Anirbaan
Controlling a Raspberry pi 4 with my laptop
Sun May 16, 2021 7:23 pm
Dear All,
I have had full success previously trying to interface the raspberry pi using its IP address , an RJ45 LAN ethernet cable via the USB port on the laptop, using the MOBAXTERM . After such success I tried to interface with my android phone but had not been successful, because of difficulty with my mobile's hotspot. Lately for a project I am trying to interface the raspberry PI with my laptop following the early procedure, but when the remote SSH session is started on the MOBAXTERM it gives the error message : Connection Refused. It is a similar message when I have used PUTTY after enabling theX11 transfer.
To check if the IP address has been correctly noted I have used the Advanced IP Scanner after connecting the raspberry pi with the ethernet cable with my laptop and then deliberately disconnecting the wi-fi of my laptop and indeed it could detect the IP of my raspberry pi. Furthermore, I pinged the IP address at the IP scanner and was successful and then also pinged at the command prompt and it was pinging successfully as well. All this time I kept the wi-fi of my laptop off. Also from the overview the power LED and the booting LED and two of the LAN LEDs are ON on the raspberry pi 4B .
I had followed these 2 videos:
1. to connect to the laptop:
https://www.youtube.com/watch?v=AJ7skYS5bjI
2. to connect to the Android phone:
https://www.youtube.com/watch?v=jHvJ-7lIySs
Would like to know what should I do to control my raspberry pi by my laptop.
kerry_s
Re: Controlling a Raspberry pi 4 with my laptop
Sun May 16, 2021 8:43 pm
the standard way is to enable vnc server in the preferences.
then install realvnc on your laptop & android.
Anirbaan
Sun May 16, 2021 8:55 pm
Hi Kerry_s where to find the Preferences
kerry_s
Sun May 16, 2021 9:08 pm
menu> preferences> raspi config
Anirbaan
Sun May 16, 2021 9:20 pm
I see which means we first need to have the raspberry pi work with a monitor and a keyboard, then do the menu>preferences>raspiconfig , install the vnc in the raspberry pi and then can work in the headless mode
Is it so @ Kerry_s
kerry_s
Sun May 16, 2021 9:29 pm
no, if you can ssh in run "sudo raspi-config", number 3 interface options> p3 vnc, press enter & select yes with the tab key.
forgot while your in there, you need to set a display size.
kerry_s
Sun May 16, 2021 9:34 pm
then you'll be able to connect using your current user password.
FTrevorGowen
Sun May 16, 2021 9:52 pm
Again, if you can SSH into the Pi, an alternative to using a preset display size and VNC'ng into that it's also possible to start the RealVNC server manually in virtual mode with any convenient geometry (using display :1 instead of :0) .
FWIW, see my notes & examples here: http://www.cpmspectrepi.uk/raspberry_pi ... uster.html
Trev.
Still running Raspbian Jessie or Stretch on some older Pi's (an A, B1, 2xB2, B+, P2B, 3xP0, P0W, 2xP3A+, P3B, B+, and a A+) but Buster on the P3B+, P4B's & P400. See: https://www.cpmspectrepi.uk/raspberry_pi/raspiidx.htm
Anirbaan
Sun May 16, 2021 10:08 pm
@kerry_S
Hi Kerry,
As I mentioned either using PUTTY or MOBAXTERM with the LAN connected with the PI I am getting the message Network Refusal, therefore the only alternative is first setting up the desktop and then going from there.
kerry_s
Sun May 16, 2021 10:19 pm
yeah, if you didn't set it up in advance.
just to let you know the next time you create an image, the rpi-imager has a hidden advanced mode.
press: ctrl+shift+x
to access it.
