wrote:No sources = no port.
all though an emulator! may run the game
its is no port!
lend me your arms, fast as thunderbolts, for a pillow on my journey.
If the environment was a bank, would it be too big to fail
so long; and thanks for all the pi
OpenBor on RaspberryPi
I am not talking about Streets of Rage Remake. I am talking about Openbor which plays .paks made with the OpenBor Engine. I was wondering how he got OpenBor compiled to play on Raspberry Pi, as he stated above, in this thread.duberry wrote:no allways. !!!mrpi64 wrote:Not allways... Use an emulator! Like a DS rom using Desmume.Vanfanel wrote:No sources = no port.
its is no port!
Thank You
InsertCoin25
I would be interested in that as well. Beats of Rage used a scripting engine so it shouldn't be too hard to port it over. I have a number of good games made with open BOR (my favorites are the Golden Axe fan games.)
I have got a compiled version ready in a tar file if anyone would like it just drop me your email address , the file is just under 2mb
in addition you'll need is to download a openbor game pak , unpack it using the tools and move into the pak folder and then play-a-way
my favs are golden axe and final fight
PM sent with email address.
Thank You
InsertCoin25
Thank You
InsertCoin25
Anyone else having problems getting OpenBor to boot? Mine goes straight to a black screen when I execute the runopenbor.sh and just hangs there, making me reboot the Pi. Do I need to run this through the terminal?
Thank You
InsertCoin25
Thank You
InsertCoin25
I've email you over a step by step on how I got this to work , and yes it runs must faster from terminal , so if you are in X logout and try againInsertCoin25 wrote:Anyone else having problems getting OpenBor to boot? Mine goes straight to a black screen when I execute the runopenbor.sh and just hangs there, making me reboot the Pi. Do I need to run this through the terminal?
Thank You
InsertCoin25
any progress?
- PiKISS for Raspberry Pi: https://github.com/jmcerrejon/PiKISS
- Blog: https://misapuntesde.com/
- Patreon: https://www.patreon.com/cerrejon?fan_landing=true
- Twitter: https://twitter.com/ulysess10
- Discord: https://discord.gg/Y7WFeC5
would like a copy of the tar if you would post here please mate?
CodenameV,
I was trying to compile PainTown (OpenBOR + Mugen) to RPi but I corrupted my SD card during the process.
Do you intend to try to compile PainTown too?
I'll certainly try to give it a go , as for the compiled openbor if anyone would like it ,it's currently on my skydrive so send me you email address ( PM if you prefer ) and I'll share it to you
CodenameV
CodenameV
CodenameV,
Thank you for the file, I will test it using my SD card test!!!
CodenameV,
Is it take a while to load a pak file? I tried 6 paks but all of them freezes in black screen.
The menu screen works normally but I tried to run paks with and without menu screen and only black screen.
Hi using the included tools unpack the pak file and try it again , I remember having a few problems with certain pak files until I unpacked them ( then later repacked them )mgoulart wrote:CodenameV,
I managed to compile paintown today, but in its current state its very slow, if I get chance I will try and optimize it more towards the PI hardware , if anyone else fancies trying the compiling is simple , just download the source from the project web site
http://paintown.sourceforge.net/
I downloaded version 3.6
http://sourceforge.net/projects/paintow ... 2/download
unpack it and execute the easy-compile-ubuntu script and that was it
I'll try and post the compiled version later but for now why not give it a go yourselves
CodenameV,
Did you compile it using SDL engine or Allegro 5 engine?
I will try to use the unpack tool!
The SDL engine to start with and heres a link to the compiled file sitting on my onedrive
https://onedrive.live.com/redir?resid=F ... 60DA%21182
for anyone whos interested
, download the source from the above link , untar , when completed untar the compiled file and copy into the folder, then just run paintown , either from terminal or X but its obviously much slower in X
