It needs some minor adjustments for composite/old low resolution SD TV type screen.
When it comes up, I see the first 5 directories (including the ".."). When I arrow down, the selected directory disappears off the bottom after the 5th one. I can arrow down 10 or 11 times, and it will then skip to the top of the next page. So I never get to see the directories on the bottom of each page. If I click return when the selected directory is hidden, it opens it up.
Well, you can simply adjust this setting in the 'conf.h' file
. Just set 'AMOUNT_ENTRIES' to 5 or whatever you want. If the font is too large for you you can set the fontsize as well.
I highly recommend to get the latest version off github. Many things have changed in the last week. I have stabilized the plugin API and added a plugin launcher which will, that is the next step, dynamically load plugins. I added vietnamese live TV (for my GF, but you can easily deactivate it in settings.mak) and Jupiterbroadcasting live streaming (although this is quite unstable at the moment, I need to fix that).
To update, just enter
Upcoming features:
- dynamic plugin loading
- music browser
- picture browser
Have fun
