If want to control a two motors using a double H-bridge, Which pins do I connect to? On the E14 forum, I am working with someone of a motor project and this is what he suggested:Grumpy Mike wrote:These are the two signals Serial DAta and Serial CLock that are used in the I2C interface. Nothing to do with the PWM.Can some explain SDA and SCL channels to me
GPIO 18 can be assigned to be PWM0, the other PWM output, PWM1, can be assigned on the following pins:-
GPIO 13
GPIO 19
GPIO 41
GPIO 45
None of which are brought out on P1 or P5 of the issue 2 Pi.
As you can see in the diagram, he has put the controls through SDA +SCL on pins 3 and 5. Will this give me varible speed control of the motors?
http://www.element14.com/community/mess ... rt=0#60348
