raspteam
How to compile a cross compiler for arm
Sun Nov 04, 2012 5:46 pm
I used many libs found on web but any of the downloaded packages do not worked correctly. I also tried to recompile source in order to not have problems of dependencies. Therefore I don't manage to compile a simple project on a computer and to execute it on raspberry board.
Where can I found a good tutorial (not using GIT) and where does a package source for arm compiler can be found?
There is someone who has allready compile a cross sources for arm?
jecxjo
Re: How to compile a cross compiler for arm
Mon Nov 05, 2012 1:40 am
Gave me a reason to move info from my old site to my new one so here is my tutorial on building a cross compiler environment.
http://jecxjo.motd.org/code/blosxom.cgi ... nvironment
xmpp: jecxjo@dukgo.com
Blog: http://jecxjo.motd.org/code
raspteam
Fri Nov 16, 2012 4:56 am
I used your tutorial to install GitHub because it is a easy way to compile C source and generate a elf file. The explanations are good and worked fine. However this binary file has no extension and is not runable under Qemu or rasp board using classical command line; The response is the file is considered like a repository. If I use bash command line before exe, the binary file does not run.
When I used command 'file' on exe the result is and elf file for arm.
I would like to generate an application which runs on kernel wheezy.
I viewed the way to run an exe is to replace kernel vmlinuz by this exe.
Does a solution exist to run the output file from compilation?
Is it a really output file which can be executed on an kernel?
How to compile C files and generate an application which will be able to run on kernel wheezy?
raspteam
Sun Jan 05, 2014 9:57 pm
Finally I used crosstoolng 1.17 then I used my own configuration in order to have a fully compatible hard floating cross-compiler with the Wheesy OS version.
Here is the configuration of the crosstoolng 1.17 (crosstool.config file)
# Automatically generated make config: don't edit
# crosstool-NG 1.18.0 Configuration
# Thu Oct 24 23:31:39 2013
CT_CONFIGURE_has_xz=y
CT_MODULES=y
# Paths and misc options
# crosstool-NG behavior
# CT_OBSOLETE is not set
# CT_EXPERIMENTAL is not set
# CT_DEBUG_CT is not set
# Paths
CT_LOCAL_TARBALLS_DIR="${HOME}/Documents/crossbuild/tarballs"
CT_SAVE_TARBALLS=y
CT_WORK_DIR="${HOME}/Documents/crossbuild/.build"
CT_PREFIX_DIR="/opt/x-tools/${CT_TARGET}"
CT_INSTALL_DIR="${CT_PREFIX_DIR}"
CT_RM_RF_PREFIX_DIR=y
CT_REMOVE_DOCS=y
CT_INSTALL_DIR_RO=y
# CT_STRIP_ALL_TOOLCHAIN_EXECUTABLES is not set
# Downloading
# CT_FORBID_DOWNLOAD is not set
# CT_FORCE_DOWNLOAD is not set
CT_CONNECT_TIMEOUT=10
# CT_ONLY_DOWNLOAD is not set
# CT_USE_MIRROR is not set
# Extracting
# CT_FORCE_EXTRACT is not set
CT_OVERIDE_CONFIG_GUESS_SUB=y
# CT_ONLY_EXTRACT is not set
CT_PATCH_BUNDLED=y
# CT_PATCH_LOCAL is not set
# CT_PATCH_BUNDLED_LOCAL is not set
# CT_PATCH_LOCAL_BUNDLED is not set
# CT_PATCH_BUNDLED_FALLBACK_LOCAL is not set
# CT_PATCH_LOCAL_FALLBACK_BUNDLED is not set
# CT_PATCH_NONE is not set
CT_PATCH_ORDER="bundled"
# Build behavior
CT_PARALLEL_JOBS=0
CT_LOAD=""
CT_USE_PIPES=y
CT_EXTRA_CFLAGS_FOR_BUILD=""
CT_EXTRA_LDFLAGS_FOR_BUILD=""
CT_EXTRA_CFLAGS_FOR_HOST=""
CT_EXTRA_LDFLAGS_FOR_HOST=""
# CT_CONFIG_SHELL_SH is not set
# CT_CONFIG_SHELL_ASH is not set
CT_CONFIG_SHELL_BASH=y
# CT_CONFIG_SHELL_CUSTOM is not set
CT_CONFIG_SHELL="${bash}"
# Logging
# CT_LOG_ERROR is not set
# CT_LOG_WARN is not set
# CT_LOG_INFO is not set
CT_LOG_EXTRA=y
# CT_LOG_ALL is not set
# CT_LOG_DEBUG is not set
CT_LOG_LEVEL_MAX="EXTRA"
# CT_LOG_SEE_TOOLS_WARN is not set
CT_LOG_PROGRESS_BAR=y
CT_LOG_TO_FILE=y
CT_LOG_FILE_COMPRESS=y
# Target options
CT_ARCH="arm"
CT_ARCH_SUPPORTS_BOTH_MMU=y
CT_ARCH_SUPPORTS_BOTH_ENDIAN=y
CT_ARCH_SUPPORTS_32=y
CT_ARCH_SUPPORTS_WITH_ARCH=y
CT_ARCH_SUPPORTS_WITH_CPU=y
CT_ARCH_SUPPORTS_WITH_TUNE=y
CT_ARCH_SUPPORTS_WITH_FLOAT=y
CT_ARCH_SUPPORTS_WITH_FPU=y
CT_ARCH_SUPPORTS_SOFTFP=y
CT_ARCH_DEFAULT_HAS_MMU=y
CT_ARCH_DEFAULT_LE=y
CT_ARCH_DEFAULT_32=y
CT_ARCH_ARCH="armv6"
CT_ARCH_CPU="arm1176jzf-s"
CT_ARCH_TUNE=""
CT_ARCH_FPU="vfp"
# CT_ARCH_BE is not set
CT_ARCH_LE=y
CT_ARCH_32=y
CT_ARCH_BITNESS=32
CT_ARCH_FLOAT_HW=y
# CT_ARCH_FLOAT_SW is not set
CT_TARGET_CFLAGS=""
CT_TARGET_LDFLAGS=""
# CT_ARCH_alpha is not set
CT_ARCH_arm=y
# CT_ARCH_avr32 is not set
# CT_ARCH_blackfin is not set
# CT_ARCH_m68k is not set
# CT_ARCH_mips is not set
# CT_ARCH_powerpc is not set
# CT_ARCH_s390 is not set
# CT_ARCH_sh is not set
# CT_ARCH_sparc is not set
# CT_ARCH_x86 is not set
CT_ARCH_alpha_AVAILABLE=y
CT_ARCH_arm_AVAILABLE=y
CT_ARCH_avr32_AVAILABLE=y
CT_ARCH_blackfin_AVAILABLE=y
CT_ARCH_m68k_AVAILABLE=y
CT_ARCH_microblaze_AVAILABLE=y
CT_ARCH_mips_AVAILABLE=y
CT_ARCH_powerpc_AVAILABLE=y
CT_ARCH_s390_AVAILABLE=y
CT_ARCH_sh_AVAILABLE=y
CT_ARCH_sparc_AVAILABLE=y
CT_ARCH_x86_AVAILABLE=y
CT_ARCH_SUFFIX=""
# Generic target options
# CT_MULTILIB is not set
CT_ARCH_USE_MMU=y
CT_ARCH_ENDIAN="little"
# Target optimisations
# CT_ARCH_FLOAT_SOFTFP is not set
CT_ARCH_FLOAT="hard"
# arm other options
CT_ARCH_ARM_MODE="arm"
CT_ARCH_ARM_MODE_ARM=y
# CT_ARCH_ARM_MODE_THUMB is not set
CT_ARCH_ARM_INTERWORKING=y
CT_ARCH_ARM_EABI_FORCE=y
CT_ARCH_ARM_EABI=y
# Toolchain options
# General toolchain options
CT_FORCE_SYSROOT=y
CT_USE_SYSROOT=y
CT_SYSROOT_NAME="sysroot"
CT_SYSROOT_DIR_PREFIX=""
CT_WANTS_STATIC_LINK=y
# CT_STATIC_TOOLCHAIN is not set
CT_TOOLCHAIN_PKGVERSION=""
CT_TOOLCHAIN_BUGURL="file:///usr/share/doc/gcc-4.6/README.Bugs"
# Tuple completion and aliasing
CT_TARGET_VENDOR="rpi"
CT_TARGET_ALIAS_SED_EXPR=""
CT_TARGET_ALIAS="arm-rpilinux-gnueabihf"
# Toolchain type
CT_CROSS=y
# CT_CANADIAN is not set
CT_TOOLCHAIN_TYPE="cross"
# Build system
CT_BUILD=""
CT_BUILD_PREFIX="/opt/x-tool/${CT_TARGET}"
CT_BUILD_SUFFIX=""
# Misc options
CT_TOOLCHAIN_ENABLE_NLS=y
# Operating System
CT_KERNEL_SUPPORTS_SHARED_LIBS=y
CT_KERNEL="linux"
CT_KERNEL_VERSION="3.6.11"
# CT_KERNEL_bare_metal is not set
CT_KERNEL_linux=y
CT_KERNEL_bare_metal_AVAILABLE=y
CT_KERNEL_linux_AVAILABLE=y
# CT_KERNEL_V_3_7_3 is not set
# CT_KERNEL_V_3_7_2 is not set
# CT_KERNEL_V_3_7_1 is not set
# CT_KERNEL_V_3_7 is not set
CT_KERNEL_V_3_6=y
# CT_KERNEL_V_3_5 is not set
# CT_KERNEL_V_3_4 is not set
# CT_KERNEL_V_3_3 is not set
# CT_KERNEL_V_3_2 is not set
# CT_KERNEL_V_3_1 is not set
# CT_KERNEL_V_3_0 is not set
# CT_KERNEL_V_2_6_39 is not set
# CT_KERNEL_V_2_6_38 is not set
# CT_KERNEL_V_2_6_37 is not set
# CT_KERNEL_V_2_6_36 is not set
# CT_KERNEL_V_2_6_33 is not set
# CT_KERNEL_V_2_6_32 is not set
# CT_KERNEL_V_2_6_31 is not set
# CT_KERNEL_V_2_6_27 is not set
# CT_KERNEL_LINUX_CUSTOM is not set
CT_KERNEL_windows_AVAILABLE=y
# Common kernel options
CT_SHARED_LIBS=y
# linux other options
CT_KERNEL_LINUX_VERBOSITY_0=y
# CT_KERNEL_LINUX_VERBOSITY_1 is not set
# CT_KERNEL_LINUX_VERBOSITY_2 is not set
CT_KERNEL_LINUX_VERBOSE_LEVEL=0
CT_KERNEL_LINUX_INSTALL_CHECK=y
# Binary utilities
CT_ARCH_BINFMT_ELF=y
CT_BINUTILS="binutils"
CT_BINUTILS_binutils=y
# GNU binutils
CT_BINUTILS_V_2_22=y
# CT_BINUTILS_V_2_21_53 is not set
# CT_BINUTILS_V_2_21_1a is not set
# CT_BINUTILS_V_2_20_1a is not set
# CT_BINUTILS_V_2_19_1a is not set
# CT_BINUTILS_V_2_18a is not set
CT_BINUTILS_VERSION="2.22"
CT_BINUTILS_2_22_or_later=y
CT_BINUTILS_2_21_or_later=y
CT_BINUTILS_2_20_or_later=y
CT_BINUTILS_2_19_or_later=y
CT_BINUTILS_2_18_or_later=y
CT_BINUTILS_HAS_HASH_STYLE=y
CT_BINUTILS_HAS_GOLD=y
CT_BINUTILS_GOLD_SUPPORTS_ARCH=y
CT_BINUTILS_HAS_PLUGINS=y
CT_BINUTILS_HAS_PKGVERSION_BUGURL=y
CT_BINUTILS_FORCE_LD_BFD=y
CT_BINUTILS_LINKER_LD=y
# CT_BINUTILS_LINKER_LD_GOLD is not set
# CT_BINUTILS_LINKER_GOLD_LD is not set
CT_BINUTILS_LINKERS_LIST="ld"
CT_BINUTILS_LINKER_DEFAULT="bfd"
CT_BINUTILS_PLUGINS=y
CT_BINUTILS_EXTRA_CONFIG_ARRAY=""
CT_BINUTILS_FOR_TARGET=y
CT_BINUTILS_FOR_TARGET_IBERTY=y
CT_BINUTILS_FOR_TARGET_BFD=y
# binutils other options
# C compiler
CT_CC="gcc"
CT_CC_VERSION="4.6.3"
CT_CC_CORE_PASSES_NEEDED=y
CT_CC_gcc=y
# CT_CC_GCC_SHOW_LINARO is not set
# CT_CC_V_4_7_2 is not set
# CT_CC_V_4_7_1 is not set
# CT_CC_V_4_7_0 is not set
CT_CC_V_4_6_3=y
# CT_CC_V_4_6_2 is not set
# CT_CC_V_4_6_1 is not set
# CT_CC_V_4_6_0 is not set
# CT_CC_V_4_5_3 is not set
# CT_CC_V_4_5_2 is not set
# CT_CC_V_4_5_1 is not set
# CT_CC_V_4_5_0 is not set
# CT_CC_V_4_4_7 is not set
# CT_CC_V_4_4_6 is not set
# CT_CC_V_4_4_5 is not set
# CT_CC_V_4_4_4 is not set
# CT_CC_V_4_4_3 is not set
# CT_CC_V_4_4_2 is not set
# CT_CC_V_4_4_1 is not set
# CT_CC_V_4_4_0 is not set
# CT_CC_V_4_3_6 is not set
# CT_CC_V_4_3_5 is not set
# CT_CC_V_4_3_4 is not set
# CT_CC_V_4_3_3 is not set
# CT_CC_V_4_3_2 is not set
# CT_CC_V_4_3_1 is not set
# CT_CC_V_4_2_4 is not set
# CT_CC_V_4_2_2 is not set
CT_CC_GCC_4_2_or_later=y
CT_CC_GCC_4_3_or_later=y
CT_CC_GCC_4_4_or_later=y
CT_CC_GCC_4_5_or_later=y
CT_CC_GCC_4_6=y
CT_CC_GCC_4_6_or_later=y
CT_CC_GCC_HAS_GRAPHITE=y
CT_CC_GCC_HAS_LTO=y
CT_CC_GCC_HAS_PKGVERSION_BUGURL=y
CT_CC_GCC_HAS_BUILD_ID=y
CT_CC_GCC_ENABLE_PLUGINS=y
CT_CC_GCC_USE_GMP_MPFR=y
CT_CC_GCC_USE_PPL_CLOOG=y
CT_CC_GCC_USE_MPC=y
CT_CC_GCC_HAS_LIBQUADMATH=y
CT_CC_LANG_FORTRAN=y
CT_CC_SUPPORT_CXX=y
CT_CC_SUPPORT_FORTRAN=y
CT_CC_SUPPORT_JAVA=y
CT_CC_SUPPORT_ADA=y
CT_CC_SUPPORT_OBJC=y
CT_CC_SUPPORT_OBJCXX=y
# Additional supported languages:
CT_CC_LANG_CXX=y
# CT_CC_LANG_JAVA is not set
# gcc other options
CT_CC_ENABLE_CXX_FLAGS=""
CT_CC_CORE_EXTRA_CONFIG_ARRAY=""
CT_CC_EXTRA_CONFIG_ARRAY="--enable-tls"
CT_CC_STATIC_LIBSTDCXX=y
CT_CC_GCC_SYSTEM_ZLIB=y
# Optimisation features
CT_CC_GCC_USE_GRAPHITE=y
CT_CC_GCC_USE_LTO=y
# Settings for libraries running on target
CT_CC_GCC_ENABLE_TARGET_OPTSPACE=y
# CT_CC_GCC_LIBMUDFLAP is not set
# CT_CC_GCC_LIBGOMP is not set
# CT_CC_GCC_LIBSSP is not set
# CT_CC_GCC_LIBQUADMATH is not set
# Misc. obscure options.
CT_CC_CXA_ATEXIT=y
# CT_CC_GCC_DISABLE_PCH is not set
# CT_CC_GCC_SJLJ_EXCEPTIONS is not set
CT_CC_GCC_LDBL_128=m
CT_CC_GCC_BUILD_ID=y
# C-library
CT_LIBC="eglibc"
CT_LIBC_VERSION="2_13"
CT_LIBC_eglibc=y
# CT_LIBC_glibc is not set
# CT_LIBC_uClibc is not set
CT_LIBC_eglibc_AVAILABLE=y
# CT_LIBC_EGLIBC_V_2_17 is not set
# CT_LIBC_EGLIBC_V_2_16 is not set
# CT_LIBC_EGLIBC_V_2_15 is not set
# CT_LIBC_EGLIBC_V_2_14 is not set
CT_LIBC_EGLIBC_V_2_13=y
# CT_LIBC_EGLIBC_V_2_12 is not set
# CT_LIBC_EGLIBC_V_2_11 is not set
# CT_LIBC_EGLIBC_V_2_10 is not set
# CT_LIBC_EGLIBC_V_2_9 is not set
# CT_LIBC_EGLIBC_V_TRUNK is not set
# svn is missing. You'll have to either:
#   - have a pre-downloaded local tarball
#   - or have a LAN mirror with a pre-downloaded tarball
# otherwise you won't be able to download eglibc
# CT_EGLIBC_OPT_SIZE is not set
# CT_EGLIBC_CUSTOM_CONFIG is not set
CT_LIBC_glibc_AVAILABLE=y
CT_LIBC_mingw_AVAILABLE=y
CT_LIBC_newlib_AVAILABLE=y
CT_LIBC_none_AVAILABLE=y
CT_LIBC_uClibc_AVAILABLE=y
CT_LIBC_SUPPORT_THREADS_ANY=y
CT_LIBC_SUPPORT_NPTL=y
CT_LIBC_SUPPORT_LINUXTHREADS=y
CT_THREADS="nptl"
# Common C library options
CT_THREADS_NPTL=y
# CT_THREADS_LINUXTHREADS is not set
# CT_LIBC_XLDD is not set
# eglibc other options
CT_LIBC_GLIBC_MAY_FORCE_PORTS=y
CT_LIBC_glibc_familly=y
CT_LIBC_GLIBC_EXTRA_CONFIG_ARRAY=""
CT_LIBC_GLIBC_CONFIGPARMS=""
CT_LIBC_GLIBC_EXTRA_CFLAGS=""
CT_LIBC_EXTRA_CC_ARGS=""
# CT_LIBC_DISABLE_VERSIONING is not set
CT_LIBC_OLDEST_ABI=""
# CT_LIBC_GLIBC_FORCE_UNWIND is not set
CT_LIBC_GLIBC_USE_PORTS=y
CT_LIBC_ADDONS_LIST=""
# WARNING !!!
#   For glibc >= 2.8, it can happen that the tarballs
#   for the addons are not available for download.
#   If that happens, bad luck... Try a previous version
#   or try again later... :-(
# CT_LIBC_LOCALES is not set
# CT_LIBC_GLIBC_KERNEL_VERSION_NONE is not set
# CT_LIBC_GLIBC_KERNEL_VERSION_AS_HEADERS is not set
CT_LIBC_GLIBC_KERNEL_VERSION_CHOSEN=y
CT_LIBC_GLIBC_MIN_KERNEL_VERSION="3.6.11"
CT_LIBC_GLIBC_MIN_KERNEL="3.6.11"
# Debug facilities
CT_DEBUG_dmalloc=y
CT_DMALLOC_V_5_5_2=y
CT_DMALLOC_VERSION="5.5.2"
CT_DEBUG_duma=y
CT_DUMA_A=y
CT_DUMA_SO=y
CT_DUMA_V_2_5_15=y
CT_DUMA_VERSION="2_5_15"
CT_DEBUG_gdb=y
CT_GDB_CROSS=y
# CT_GDB_CROSS_STATIC is not set
# CT_GDB_CROSS_SIM is not set
CT_GDB_CROSS_PYTHON=y
CT_GDB_CROSS_EXTRA_CONFIG_ARRAY=""
CT_GDB_NATIVE=y
# CT_GDB_NATIVE_STATIC is not set
CT_GDB_GDBSERVER=y
CT_GDB_GDBSERVER_STATIC=y
# gdb version
# CT_DEBUG_GDB_SHOW_LINARO is not set
# CT_GDB_V_7_4_1 is not set
# CT_GDB_V_7_4 is not set
# CT_GDB_V_7_3_1 is not set
# CT_GDB_V_7_3a is not set
# CT_GDB_V_7_2a is not set
# CT_GDB_V_7_1a is not set
# CT_GDB_V_7_0_1a is not set
# CT_GDB_V_7_0a is not set
CT_GDB_V_6_8a=y
CT_GDB_VERSION="6.8a"
CT_DEBUG_ltrace=y
CT_LTRACE_V_0_5_3=y
# CT_LTRACE_V_0_5_2 is not set
CT_LTRACE_VERSION="0.5.3"
CT_LTRACE_0_5_3_or_later=y
CT_DEBUG_strace=y
# CT_STRACE_V_4_6 is not set
# CT_STRACE_V_4_5_20 is not set
CT_STRACE_V_4_5_19=y
# CT_STRACE_V_4_5_18 is not set
CT_STRACE_VERSION="4.5.19"
# Companion libraries
CT_COMPLIBS_NEEDED=y
CT_GMP_NEEDED=y
CT_MPFR_NEEDED=y
CT_PPL_NEEDED=y
CT_CLOOG_NEEDED=y
CT_MPC_NEEDED=y
CT_COMPLIBS=y
CT_GMP=y
CT_MPFR=y
CT_PPL=y
CT_CLOOG=y
CT_MPC=y
CT_LIBELF_TARGET=y
# CT_GMP_V_5_0_2 is not set
# CT_GMP_V_5_0_1 is not set
CT_GMP_V_4_3_2=y
# CT_GMP_V_4_3_1 is not set
# CT_GMP_V_4_3_0 is not set
CT_GMP_VERSION="4.3.2"
CT_MPFR_V_3_1_0=y
# CT_MPFR_V_3_0_1 is not set
# CT_MPFR_V_3_0_0 is not set
# CT_MPFR_V_2_4_2 is not set
# CT_MPFR_V_2_4_1 is not set
# CT_MPFR_V_2_4_0 is not set
CT_MPFR_VERSION="3.1.0"
CT_PPL_V_0_11_2=y
# CT_PPL_V_0_11_1 is not set
# CT_PPL_V_0_11 is not set
# CT_PPL_V_0_10_2 is not set
CT_PPL_VERSION="0.11.2"
CT_PPL_0_11=y
CT_PPL_NEEDS_LIBPWL=y
CT_CLOOG_V_0_15_11=y
# CT_CLOOG_V_0_15_10 is not set
# CT_CLOOG_V_0_15_9 is not set
# CT_CLOOG_V_0_15_8 is not set
# CT_CLOOG_V_0_15_7 is not set
# CT_CLOOG_V_0_15_6 is not set
CT_CLOOG_VERSION="0.15.11"
CT_CLOOG_0_15_1x=y
CT_CLOOG_NEEDS_AUTORECONF=y
CT_MPC_V_0_9=y
# CT_MPC_V_0_8_2 is not set
# CT_MPC_V_0_8_1 is not set
# CT_MPC_V_0_7 is not set
CT_MPC_VERSION="0.9"
# libelf version needed to build for target
CT_LIBELF_V_0_8_13=y
# CT_LIBELF_V_0_8_12 is not set
CT_LIBELF_VERSION="0.8.13"
# Companion libraries common options
# CT_COMPLIBS_CHECK is not set
This configuration generates a fully compatible environnement for Wheesy image.
