Hey Paul
I'm currently using the custom kernel on the Raspbian distribution. I just connected an external GPS antenna to my Adafruit GPS receiver, so that might further improve the jitter (although I don't think ntpd can go below 0.002?) .
If it makes a difference I run ntpd as root.
The first time I tried running an ntpd server system I tried using a USB GPS Dongle. It tended to have very high jitter, your system seems to be fairing much better than that, well done
Would you, by any chance, be willing to give me the code for your web interface? The graphs ? I promise I won't give it to anyone else if you wish and obviously I wouldn't remove your name from it. I'd love to have some stats on my server but I don't really have the motivation to go and work out how to do it
(or rather it isn't a high enough priority at the moment).
On another note, this is my draft guide to re-creating this, so if peterwillcn would like to let me know if this works... that'd be great :
This is a short guide detailing how I got my Pi to act as a stratum 1 NTP server using an Adafruit GPS with PPS output. This same guide should work with almost any other TTL GPS with PPS output.
Firstly, buy a GPS with a TTL UART for NMEA and a PPS output on 3.3V :
http://adafruit.com/products/746 .
You might also want to buy a
u.FL adaptor and
GPS antenna.
Prepare a new Raspberry Pi with a Raspbian SD card installation.
Boot the Pi and prepare it to your liking (set up networking, ssh, etc.)
Download the following :
modules.tar.gz
and
kernel.tar.gz
The above tar.gz files were provided by chrisrpt. They contain custom compiled modules and a kernel image which support PPS on one of the Pi's GPIO pins (GPIO23).
In a suitable directory, extract the contents of the kernel.tar.gz file and move the results into place :
tar -xvf kernel.tar.gz
mv /boot/kernel.img /boot/kernel.img.old
mv Image /boot/kernel.img
Once again, extract the contents of the modules.tar.gz file :
Now you just need NTPd
Get the latest production source code of ntp :
http://www.ntp.org/downloads.html . At the time of this post's writing it was
ntp-4.2.6p5 .
Extract this file : tar -xvf ntp-4.2.6p5.tar.gz
Change into the new directory : cd ntp-4.2.6p5
Configure : ./configure --enable-ATOM --enable-NMEA
Eventually : make
and finally : make install
You may be missing dependencies, if you are configure will tell you.
Edit the init.d script for ntp : nano /etc/init.d/ntp
and add hashes/lines so that you have the following lines :
#if [ -e /var/lib/ntp/ntp.conf.dhcp ]; then
# NTPD_OPTS="$NTPD_OPTS -c /var/lib/ntp/ntp.conf.dhcp"
#fi
NTPD_OPTS="$NTPD_OPTS -g"
This prevents NTP from listening to your DHCP server, if you have one.
Change the "RUNASUSER" variable to "root".
Press Ctrl + X and press Y to exit and save.
Now remove any references to ttyAMA0 from your inittab :
nano /etc/inittab
Comment the following out so that it looks like this :
#Spawn a getty on Raspberry Pi serial line
#T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100
Once again, Ctrl + X and then press Y to save.
nano /boot/cmdline.txt
Remove any arguments that reference "ttyAMA0" so that the conent of the file looks like this :
dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
Edit /etc/ntp.conf and add the configuration for your GPS as well as (optionally) another time source as a backup.
nano /etc/ntp.conf
Example ntp.conf file :
# /etc/ntp.conf, configuration for ntpd; see ntp.conf(5) for help
driftfile /var/lib/ntp/ntp.drift
statsdir /var/log/ntpstats/
statistics loopstats peerstats clockstats
filegen loopstats file loopstats type day enable
filegen peerstats file peerstats type day enable
filegen clockstats file clockstats type day enable
server 127.127.20.0 mode 24 minpoll 3 iburst true prefer #use ZDA only!
fudge 127.127.20.0 flag1 1 time2 0.350
server 0.pool.ntp.org
server 1.pool.ntp.org
restrict -4 default kod notrap nomodify nopeer noquery
restrict -6 default kod notrap nomodify nopeer noquery
restrict 127.0.0.1
restrict ::1
Mode 24 restricts ntp to using $GPZDA NMEA outputs only. Mode 24 also specifies the baud rate of the GPS at 9600bps, which is also the default of the Adafruit GPSs.
Finally, connect the following cables :
GPS PI
GND GND (Pin 6 )
VIN +5V (Pin 2 )
TX RX (Pin 10, GPIO 15)
RX TX (Pin 8 , GPIO 14)
PPS PPS (Pin 16, GPIO 23)
Edit /etc/modules and add "pps-gpio" to the end of the file :
echo "pps-gpio" >> /etc/modules
Create a new file in /etc/udev/rules.d/09.pps.rules.
Populate this file with the following :
KERNEL=="ttyAMA0", SYMLINK+="gps0"
KERNEL=="pps0", OWNER="root", GROUP="tty", MODE="0777", SYMLINK+="gpspps0"
Restart the Pi.
