clicky
i2c bus address
Tue Nov 27, 2012 1:42 pm
Hi all,
I must have missed something, but now I have installed the latest kernel and updated firmware (all part of the same process) for 512Mb device I found that two i2c buses have swapped addresses!
Previously using Chris's Digital Realm kernel i2c bus on the header (gpio 0 and gpio 1) was on bus 0. Now it is on bus 1. Am I making a mistake somewhere in the way module is loaded and configured or it is meant to be like that and previous kernel/kernel builds got it wrong?
Gert van Loo
Re: i2c bus address
Tue Nov 27, 2012 7:40 pm
Yes, you did miss something
The rev-2 spec states that the I2C port on the GPIO connector and the Camera have been swapped.
So I2C0 <=> I2C1
clicky
Re: i2c bus address
Wed Nov 28, 2012 3:53 pm
Oh, thanks! That makes perfect sense. Only think I am not sure now is (as I have both revision RPis and would like to use both):
a) should I in software detect revision of board and adjust bus number accordingly?
or
b) is there a way something else to do it for me (underlying software, kernel, module or whatever is responsible for it)?
If it is the first one, does anyone know good reference how to detect revision of the board so I can adjust bus number accordingly?
[email protected]
Re: i2c bus address
Wed Nov 28, 2012 4:44 pm
clicky wrote:Oh, thanks! That makes perfect sense. Only think I am not sure now is (as I have both revision RPis and would like to use both):
or
Detect the board ID )-:
I've been through several iterations of this - boards programmed incorrectly, with bogus numbers and so on and finally settled on this algorithm:
Read /proc/cpuinfo and search for "Revision" and extract the string.
Look at the last digit - if it's "2" or "3" then it's a Rev 1 board - anything else and it's Rev 2.
no-doubt this will break again in the future, but for now, it seems to be the best way.
(It won't catch the incorrectly programmed rev 1's which have 0000 there, but I'm fairly sure I've heard of a Rev 2 with 0000 there too)
I wish there was a better way.
-Gordon
techpaul
Re: i2c bus address
Wed Nov 28, 2012 5:35 pm
Wish total memory was reported so you couls tell that must be rev 2
Just another techie on the net - For GPIO boards see http:///www.facebook.com/pcservicesreading
or http://www.pcserviceselectronics.co.uk/pi/
[email protected]
Re: i2c bus address
Wed Nov 28, 2012 7:04 pm
techpaul wrote:Wish total memory was reported so you couls tell that must be rev 2
I've a funny feeling some very early Rev 2's only had 256MB on them, so even if that were possible, it might not be foolproof...
-Gordon
techpaul
Re: i2c bus address
Wed Nov 28, 2012 8:08 pm
-Gordon
The joys of version control :-)
techpaul
Re: i2c bus address
Mon Dec 03, 2012 12:05 am
-Gordon
Suddenly remembered what I realy should have said.
But all units with 512MB are Rev 2, so at that point no further revision checks (until Rev 3 appears).
If 256MB still do other checks for revision.2
clicky
Re: i2c bus address
Mon Dec 03, 2012 8:06 am
techpaul wrote: Suddenly remembered what I realy should have said.
That's good to know, but rev 2 board without flashed firmware (updated kernel or whatever else is needed or however it is called) is still reporting 256Mb of memory, so it isn't the most deterministic way. And as you said, it doesn't cover future changes :( I think I'll, for now, stick with trying to identify Rev 1 board and hope that Rev 3 will have bus on the same place... Anyway - thanks all for the ideas! :)
