mox386
Nothing in Kodi works
Sat Nov 14, 2020 6:37 pm
I tried installing and using Kodi on Buster on a raspberry pi 4 B recently. This was the 2nd attempt at using kodi as I did try it out some years back and since nothing worked back then I gave up. I think this was circa 2012.
New attempt I tried even more stuff out than before and was very persistent about it.
Youtube; failed because the client required but was not allowed to login
hulu; doesn't exist even though some articles say it does
amazon; failed, no support, and weird way of installing
crackle; failed miserably
retroarch (and various other emulators/programs); failed (only supported on specific OSs apparently)
most music apps straight up don't work either from the repository, their own hosted repository, or install-from-zip
There were a lot more but, and a few weather apps failed as well.
I was only able to get some standalone game with pipes and the yahoo weather to work. NOTHING else works other than local files (vids/music/etc)
I was wondering if others have had the same kind of experience installing/using kodi on Buster. My main suspicion is that I just have missed something or don't understand something extremely basic.
Is it that kodi is only meant for local files mostly? Are only some specific addons I don't know about supported/working? Could it be that I have to use OSMC, Xbian, Openelec, or Libreelec otherwise nothing works (in which case this post is on the wrong forum)?
Thanks for any advice/help/notes in advance
Colonize-the-moon.com
Re: Nothing in Kodi works
Sat Nov 14, 2020 6:46 pm
Personally I have always used LibreElec and only installed Official add-ons from within Kodi, never tried to install unofficial add-ons due to legalities etcetera..
If there is a requirement for DRM, the Raspberry Pi is not classed as a Secure Platform and therefore services which require DRM *may* not function:
https://libreelec.tv/about/
Many 3rd party add-ons are compiled for x86 CPU Linux and not ARM CPU Linux.
My other Linux machines are a ChromeBox & Intel CoreDuo Desktop
LTolledo
Sat Nov 14, 2020 8:49 pm
Kodi works for me...
but not with the most common problem culprit called "user misconceptions"
been enjoying Kodi over Raspbian/RPiOS for the last 3 years or so...
Some people be like:
geffers
Sat Nov 14, 2020 9:31 pm
I've used Kodi on a couple of Pi devices mainly as a DLNA client to play my own stored content. Both are the KODI image and not a Pi operating system with Kodi subsequently installed.
What I do use it for successfully is as a TVHeadend client to a TV tuner working on my network, that streams TV content over the network nicely.
Other addons I've had working, then suddenly don't - NASA a good example and that is an official one.
Youtube takes an eternity to open. Having said that both Kodi Pi devices are on an original Pi 1 with only two USB ports.
Geoff
