- Anne_Carlill
- Contact: Website Facebook Twitter
Beginner with Pico on an R Pi 3
Hi, I have Thonny that's working with Python 3.5.3. I've updated and upgraded my R Pi. I held down BOOTSEL and put the Pico into a USB slot. My R Pi recognises the Pico as it puts up a 'Removable medium is inserted ' box. I cancelled that and looked back at Thonny. The 'Python 3.5.3' version note is at the bottom left hand side of the screen under the title Shell (rather than on RHS as it says in instructions) and is greyed out. It does nothing when I try to click on it. I'm following the instructions on: https://projects.raspberrypi.org/en/pro ... the-pico/3 . I've tried a number of times but I don't get the python options (eg micropython) coming up. Is it because I'm not getting the Pico into the correct Mass Storage mode? Or is it that my version of Python or Thonny is not the latest? Or is it something else? The version of python I have is 3.5.3-1 but when I tried to upgrade it with sudo apt-get upgrade python3 the terminal stated that it was the latest version.
Re: Beginner with Pico on an R Pi 3
Don't cancel; you need to copy and drop the MicoPython .uf2 firmware file to the Pi Pico drive.Anne_Carlill wrote: ↑Sun Jan 24, 2021 4:15 pmMy R Pi recognises the Pico as it puts up a 'Removable medium is inserted ' box. I cancelled that and looked back at Thonny.
- Anne_Carlill
Thanks @hippy , I’ll try that tomorrow. All the best, Anne
- Anne_Carlill
@hippy wrote:
My version of the OS is Raspbian Stretch and I've had a look around my File Manager and found two references to Thonny. 1) in / usr/bin/ and 2) in / usr/lib/python3/dist-packages/ . I also have a python3.5 folder which is here / usr/lib/python3.5 which doesn't seem to contain any files or folders related to Thonny. I'm still wondering whether I have the latest version of Thonny and whether I should get a new SD card and download the very latest Raspbian OS and packages. Then I should start again. I'm still following these instructions: https://projects.raspberrypi.org/en/pro ... the-pico/3
So I've kept the File Manager box open with title 'RPI-RP2', on my R Pi 3. I assume the fact that I see this, tells me that my Pico has connected and is in mass storage device mode. But Thonny still has no Python version on screen which I can click on.Don't cancel; you need to copy and drop the MicoPython .uf2 firmware file to the Pi Pico drive.
Anne_Carlill wrote: ↑Mon Jan 25, 2021 9:55 amI'm still wondering whether I have the latest version of Thonny and whether I should get a new SD card and download the very latest Raspbian OS and packages. Then I should start again.
I can answer this non-Pico part of your query.
You most definitely do NOT have a current copy of the Operating System, the Python3 interpreter, or the Thonny ide/editor. Your Raspbian Stretch system was superceded in June 2019.
Retrying - on a new/spare microSD card if you prefer - with a fresh installation of the current (mid-January 2021) release of the RasPiOS Buster Operating System would be a good troubleshooting step.
Edit: wrong previous Debian release name
- Anne_Carlill
Ah, I think I've solved it. I found a newer SD card which was using the Buster OS then, in the terminal, I did the usual update and upgrade then I used sudo apt-get upgrade thonny and it installed an upgraded Thonny which has Python 3.7.3 stated in the bottom right hand corner. I assume copying the firmware to the pico will work now.
I apologise @B.Goode . I didn't see your post until I'd written this.
Thank you very much for your help. I really appreciate having this forum!
Anne_Carlill wrote: ↑Mon Jan 25, 2021 11:42 amAh, I think I've solved it. I found a newer SD card which was using the Buster OS then, in the terminal, I did the usual update and upgrade then I used sudo apt-get upgrade thonny and it installed an upgraded Thonny which has Python 3.7.3 stated in the bottom right hand corner. I assume copying the firmware to the pico will work now.
You are certainly in a better position to get help/support if things don't work out as you hope.
Do STEM have lots of plans for deploying PIco boards?
Subsequent update: Pleased to see from your Tweets that you are now up and running. Well Done!
- Anne_Carlill
Yes, thanks @B.Goode . I am really getting started now that I’ve saved some files to the Pico. There’s a book ‘Get started with Micropython on Raspberry Pi Pico’ which is downloadable for free from raspberrypi.org . My printed copy came yesterday and I’m working from that now.
