rbej
OpenElec Builds with GUI 1080p.
Mon Oct 22, 2012 1:58 pm
Rbej Frodo Branch
http://www.mediafire.com/?10456ccz13ard
- Xbmc 12.2 Frodo (02.05.2013)
- Rpi kernel 3.8.y (01.05.2013)
- Rpi firmware (01.05.2013)
- Pvr Addon (20.04.2013) with MythTV 1.6.10
- Xvdr Addon 0.9.8
- Gpu memory set to 100mb on default for Rpi 256mb (fix kernal killing Xbmc task on Rpi 256mb board) and Gpu memory set to 256mb on default for Rpi 512mb.
Special features
- enable 128mb swap file
- add Gui resolution change (taken from XBIAN)
- remove battery level info from System Information and add info about build version (taken from XBIAN)
- NFS auto-update patches for USB/NFS/SMB on Rpi
- remove Cpu usage bar from System Information
- Network Cache Redux
- librtmp (10.04.2013)
- float audio patch (performance up 15-20% when play movies. Working only with FFmpeg 1.2)
- FFmpeg 1.2
- Performance patches (UI)
- play CD audio on Rpi
- fixes PGS subtitles
- remove unnecessary gl ifdef
- fix for hang following seek after eos
- make ffmpeg demuxer observe pmt changes with PR 2701
- subs fixes
- PR 2700 adopted to OmxPlayer
Please read this:
https://github.com/xbmc/xbmc/pull/1388
No more cachemembuffersize in advenced setting. Please delete it and add this:
<alwaysforcebuffer>true</alwaysforcebuffer>
<freememorycachepercent>5</freememorycachepercent>
1. alwaysforcebuffer: This will force everything ran through dvdplayer to be buffered that would not be normal buffered except Optical Media. This includes SMB, Local Files, OS Network Shares, etc.
2. freememorycachepercent: The amount of free memory to use as buffer size. Please note that of the percentage of free memory used ~75% will be used for forward buffering and ~25% will be used for the back buffer.
Add to advencedsettings <guires>XXXX</guires>
XXXX = GUI resolution. 480p,720p,900p,1080p. <guires>720</guires>, <guires>1080</guires> etc...
Update Instruction:
http://wiki.openelec.tv/index.php?title ... g_OpenELEC
For Rpi 512Mb set gpu_mem=256 and change GUI to 1080p.
For Rpi 256Mb set gpu_mem=100 and change GUI to 900p.
or clean install:
http://wiki.openelec.tv/index.php?title ... spberry_Pi
welshblob
Re: OpenElec Builds with GUI 1080p.
Mon Oct 22, 2012 3:09 pm
Are you saying that the nornal openelec builds are not running with the GUI at 1080p?
I'm running build r12195 and the system info page seems to think its running at 1920x1080 @ 60 Hz and the TV thinks its on a 1080p source?
Rob
Wanderlei
Mon Oct 22, 2012 4:01 pm
welshblob wrote:Are you saying that the nornal openelec builds are not running with the GUI at 1080p?
Rob
As far as I am aware it was fairly recent that they started upscaling the menus.
I am rocking r12015 and I pretty sure its has naitive 1080p, also best for wifi and CEC compatibility for my setup. I try pretty much every build but this one has been favourite so far.
I will probably stick with it for a while until problems with omxplayer improve.
malakai
Mon Oct 22, 2012 4:05 pm
Seems fishy considering the most current build is
OpenELEC-RPi.arm-devel-20121020212708-r12220.tar.bz2
http://sources.openelec.tv/tmp/image/openelec-rpi/
I would call it something other than an updated build number like try my custom port of it, anything but adding a number to their building scheme.
Wanderlei
Mon Oct 22, 2012 4:09 pm
malakai wrote:Seems fishy considering the most current build is
I was pointed to get build from there also, but there is also here "http://openelec.thestateofme.com/" and it is update more often and has new builds.
I was confused which is 'official'?
malakai
Mon Oct 22, 2012 4:17 pm
Same here didn't even know about that one. More releases isn't necessarily a good thing and something to think about. If you push an update every other week how much testing goes into the product. This is just from personal experience with flavors of Linux I tend to stay with the one that doesn't update constantly. They seem be more stable in the end. The only updates to really be concerned with are security patches if they want to push one every half hour fine but if it works don't try to fix it.
That is all just my opinion don't take it to heart if you have another but I think it's something that should really be considered for new users. Review what is changing and decide if you really need it.
Thanks for the posts though I haven't done much with XBMC on the Pi now I know more than I did yesterday :)
rbej
Mon Oct 22, 2012 6:21 pm
Dont worry. This is official build with only one small not official patch.
Im only change two values in one file. 1280x720 on 1920x1080.
Working perfect and now GUI is 1080p.
rbej
Wed Oct 24, 2012 4:55 pm
Build r12256 with GUI 1080p
http://netload.in/dateiI4lIWGWr9b/OpenE ... ar.bz2.htm
Update Instruction:
http://openelec.tv/installation/updating
After update, please delete guisettings.xml and reboot Rpi.
EXPERIMENTAL VERSION. USE AT YOUR OWN RISK!!. NO SUPPORT FROM XBMC TEAM!!.
milhouse
Fri Oct 26, 2012 1:52 am
Would be interesting to see how stable a 1080p GUI is with build r12268, as this build fixes a lot of the OMX resource/memory errors that forced the developers to upscale the GUI in the first place.
rbej
Fri Oct 26, 2012 8:33 am
Build r12275 with GUI 1080p
http://netload.in/dateiNDVHUDaPIZ/OpenE ... ar.bz2.htm
Update Instruction:
milhouse
Fri Oct 26, 2012 9:28 am
rbej wrote:Build r12275 with GUI 1080p
Very nice - the GUI is noticeably sharper. Unfortunately it makes it even more obvious how horribly pixelated fanart now is...
rbej
Tue Oct 30, 2012 7:09 am
Build r12322 with GUI 1080p
http://netload.in/dateimfvGtatx0s/OpenE ... ar.bz2.htm
Update Instruction:
jesus225
Tue Oct 30, 2012 9:01 am
My TV resolution is currently 1680x1050. Using official image it leads in upscaling from 720p and the gui is totally blurry as you know.
My query is: Should I re-compile my own build for 1680x1050 or will the one with 1080p gui work fine?
In fact, I don't even know how the scaling works and I wonder if using 1080p build with 1680x1050 TV means downscaling from 1080p instead of showing native 1680x1050.
Thank you in advance.
rbej
Tue Oct 30, 2012 9:49 am
Try GUI 1080p version. Everything will be sharp.
rbej
Thu Nov 01, 2012 6:45 am
Build r12350 with GUI 1080p
http://netload.in/dateiJc8ccvX4fe/OpenE ... ar.bz2.htm
Update Instruction:
Vulpes
Sat Nov 03, 2012 2:47 pm
Can you tell me what excatly did you change to achieve real 1080p?
Vulpes
Sat Nov 03, 2012 5:24 pm
Thanks.
rbej
Tue Nov 06, 2012 8:58 pm
Build r12383 with GUI 1080p.
http://netload.in/dateiS6F9i5IgoE/OpenE ... ar.bz2.htm
Update Instruction:
rbej
Thu Nov 08, 2012 6:55 am
Build r12431 with GUI 1080p.
http://netload.in/dateiEvNn9ItxYb/OpenE ... ar.bz2.htm
Update Instruction:
rbej
Sun Nov 11, 2012 8:33 pm
Build r12457 with GUI 1080p.
http://netload.in/dateirRDfamZXtR/OpenE ... ar.bz2.htm
Update Instruction:
rbej
Fri Nov 16, 2012 9:18 am
Build r12485 with GUI 1080p.
http://netload.in/dateirqC6UrmIqP/OpenE ... ar.bz2.htm
Update Instruction:
rbej
Sat Nov 17, 2012 10:29 am
Build r12492 with GUI 1080p.
http://netload.in/dateiT4HtsEX57w/OpenE ... ar.bz2.htm
Build without LCD Driver.
Two bugs is fixed:
-100% Cpu usage.
-soft reboot not working properly.
Update Instruction:
rbej
Mon Nov 19, 2012 2:39 pm
Build r12502 with GUI 1080p.
http://netload.in/dateiWdmGngS5WV/OpenE ... ar.bz2.htm
Update Instruction:
rbej
Thu Nov 22, 2012 8:17 pm
Build r12555 with GUI 1080p.
http://netload.in/dateiXxrNtBMK2s/OpenE ... ar.bz2.htm
Update Instruction:
Return to “Media centres”
