I've seen a few people asking about http://www.linuxfromscratch.org on the Pi so I started a site just for you:
http://www.intestinate.com/pilfs
Hope someone likes it!
Re: Linux From Scratch on the Raspberry Pi
This looks great, thanks for sharing.
This is exactly what I needed thank you. I'm waiting for easier tutorials on your website.
My very own distro; this may get me over the hump -!
OMG... masochists in our midst..Mogwai wrote:I've seen a few people asking about http://www.linuxfromscratch.org on the Pi
LFS is a great way to learn about the nitty-gritty of building and installing Linux, and the leasons learned will stay with you for a (very) long time - Remember doing an LFS build on an x86 800MHz box which took about a whole week... Think it might take a bit longer than that on a Pi, but still worth doing, if nothing more than an educational exercise.
Once done with LFS, you gotta go for a full BLFS install
Haha, I admit it does take a bit of a control freak to attempt putting together your own distro.Serac wrote: OMG... masochists in our midst..
The build time is just a couple of days though
You just need a decent build systemMogwai wrote:Serac wrote: The build time is just a couple of days though
That looks really cool! I'd love to see a Raspberry Pi specific guide to building with Yocto, with recipes for the kernel and XBMC etc.keylevel wrote: You just need a decent build systemI can build 'Poky' (see https://yoctoproject.org) in about 56 minutes on a system with 4GHz quad core (with hyper threading), 16GB RAM and SSD. This gives a complete distro (kernel, etc.) and I found it much, much easier to use. It provides a complete cross-tools / build environment (built from source) so it's easy to add libraries, applications, etc. once you've got the basic image running.
- fos
- Contact: Website
Very nice!
I will need another SD card to experiment with. I use it at home on an old via board.
Thank you!
Jeff
Thank you!
Jeff
https://faroutscience.com
There is a project on Github (https://github.com/djwillis/meta-raspberrypi) that provides a basic (for now) BSP (Board Support Package) for the RPi. This pulls in the official kernel from https://github.com/raspberrypi. It's still very much work-in-progress, but it does allow you to build a set of files (firmware, kernel, root fs) that will give you a running system.Mogwai wrote: That looks really cool! I'd love to see a Raspberry Pi specific guide to building with Yocto, with recipes for the kernel and XBMC etc.
There is a lot of recipe support for other bits and the core is compatible with OpenEmbedded (http://openembedded.org) so recipes from it can be used as well.
It fairly easy to create your own recipe if there is a package you need which isn't already supported. I use these for my own custom auto-tooled projects and it only takes a few lines of recipe to get something that builds. Qemu is also supported (as another 'BSP'), which means you can do all the build and test work on a more powerful system (saves a lot of time) and then simply switch to target the RPi when you're happy it's ready to deploy. All the cross-tools needed for this are 'included' (they are built as needed) within Yocto.
It's probably worth me putting in a request to set up a forum for Yocto so that I can (when I get some time!) add some basic instructions. General use and configuration of Yocto is well covered by the documentation on the Yocto site (much better than OpenEmbedded, which is why I use it).
Update:
I put up a showcase SD-card image for people who just want to test drive an LFS system with some nice apps. Comes with OMXPlayer, XBMC, RetroArch, Quake3, a minimal Razor-QT + Openbox desktop environment and the QupZilla web browser.
If you have a spare card around, please give it a try and let me know how it compares to your distribution of choice and what software you'd like to see in the next image.
- fos
- Contact: Website
If you need donations for contributions to help with R Pi LFS, please let me know.
Thanks for your hard work,
Jeff
Jeff
Thanks Jeff, appreciate it!fos wrote:If you need donations for contributions to help with R Pi LFS, please let me know.
Jeff
Right now, hosting the PiLFS project is completely free.
However, there would be no PiLFS without the original LFS project.
So please consider making a small donation on their page: http://www.linuxfromscratch.org/lfs/contribute.html
I've been playing with Freescale's Linux Target Image Builder (LTIB - http://ltib.org/) in order to cross-compile my own Linux distro for the Raspi.
My ultimate goal was to have an environment in which I could cross-compile packages for the Pi which had various and several prerequisites, and things would magically link against the proper libs, use the proper headers, etc. LTIB gives you a lot of that for free.
In any case, I've made some progress. I've successfully built a rootfs image (including a kernel and BusyBox) on my x86 desktop that I plan to try and boot on a Pi when I get home in a few hours. If there's enough interest, I'll look into cleaning it up and sharing with the community.
To clarify, I meant that I would clean up and share my LTIB and cross-compiler configs if there was interest.
Another update:
New and improved showcase image online, includes the following software:
- OMXPlayer - With support for .srt subtitles.
- YT - YouTube Console Client
- XBMC - With support for CEC, Avahi, Samba & SSH
- RetroArch / EmulationStation - With emulators for NES, SNES, SMS, Genesis, Game Boy & Neo Geo (Final Burn Alpha)
- Razor-QT + Fluxbox - Minimal desktop with QupZilla web browser.
- Quake3
This looks great - added to my ever growing list of things to play with on my Pi!!
My computing blog including Raspberry Pi: http://katescomputingcapers.wordpress.com/
thanks for the showcase image you made. it works but I m not able to log in because I dont know the log in. the password is mentioned but not the log in. thanks in advance.bye
Ah, sorry about that.pallots wrote:Hi,
Login is "root"
Password is "pilfs"
a bit late for a comment about this:keylevel wrote: You just need a decent build systemI can build 'Poky' (see https://yoctoproject.org) in about 56 minutes on a system with 4GHz quad core (with hyper threading), 16GB RAM and SSD. This gives a complete distro (kernel, etc.) and I found it much, much easier to use. It provides a complete cross-tools / build environment (built from source) so it's easy to add libraries, applications, etc. once you've got the basic image running.
thats basically what OpenELEC (www.openelec.tv) is or providesMogwai wrote:That looks really cool! I'd love to see a Raspberry Pi specific guide to building with Yocto, with recipes for the kernel and XBMC etc.
