diecast
Revision 0000 - gpio not working
Fri Sep 28, 2012 9:05 pm
I've tried using wiringPi and it gave an error:
piBoardRev: Unable to determine board revision from 0
gpio: Unable to initialise wiringPi mode
So I jumped onto IRC #raspberrypi and asked what was the issue. I have a Revision 0000 board
/proc/cpuinfo
Processor       : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS        : 697.95
Features        : swp half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant     : 0x0
CPU part        : 0xb76
CPU revision    : 7
Hardware        : BCM2708
Revision        : 0000
Serial          : 0000000001864fca
I also exported pins 28,29,30,31 after a recommendation and the output was 1 0 0 0 .
A fix to wiringPi.c was suggested by Gordon:
-- wiringPi.c  2012-09-28 16:53:05.000000000 -0400
+++ /opt/wiringPi/wiringPi/wiringPi.c   2012-09-28 12:37:04.614009947 -0400
@@ -449,8 +449,9 @@ int piBoardRev (void)
     boardRev = 2 ;
   else
-    fprintf (stderr, "warning: piBoardRev: Unable to determine board revision from %d assuming Rev 1\n", r) ;
-    boardRev = 1 ;
+    fprintf (stderr, "piBoardRev: Unable to determine board revision from %d\n", r) ;
+    errno = 0 ;
+    return -1 ;
Is this safe to run as I did receive some "try at your own risk" remarks. What version do I have and why is it 0000 in /proc/cpuinfo ?
dom
Re: Revision 0000 - gpio not working
Fri Sep 28, 2012 9:53 pm
The revision of 0000 is incorrect.
You can correct this with
program_board_rev=2
in config.txt and boot once.
You can check the correct revision by looking at:
http://www.raspberrypi.org/archives/1929
diecast
Sun Sep 30, 2012 11:03 pm
dom wrote:The revision of 0000 is incorrect.
program_board_rev=2
Thank you, I changed it to '2' as suggested and now it works fine.
Burngate
Mon Oct 01, 2012 10:01 am
From what has been said here, and from one or two posts elsewhere on the forum, I've gained the impression that the SoC has its revision number and its serial number burnt in after it's been built onto the Pi (and a very few Pis have missed the burn stage)
Is this true? I can see why it would have to be for the revision number, but if the serial number is also burnt at that stage, given that there's more than one factory what guarantee is there that they'll be unique?
Also, what else is burnt in at that stage (and could potentially been missed)?
RaTTuS
Contact: Twitter YouTube
Mon Oct 01, 2012 10:05 am
that serial number is very low....
I wonder if there is a market for unburnt ones.... ;-p
Covfefe
rurwin
Wed Jan 27, 2016 10:38 am
I've split out the newer posts that were off-topic and I'll lock this to ensure it doesn't get reused.
If your board revision is not all zeros, then this is not your issue.
