sheriff076
Quake 3
Sat Sep 22, 2012 2:38 pm
I downloaded Quake 3 'with sound' from this link: http://www.memetic.org/quake-3-with-sou ... pberry-pi/
After unzipping it I ran the file with ./ioquake3.arm command and every thing worked fine from the first time and the game is playable. I then made a number of changes to configuration settings in the game, graphics, sound etc but when I quit the game and re load it those settings have not been saved.
Is this the norm that Quake 3 doesn't 'remember' my options or is it running in some sort of read only mode?
I notice on other Quake 3 installation guides, that chmod commands need to be run on certain files to allow the game to launch but the site above doesn't specify the need and the game runs anyway.
Thanks in advance.
Regards,
Steve
malakai
Re: Quake 3
Sat Sep 22, 2012 2:43 pm
does
sudo ./ioquake3.arm allow for you to save the files once configured in game.
Found this it looks like the file to change maybe found here
ok, i found out the problem already. Its because I don't have permission to write the q3config.cfg file.
The file is hidden, located at ~/.q3a/baseq3/q3config.cfg .
http://www.raspians.com - always looking for content feel free to ask to have it posted. Or sign up and message me to become a contributor to the site. Raspians is not affiliated with the Raspberry Pi Foundation. (RPi's + You = Raspians)
sheriff076
Re: Quake 3
Sun Sep 23, 2012 8:07 am
Hi, Thanks replying.
I tried sudo but it didnt solve the issue. If, as you suspect the config file is read only what do i need to do to make it write enabled.
Will this allow the game settings to be changed and saved?
Regards,
Steve
Licaon_Kter
Re: Quake 3
Mon Sep 24, 2012 3:44 pm
run: sudo chmod 777 /home/pi/.q3a/baseq3/q3config.cfg
I did see something strange too as like Quake3 would run as root or something, I just fixed it like this: sudo ln -s /home/pi/.q3a /root/.q3a
BFQ+BFS or RT on a RPi? 4'real: https://github.com/licaon-kter/ (source and compiled!)
malakai
Re: Quake 3
Mon Sep 24, 2012 4:49 pm
Licaon_Kter wrote:run: sudo chmod 777 /home/pi/.q3a/baseq3/q3config.cfg
Still remembering Linux and learning at the same time does this command make a symbolic link to the root account so they can run it because what got me is help me here if I sudo run something I am running it as root giving it all permissions as root so saving the config I am doing it as root not pi
Thanks for any help clearing this up for me :)
teeth_03
Re: Quake 3
Tue Sep 25, 2012 6:57 pm
A little punctuation goes a long way man, can you retype that so we can understand you?
Licaon_Kter
Re: Quake 3
Wed Sep 26, 2012 11:26 pm
Quickly take these: ..................,,,,,,,,,,,,,,,,,,,,,,!!!!!!!!!!!!!!!!!!!!!!??????????????
Anyway, yeah, kinda, I made that link so that quake3 uses the same settings either way, root or user.
Return to “Raspberry Pi OS”
