sudo apt-get update && sudo apt-get install pistore
On another computer (not a PCChrisSwan wrote:Are you on PC when doing this? In order to upload currently you need to be in the Pi Store on the Pi itself, and then use the Upload section.
Very soon you will be able to upload from PC as well, and a detailed instructions page will shortly be provided.
dan3008 wrote:Pays your money, takes your choice
You need to do a separate upload for each platform, but these can all be managed under the one project. If you just select a new platform in the project's 'Platforms/Installers' tab, you're presented with a set of Upload/Build buttons for each platform.jackokring wrote:Just wondering what the situation is with LinuxPC/Pi dual release is. Do you just upload one thing and select 2 platforms or is a double upload needed? I could have two startup scripts in the one release. It could even work on windows if someone else wrote the startup script.
