ToddFerrante
$PATH and scripts
Sun Sep 30, 2012 8:12 pm
I'm about to rip my hair out I'm so frustrated. I just flashed back to a fresh Raspberrian, and updated. I've created the classic "hello world" script in /usr/local/bin, called "test". When I check my path with "echo $PATH", that directory is in my path. "pwd" shows that I'm in that directory. I used the nano editor to create the script, and chmod'd it to be executable. If I type "./test", it works properly. If I type "test", it does nothing. No error message, just another command line prompt. I must be doing some simple wrong, but I can't figure it out. Any ideas?
Todd F.
itimpi
Re: $PATH and scripts
Sun Sep 30, 2012 8:33 pm
Isn't test a reserved word in the shell?
ToddFerrante
Sun Sep 30, 2012 8:45 pm
That was the problem. I renamed it "tftest" and it worked properly. I knew there had to be a simple answer.
Todd F.
jojopi
Sun Sep 30, 2012 9:35 pm
itimpi wrote:Isn't test a reserved word in the shell?
Technically it is not a reserved word, but it is a builtin shell command in bash. You can disable a builtin with "enable -n test" and then "test" will run the first version from $PATH, probably /usr/local/bin. However, it is still a bad idea to call a program /usr/local/bin/test because there is also a standard binary /usr/bin/test, compatible with the builtin, and overriding it in /usr/local/bin could potentially break programs that rely on it.
billb
Sun Sep 30, 2012 9:36 pm
The which command is useful for things like this ... it will tell you the location of which program/command that would run had you entered it by itself.
In this case:
which test
Would say:
/usr/bin/test
For more info see:
man which
(yeah I know, a sandwich is a sandwich... :P)
jojopi
Sun Sep 30, 2012 9:46 pm
billb wrote:which test
Would say:
/usr/bin/test
Which, no pun intended, is completely wrong. "which" is an external command and knows nothing about shell builtins. It is pointless and should never be used. Instead, "type test" will tell you "test is a shell builtin" or, if disabled, "test is /usr/local/bin/test".
billb
Sun Sep 30, 2012 9:56 pm
Thanks -- "type" looks much more useful than "which" :)
Joe Schmoe
Sun Sep 30, 2012 10:01 pm
Since my fingers are used to typing 'which' or 'where', I usually alias one or both (on those rare occasions when I'm using bash as an interactive shell) to "type -a".
